[opa-nightly-tests] jelly OPA_Daily_Tests_1103Sun_FAILED!!!
hdftest hdftest at hdfgroup.org
Sun Nov 3 23:55:09 CST 2019
*** OPA Tests on 1103Sun ***
   Tests Summary
****FAILED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam****
****FAILED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala****
****FAILED moohan: standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan****
****FAILED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich****
****FAILED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl****
****FAILED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus****
   Tests Time Summary
jam: Ran 1(0/1/0) tests, Grand total test time =  0m 1s
koala: Ran 1(0/1/0) tests, Grand total test time =  0m 0s
platypus: Ran 1(0/1/0) tests, Grand total test time =  0m 1s
moohan: Ran 1(0/1/0) tests, Grand total test time =  0m 2s
ostrich: Ran 2(0/2/0) tests, Grand total test time =  0m 1s
jelly: Ran 6(0/0/0) hosts, Grand total test time =  0m 58s
   Timekeeper log
Timekeeper started at Sun Nov  3 23:54:12 CST 2019
Timekeeper sleeping for 720 seconds
   Tests Failures
Dumping logfile of jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/jam_1103Sun_2354
EC2_PRIVATE_KEY=/home/hdftest/.ec2/pk-6HKISUOM3HT2PWDQB4PLG67KTWOVVKOK.pem
G_BROKEN_FILENAMES=1
GROUP=hdf
HDF5_ACLOCAL=/mnt/hdf/packages/AUTOTOOLS/automake/1.15/i386/bin/aclocal-1.15
HDF5_AUTOCONF=/mnt/hdf/packages/AUTOTOOLS/autoconf/2.69/i386/bin/autoconf
HDF5_AUTOHEADER=/mnt/hdf/packages/AUTOTOOLS/autoconf/2.69/i386/bin/autoheader
HDF5_AUTOMAKE=/mnt/hdf/packages/AUTOTOOLS/automake/1.15/i386/bin/automake-1.15
HDF5_LIBTOOL=/mnt/hdf/packages/AUTOTOOLS/libtool/2.4.6/i386/bin/libtool
HDF5_M4=/mnt/hdf/packages/AUTOTOOLS/m4/1.4.17/i386/bin/m4
HDF5TestExpress=yes
HOME=/home/hdftest
HOST=jam
HOSTTYPE=i386-linux
KDEDIR=/usr
KDE_IS_PRELINKED=1
LANG=en_US.UTF-8
LESSOPEN=|/usr/bin/lesspipe.sh %s
LOADEDMODULES=
LOGNAME=hdftest
LS_COLORS=
MACHTYPE=i386
MAIL=/var/spool/mail/hdftest
MAKE=gmake
MANPATH=/usr/local/man:/usr/share/man:/usr/kerberos/man
MODULEPATH=/usr/share/Modules/modulefiles:/etc/modulefiles
MODULESHOME=/usr/share/Modules
OSTYPE=linux
PATH=/home/hdftest/bin:/usr/hdf/bin:/home/hdftest/bin:/usr/hdf/bin:/usr/local/bin:/bin:/usr/bin:/usr/kerberos/bin:/mnt/hdf/ec2-api-tools/bin
PWD=/mnt/scr1/SnapTest/snapshots-opa
SET_PATH=yes
SHELL=/bin/tcsh
SHLVL=3
SSH_CLIENT=10.10.10.120 45647 22
SSH_CONNECTION=10.10.10.120 45647 10.10.10.86 22
SVNROOT=http://svn.hdfgroup.uiuc.edu
USER=hdftest
_=/usr/bin/printenv
VENDOR=intel
===Done Dumping environment variables after option parsing ===
===== Run Tests: Sun Nov  3 23:54:26 CST 2019 =====
Remove contents of jam.\n
/usr/bin/diff: /home/hdftest/snapshots-opa/previous/MANIFEST: No such file or directory
/usr/bin/diff: /home/hdftest/snapshots-opa/current/MANIFEST: No such file or directory
===== configure: Sun Nov  3 23:54:26 CST 2019 =====
bin/snapshot: line 140: /home/hdftest/snapshots-opa/current/configure: No such file or directory
Failed running configure
Test failed.  Test directory and files from failed test were saved in
/mnt/scr1/SnapTest/snapshots-opa/TestDir/jam_1103Sun_2354.
