[opa-nightly-tests] jelly OPA_Daily_Tests_1123Tue_FAILED!!!
hdftest
hdftest at hdfgroup.org
Tue Nov 23 22:21:51 CST 2021
*** OPA Tests on 1123Tue ***
Tests Summary
****FAILED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus****
PASSED jelly: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED moohan: standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
PASSED osx1011test: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy osx1011test
Tests Time Summary
platypus: Ran 1(0/1/0) tests, Grand total test time = 0m 8s
koala: Ran 1(1/0/0) tests, Grand total test time = 0m 32s
jelly: Ran 1(1/0/0) tests, Grand total test time = 1m 3s
osx1011test: Ran 1(1/0/0) tests, Grand total test time = 1m 2s
moohan: Ran 1(1/0/0) tests, Grand total test time = 1m 21s
jelly: Ran 6(0/0/0) hosts, Grand total test time = 2m 27s
Timekeeper log
Timekeeper started at Tue Nov 23 22:19:36 CST 2021
Timekeeper sleeping for 1200 seconds
Tests Failures
Dumping logfile of platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/platypus_1123Tue_2219
checking whether to enable strict fairness checks... no
checking that generated files are newer than configure... done
configure: creating ./config.status
config.status: creating Makefile
config.status: creating src/Makefile
config.status: creating test/Makefile
config.status: creating openpa.pc
config.status: creating src/config.h
config.status: executing depfiles commands
config.status: executing libtool commands
config.status: executing src/opa_config.h commands
config.status: creating src/opa_config.h - prefix OPA for src/config.h defines
===== make: Tue Nov 23 22:20:02 CST 2021 =====
Making all in src
gmake[1]: Entering directory `/scr/hdftest/snapshots-opa/TestDir/platypus/src'
gmake all-am
gmake[2]: Entering directory `/scr/hdftest/snapshots-opa/TestDir/platypus/src'
CC opa_primitives.lo
CC opa_queue.lo
CCLD libopa.la
gmake[2]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/platypus/src'
gmake[1]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/platypus/src'
Making all in test
gmake[1]: Entering directory `/scr/hdftest/snapshots-opa/TestDir/platypus/test'
gmake[1]: Nothing to be done for `all'.
gmake[1]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/platypus/test'
gmake[1]: Entering directory `/scr/hdftest/snapshots-opa/TestDir/platypus'
gmake[1]: Nothing to be done for `all-am'.
gmake[1]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/platypus'
Disk Usage=632 KB
Making check in src
Making check in test
gmake sanity test_primitives test_barriers test_queue
gmake[2]: Entering directory `/scr/hdftest/snapshots-opa/TestDir/platypus/test'
CC sanity.o
CCLD sanity
CC test_primitives.o
/home/hdftest/snapshots-opa/current/test/test_primitives.c:4974: fatal error: error writing to /tmp/cc0q0wpz.s: No space left on device
compilation terminated.
