[opa-nightly-tests] jelly OPA_Daily_Tests_1101Fri_FAILED!!!
hdftest
hdftest at hdfgroup.org
Fri Nov 1 23:56:23 CDT 2019
*** OPA Tests on 1101Fri ***
Tests Summary
****FAILED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam****
****FAILED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala****
****FAILED moohan: standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan****
****FAILED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich****
****FAILED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl****
****FAILED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus****
Tests Time Summary
jam: Ran 1(0/1/0) tests, Grand total test time = 0m 1s
koala: Ran 1(0/1/0) tests, Grand total test time = 0m 1s
platypus: Ran 1(0/1/0) tests, Grand total test time = 0m 1s
moohan: Ran 1(0/1/0) tests, Grand total test time = 0m 1s
ostrich: Ran 2(0/2/0) tests, Grand total test time = 0m 2s
jelly: Ran 6(0/0/0) hosts, Grand total test time = 0m 57s
Timekeeper log
Timekeeper started at Fri Nov 1 23:55:26 CDT 2019
Timekeeper sleeping for 720 seconds
Tests Failures
Dumping logfile of jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/jam_1101Fri_2355
MAIL=/var/spool/mail/hdftest
MAKE=gmake
MANPATH=/usr/local/man:/usr/share/man:/usr/kerberos/man
MODULEPATH=/usr/share/Modules/modulefiles:/etc/modulefiles
MODULESHOME=/usr/share/Modules
OSTYPE=linux
PATH=/home/hdftest/bin:/usr/hdf/bin:/home/hdftest/bin:/usr/hdf/bin:/usr/local/bin:/bin:/usr/bin:/usr/kerberos/bin:/mnt/hdf/ec2-api-tools/bin
PWD=/mnt/scr1/SnapTest/snapshots-opa
SET_PATH=yes
SHELL=/bin/tcsh
SHLVL=3
SSH_CLIENT=10.10.10.120 48473 22
SSH_CONNECTION=10.10.10.120 48473 10.10.10.86 22
SVNROOT=http://svn.hdfgroup.uiuc.edu
USER=hdftest
_=/usr/bin/printenv
VENDOR=intel
===Done Dumping environment variables after option parsing ===
===== Run Tests: Fri Nov 1 23:55:41 CDT 2019 =====
Remove contents of jam.\n
/usr/bin/diff: /home/hdftest/snapshots-opa/previous/MANIFEST: No such file or directory
/usr/bin/diff: /home/hdftest/snapshots-opa/current/MANIFEST: No such file or directory
===== configure: Fri Nov 1 23:55:41 CDT 2019 =====
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether gmake sets $(MAKE)... yes
checking whether gmake supports nested variables... yes
checking for style of include used by gmake... GNU
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking whether gcc understands -c and -o together... yes
checking dependency style of gcc... gcc3
checking for ar... ar
checking the archiver (ar) interface... ar
/home/hdftest/snapshots-opa/current/configure: line 4189: syntax error near unexpected token `2.2.6'
/home/hdftest/snapshots-opa/current/configure: line 4189: `LT_PREREQ(2.2.6)'
Failed running configure
Test failed. Test directory and files from failed test were saved in
/mnt/scr1/SnapTest/snapshots-opa/TestDir/jam_1101Fri_2355.
===== Exit bin/snapshot with status=2: Fri Nov 1 23:55:42 CDT 2019 =====
Dumping done
Dumping logfile of koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/koala_1101Fri_2355
MAKE=gmake
OSTYPE=linux
SET_PATH=yes
SHELL=/bin/tcsh
SHLVL=3
SSH_ASKPASS=/usr/libexec/openssh/gnome-ssh-askpass
SSH_CLIENT=10.10.10.120 55336 22
SSH_CONNECTION=10.10.10.120 55336 10.10.10.89 22
USER=hdftest
_=/usr/bin/printenv
VENDOR=unknown
===== Run Tests: Fri Nov 1 23:55:43 CDT 2019 =====
Remove contents of koala.\n
===== configure: Fri Nov 1 23:55:43 CDT 2019 =====
/scr/hdftest/snapshots-opa/TestDir/koala_1101Fri_2355.