===== Exit bin/snapshot with status=127: Sun Nov  3 23:54:26 CST 2019 =====
Sun Nov  3 23:54:27 CST 2019
Dumping done
Dumping logfile of koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/koala_1103Sun_2354
CCACHE_DISABLE=yes
CVSROOT=/mnt/hdf/cvs
CVS_RSH=ssh
EC2_CERT=/home/hdftest/.ec2/cert-6HKISUOM3HT2PWDQB4PLG67KTWOVVKOK.pem
EC2_HOME=/mnt/hdf/ec2-api-tools
GROUP=hdf
HDF5TestExpress=yes
HOME=/home/hdftest
HOST=koala
HOSTTYPE=x86_64-linux
KDEDIR=/usr
KDE_IS_PRELINKED=1
LANG=en_US.UTF-8
LOADEDMODULES=
LOGNAME=hdftest
LS_COLORS=
MACHTYPE=x86_64
MAKE=gmake
OSTYPE=linux
SET_PATH=yes
SHELL=/bin/tcsh
SHLVL=3
SSH_ASKPASS=/usr/libexec/openssh/gnome-ssh-askpass
SSH_CLIENT=10.10.10.120 52514 22
SSH_CONNECTION=10.10.10.120 52514 10.10.10.89 22
USER=hdftest
_=/usr/bin/printenv
VENDOR=unknown
===== Run Tests: Sun Nov  3 23:54:29 CST 2019 =====
Remove contents of koala.\n
===== configure: Sun Nov  3 23:54:29 CST 2019 =====
/scr/hdftest/snapshots-opa/TestDir/koala_1103Sun_2354.
===== Exit bin/snapshot with status=127: Sun Nov  3 23:54:29 CST 2019 =====
Dumping done
Dumping logfile of platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/platypus_1103Sun_2354
LANG=en_US.UTF-8
LESSOPEN=||/usr/bin/lesspipe.sh %s
LMOD_arch=x86_64
LMOD_CMD=/usr/share/lmod/lmod/libexec/lmod
LMOD_COLORIZE=yes
LMOD_DIR=/usr/share/lmod/lmod/libexec
LMOD_FULL_SETTARG_SUPPORT=no
LMOD_PKG=/usr/share/lmod/lmod
LMOD_PREPEND_BLOCK=normal
LMOD_SETTARG_CMD=:
LMOD_sys=Linux
LMOD_VERSION=6.5.1
LOADEDMODULES=
LOGNAME=hdftest
LS_COLORS=
MACHTYPE=x86_64
MAKE=gmake
MANPATH=/usr/share/lmod/lmod/share/man:/usr/local/man:/usr/share/man:/usr/kerberos/man
MODULEPATH=/etc/modulefiles:/usr/share/modulefiles:/usr/share/modulefiles/Linux:/usr/share/modulefiles/Core:/usr/share/lmod/lmod/modulefiles/Core
MODULEPATH_ROOT=/usr/share/modulefiles
MODULESHOME=/usr/share/lmod/lmod
OSTYPE=linux
SELINUX_LEVEL_REQUESTED=
SELINUX_ROLE_REQUESTED=
SELINUX_USE_CURRENT_RANGE=
SET_PATH=yes
SHELL=/bin/tcsh
SHLVL=3
SSH_CLIENT=10.10.10.120 50921 22
SSH_CONNECTION=10.10.10.120 50921 10.10.10.104 22
TARG_TITLE_BAR_PAREN=
USER=hdftest
_=/usr/bin/printenv
VENDOR=unknown
===== Run Tests: Sun Nov  3 23:54:32 CST 2019 =====
Remove contents of platypus.\n
===== configure: Sun Nov  3 23:54:32 CST 2019 =====
/scr/hdftest/snapshots-opa/TestDir/platypus_1103Sun_2354.
