[opa-nightly-tests] jelly OPA_Daily_Tests_1103Fri
hdftest
hdftest at hdfgroup.org
Fri Nov 3 23:57:03 CDT 2023
*** OPA Tests on 1103Fri ***
Tests Summary
PASSED jelly: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED moohan: standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Tests Time Summary
koala: Ran 1(1/0/0) tests, Grand total test time = 0m 33s
platypus: Ran 1(1/0/0) tests, Grand total test time = 0m 45s
jelly: Ran 1(1/0/0) tests, Grand total test time = 1m 6s
moohan: Ran 1(1/0/0) tests, Grand total test time = 1m 22s
jelly: Ran 6(0/0/0) hosts, Grand total test time = 2m 29s
Timekeeper log
Timekeeper started at Fri Nov 3 23:54:46 CDT 2023
Timekeeper sleeping for 1200 seconds
Tests Failures
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
23:54:24 up 100 days, 2:56, 1 user, load average: 0.00, 0.01, 0.05
Filesystem 1K-blocks Used Available Use% Mounted on
devtmpfs 65868920 0 65868920 0% /dev
tmpfs 4194304 15540 4178764 1% /dev/shm
tmpfs 65880516 1043052 64837464 2% /run
tmpfs 65880516 0 65880516 0% /sys/fs/cgroup
/dev/mapper/centos00-root 16766976 9959052 6807924 60% /
/dev/md0 3904859232 2225256064 1679603168 57% /scr
tmpfs 65880516 0 65880516 0% /mnt/daos
/dev/md10 11718682624 7824648500 3894034124 67% /mnt/wrk
/dev/mapper/centos00-opt 134152192 127161992 6990200 95% /opt
/dev/sda1 520876 288780 232096 56% /boot
10.10.10.85:/data/ftp 480719104 432364672 23935232 95% /mnt/ftp
10.10.10.86:/mnt/hdf 961432576 877981696 34612224 97% /mnt/hdf
10.10.10.86:/mnt/scr1 961432576 878910464 33683456 97% /mnt/scr1
10.10.10.85:/data/web 480719104 432364672 23935232 95% /mnt/web
tmpfs 13176104 0 13176104 0% /run/user/29138
10.10.10.86:/home 961432576 152906752 759688192 17% /home
tmpfs 13176104 0 13176104 0% /run/user/27429
tmpfs 13176104 0 13176104 0% /run/user/22417
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_1103Fri
*** launching tests from jelly ***
TESTHOST is jelly
koala
platypus
moohan
ostrich
osx1011test
Fork off timekeeper 20
Testing jelly
ssh -o ConnectTimeout=60 jelly -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jelly
23:54:52 up 100 days, 2:57, 1 user, load average: 0.08, 0.03, 0.05
tmpfs 65880516 1043092 64837424 2% /run
/dev/mapper/centos00-root 16766976 9959036 6807940 60% /
10.10.10.85:/data/ftp 480719104 432320768 23979136 95% /mnt/ftp
10.10.10.86:/mnt/scr1 961432576 878912512 33682432 97% /mnt/scr1
10.10.10.85:/data/web 480719104 432320768 23979136 95% /mnt/web
Extract source and run autogen if .
Fri Nov 3 23:55:02 CDT 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly tests in jelly ***
Uname -a: Linux jelly 3.10.0-1160.80.1.el7.x86_64 #1 SMP Tue Nov 8 15:48:59 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/jelly_1103Fri_2355
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly tests for jelly ***
Fri Nov 3 23:56:08 CDT 2023
Total time = 1m 6s
*** finished tests in jelly ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
23:54:54 up 118 days, 15:32, 0 users, load average: 0.01, 0.02, 0.00
/dev/sda7 22292052 4428140 16713260 21% /
/dev/sda5 12192608 402044 11161220 4% /tmp
/dev/sda3 12192636 1189360 10373932 11% /var
/dev/sda1 101086 18614 77253 20% /boot
/dev/sdc1 41279536 26323756 12858900 68% /usr
/dev/sdb 152754284 79846716 65148108 56% /scr
tmpfs 6149552 0 6149552 0% /dev/shm
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Fri Nov 3 23:55:04 CDT 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-409.el5 #1 SMP Tue Mar 15 18:13:50 EDT 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/koala_1103Fri_2355
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Fri Nov 3 23:55:37 CDT 2023
Total time = 0m 33s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
23:54:57 up 118 days, 15:32, 0 users, load average: 0.35, 0.33, 0.22
/dev/sda6 54205540 43007028 8438372 84% /
tmpfs 6099068 0 6099068 0% /dev/shm
/dev/sda1 194241 48310 135691 27% /boot
/dev/sda2 12850716 187648 12003612 2% /tmp
/dev/sda3 12850716 5568824 6622436 46% /var
/dev/sdd 152623212 120980924 23882828 84% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Fri Nov 3 23:55:07 CDT 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.22.1.el6.x86_64 #1 SMP Wed Mar 23 03:35:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/platypus_1103Fri_2355
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Fri Nov 3 23:55:52 CDT 2023
Total time = 0m 45s
*** finished tests in platypus ***
Testing moohan
ssh -o ConnectTimeout=60 moohan -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname moohan
23:55:01 up 50 days, 5:01, 1 user, load average: 0.27, 0.30, 0.26
/dev/mapper/centos_moohan-root 52196352 10417912 41778440 20% /
devtmpfs 3923072 0 3923072 0% /dev
tmpfs 3939844 84 3939760 1% /dev/shm
tmpfs 3939844 418768 3521076 11% /run
tmpfs 3939844 0 3939844 0% /sys/fs/cgroup
/dev/md126p1 506752 312960 193792 62% /boot
/dev/mapper/centos_moohan-var 16371712 4238508 12133204 26% /var
/dev/mapper/centos_moohan-scr 858065536 397623140 460442396 47% /scr
/dev/mapper/centos_moohan-tmp 16371712 33400 16338312 1% /tmp
gumund:/data/ftp 480719104 432320768 23979136 95% /mnt/ftp
gumund:/data/web 480719104 432320768 23979136 95% /mnt/web
tmpfs 787972 16 787956 1% /run/user/42
jam:/home 961432576 152906752 759688192 17% /home
jam:/mnt/hdf 961432576 877981696 34612224 97% /mnt/hdf
jam:/mnt/scr1 961432576 878912512 33682432 97% /mnt/scr1
tmpfs 787972 0 787972 0% /run/user/27429
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
Fri Nov 3 23:55:11 CDT 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests in moohan ***
Uname -a: Linux moohan.ad.hdfgroup.org 3.10.0-327.10.1.el7.x86_64 #1 SMP Tue Feb 16 17:03:50 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/moohan_1103Fri_2355
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests for moohan ***
Fri Nov 3 23:56:33 CDT 2023
Total time = 1m 22s
*** finished tests in moohan ***
Testing ostrich
ostrich is not reachable (Fri Nov 3 23:55:01 CDT 2023)
****SYSTEM ERROR: ostrich is not reachable (Fri Nov 3 23:55:01 CDT 2023)
****INCOMPLETE ostrich: snaptest did not complete****
Testing osx1011test
ssh -o ConnectTimeout=60 osx1011test -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname osx1011test
grep: /proc/cpuinfo: No such file or directory
snapshots-opa: No such file or directory.
/mnt/scr1/SnapTest/snapshots-opa/bin/runtest: Command not found.
****SYSTEM ERROR osx1011test: Abnormal exit from runtest ****
****SYSTEM ERROR osx1011test: runtest command failed ****
More information about the opa-nightly-tests