===== Exit bin/snapshot with status=2: Fri Nov 1 23:55:44 CDT 2019 =====
Dumping done
Dumping logfile of platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/platypus_1101Fri_2355
MODULESHOME=/usr/share/lmod/lmod
OSTYPE=linux
SELINUX_LEVEL_REQUESTED=
SELINUX_ROLE_REQUESTED=
SELINUX_USE_CURRENT_RANGE=
SET_PATH=yes
SHELL=/bin/tcsh
SHLVL=3
SSH_CLIENT=10.10.10.120 53743 22
SSH_CONNECTION=10.10.10.120 53743 10.10.10.104 22
TARG_TITLE_BAR_PAREN=
USER=hdftest
_=/usr/bin/printenv
VENDOR=unknown
===== Run Tests: Fri Nov 1 23:55:46 CDT 2019 =====
Remove contents of platypus.\n
===== configure: Fri Nov 1 23:55:46 CDT 2019 =====
/scr/hdftest/snapshots-opa/TestDir/platypus_1101Fri_2355.
===== Exit bin/snapshot with status=2: Fri Nov 1 23:55:47 CDT 2019 =====
Dumping done
Dumping logfile of moohan: standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/moohan_1101Fri_2355
QTDIR=/usr/lib64/qt-3.3
QT_GRAPHICSSYSTEM_CHECKED=1
QTINC=/usr/lib64/qt-3.3/include
QTLIB=/usr/lib64/qt-3.3/lib
QT_PLUGIN_PATH=/usr/lib64/kde4/plugins:/usr/lib/kde4/plugins
SET_PATH=yes
SHELL=/bin/tcsh
SHLVL=3
SSH_CLIENT=10.10.10.120 55065 22
SSH_CONNECTION=10.10.10.120 55065 10.10.10.93 22
USER=hdftest
_=/usr/bin/printenv
VENDOR=unknown
XDG_RUNTIME_DIR=/run/user/27429
XDG_SESSION_ID=221859
===== Run Tests: Fri Nov 1 23:55:49 CDT 2019 =====
Remove contents of moohan.\n
===== configure: Fri Nov 1 23:55:49 CDT 2019 =====
checking for a thread-safe mkdir -p... /usr/bin/mkdir -p
/scr/hdftest/snapshots-opa/TestDir/moohan_1101Fri_2355.
===== Exit bin/snapshot with status=2: Fri Nov 1 23:55:50 CDT 2019 =====
Dumping done
Dumping logfile of ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_1101Fri_2355
OSTYPE=linux
PATH=/home/hdftest/bin:/usr/hdf/bin:/home/hdftest/bin:/usr/lib64/qt-3.3/bin:/usr/hdf/bin:/usr/local/bin:/bin:/usr/bin:/usr/kerberos/bin:/mnt/hdf/ec2-api-tools/bin
SET_PATH=yes
SHELL=/bin/tcsh
SHLVL=3
SSH_CLIENT=10.10.10.120 56979 22
SSH_CONNECTION=10.10.10.120 56979 10.10.10.95 22
USER=hdftest
_=/usr/bin/printenv
VENDOR=unknown
===== Run Tests: Fri Nov 1 23:55:51 CDT 2019 =====
Remove contents of ostrich.\n
===== configure: Fri Nov 1 23:55:52 CDT 2019 =====
/scr/hdftest/snapshots-opa/TestDir/ostrich_1101Fri_2355.
