[opa-nightly-tests] jelly OPA_Daily_Tests_1109Thu_FAILED!!!
hdftest
hdftest at hdfgroup.org
Fri Nov 10 00:03:39 CST 2023
*** OPA Tests on 1109Thu ***
Tests Summary
****FAILED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala****
PASSED jelly: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly
PASSED moohan: standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Tests Time Summary
platypus: Ran 1(1/0/0) tests, Grand total test time = 0m 42s
jelly: Ran 1(1/0/0) tests, Grand total test time = 1m 5s
moohan: Ran 1(1/0/0) tests, Grand total test time = 1m 23s
koala: Ran 1(0/1/0) tests, Grand total test time = 6m 21s
jelly: Ran 6(0/0/0) hosts, Grand total test time = 7m 21s
Timekeeper log
Timekeeper started at Thu Nov 9 23:56:30 CST 2023
Timekeeper sleeping for 1200 seconds
Tests Failures
Dumping logfile of koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/koala_1109Thu_2356
Testing memory barriers with linear array with 2 threads PASSED
Testing memory barriers with local variables with 2 threads PASSED
Testing memory barriers with scattered array with 2 threads PASSED
Testing memory barriers with linear array with 4 threads PASSED
Testing memory barriers with local variables with 4 threads PASSED
Testing memory barriers with scattered array with 4 threads PASSED
Testing memory barriers with linear array with 10 threads PASSED
Testing memory barriers with local variables with 10 threads PASSED
Testing memory barriers with scattered array with 10 threads PASSED
Testing memory barriers with linear array with 100 threads PASSED
Testing memory barriers with local variables with 100 threads PASSED
Testing memory barriers with scattered array with 100 threads PASSED
All barriers tests passed.
PASS: test_barriers
Testing queue sanity PASSED
Testing multithreaded queue with 2 threads PASSED
Testing multithreaded queue (empty queue) with 2 threads PASSED
Testing multithreaded queue (full queue) with 2 threads PASSED
Testing multithreaded queue with 4 threads PASSED
Testing multithreaded queue (empty queue) with 4 threads Incorrect number of elements dequeued: 1262308 Expected: 1500000
*FAILED*
at /home/hdftest/snapshots-opa/current/test/test_queue.c:399 in test_queue_threaded()...
Unexpected return from 1 thread
Testing multithreaded queue (full queue) with 4 threads PASSED
Testing multithreaded queue with 10 threads PASSED
Testing multithreaded queue (empty queue) with 10 threads Incorrect number of elements dequeued: 3238477 Expected: 4500000
*FAILED*
Testing multithreaded queue (full queue) with 10 threads PASSED
Testing multithreaded queue with 100 threads PASSED
Testing multithreaded queue (empty queue) with 100 threads Incorrect number of elements dequeued: 4818679 Expected: 4950000
*FAILED*
Testing multithreaded queue (full queue) with 100 threads PASSED
***** 3 QUEUE TESTS FAILED! *****
FAIL: test_queue
1 of 4 tests failed
Please report to https://trac.mpich.org/projects/openpa/newticket
gmake[2]: *** [check-TESTS] Error 1
gmake[2]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/koala/test'
gmake[1]: *** [check-am] Error 2
gmake[1]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/koala/test'
gmake: *** [check-recursive] Error 1
Failed running make check
===== Exit bin/snapshot with status=2: Fri Nov 10 00:03:09 CST 2023 =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
23:56:08 up 106 days, 3:58, 5 users, load average: 0.00, 0.01, 0.05
Filesystem 1K-blocks Used Available Use% Mounted on
devtmpfs 65868920 0 65868920 0% /dev
tmpfs 4194304 22636 4171668 1% /dev/shm
tmpfs 65880516 1092356 64788160 2% /run
tmpfs 65880516 0 65880516 0% /sys/fs/cgroup
/dev/mapper/centos00-root 16766976 9347356 7419620 56% /
/dev/md0 3904859232 2256778220 1648081012 58% /scr
tmpfs 65880516 0 65880516 0% /mnt/daos
/dev/md10 11718682624 7824820992 3893861632 67% /mnt/wrk
/dev/mapper/centos00-opt 134152192 127161992 6990200 95% /opt
/dev/sda1 520876 288780 232096 56% /boot
10.10.10.85:/data/ftp 480719104 436709248 19590656 96% /mnt/ftp
10.10.10.86:/mnt/hdf 961432576 879810560 32783360 97% /mnt/hdf
10.10.10.86:/mnt/scr1 961432576 884606976 27986944 97% /mnt/scr1
10.10.10.85:/data/web 480719104 436709248 19590656 96% /mnt/web
tmpfs 13176104 0 13176104 0% /run/user/29138
10.10.10.86:/home 961432576 152906752 759688192 17% /home
tmpfs 13176104 0 13176104 0% /run/user/22417
tmpfs 13176104 0 13176104 0% /run/user/27429
tmpfs 13176104 0 13176104 0% /run/user/10022
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_1109Thu
*** launching tests from jelly ***
TESTHOST is jelly
koala
platypus
moohan
ostrich
osx1011test
Fork off timekeeper 20
Testing jelly
ssh -o ConnectTimeout=60 jelly -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jelly
23:56:36 up 106 days, 3:59, 5 users, load average: 0.29, 0.08, 0.07
tmpfs 65880516 1092396 64788120 2% /run
/dev/mapper/centos00-root 16766976 9347340 7419636 56% /
10.10.10.86:/mnt/scr1 961432576 884609024 27985920 97% /mnt/scr1
Extract source and run autogen if .
