[opa-nightly-tests] jelly OPA_Daily_Tests_1230Mon_FAILED!!!
hdftest
hdftest at hdfgroup.org
Mon Dec 30 00:24:26 CST 2019
*** OPA Tests on 1230Mon ***
Tests Summary
****FAILED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus****
PASSED jelly: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED moohan: standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
PASSED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
PASSED osx1011test: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy osx1011test
Tests Time Summary
platypus: Ran 1(0/1/0) tests, Grand total test time = 0m 9s
koala: Ran 1(1/0/0) tests, Grand total test time = 0m 32s
jelly: Ran 1(1/0/0) tests, Grand total test time = 0m 57s
osx1011test: Ran 1(1/0/0) tests, Grand total test time = 1m 31s
ostrich: Ran 2(2/0/0) tests, Grand total test time = 4m 42s
moohan: Ran 1(1/0/0) tests, Grand total test time = 7m 48s
jelly: Ran 6(0/0/0) hosts, Grand total test time = 8m 55s
Timekeeper log
Timekeeper started at Mon Dec 30 00:15:42 CST 2019
Timekeeper sleeping for 1200 seconds
Tests Failures
Dumping logfile of platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/platypus_1230Mon_0016
configure: creating ./config.status
config.status: creating Makefile
config.status: creating src/Makefile
config.status: creating test/Makefile
config.status: creating openpa.pc
config.status: creating src/config.h
config.status: executing depfiles commands
config.status: executing libtool commands
config.status: executing src/opa_config.h commands
config.status: creating src/opa_config.h - prefix OPA for src/config.h defines
===== make: Mon Dec 30 00:16:09 CST 2019 =====
Making all in src
gmake[1]: Entering directory `/scr/hdftest/snapshots-opa/TestDir/platypus/src'
gmake all-am
gmake[2]: Entering directory `/scr/hdftest/snapshots-opa/TestDir/platypus/src'
CC opa_primitives.lo
CC opa_queue.lo
CCLD libopa.la
gmake[2]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/platypus/src'
gmake[1]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/platypus/src'
Making all in test
gmake[1]: Entering directory `/scr/hdftest/snapshots-opa/TestDir/platypus/test'
gmake[1]: Nothing to be done for `all'.
gmake[1]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/platypus/test'
gmake[1]: Entering directory `/scr/hdftest/snapshots-opa/TestDir/platypus'
gmake[1]: Nothing to be done for `all-am'.
gmake[1]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/platypus'
Disk Usage=636 KB
Making check in src
Making check in test
gmake sanity test_primitives test_barriers test_queue
gmake[2]: Entering directory `/scr/hdftest/snapshots-opa/TestDir/platypus/test'
CC sanity.o
CCLD sanity
CC test_primitives.o
/home/hdftest/snapshots-opa/current/test/test_primitives.c:4974: fatal error: error writing to /tmp/ccCykS52.s: No space left on device
compilation terminated.
gmake[2]: *** [test_primitives.o] Error 1
gmake[2]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/platypus/test'
gmake[1]: *** [check-am] Error 2
gmake: *** [check-recursive] Error 1
Failed running make check
Test failed. Test directory and files from failed test were saved in
/scr/hdftest/snapshots-opa/TestDir/platypus_1230Mon_0016.