===== Exit bin/snapshot with status=2: Fri Nov 1 23:55:52 CDT 2019 =====
Dumping done
Dumping logfile of ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
OSTYPE=linux
SET_PATH=yes
SHELL=/bin/tcsh
SHLVL=3
USER=hdftest
_=/usr/bin/printenv
VENDOR=unknown
===== Run Tests: Fri Nov 1 23:55:52 CDT 2019 =====
checking for gcc... /opt/xl/current/xlc
checking whether we are using the GNU C compiler... no
checking whether /opt/xl/current/xlc accepts -g... yes
checking for /opt/xl/current/xlc option to accept ISO C89... none needed
checking whether /opt/xl/current/xlc understands -c and -o together... yes
checking dependency style of /opt/xl/current/xlc... xlc
===== Exit bin/snapshot with status=2: Fri Nov 1 23:55:53 CDT 2019 =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
23:55:16 up 11 days, 15:41, 18 users, load average: 2.93, 2.94, 3.82
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/mapper/centos00-root 16766976 9006512 7760464 54% /
devtmpfs 65864052 0 65864052 0% /dev
tmpfs 65874008 24404 65849604 1% /dev/shm
tmpfs 65874008 158620 65715388 1% /run
tmpfs 65874008 0 65874008 0% /sys/fs/cgroup
tmpfs 65874008 0 65874008 0% /mnt/daos
/dev/md0 3904859232 827461520 3077397712 22% /scr
/dev/md10 11718682624 7397815784 4320866840 64% /mnt/wrk
/dev/sda1 520876 169532 351344 33% /boot
/dev/mapper/centos00-opt 134152192 119922832 14229360 90% /opt
10.10.10.86:/home 198351872 89836544 98276352 48% /home
10.10.10.86:/mnt/hdf 961432576 912580608 14336 100% /mnt/hdf
10.10.10.86:/mnt/scr1 961432576 886458368 26136576 98% /mnt/scr1
tmpfs 13174804 0 13174804 0% /run/user/10093
tmpfs 13174804 0 13174804 0% /run/user/10094
10.10.10.85:/data/ftp 480719104 410313856 45986048 90% /mnt/ftp
10.10.10.85:/data/web 480719104 410313856 45986048 90% /mnt/web
tmpfs 13174804 0 13174804 0% /run/user/30308
tmpfs 13174804 0 13174804 0% /run/user/10019
tmpfs 13174804 0 13174804 0% /run/user/17929
tmpfs 13174804 0 13174804 0% /run/user/22417
tmpfs 13174804 0 13174804 0% /run/user/27429
tmpfs 13174804 0 13174804 0% /run/user/10057
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_1101Fri
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1101Fri.111082: No such file or directory
rm: cannot remove ‘/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1101Fri.111082’: No such file or directory
*** launching tests from jelly ***
TESTHOST is jam
koala
platypus
moohan
ostrich
osx1010test
Fork off timekeeper 12
Testing jam
ssh -o ConnectTimeout=60 jam -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
23:55:31 up 11 days, 15:42, 2 users, load average: 0.12, 0.18, 0.14
/dev/sda3 31738420 17809048 12291144 60% /
/dev/sda1 101086 17532 78335 19% /boot
/dev/sda2 31738420 254712 29845480 1% /tmp
/dev/sda6 31738392 6614100 23486068 22% /var
/dev/sda7 31738392 18568612 11531556 62% /usr
/dev/sda8 124991068 192208 118347160 1% /var/tmp
/dev/mapper/VolGroup00-home
198351840 89837160 98276320 48% /home
/dev/sde1 961432072 886457984 26136088 98% /mnt/scr1
/dev/sdf1 961432072 912580204 13868 100% /mnt/hdf
tmpfs 8313628 0 8313628 0% /dev/shm
10.10.10.15:/volume1/hdf2
1437485440 579843584 857539456 41% /mnt/hdf2
gumund:/data/ftp 480719104 410313856 45986048 90% /mnt/ftp
gumund:/data/web 480719104 410313856 45986048 90% /mnt/web
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Extract source and run autogen if .