gmake[2]: *** [test_primitives.o] Error 1
gmake[2]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/platypus/test'
gmake[1]: *** [check-am] Error 2
gmake: *** [check-recursive] Error 1
Failed running make check
===== Exit bin/snapshot with status=2: Tue Nov 23 22:20:05 CST 2021 =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
22:19:14 up 204 days, 1:45, 8 users, load average: 6.02, 6.22, 6.34
Filesystem 1K-blocks Used Available Use% Mounted on
devtmpfs 65868460 0 65868460 0% /dev
tmpfs 65880616 278976 65601640 1% /dev/shm
tmpfs 65880616 2231544 63649072 4% /run
tmpfs 65880616 0 65880616 0% /sys/fs/cgroup
/dev/mapper/centos00-root 16766976 12414468 4352508 75% /
tmpfs 65880616 0 65880616 0% /mnt/daos
/dev/md0 3904859232 1781394872 2123464360 46% /scr
/dev/sda1 520876 245196 275680 48% /boot
/dev/mapper/centos00-opt 134152192 116298484 17853708 87% /opt
/dev/md10 11718682624 7611195764 4107486860 65% /mnt/wrk
10.10.10.86:/home 961432576 92071936 820521984 11% /home
10.10.10.86:/mnt/hdf 961432576 905116672 7477248 100% /mnt/hdf
10.10.10.86:/mnt/scr1 961432576 858559488 54035456 95% /mnt/scr1
10.10.10.85:/data/ftp 480719104 404320640 51979264 89% /mnt/ftp
10.10.10.85:/data/web 480719104 404320640 51979264 89% /mnt/web
tmpfs 13176124 0 13176124 0% /run/user/10094
tmpfs 13176124 0 13176124 0% /run/user/29138
tmpfs 13176124 0 13176124 0% /run/user/22417
tmpfs 13176124 0 13176124 0% /run/user/10013
tmpfs 13176124 0 13176124 0% /run/user/27429
tmpfs 13176124 0 13176124 0% /run/user/17929
tmpfs 13176124 0 13176124 0% /run/user/10095
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_1123Tue
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1123Tue.4123: No such file or directory
rm: cannot remove ‘/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1123Tue.4123’: No such file or directory
*** launching tests from jelly ***
TESTHOST is jelly
koala
platypus
moohan
ostrich
osx1011test
Fork off timekeeper 20
Testing jelly
ssh -o ConnectTimeout=60 jelly -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jelly
22:19:42 up 204 days, 1:45, 8 users, load average: 6.08, 6.22, 6.34
tmpfs 65880616 2231584 63649032 4% /run
/dev/mapper/centos00-root 16766976 12414428 4352548 75% /
/dev/md0 3904859232 1781395712 2123463520 46% /scr
10.10.10.86:/mnt/scr1 961432576 858560512 54033408 95% /mnt/scr1
Extract source and run autogen if .
Tue Nov 23 22:19:52 CST 2021
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly tests in jelly ***
Uname -a: Linux jelly 3.10.0-1160.24.1.el7.x86_64 #1 SMP Thu Apr 8 19:51:47 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/jelly_1123Tue_2219
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly tests for jelly ***
Tue Nov 23 22:20:55 CST 2021
Total time = 1m 3s
*** finished tests in jelly ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
22:19:44 up 144 days, 12:56, 0 users, load average: 0.01, 0.01, 0.03
/dev/sda7 22292052 4428020 16713380 21% /
/dev/sda5 12192608 392424 11170840 4% /tmp
/dev/sda3 12192636 1122116 10441176 10% /var
/dev/sda1 101086 18614 77253 20% /boot
/dev/sdc1 41279536 26323756 12858900 68% /usr
/dev/sdb 152754284 75795364 69199460 53% /scr
tmpfs 6149552 0 6149552 0% /dev/shm
gumund:/data/ftp 480719104 404320640 51979264 89% /mnt/ftp
gumund:/data/web 480719104 404320640 51979264 89% /mnt/web
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Tue Nov 23 22:19:54 CST 2021
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-409.el5 #1 SMP Tue Mar 15 18:13:50 EDT 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/koala_1123Tue_2219
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Tue Nov 23 22:20:26 CST 2021
Total time = 0m 32s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