===== Exit bin/snapshot with status=2: Mon Dec 30 00:16:12 CST 2019 =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
00:15:21 up 69 days, 17:01, 17 users, load average: 11.67, 5.37, 3.38
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/mapper/centos00-root 16766976 12456952 4310024 75% /
devtmpfs 65864052 0 65864052 0% /dev
tmpfs 65874008 442016 65431992 1% /dev/shm
tmpfs 65874008 1305396 64568612 2% /run
tmpfs 65874008 0 65874008 0% /sys/fs/cgroup
tmpfs 65874008 0 65874008 0% /mnt/daos
/dev/md0 3904859232 911401868 2993457364 24% /scr
/dev/md10 11718682624 7578675324 4140007300 65% /mnt/wrk
/dev/sda1 520876 169532 351344 33% /boot
/dev/mapper/centos00-opt 134152192 120065388 14086804 90% /opt
10.10.10.86:/home 198351872 91166720 96947200 49% /home
10.10.10.86:/mnt/hdf 961432576 911731712 862208 100% /mnt/hdf
10.10.10.86:/mnt/scr1 961432576 877320192 35273728 97% /mnt/scr1
tmpfs 13174804 0 13174804 0% /run/user/10093
tmpfs 13174804 0 13174804 0% /run/user/10094
10.10.10.85:/data/ftp 480719104 420122624 36177280 93% /mnt/ftp
10.10.10.85:/data/web 480719104 420122624 36177280 93% /mnt/web
tmpfs 13174804 0 13174804 0% /run/user/10013
tmpfs 13174804 0 13174804 0% /run/user/10074
tmpfs 13174804 0 13174804 0% /run/user/10019
tmpfs 13174804 0 13174804 0% /run/user/17929
tmpfs 13174804 0 13174804 0% /run/user/29138
tmpfs 13174804 0 13174804 0% /run/user/27429
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_1230Mon
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1230Mon.101292: No such file or directory
rm: cannot remove ‘/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1230Mon.101292’: No such file or directory
*** launching tests from jelly ***
TESTHOST is jelly
koala
platypus
moohan
ostrich
osx1011test
Fork off timekeeper 20
Testing jelly
ssh -o ConnectTimeout=60 jelly -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jelly
00:15:49 up 69 days, 17:01, 17 users, load average: 12.60, 6.23, 3.73
/dev/mapper/centos00-root 16766976 12456968 4310008 75% /
tmpfs 65874008 1305424 64568584 2% /run
/dev/md0 3904859232 911240704 2993618528 24% /scr
/dev/md10 11718682624 7578675304 4140007320 65% /mnt/wrk
10.10.10.86:/mnt/scr1 961432576 877322240 35272704 97% /mnt/scr1
Extract source and run autogen if .
Mon Dec 30 00:15:59 CST 2019
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly tests in jelly ***
Uname -a: Linux jelly 3.10.0-327.18.2.el7.x86_64 #1 SMP Thu May 12 11:03:55 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/jelly_1230Mon_0015
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly tests for jelly ***
Mon Dec 30 00:16:56 CST 2019
Total time = 0m 57s
*** finished tests in jelly ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
00:15:51 up 69 days, 14:18, 1 user, load average: 0.00, 0.00, 0.00
/dev/sda7 22292052 4427892 16713508 21% /
/dev/sda5 12192608 371588 11191676 4% /tmp
/dev/sda3 12192636 1041180 10522112 10% /var
/dev/sda1 101086 18614 77253 20% /boot
/dev/sdc1 41279536 26323756 12858900 68% /usr
/dev/sdb 152754284 72048992 72945832 50% /scr
tmpfs 6149552 0 6149552 0% /dev/shm
gumund:/data/ftp 480719104 420122624 36177280 93% /mnt/ftp
gumund:/data/web 480719104 420122624 36177280 93% /mnt/web
10.10.10.15:/volume1/readonly
1437485440 578600320 858782720 41% /mnt/ro-src
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Mon Dec 30 00:16:01 CST 2019
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-409.el5 #1 SMP Tue Mar 15 18:13:50 EDT 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/koala_1230Mon_0016
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Mon Dec 30 00:16:33 CST 2019
Total time = 0m 32s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
00:15:53 up 69 days, 14:18, 1 user, load average: 1.74, 1.48, 1.20
/dev/sda6 54205540 43007028 8438372 84% /
tmpfs 6099068 0 6099068 0% /dev/shm
/dev/sda1 194241 48310 135691 27% /boot
/dev/sda2 12850716 12174788 16472 100% /tmp
/dev/sda3 12850716 12686848 0 100% /var
/dev/sdd 152623212 134360364 10503388 93% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Mon Dec 30 00:16:04 CST 2019
