[opa-nightly-tests] jelly OPA_Daily_Tests_0227Sun_FAILED!!!
hdftest hdftest at hdfgroup.org
Sun Feb 27 22:44:10 CST 2022
*** OPA Tests on 0227Sun ***
   Tests Summary
****FAILED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus****
PASSED jelly: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED moohan: standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
PASSED osx1011test: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy osx1011test
   Tests Time Summary
platypus: Ran 1(0/1/0) tests, Grand total test time =  0m 8s
koala: Ran 1(1/0/0) tests, Grand total test time =  0m 33s
jelly: Ran 1(1/0/0) tests, Grand total test time =  1m 3s
osx1011test: Ran 1(1/0/0) tests, Grand total test time =  1m 12s
moohan: Ran 1(1/0/0) tests, Grand total test time =  4m 48s
jelly: Ran 6(0/0/0) hosts, Grand total test time =  5m 54s
   Timekeeper log
Timekeeper started at Sun Feb 27 22:38:28 CST 2022
Timekeeper sleeping for 1200 seconds
   Tests Failures
Dumping logfile of platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/platypus_0227Sun_2238
checking whether to enable strict fairness checks... no
checking that generated files are newer than configure... done
configure: creating ./config.status
config.status: creating Makefile
config.status: creating src/Makefile
config.status: creating test/Makefile
config.status: creating openpa.pc
config.status: creating src/config.h
config.status: executing depfiles commands
config.status: executing libtool commands
config.status: executing src/opa_config.h commands
config.status: creating src/opa_config.h - prefix OPA for src/config.h defines
===== make: Sun Feb 27 22:38:53 CST 2022 =====
Making all in src
gmake[1]: Entering directory `/scr/hdftest/snapshots-opa/TestDir/platypus/src'
gmake  all-am
gmake[2]: Entering directory `/scr/hdftest/snapshots-opa/TestDir/platypus/src'
  CC       opa_primitives.lo
  CC       opa_queue.lo
  CCLD     libopa.la
gmake[2]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/platypus/src'
gmake[1]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/platypus/src'
Making all in test
gmake[1]: Entering directory `/scr/hdftest/snapshots-opa/TestDir/platypus/test'
gmake[1]: Nothing to be done for `all'.
gmake[1]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/platypus/test'
gmake[1]: Entering directory `/scr/hdftest/snapshots-opa/TestDir/platypus'
gmake[1]: Nothing to be done for `all-am'.
gmake[1]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/platypus'
Disk Usage=636 KB
Making check in src
Making check in test
gmake  sanity test_primitives test_barriers test_queue
gmake[2]: Entering directory `/scr/hdftest/snapshots-opa/TestDir/platypus/test'
  CC       sanity.o
  CCLD     sanity
  CC       test_primitives.o
/home/hdftest/snapshots-opa/current/test/test_primitives.c:4974: fatal error: error writing to /tmp/ccjw1k9f.s: No space left on device
compilation terminated.