22:19:47 up 144 days, 12:56, 0 users, load average: 0.21, 0.20, 0.21
/dev/sda6 54205540 43007028 8438372 84% /
tmpfs 6099068 0 6099068 0% /dev/shm
/dev/sda1 194241 48310 135691 27% /boot
/dev/sda2 12850716 12174828 16432 100% /tmp
/dev/sda3 12850716 5750216 6441044 48% /var
/dev/sdd 152623212 118530136 26333616 82% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Tue Nov 23 22:19:57 CST 2021
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.22.1.el6.x86_64 #1 SMP Wed Mar 23 03:35:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Total time = 0m 8s
*** finished tests in platypus ***
****SYSTEM ERROR platypus: Abnormal exit from runtest ****
****SYSTEM ERROR platypus: runtest command failed ****
Testing moohan
ssh -o ConnectTimeout=60 moohan -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname moohan
22:19:50 up 40 days, 4:45, 1 user, load average: 0.15, 0.51, 0.72
/dev/mapper/centos_moohan-root 52196352 10269296 41927056 20% /
devtmpfs 3923072 0 3923072 0% /dev
tmpfs 3939844 84 3939760 1% /dev/shm
tmpfs 3939844 418796 3521048 11% /run
tmpfs 3939844 0 3939844 0% /sys/fs/cgroup
/dev/md126p1 506752 312960 193792 62% /boot
/dev/mapper/centos_moohan-tmp 16371712 33400 16338312 1% /tmp
/dev/mapper/centos_moohan-scr 858065536 405527140 452538396 48% /scr
/dev/mapper/centos_moohan-var 16371712 4173880 12197832 26% /var
jam:/home 961432576 92071936 820521984 11% /home
jam:/mnt/scr1 961432576 858560512 54033408 95% /mnt/scr1
jam:/mnt/hdf 961432576 905116672 7477248 100% /mnt/hdf
tmpfs 787972 16 787956 1% /run/user/42
tmpfs 787972 0 787972 0% /run/user/0
tmpfs 787972 0 787972 0% /run/user/27429
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
Tue Nov 23 22:20:00 CST 2021
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests in moohan ***
Uname -a: Linux moohan.ad.hdfgroup.org 3.10.0-327.10.1.el7.x86_64 #1 SMP Tue Feb 16 17:03:50 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/moohan_1123Tue_2220
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests for moohan ***
Tue Nov 23 22:21:21 CST 2021
Total time = 1m 21s
*** finished tests in moohan ***
Testing ostrich
ostrich is not reachable (Tue Nov 23 22:19:52 CST 2021)
****SYSTEM ERROR: ostrich is not reachable (Tue Nov 23 22:19:52 CST 2021)
****INCOMPLETE ostrich: snaptest did not complete****
Testing osx1011test
ssh -o ConnectTimeout=60 osx1011test -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname osx1011test
grep: /proc/cpuinfo: No such file or directory
22:19 up 339 days, 8:20, 0 users, load averages: 1.11 1.25 1.30
Filesystem 512-blocks Used Available Capacity iused ifree %iused Mounted on
/dev/disk1 1951137792 198388024 1752237768 11% 24862501 219029721 10% /
devfs 357 357 0 100% 619 0 100% /dev
map auto_nfs 0 0 0 100% 0 0 100% /mnt/hdf
map auto_nfs 0 0 0 100% 0 0 100% /mnt/scr1
map auto_nfs 0 0 0 100% 0 0 100% /home
jam.ad.hdfgroup.org:/mnt/scr1 1922864144 1717121832 108066312 95% 3429014 118680938 3% /mnt/scr1
jam.ad.hdfgroup.org:/home 1922864144 184144232 1641043912 11% 960038 121149914 1% /home
jam.ad.hdfgroup.org:/mnt/hdf 1922864144 1810233816 14954328 100% 10735136 111374816 9% /mnt/hdf
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy osx1011test
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy osx1011test tests in osx1011test ***
Uname -a: Darwin osx1011test.ad.hdfgroup.org 15.6.0 Darwin Kernel Version 15.6.0: Thu Jun 21 20:07:40 PDT 2018; root:xnu-3248.73.11~1/RELEASE_X86_64 x86_64
/Users/hdftest/snapshots-opa/log/osx1011test_1123Tue_2220
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy osx1011test tests for osx1011test ***
Tue Nov 23 22:21:07 CST 2021
Total time = 1m 2s
*** finished tests in osx1011test ***
More information about the opa-nightly-tests