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
Running snapshot with output saved in
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Total time = 0m 1s
*** finished tests in jam ***
****SYSTEM ERROR jam: Abnormal exit from runtest ****
****SYSTEM ERROR jam: runtest command failed ****
Testing koala
ssh -o ConnectTimeout=60 koala -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
23:55:33 up 11 days, 12:57, 1 user, load average: 0.05, 0.02, 0.00
/dev/sda7 22292052 4427884 16713516 21% /
/dev/sda5 12192608 392484 11170780 4% /tmp
/dev/sda3 12192636 1028700 10534592 9% /var
/dev/sda1 101086 18614 77253 20% /boot
/dev/sdc1 41279536 26323756 12858900 68% /usr
/dev/sdb 152754284 72014448 72980376 50% /scr
tmpfs 6149552 0 6149552 0% /dev/shm
10.10.10.15:/volume1/readonly
1437485440 579843584 857539456 41% /mnt/ro-src
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-409.el5 #1 SMP Tue Mar 15 18:13:50 EDT 2016 x86_64 x86_64 x86_64 GNU/Linux
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Total time = 0m 1s
*** finished tests in koala ***
****SYSTEM ERROR koala: Abnormal exit from runtest ****
****SYSTEM ERROR koala: runtest command failed ****
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
23:55:36 up 11 days, 12:57, 0 users, load average: 0.11, 0.31, 0.92
/dev/sda6 54205540 43007028 8438372 84% /
tmpfs 6099068 0 6099068 0% /dev/shm
/dev/sda1 194241 48310 135691 27% /boot
/dev/sda2 12850716 102180 12089080 1% /tmp
/dev/sda3 12850716 5665252 6526008 47% /var
/dev/sdd 152623212 114799776 30063976 80% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.22.1.el6.x86_64 #1 SMP Wed Mar 23 03:35:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Total time = 0m 1s
*** finished tests in platypus ***
****SYSTEM ERROR platypus: Abnormal exit from runtest ****
****SYSTEM ERROR platypus: runtest command failed ****
Testing moohan
ssh -o ConnectTimeout=60 moohan -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname moohan
23:55:39 up 124 days, 7:29, 1 user, load average: 0.03, 0.24, 0.72
/dev/mapper/centos_moohan-root 52196352 9618976 42577376 19% /
devtmpfs 3923072 0 3923072 0% /dev
tmpfs 3939844 84 3939760 1% /dev/shm
tmpfs 3939844 410580 3529264 11% /run
tmpfs 3939844 0 3939844 0% /sys/fs/cgroup
/dev/md126p1 506752 312676 194076 62% /boot
/dev/mapper/centos_moohan-scr 858065536 407668560 450396976 48% /scr
/dev/mapper/centos_moohan-var 16371712 5875616 10496096 36% /var
/dev/mapper/centos_moohan-tmp 16371712 174840 16196872 2% /tmp
jam:/mnt/scr1 961432576 886458368 26136576 98% /mnt/scr1
jam:/mnt/hdf 961432576 912580608 14336 100% /mnt/hdf
jam:/home 198351872 89836544 98276352 48% /home
tmpfs 787972 16 787956 1% /run/user/42
10.10.10.15:/volume1/readonly 1437485440 579843584 857539456 41% /mnt/ro-src
tmpfs 787972 0 787972 0% /run/user/27429
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests in moohan ***
Uname -a: Linux moohan.ad.hdfgroup.org 3.10.0-327.10.1.el7.x86_64 #1 SMP Tue Feb 16 17:03:50 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests for moohan ***
Total time = 0m 1s
*** finished tests in moohan ***
****SYSTEM ERROR moohan: Abnormal exit from runtest ****
****SYSTEM ERROR moohan: runtest command failed ****
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
23:55:41 up 11 days, 12:23, 0 users, load average: 0.02, 0.17, 1.02
/dev/mapper/vg_ostrich-lv_root
140479384 28860160 104480180 22% /
tmpfs 7821504 0 7821504 0% /dev/shm
/dev/sda2 487652 107077 354975 24% /boot
/dev/sdb2 124477364 112487448 5660164 96% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-696.20.1.el6.ppc64 #1 SMP Fri Jan 12 14:20:08 EST 2018 ppc64 ppc64 ppc64 GNU/Linux
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Total time = 0m 1s
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich ***
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich ***
Total time = 0m 1s
*** finished tests in ostrich ***
****SYSTEM ERROR ostrich: Abnormal exit from runtest ****
****SYSTEM ERROR ostrich: runtest command failed ****
Testing osx1010test
osx1010test is not reachable (Fri Nov 1 23:55:41 CDT 2019)
****SYSTEM ERROR: osx1010test is not reachable (Fri Nov 1 23:55:41 CDT 2019)
****INCOMPLETE osx1010test: snaptest did not complete****
*** finished tests in jelly ***
More information about the opa-nightly-tests
