[opa-nightly-tests] jelly OPA_Daily_Tests_1108Fri_FAILED!!!
hdftest
hdftest at hdfgroup.org
Fri Nov 8 07:38:38 CST 2019
*** OPA Tests on 1108Fri ***
Tests Summary
****FAILED jelly: standard****
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED moohan: standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
PASSED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Tests Time Summary
koala: Ran 1(1/0/0) tests, Grand total test time = 0m 32s
platypus: Ran 1(1/0/0) tests, Grand total test time = 0m 41s
jelly: Ran 1(0/1/0) tests, Grand total test time = 0m 57s
moohan: Ran 1(1/0/0) tests, Grand total test time = 1m 7s
ostrich: Ran 2(2/0/0) tests, Grand total test time = 4m 41s
jelly: Ran 6(0/0/0) hosts, Grand total test time = 5m 47s
Timekeeper log
Timekeeper started at Fri Nov 8 07:33:00 CST 2019
Timekeeper sleeping for 720 seconds
Tests Failures
Dumping logfile of jelly: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/jelly_1108Fri_0733
Testing memory barriers with scattered array with 4 threads PASSED
Testing memory barriers with linear array with 10 threads PASSED
Testing memory barriers with local variables with 10 threads PASSED
Testing memory barriers with scattered array with 10 threads PASSED
Testing memory barriers with linear array with 100 threads PASSED
Testing memory barriers with local variables with 100 threads PASSED
Testing memory barriers with scattered array with 100 threads PASSED
All barriers tests passed.
PASS: test_barriers
Testing queue sanity PASSED
Testing multithreaded queue with 2 threads PASSED
Testing multithreaded queue (empty queue) with 2 threads PASSED
Testing multithreaded queue (full queue) with 2 threads PASSED
Testing multithreaded queue with 4 threads PASSED
Testing multithreaded queue (empty queue) with 4 threads PASSED
Testing multithreaded queue (full queue) with 4 threads PASSED
Testing multithreaded queue with 10 threads PASSED
Testing multithreaded queue (empty queue) with 10 threads PASSED
Testing multithreaded queue (full queue) with 10 threads PASSED
Testing multithreaded queue with 100 threads PASSED
Testing multithreaded queue (empty queue) with 100 threads PASSED
Testing multithreaded queue (full queue) with 100 threads PASSED
All queue tests passed.
PASS: test_queue
All 4 tests passed
gmake[2]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/jelly/test'
gmake[1]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/jelly/test'
gmake[1]: Entering directory `/scr/hdftest/snapshots-opa/TestDir/jelly'
gmake[1]: Nothing to be done for `check-am'.
gmake[1]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/jelly'
Disk Usage=1652 KB
Making install in src
gmake[1]: Entering directory `/scr/hdftest/snapshots-opa/TestDir/jelly/src'
gmake[2]: Entering directory `/scr/hdftest/snapshots-opa/TestDir/jelly/src'
/usr/bin/mkdir -p '/usr/local/lib'
/bin/sh ../libtool --mode=install /usr/bin/install -c libopa.la '/usr/local/lib'
libtool: install: /usr/bin/install -c .libs/libopa.lai /usr/local/lib/libopa.la
/usr/bin/install: cannot create regular file '/usr/local/lib/libopa.la': Permission denied
gmake[2]: *** [install-libLTLIBRARIES] Error 1
gmake[2]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/jelly/src'
gmake[1]: *** [install-am] Error 2
gmake[1]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/jelly/src'
gmake: *** [install-recursive] Error 1
Failed running make install
Test failed. Test directory and files from failed test were saved in
/scr/hdftest/snapshots-opa/TestDir/jelly_1108Fri_0733.