gmake[2]: *** [test_primitives.o] Error 1
gmake[2]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/platypus/test'
gmake[1]: *** [check-am] Error 2
gmake: *** [check-recursive] Error 1
Failed running make check
===== Exit bin/snapshot with status=2: Sun Feb 27 22:38:56 CST 2022 =====
Dumping done
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 22:38:06 up 74 days,  5:36, 10 users,  load average: 4.30, 5.37, 6.23
Filesystem                  1K-blocks       Used  Available Use% Mounted on
devtmpfs                     65868460          0   65868460   0% /dev
tmpfs                        65880616     158988   65721628   1% /dev/shm
tmpfs                        65880616     708580   65172036   2% /run
tmpfs                        65880616          0   65880616   0% /sys/fs/cgroup
/dev/mapper/centos00-root    16766976   10677080    6089896  64% /
tmpfs                        65880616          0   65880616   0% /mnt/daos
/dev/md0                   3904859232 1889506984 2015352248  49% /scr
/dev/md10                 11718682624 7773012472 3945670152  67% /mnt/wrk
/dev/sda1                      520876     245196     275680  48% /boot
/dev/mapper/centos00-opt    134152192  116298488   17853704  87% /opt
10.10.10.86:/mnt/scr1       961432576  873614336   38980608  96% /mnt/scr1
10.10.10.86:/mnt/hdf        961432576  908977152    3617792 100% /mnt/hdf
10.10.10.86:/home           961432576   97048576  815546368  11% /home
10.10.10.85:/data/web       480719104  405906560   50393344  89% /mnt/web
10.10.10.85:/data/ftp       480719104  405906560   50393344  89% /mnt/ftp
tmpfs                        13176124          0   13176124   0% /run/user/29138
tmpfs                        13176124          0   13176124   0% /run/user/10094
tmpfs                        13176124          0   13176124   0% /run/user/10057
tmpfs                        13176124          0   13176124   0% /run/user/27429
tmpfs                        13176124          0   13176124   0% /run/user/21796
tmpfs                        13176124          0   13176124   0% /run/user/10019
tmpfs                        13176124          0   13176124   0% /run/user/10008
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0227Sun
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0227Sun.51404: No such file or directory
rm: cannot remove ‘/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0227Sun.51404’: No such file or directory
*** launching tests from jelly ***
TESTHOST is jelly
koala
platypus
moohan
ostrich
osx1011test
    Fork off timekeeper 20
Testing jelly
ssh -o ConnectTimeout=60 jelly -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jelly
 22:38:33 up 74 days,  5:37, 10 users,  load average: 3.52, 5.08, 6.11
tmpfs                        65880616     708620   65171996   2% /run
/dev/mapper/centos00-root    16766976   10677044    6089932  64% /
/dev/md0                   3904859232 1890079772 2014779460  49% /scr
10.10.10.86:/mnt/scr1       961432576  873576448   39017472  96% /mnt/scr1
Extract source and run autogen if .
Sun Feb 27 22:38:44 CST 2022
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly tests in jelly ***
Uname -a: Linux jelly 3.10.0-1160.24.1.el7.x86_64 #1 SMP Thu Apr 8 19:51:47 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
Running snapshot with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/jelly_0227Sun_2238
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly tests for jelly ***
Sun Feb 27 22:39:47 CST 2022
Total time = 1m 3s
*** finished tests in jelly ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
 22:38:35 up 240 days, 13:15,  0 users,  load average: 0.00, 0.00, 0.00
/dev/sda7             22292052   4428032  16713368  21% /
/dev/sda5             12192608    395808  11167456   4% /tmp
/dev/sda3             12192636   1134700  10428592  10% /var
/dev/sda1               101086     18614     77253  20% /boot
/dev/sdc1             41279536  26323756  12858900  68% /usr
/dev/sdb             152754284  75879472  69115352  53% /scr
tmpfs                  6149552         0   6149552   0% /dev/shm
gumund:/data/ftp     480719104 405906560  50393344  89% /mnt/ftp
gumund:/data/web     480719104 405906560  50393344  89% /mnt/web
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Sun Feb 27 22:38:46 CST 2022
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-409.el5 #1 SMP Tue Mar 15 18:13:50 EDT 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/koala_0227Sun_2238
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Sun Feb 27 22:39:18 CST 2022
