[opa-nightly-tests] jelly OPA_Daily_Tests_1219Tue
hdftest
hdftest at hdfgroup.org
Wed Dec 20 00:02:14 CST 2023
*** OPA Tests on 1219Tue ***
Tests Summary
PASSED jelly: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly
PASSED moohan: standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Tests Time Summary
platypus: Ran 1(1/0/0) tests, Grand total test time = 0m 42s
jelly: Ran 1(1/0/0) tests, Grand total test time = 1m 6s
moohan: Ran 1(1/0/0) tests, Grand total test time = 1m 21s
jelly: Ran 6(0/0/0) hosts, Grand total test time = 20m 43s
Timekeeper log
Timekeeper started at Tue Dec 19 23:41:44 CST 2023
Timekeeper sleeping for 1200 seconds
Timekeeper woke up at Wed Dec 20 00:01:44 CST 2023, looking for processes to terminate...
terminating process PID.koala_koala (30235)
Remote shell command ended. But some processes might still be
running in the remote machine. Login there to verify.
Timekeeper ended at Wed Dec 20 00:01:44 CST 2023
Tests Failures
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
23:41:21 up 146 days, 3:43, 1 user, load average: 0.02, 0.04, 0.07
Filesystem 1K-blocks Used Available Use% Mounted on
devtmpfs 65868920 0 65868920 0% /dev
tmpfs 4194304 22424 4171880 1% /dev/shm
tmpfs 65880516 1461260 64419256 3% /run
tmpfs 65880516 0 65880516 0% /sys/fs/cgroup
/dev/mapper/centos00-root 16766976 9008684 7758292 54% /
/dev/md0 3904859232 2884048756 1020810476 74% /scr
tmpfs 65880516 0 65880516 0% /mnt/daos
/dev/md10 11718682624 8048668552 3670014072 69% /mnt/wrk
/dev/mapper/centos00-opt 134152192 127161992 6990200 95% /opt
/dev/sda1 520876 288780 232096 56% /boot
10.10.10.85:/data/ftp 480719104 439319552 16980352 97% /mnt/ftp
10.10.10.86:/mnt/hdf 961432576 881485824 31109120 97% /mnt/hdf
10.10.10.86:/mnt/scr1 961432576 883938304 28656640 97% /mnt/scr1
10.10.10.85:/data/web 480719104 439319552 16980352 97% /mnt/web
tmpfs 13176104 0 13176104 0% /run/user/29138
10.10.10.86:/home 961432576 153606144 758987776 17% /home
tmpfs 13176104 0 13176104 0% /run/user/27429
tmpfs 13176104 0 13176104 0% /run/user/22417
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_1219Tue
*** launching tests from jelly ***
TESTHOST is jelly
koala
platypus
moohan
ostrich
osx1011test
Fork off timekeeper 20
Testing jelly
ssh -o ConnectTimeout=60 jelly -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jelly
23:41:49 up 146 days, 3:44, 1 user, load average: 0.09, 0.05, 0.08
tmpfs 65880516 1461300 64419216 3% /run
/dev/mapper/centos00-root 16766976 9008648 7758328 54% /
10.10.10.86:/mnt/scr1 961432576 883939328 28654592 97% /mnt/scr1
Extract source and run autogen if .
Tue Dec 19 23:42:00 CST 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly tests in jelly ***
Uname -a: Linux jelly 3.10.0-1160.80.1.el7.x86_64 #1 SMP Tue Nov 8 15:48:59 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/jelly_1219Tue_2342
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly tests for jelly ***
Tue Dec 19 23:43:05 CST 2023
Total time = 1m 5s
*** finished tests in jelly ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
23:42:28 up 39 days, 13:23, 0 users, load average: 118.72, 118.17, 118.19
/dev/sda7 22292052 4428156 16713244 21% /
/dev/sda5 12192608 409156 11154108 4% /tmp
/dev/sda3 12192636 3396488 8166804 30% /var
/dev/sda1 101086 18614 77253 20% /boot
/dev/sdc1 41279536 26323756 12858900 68% /usr
/dev/sdb 152754284 79910024 65084800 56% /scr
tmpfs 6149552 0 6149552 0% /dev/shm
gumund:/data/ftp 480719104 439319552 16980352 97% /mnt/ftp
gumund:/data/web 480719104 439319552 16980352 97% /mnt/web
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Tue Dec 19 23:42:57 CST 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-409.el5 #1 SMP Tue Mar 15 18:13:50 EDT 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/koala_1219Tue_2343
****INCOMPLETE koala: snaptest did not complete****
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
23:42:10 up 164 days, 16:20, 0 users, load average: 0.45, 0.43, 0.23
/dev/sda6 54205540 43007028 8438372 84% /
tmpfs 6099068 0 6099068 0% /dev/shm
/dev/sda1 194241 48310 135691 27% /boot
/dev/sda2 12850716 72488 12118772 1% /tmp
/dev/sda3 12850716 4674740 7516520 39% /var
/dev/sdd 152623212 121625364 23238388 84% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Tue Dec 19 23:42:21 CST 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.22.1.el6.x86_64 #1 SMP Wed Mar 23 03:35:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/platypus_1219Tue_2342
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Tue Dec 19 23:43:02 CST 2023
Total time = 0m 41s
*** finished tests in platypus ***
Testing moohan
ssh -o ConnectTimeout=60 moohan -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname moohan
23:42:13 up 96 days, 5:49, 1 user, load average: 0.33, 0.34, 0.45
/dev/mapper/centos_moohan-root 52196352 10417912 41778440 20% /
devtmpfs 3923072 0 3923072 0% /dev
tmpfs 3939844 84 3939760 1% /dev/shm
tmpfs 3939844 418796 3521048 11% /run
tmpfs 3939844 0 3939844 0% /sys/fs/cgroup
/dev/md126p1 506752 312960 193792 62% /boot
/dev/mapper/centos_moohan-var 16371712 4008052 12363660 25% /var
/dev/mapper/centos_moohan-scr 858065536 400331568 457733968 47% /scr
/dev/mapper/centos_moohan-tmp 16371712 33416 16338296 1% /tmp
tmpfs 787972 16 787956 1% /run/user/42
jam:/home 961432576 153606144 758987776 17% /home
jam:/mnt/hdf 961432576 881485824 31109120 97% /mnt/hdf
jam:/mnt/scr1 961432576 883939328 28654592 97% /mnt/scr1
tmpfs 787972 0 787972 0% /run/user/27429
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
Tue Dec 19 23:42:23 CST 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests in moohan ***
Uname -a: Linux moohan.ad.hdfgroup.org 3.10.0-327.10.1.el7.x86_64 #1 SMP Tue Feb 16 17:03:50 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/moohan_1219Tue_2342
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests for moohan ***
Tue Dec 19 23:43:44 CST 2023
Total time = 1m 21s
*** finished tests in moohan ***
Testing ostrich
ostrich is not reachable (Tue Dec 19 23:42:13 CST 2023)
****SYSTEM ERROR: ostrich is not reachable (Tue Dec 19 23:42:13 CST 2023)
****INCOMPLETE ostrich: snaptest did not complete****
Testing osx1011test
ssh -o ConnectTimeout=60 osx1011test -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname osx1011test
grep: /proc/cpuinfo: No such file or directory
snapshots-opa: No such file or directory.
/mnt/scr1/SnapTest/snapshots-opa/bin/runtest: Command not found.
****SYSTEM ERROR osx1011test: Abnormal exit from runtest ****
****SYSTEM ERROR osx1011test: runtest command failed ****
More information about the opa-nightly-tests