===== Exit bin/snapshot with status=2: Fri Nov 8 07:34:14 CST 2019 =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
07:32:41 up 18 days, 18 min, 19 users, load average: 0.13, 0.70, 0.71
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/mapper/centos00-root 16766976 12451056 4315920 75% /
devtmpfs 65864052 0 65864052 0% /dev
tmpfs 65874008 155308 65718700 1% /dev/shm
tmpfs 65874008 273308 65600700 1% /run
tmpfs 65874008 0 65874008 0% /sys/fs/cgroup
tmpfs 65874008 0 65874008 0% /mnt/daos
/dev/md0 3904859232 811043884 3093815348 21% /scr
/dev/md10 11718682624 7532243624 4186439000 65% /mnt/wrk
/dev/sda1 520876 169532 351344 33% /boot
/dev/mapper/centos00-opt 134152192 119922832 14229360 90% /opt
10.10.10.86:/home 198351872 90516480 97596416 49% /home
10.10.10.86:/mnt/hdf 961432576 906984448 5610496 100% /mnt/hdf
10.10.10.86:/mnt/scr1 961432576 893878272 18716672 98% /mnt/scr1
tmpfs 13174804 0 13174804 0% /run/user/10093
tmpfs 13174804 0 13174804 0% /run/user/10094
10.10.10.85:/data/ftp 480719104 411072512 45227392 91% /mnt/ftp
10.10.10.85:/data/web 480719104 411072512 45227392 91% /mnt/web
tmpfs 13174804 0 13174804 0% /run/user/30308
tmpfs 13174804 0 13174804 0% /run/user/17929
tmpfs 13174804 0 13174804 0% /run/user/10046
tmpfs 13174804 0 13174804 0% /run/user/10019
tmpfs 13174804 0 13174804 0% /run/user/27429
tmpfs 13174804 0 13174804 0% /run/user/10013
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_1108Fri
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1108Fri.180818: No such file or directory
rm: cannot remove ‘/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1108Fri.180818’: No such file or directory
*** launching tests from jelly ***
TESTHOST is jelly
koala
platypus
moohan
ostrich
osx1010test
Fork off timekeeper 12
Testing jelly
ssh -o ConnectTimeout=60 jelly -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jelly
07:33:07 up 18 days, 19 min, 19 users, load average: 0.31, 0.69, 0.70
/dev/mapper/centos00-root 16766976 12451308 4315668 75% /
tmpfs 65874008 273340 65600668 1% /run
10.10.10.86:/mnt/scr1 961432576 893881344 18713600 98% /mnt/scr1
TEST_TYPES=standard
Extract source and run autogen if .
Fri Nov 8 07:33:17 CST 2019
*** starting standard tests in jelly ***
Uname -a: Linux jelly 3.10.0-327.18.2.el7.x86_64 #1 SMP Thu May 12 11:03:55 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
Running snapshot with output saved in
*** finished standard tests for jelly ***
Total time = 0m 57s
*** finished tests in jelly ***
****SYSTEM ERROR jelly: Abnormal exit from runtest ****
****SYSTEM ERROR jelly: runtest command failed ****
Testing koala
ssh -o ConnectTimeout=60 koala -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
07:33:08 up 17 days, 21:35, 1 user, load average: 0.00, 0.01, 0.00
/dev/sda7 22292052 4427884 16713516 21% /
/dev/sda5 12192608 377728 11185536 4% /tmp
/dev/sda3 12192636 1032324 10530968 9% /var
/dev/sda1 101086 18614 77253 20% /boot
/dev/sdc1 41279536 26323756 12858900 68% /usr
/dev/sdb 152754284 72015904 72978920 50% /scr
tmpfs 6149552 0 6149552 0% /dev/shm
gumund:/data/ftp 480719104 411072512 45227392 91% /mnt/ftp
gumund:/data/web 480719104 411072512 45227392 91% /mnt/web
10.10.10.15:/volume1/readonly
1437485440 580201600 857181440 41% /mnt/ro-src
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Fri Nov 8 07:33:19 CST 2019
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-409.el5 #1 SMP Tue Mar 15 18:13:50 EDT 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/koala_1108Fri_0733