===== Exit bin/snapshot with status=127: Sun Nov  3 23:54:32 CST 2019 =====
Dumping done
Dumping logfile of moohan: standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/moohan_1103Sun_2354
LMOD_arch=x86_64
LMOD_COLORIZE=yes
LMOD_SETTARG_CMD=:
LMOD_sys=Linux
LMOD_VERSION=6.3.4
LOGNAME=hdftest
MACHTYPE=x86_64
MAKE=gmake
MODULEPATH=/etc/modulefiles:/usr/share/modulefiles:/usr/share/Modules/modulefiles:/usr/share/modulefiles/Linux:/usr/share/modulefiles/Core:/usr/share/lmod/lmod/modulefiles/Core
OSTYPE=linux
PATH=/home/hdftest/bin:/usr/hdf/bin:/home/hdftest/bin:/usr/lib64/qt-3.3/bin:/usr/hdf/bin:/usr/local/bin:/usr/bin:/usr/kerberos/bin:/bin:/mnt/hdf/ec2-api-tools/bin
QTDIR=/usr/lib64/qt-3.3
QT_GRAPHICSSYSTEM_CHECKED=1
QTINC=/usr/lib64/qt-3.3/include
QTLIB=/usr/lib64/qt-3.3/lib
QT_PLUGIN_PATH=/usr/lib64/kde4/plugins:/usr/lib/kde4/plugins
SET_PATH=yes
SHELL=/bin/tcsh
SHLVL=3
SSH_CLIENT=10.10.10.120 52243 22
SSH_CONNECTION=10.10.10.120 52243 10.10.10.93 22
USER=hdftest
_=/usr/bin/printenv
VENDOR=unknown
XDG_RUNTIME_DIR=/run/user/27429
XDG_SESSION_ID=225471
===== Run Tests: Sun Nov  3 23:54:38 CST 2019 =====
Remove contents of moohan.\n
===== configure: Sun Nov  3 23:54:38 CST 2019 =====
/scr/hdftest/snapshots-opa/TestDir/moohan_1103Sun_2354.
===== Exit bin/snapshot with status=127: Sun Nov  3 23:54:38 CST 2019 =====
Dumping done
Dumping logfile of ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_1103Sun_2354
LMOD_arch=ppc64
LMOD_COLORIZE=yes
LMOD_SETTARG_CMD=:
LMOD_sys=Linux
LMOD_VERSION=6.5.1
LOADEDMODULES=
LOGNAME=hdftest
LS_COLORS=
MACHTYPE=powerpc64
MAKE=gmake
OSTYPE=linux
PATH=/home/hdftest/bin:/usr/hdf/bin:/home/hdftest/bin:/usr/lib64/qt-3.3/bin:/usr/hdf/bin:/usr/local/bin:/bin:/usr/bin:/usr/kerberos/bin:/mnt/hdf/ec2-api-tools/bin
SET_PATH=yes
SHELL=/bin/tcsh
SHLVL=3
SSH_CLIENT=10.10.10.120 54157 22
SSH_CONNECTION=10.10.10.120 54157 10.10.10.95 22
USER=hdftest
_=/usr/bin/printenv
VENDOR=unknown
===== Run Tests: Sun Nov  3 23:54:39 CST 2019 =====
Remove contents of ostrich.\n
===== configure: Sun Nov  3 23:54:39 CST 2019 =====
/scr/hdftest/snapshots-opa/TestDir/ostrich_1103Sun_2354.