Thu Nov 9 23:56:46 CST 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly tests in jelly ***
Uname -a: Linux jelly 3.10.0-1160.80.1.el7.x86_64 #1 SMP Tue Nov 8 15:48:59 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/jelly_1109Thu_2356
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly tests for jelly ***
Thu Nov 9 23:57:51 CST 2023
Total time = 1m 5s
*** finished tests in jelly ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
23:56:38 up 124 days, 16:34, 0 users, load average: 3.00, 3.00, 2.95
/dev/sda7 22292052 4428144 16713256 21% /
/dev/sda5 12192608 386460 11176804 4% /tmp
/dev/sda3 12192636 1196436 10366856 11% /var
/dev/sda1 101086 18614 77253 20% /boot
/dev/sdc1 41279536 26323756 12858900 68% /usr
/dev/sdb 152754284 79896368 65098456 56% /scr
tmpfs 6149552 0 6149552 0% /dev/shm
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Thu Nov 9 23:56:49 CST 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-409.el5 #1 SMP Tue Mar 15 18:13:50 EDT 2016 x86_64 x86_64 x86_64 GNU/Linux
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Total time = 6m 21s
*** finished tests in koala ***
****SYSTEM ERROR koala: Abnormal exit from runtest ****
****SYSTEM ERROR koala: runtest command failed ****
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
23:56:41 up 124 days, 16:34, 0 users, load average: 0.49, 0.43, 0.27
/dev/sda6 54205540 43007028 8438372 84% /
tmpfs 6099068 0 6099068 0% /dev/shm
/dev/sda1 194241 48310 135691 27% /boot
/dev/sda2 12850716 191248 12000012 2% /tmp
/dev/sda3 12850716 5553760 6637500 46% /var
/dev/sdd 152623212 121709188 23154564 85% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Thu Nov 9 23:56:51 CST 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.22.1.el6.x86_64 #1 SMP Wed Mar 23 03:35:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/platypus_1109Thu_2356
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Thu Nov 9 23:57:33 CST 2023
Total time = 0m 42s
*** finished tests in platypus ***
Testing moohan
ssh -o ConnectTimeout=60 moohan -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname moohan
23:56:44 up 56 days, 6:03, 1 user, load average: 0.33, 0.29, 0.29
/dev/mapper/centos_moohan-root 52196352 10417912 41778440 20% /
devtmpfs 3923072 0 3923072 0% /dev
tmpfs 3939844 84 3939760 1% /dev/shm
tmpfs 3939844 418768 3521076 11% /run
tmpfs 3939844 0 3939844 0% /sys/fs/cgroup
/dev/md126p1 506752 312960 193792 62% /boot
/dev/mapper/centos_moohan-var 16371712 4199176 12172536 26% /var
/dev/mapper/centos_moohan-scr 858065536 398259648 459805888 47% /scr
/dev/mapper/centos_moohan-tmp 16371712 33400 16338312 1% /tmp
gumund:/data/ftp 480719104 436709248 19590656 96% /mnt/ftp
gumund:/data/web 480719104 436709248 19590656 96% /mnt/web
tmpfs 787972 16 787956 1% /run/user/42
jam:/home 961432576 152906752 759688192 17% /home
jam:/mnt/hdf 961432576 879810560 32783360 97% /mnt/hdf
jam:/mnt/scr1 961432576 884609024 27985920 97% /mnt/scr1
tmpfs 787972 0 787972 0% /run/user/27429
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
Thu Nov 9 23:56:54 CST 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests in moohan ***
Uname -a: Linux moohan.ad.hdfgroup.org 3.10.0-327.10.1.el7.x86_64 #1 SMP Tue Feb 16 17:03:50 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/moohan_1109Thu_2356
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests for moohan ***
Thu Nov 9 23:58:17 CST 2023
Total time = 1m 23s
*** finished tests in moohan ***
Testing ostrich
ostrich is not reachable (Thu Nov 9 23:56:43 CST 2023)
****SYSTEM ERROR: ostrich is not reachable (Thu Nov 9 23:56:43 CST 2023)
****INCOMPLETE ostrich: snaptest did not complete****
Testing osx1011test
ssh -o ConnectTimeout=60 osx1011test -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname osx1011test
grep: /proc/cpuinfo: No such file or directory
snapshots-opa: No such file or directory.
/mnt/scr1/SnapTest/snapshots-opa/bin/runtest: Command not found.
****SYSTEM ERROR osx1011test: Abnormal exit from runtest ****
****SYSTEM ERROR osx1011test: runtest command failed ****
More information about the opa-nightly-tests