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Fri Nov 8 07:33:50 CST 2019
Total time = 0m 31s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
07:33:11 up 17 days, 21:35, 1 user, load average: 0.09, 0.08, 0.46
/dev/sda6 54205540 43007028 8438372 84% /
tmpfs 6099068 0 6099068 0% /dev/shm
/dev/sda1 194241 48310 135691 27% /boot
/dev/sda2 12850716 220488 11970772 2% /tmp
/dev/sda3 12850716 5366440 6824820 45% /var
/dev/sdd 152623212 118218004 26645748 82% /scr
961432576 893923328 18670592 98% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Fri Nov 8 07:33:22 CST 2019
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.22.1.el6.x86_64 #1 SMP Wed Mar 23 03:35:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/platypus_1108Fri_0733
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Fri Nov 8 07:34:02 CST 2019
Total time = 0m 40s
*** finished tests in platypus ***
Testing moohan
ssh -o ConnectTimeout=60 moohan -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname moohan
07:33:14 up 130 days, 16:06, 1 user, load average: 1.50, 3.20, 3.31
/dev/mapper/centos_moohan-root 52196352 9618976 42577376 19% /
devtmpfs 3923072 0 3923072 0% /dev
tmpfs 3939844 84 3939760 1% /dev/shm
tmpfs 3939844 410608 3529236 11% /run
tmpfs 3939844 0 3939844 0% /sys/fs/cgroup
/dev/md126p1 506752 312676 194076 62% /boot
/dev/mapper/centos_moohan-scr 858065536 413806132 444259404 49% /scr
/dev/mapper/centos_moohan-var 16371712 5889180 10482532 36% /var
/dev/mapper/centos_moohan-tmp 16371712 308360 16063352 2% /tmp
jam:/mnt/scr1 961432576 893916160 18678784 98% /mnt/scr1
jam:/mnt/hdf 961432576 906984448 5610496 100% /mnt/hdf
jam:/home 198351872 90516480 97596416 49% /home
tmpfs 787972 16 787956 1% /run/user/42
10.10.10.15:/volume1/readonly 1437485440 580201600 857181440 41% /mnt/ro-src
tmpfs 787972 0 787972 0% /run/user/27429
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
Fri Nov 8 07:33:25 CST 2019
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests in moohan ***
Uname -a: Linux moohan.ad.hdfgroup.org 3.10.0-327.10.1.el7.x86_64 #1 SMP Tue Feb 16 17:03:50 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/moohan_1108Fri_0733
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests for moohan ***
Fri Nov 8 07:34:31 CST 2019
Total time = 1m 6s
*** finished tests in moohan ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
07:33:17 up 17 days, 21:00, 1 user, load average: 0.02, 0.04, 0.01
/dev/mapper/vg_ostrich-lv_root
140479384 28479536 104860804 22% /
tmpfs 7821504 0 7821504 0% /dev/shm
/dev/sda2 487652 99874 362178 22% /boot
/dev/sdb2 124477364 90662232 27485380 77% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Fri Nov 8 07:33:27 CST 2019
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-696.20.1.el6.ppc64 #1 SMP Fri Jan 12 14:20:08 EST 2018 ppc64 ppc64 ppc64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_1108Fri_0733
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Fri Nov 8 07:35:08 CST 2019
Total time = 1m 41s
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich ***
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_1108Fri_0735
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich ***
Fri Nov 8 07:38:08 CST 2019
Total time = 3m 0s
*** finished tests in ostrich ***
Testing osx1010test
osx1010test is not reachable (Fri Nov 8 07:33:17 CST 2019)
****SYSTEM ERROR: osx1010test is not reachable (Fri Nov 8 07:33:17 CST 2019)
****INCOMPLETE osx1010test: snaptest did not complete****
More information about the opa-nightly-tests