===== Exit bin/snapshot with status=127: Sun Nov  3 23:54:39 CST 2019 =====
Dumping done
Dumping logfile of ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
LMOD_arch=ppc64
LMOD_COLORIZE=yes
LMOD_SETTARG_CMD=:
LMOD_sys=Linux
LMOD_VERSION=6.5.1
LOADEDMODULES=
LOGNAME=hdftest
LS_COLORS=
MACHTYPE=powerpc64
MAKE=gmake
OSTYPE=linux
SET_PATH=yes
SHELL=/bin/tcsh
SHLVL=3
USER=hdftest
_=/usr/bin/printenv
VENDOR=unknown
Dumping done
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 23:54:01 up 13 days, 16:40, 19 users,  load average: 8.96, 8.42, 8.01
Filesystem                  1K-blocks       Used  Available Use% Mounted on
/dev/mapper/centos00-root    16766976    9007976    7759000  54% /
devtmpfs                     65864052          0   65864052   0% /dev
tmpfs                        65874008      39704   65834304   1% /dev/shm
tmpfs                        65874008     191444   65682564   1% /run
tmpfs                        65874008          0   65874008   0% /sys/fs/cgroup
tmpfs                        65874008          0   65874008   0% /mnt/daos
/dev/md0                   3904859232  827324732 3077534500  22% /scr
/dev/md10                 11718682624 7397615224 4321067400  64% /mnt/wrk
/dev/sda1                      520876     169532     351344  33% /boot
/dev/mapper/centos00-opt    134152192  119922832   14229360  90% /opt
10.10.10.86:/home           198351872   89937920   98174976  48% /home
10.10.10.86:/mnt/hdf        961432576  906738688    5856256 100% /mnt/hdf
10.10.10.86:/mnt/scr1       961432576  888100864   24494080  98% /mnt/scr1
tmpfs                        13174804          0   13174804   0% /run/user/10093
tmpfs                        13174804          0   13174804   0% /run/user/10094
10.10.10.85:/data/ftp       480719104  410312960   45986944  90% /mnt/ftp
10.10.10.85:/data/web       480719104  410312960   45986944  90% /mnt/web
tmpfs                        13174804          0   13174804   0% /run/user/30308
tmpfs                        13174804          0   13174804   0% /run/user/10019
tmpfs                        13174804          0   13174804   0% /run/user/17929
tmpfs                        13174804          0   13174804   0% /run/user/27429
tmpfs                        13174804          0   13174804   0% /run/user/10057
tmpfs                        13174804          0   13174804   0% /run/user/22417
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_1103Sun
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1103Sun.149224: No such file or directory
rm: cannot remove ‘/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1103Sun.149224’: No such file or directory
Sun Nov  3 23:54:11 CST 2019
*** launching tests from jelly ***
TESTHOST is jam
koala
platypus
moohan
ostrich
osx1010test
    Fork off timekeeper 12
Testing jam
ssh -o ConnectTimeout=60 jam -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
 23:54:16 up 13 days, 16:41,  2 users,  load average: 0.15, 0.21, 0.16
/dev/sda3             31738420  17809048  12291144  60% /
/dev/sda1               101086     17532     78335  19% /boot
/dev/sda2             31738420    259740  29840452   1% /tmp
/dev/sda6             31738392   5582876  24517292  19% /var
/dev/sda7             31738392  18568612  11531556  62% /usr
/dev/sda8            124991068    192208 118347160   1% /var/tmp
/dev/mapper/VolGroup00-home
                     198351840  89938788  98174692  48% /home
/dev/sde1            961432072 888101024  24493048  98% /mnt/scr1
/dev/sdf1            961432072 906738364   5855708 100% /mnt/hdf
tmpfs                  8313628         0   8313628   0% /dev/shm
10.10.10.15:/volume1/hdf2
                     1437485440 579862400 857520640  41% /mnt/hdf2
gumund:/data/ftp     480719104 410312960  45986944  90% /mnt/ftp
gumund:/data/web     480719104 410312960  45986944  90% /mnt/web
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Extract source and run autogen if .