Total time = 0m 32s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
 22:38:38 up 240 days, 13:15,  0 users,  load average: 0.01, 0.09, 0.09
/dev/sda6             54205540  43007028   8438372  84% /
tmpfs                  6099068         0   6099068   0% /dev/shm
/dev/sda1               194241     48310    135691  27% /boot
/dev/sda2             12850716  12174660     16600 100% /tmp
/dev/sda3             12850716   6132668   6058592  51% /var
/dev/sdd             152623212 118162844  26700908  82% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Sun Feb 27 22:38:48 CST 2022
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.22.1.el6.x86_64 #1 SMP Wed Mar 23 03:35:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Total time = 0m 8s
*** finished tests in platypus ***
****SYSTEM ERROR platypus: Abnormal exit from runtest ****
	****SYSTEM ERROR platypus: runtest command failed ****
Testing moohan
ssh -o ConnectTimeout=60 moohan -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname moohan
 22:38:42 up 136 days,  5:04,  1 user,  load average: 7.45, 7.79, 7.22
/dev/mapper/centos_moohan-root  52196352  10269296  41927056  20% /
devtmpfs                         3923072         0   3923072   0% /dev
tmpfs                            3939844        84   3939760   1% /dev/shm
tmpfs                            3939844    377860   3561984  10% /run
tmpfs                            3939844         0   3939844   0% /sys/fs/cgroup
/dev/md126p1                      506752    312960    193792  62% /boot
/dev/mapper/centos_moohan-tmp   16371712     35760  16335952   1% /tmp
/dev/mapper/centos_moohan-scr  858065536 403973020 454092516  48% /scr
/dev/mapper/centos_moohan-var   16371712   4613224  11758488  29% /var
jam:/home                      961432576  97048576 815546368  11% /home
jam:/mnt/scr1                  961432576 873576448  39017472  96% /mnt/scr1
jam:/mnt/hdf                   961432576 908977152   3617792 100% /mnt/hdf
tmpfs                             787972        16    787956   1% /run/user/42
tmpfs                             787972         0    787972   0% /run/user/27429
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests in moohan ***
Uname -a: Linux moohan.ad.hdfgroup.org 3.10.0-327.10.1.el7.x86_64 #1 SMP Tue Feb 16 17:03:50 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/moohan_0227Sun_2238
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests for moohan ***
Sun Feb 27 22:43:39 CST 2022
Total time = 4m 46s
*** finished tests in moohan ***
Sun Feb 27 22:43:40 CST 2022
Testing ostrich
ostrich is not reachable (Sun Feb 27 22:38:44 CST 2022)
	****SYSTEM ERROR: ostrich is not reachable (Sun Feb 27 22:38:44 CST 2022)
	****INCOMPLETE ostrich: snaptest did not complete****
Testing osx1011test
ssh -o ConnectTimeout=60 osx1011test -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname osx1011test
grep: /proc/cpuinfo: No such file or directory
22:38  up 435 days,  8:39, 0 users, load averages: 1.66 2.31 1.88
Filesystem                    512-blocks       Used  Available Capacity  iused     ifree %iused  Mounted on
/dev/disk1                    1951137792  199743648 1750882144    11% 25031954 218860268   10%   /
devfs                                357        357          0   100%      618         0  100%   /dev
map auto_nfs                           0          0          0   100%        0         0  100%   /mnt/hdf
map auto_nfs                           0          0          0   100%        0         0  100%   /mnt/scr1
map auto_nfs                           0          0          0   100%        0         0  100%   /home
jam.ad.hdfgroup.org:/mnt/scr1 1922864144 1747153552   78034592    96%  3460986 118648966    3%   /mnt/scr1
jam.ad.hdfgroup.org:/mnt/hdf  1922864144 1817954232    7233912   100% 10845263 111264689    9%   /mnt/hdf
jam.ad.hdfgroup.org:/home     1922864144  194096256 1631091888    11%   951831 121158121    1%   /home
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy osx1011test
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy osx1011test tests in osx1011test ***
Uname -a: Darwin osx1011test.ad.hdfgroup.org 15.6.0 Darwin Kernel Version 15.6.0: Thu Jun 21 20:07:40 PDT 2018; root:xnu-3248.73.11~1/RELEASE_X86_64 x86_64
   /Users/hdftest/snapshots-opa/log/osx1011test_0227Sun_2238
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy osx1011test tests for osx1011test ***
Sun Feb 27 22:40:08 CST 2022
Total time = 1m 12s
*** finished tests in osx1011test ***
More information about the opa-nightly-tests mailing list