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.22.1.el6.x86_64 #1 SMP Wed Mar 23 03:35:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Total time = 0m 8s
*** finished tests in platypus ***
****SYSTEM ERROR platypus: Abnormal exit from runtest ****
****SYSTEM ERROR platypus: runtest command failed ****
Testing moohan
ssh -o ConnectTimeout=60 moohan -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname moohan
00:15:58 up 182 days, 8:49, 1 user, load average: 7.45, 7.51, 6.52
/dev/mapper/centos_moohan-root 52196352 9618976 42577376 19% /
devtmpfs 3923072 0 3923072 0% /dev
tmpfs 3939844 3084 3936760 1% /dev/shm
tmpfs 3939844 410636 3529208 11% /run
tmpfs 3939844 0 3939844 0% /sys/fs/cgroup
/dev/md126p1 506752 312676 194076 62% /boot
/dev/mapper/centos_moohan-scr 858065536 421117236 436948300 50% /scr
/dev/mapper/centos_moohan-var 16371712 6921544 9450168 43% /var
/dev/mapper/centos_moohan-tmp 16371712 41096 16330616 1% /tmp
jam:/mnt/scr1 961432576 877322240 35272704 97% /mnt/scr1
jam:/mnt/hdf 961432576 911731712 862208 100% /mnt/hdf
jam:/home 198351872 91166720 96947200 49% /home
tmpfs 787972 16 787956 1% /run/user/42
10.10.10.15:/volume1/readonly 1437485440 578867968 858515072 41% /mnt/ro-src
tmpfs 787972 0 787972 0% /run/user/27429
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
Mon Dec 30 00:16:11 CST 2019
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests in moohan ***
Uname -a: Linux moohan.ad.hdfgroup.org 3.10.0-327.10.1.el7.x86_64 #1 SMP Tue Feb 16 17:03:50 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/moohan_1230Mon_0016
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests for moohan ***
Mon Dec 30 00:23:56 CST 2019
Total time = 7m 45s
*** finished tests in moohan ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
00:16:00 up 69 days, 13:43, 0 users, load average: 1.21, 0.76, 0.32
/dev/mapper/vg_ostrich-lv_root
140479384 28428872 104911468 22% /
tmpfs 7821504 0 7821504 0% /dev/shm
/dev/sda2 487652 99874 362178 22% /boot
/dev/sdb2 124477364 89507440 28640172 76% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Mon Dec 30 00:16:10 CST 2019
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-696.20.1.el6.ppc64 #1 SMP Fri Jan 12 14:20:08 EST 2018 ppc64 ppc64 ppc64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_1230Mon_0016
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Mon Dec 30 00:17:49 CST 2019
Total time = 1m 39s
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich ***
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_1230Mon_0017
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich ***
Mon Dec 30 00:20:52 CST 2019
Total time = 3m 3s
*** finished tests in ostrich ***
Testing osx1011test
ssh -o ConnectTimeout=60 osx1011test -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname osx1011test
grep: /proc/cpuinfo: No such file or directory
0:16 up 69 days, 17:05, 1 user, load averages: 3.02 2.29 2.02
Filesystem 512-blocks Used Available Capacity iused ifree %iused Mounted on
/dev/disk1 1951137792 264725296 1685900496 14% 33154660 210737562 14% /
devfs 356 356 0 100% 616 0 100% /dev
map auto_nfs 0 0 0 100% 0 0 100% /home
map auto_nfs 0 0 0 100% 0 0 100% /mnt/hdf
map auto_nfs 0 0 0 100% 0 0 100% /mnt/scr1
jam.ad.hdfgroup.org:/mnt/scr1 1922864144 1754644240 70543904 97% 4011189 118098763 3% /mnt/scr1
jam.ad.hdfgroup.org:/mnt/hdf 1922864144 1823464264 1723880 100% 10761719 111348233 9% /mnt/hdf
jam.ad.hdfgroup.org:/home 396703680 182334336 193892624 49% 1045324 50171060 2% /home
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy osx1011test
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy osx1011test tests in osx1011test ***
Uname -a: Darwin osx1011test.ad.hdfgroup.org 15.6.0 Darwin Kernel Version 15.6.0: Thu Jun 21 20:07:40 PDT 2018; root:xnu-3248.73.11~1/RELEASE_X86_64 x86_64
/Users/hdftest/snapshots-opa/log/osx1011test_1230Mon_0016
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy osx1011test tests for osx1011test ***
Mon Dec 30 00:17:43 CST 2019
Total time = 1m 31s
*** finished tests in osx1011test ***
More information about the opa-nightly-tests