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
Running snapshot with output saved in
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Total time = 0m 1s
*** finished tests in jam ***
****SYSTEM ERROR jam: Abnormal exit from runtest ****
	****SYSTEM ERROR jam: runtest command failed ****
Testing koala
ssh -o ConnectTimeout=60 koala -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
 23:54:19 up 13 days, 13:56,  1 user,  load average: 0.00, 0.00, 0.00
/dev/sda7             22292052   4427884  16713516  21% /
/dev/sda5             12192608    395120  11168144   4% /tmp
/dev/sda3             12192636   1027008  10536284   9% /var
/dev/sda1               101086     18614     77253  20% /boot
/dev/sdc1             41279536  26323756  12858900  68% /usr
/dev/sdb             152754284  72014812  72980012  50% /scr
tmpfs                  6149552         0   6149552   0% /dev/shm
                     961432576 888100864  24493056  98% /mnt/scr1
10.10.10.15:/volume1/readonly
                     1437485440 579862400 857520640  41% /mnt/ro-src
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-409.el5 #1 SMP Tue Mar 15 18:13:50 EDT 2016 x86_64 x86_64 x86_64 GNU/Linux
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Total time = 0m 0s
*** finished tests in koala ***
****SYSTEM ERROR koala: Abnormal exit from runtest ****
	****SYSTEM ERROR koala: runtest command failed ****
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
 23:54:21 up 13 days, 13:56,  0 users,  load average: 3.58, 4.27, 3.45
/dev/sda6             54205540  43007028   8438372  84% /
tmpfs                  6099068         0   6099068   0% /dev/shm
/dev/sda1               194241     48310    135691  27% /boot
/dev/sda2             12850716    149064  12042196   2% /tmp
/dev/sda3             12850716   5544304   6646956  46% /var
/dev/sdd             152623212 115604048  29259704  80% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.22.1.el6.x86_64 #1 SMP Wed Mar 23 03:35:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Total time = 0m 1s
*** finished tests in platypus ***
****SYSTEM ERROR platypus: Abnormal exit from runtest ****
	****SYSTEM ERROR platypus: runtest command failed ****
Testing moohan
ssh -o ConnectTimeout=60 moohan -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname moohan
 23:54:26 up 126 days,  8:27,  1 user,  load average: 4.28, 3.60, 3.18
/dev/mapper/centos_moohan-root   52196352   9618976  42577376  19% /
devtmpfs                          3923072         0   3923072   0% /dev
tmpfs                             3939844        84   3939760   1% /dev/shm
tmpfs                             3939844    402416   3537428  11% /run
tmpfs                             3939844         0   3939844   0% /sys/fs/cgroup
/dev/md126p1                       506752    312676    194076  62% /boot
/dev/mapper/centos_moohan-scr   858065536 410218252 447847284  48% /scr
/dev/mapper/centos_moohan-var    16371712   5903256  10468456  37% /var
/dev/mapper/centos_moohan-tmp    16371712    249628  16122084   2% /tmp
jam:/mnt/scr1                   961432576 888100864  24493056  98% /mnt/scr1
jam:/mnt/hdf                    961432576 906738688   5856256 100% /mnt/hdf
jam:/home                       198351872  89937920  98174976  48% /home
tmpfs                              787972        16    787956   1% /run/user/42
10.10.10.15:/volume1/readonly  1437485440 579862400 857520640  41% /mnt/ro-src
tmpfs                              787972         0    787972   0% /run/user/27429
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests in moohan ***
Uname -a: Linux moohan.ad.hdfgroup.org 3.10.0-327.10.1.el7.x86_64 #1 SMP Tue Feb 16 17:03:50 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests for moohan ***
Total time = 0m 0s
*** finished tests in moohan ***
****SYSTEM ERROR moohan: Abnormal exit from runtest ****
	****SYSTEM ERROR moohan: runtest command failed ****
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
 23:54:28 up 13 days, 13:22,  0 users,  load average: 0.87, 3.71, 4.41
/dev/mapper/vg_ostrich-lv_root
                     140479384  28927244 104413096  22% /
tmpfs                  7821504         0   7821504   0% /dev/shm
/dev/sda2               487652    107077    354975  24% /boot
/dev/sdb2            124477364  88539376  29608236  75% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-696.20.1.el6.ppc64 #1 SMP Fri Jan 12 14:20:08 EST 2018 ppc64 ppc64 ppc64 GNU/Linux
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Total time = 0m 0s
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich ***
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich ***
Total time = 0m 0s
*** finished tests in ostrich ***
****SYSTEM ERROR ostrich: Abnormal exit from runtest ****
	****SYSTEM ERROR ostrich: runtest command failed ****
Testing osx1010test
osx1010test is not reachable (Sun Nov  3 23:54:28 CST 2019)
	****SYSTEM ERROR: osx1010test is not reachable (Sun Nov  3 23:54:28 CST 2019)
	****INCOMPLETE osx1010test: snaptest did not complete****
*** finished tests in jelly ***
More information about the opa-nightly-tests mailing list
