[opa-nightly-tests] jelly OPA_Daily_Tests_1224Sun
hdftest hdftest at hdfgroup.org
Sun Dec 24 00:25:38 CST 2023
*** OPA Tests on 1224Sun ***
   Tests Summary
PASSED jelly: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly
PASSED moohan: standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
   Tests Time Summary
jelly: Ran 1(1/0/0) tests, Grand total test time =  1m 7s
platypus: Ran 1(1/0/0) tests, Grand total test time =  0m 44s
moohan: Ran 1(1/0/0) tests, Grand total test time =  1m 22s
jelly: Ran 6(0/0/0) hosts, Grand total test time =  20m 43s
   Timekeeper log
Timekeeper started at Sun Dec 24 00:05:07 CST 2023
Timekeeper sleeping for 1200 seconds
Timekeeper woke up at Sun Dec 24 00:25:07 CST 2023, looking for processes to terminate...
terminating process PID.koala_koala (17512)
Remote shell command ended.  But some processes might still be
running in the remote machine.  Login there to verify.
Timekeeper ended at Sun Dec 24 00:25:08 CST 2023
   Tests Failures
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 00:04:45 up 150 days,  4:07,  3 users,  load average: 0.01, 0.27, 0.44
Filesystem                  1K-blocks       Used  Available Use% Mounted on
devtmpfs                     65868920          0   65868920   0% /dev
tmpfs                         4194304      22424    4171880   1% /dev/shm
tmpfs                        65880516    1502444   64378072   3% /run
tmpfs                        65880516          0   65880516   0% /sys/fs/cgroup
/dev/mapper/centos00-root    16766976    9370964    7396012  56% /
/dev/md0                   3904859232 2880745572 1024113660  74% /scr
tmpfs                        65880516          0   65880516   0% /mnt/daos
/dev/md10                 11718682624 8049735348 3668947276  69% /mnt/wrk
/dev/mapper/centos00-opt    134152192  127161992    6990200  95% /opt
/dev/sda1                      520876     288780     232096  56% /boot
10.10.10.85:/data/ftp       480719104  439306624   16993280  97% /mnt/ftp
10.10.10.86:/mnt/hdf        961432576  882219008   30375936  97% /mnt/hdf
10.10.10.86:/mnt/scr1       961432576  880429056   32165888  97% /mnt/scr1
10.10.10.85:/data/web       480719104  439306624   16993280  97% /mnt/web
tmpfs                        13176104          0   13176104   0% /run/user/29138
10.10.10.86:/home           961432576  153606144  758987776  17% /home
tmpfs                        13176104          0   13176104   0% /run/user/27429
tmpfs                        13176104          0   13176104   0% /run/user/22417
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_1224Sun
*** launching tests from jelly ***
TESTHOST is jelly
koala
platypus
moohan
ostrich
osx1011test
    Fork off timekeeper 20
Testing jelly
ssh -o ConnectTimeout=60 jelly -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jelly
 00:05:13 up 150 days,  4:07,  3 users,  load average: 0.14, 0.28, 0.43
tmpfs                        65880516    1502484   64378032   3% /run
/dev/mapper/centos00-root    16766976    9371040    7395936  56% /
Extract source and run autogen if .
Sun Dec 24 00:05:23 CST 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly tests in jelly ***
Uname -a: Linux jelly 3.10.0-1160.80.1.el7.x86_64 #1 SMP Tue Nov 8 15:48:59 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
Running snapshot with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/jelly_1224Sun_0005
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly tests for jelly ***
Sun Dec 24 00:06:30 CST 2023
Total time = 1m 7s
*** finished tests in jelly ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
 00:06:06 up 43 days, 13:47,  0 users,  load average: 150.15, 149.43, 149.36
/dev/sda7             22292052   4428156  16713244  21% /
/dev/sda5             12192608    385776  11177488   4% /tmp
/dev/sda3             12192636   4097532   7465760  36% /var
/dev/sda1               101086     18614     77253  20% /boot
/dev/sdc1             41279536  26323756  12858900  68% /usr
/dev/sdb             152754284  79895328  65099496  56% /scr
tmpfs                  6149552         0   6149552   0% /dev/shm
gumund:/data/ftp     480719104 439306624  16993280  97% /mnt/ftp
gumund:/data/web     480719104 439306624  16993280  97% /mnt/web
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Sun Dec 24 00:06:27 CST 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-409.el5 #1 SMP Tue Mar 15 18:13:50 EDT 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/koala_1224Sun_0006
	****INCOMPLETE koala: snaptest did not complete****
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
 00:05:42 up 168 days, 16:43,  0 users,  load average: 0.03, 0.05, 0.13
/dev/sda6             54205540  43007028   8438372  84% /
tmpfs                  6099068         0   6099068   0% /dev/shm
/dev/sda1               194241     48310    135691  27% /boot
/dev/sda2             12850716     32976  12158284   1% /tmp
/dev/sda3             12850716   4551808   7639452  38% /var
/dev/sdd             152623212 120896740  23967012  84% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Sun Dec 24 00:05:53 CST 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.22.1.el6.x86_64 #1 SMP Wed Mar 23 03:35:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/platypus_1224Sun_0005
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Sun Dec 24 00:06:36 CST 2023
Total time = 0m 43s
*** finished tests in platypus ***
Testing moohan
ssh -o ConnectTimeout=60 moohan -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname moohan
 00:05:46 up 100 days,  6:12,  1 user,  load average: 0.11, 0.43, 0.62
/dev/mapper/centos_moohan-root  52196352  10417912  41778440  20% /
devtmpfs                         3923072         0   3923072   0% /dev
tmpfs                            3939844        84   3939760   1% /dev/shm
tmpfs                            3939844    418796   3521048  11% /run
tmpfs                            3939844         0   3939844   0% /sys/fs/cgroup
/dev/md126p1                      506752    312960    193792  62% /boot
/dev/mapper/centos_moohan-var   16371712   3739492  12632220  23% /var
/dev/mapper/centos_moohan-scr  858065536 397639660 460425876  47% /scr
/dev/mapper/centos_moohan-tmp   16371712     33416  16338296   1% /tmp
tmpfs                             787972        16    787956   1% /run/user/42
jam:/home                      961432576 153606144 758987776  17% /home
jam:/mnt/hdf                   961432576 882219008  30375936  97% /mnt/hdf
jam:/mnt/scr1                  961432576 880429056  32165888  97% /mnt/scr1
tmpfs                             787972         0    787972   0% /run/user/27429
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
Sun Dec 24 00:05:56 CST 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests in moohan ***
Uname -a: Linux moohan.ad.hdfgroup.org 3.10.0-327.10.1.el7.x86_64 #1 SMP Tue Feb 16 17:03:50 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/moohan_1224Sun_0005
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests for moohan ***
Sun Dec 24 00:07:18 CST 2023
Total time = 1m 22s
*** finished tests in moohan ***
Testing ostrich
ostrich is not reachable (Sun Dec 24 00:05:46 CST 2023)
	****SYSTEM ERROR: ostrich is not reachable (Sun Dec 24 00:05:46 CST 2023)
	****INCOMPLETE ostrich: snaptest did not complete****
Testing osx1011test
ssh -o ConnectTimeout=60 osx1011test -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname osx1011test
grep: /proc/cpuinfo: No such file or directory
snapshots-opa: No such file or directory.
/mnt/scr1/SnapTest/snapshots-opa/bin/runtest: Command not found.
****SYSTEM ERROR osx1011test: Abnormal exit from runtest ****
	****SYSTEM ERROR osx1011test: runtest command failed ****
More information about the opa-nightly-tests mailing list
