[opa-nightly-tests] jam OPA_Daily_Tests_1007Sun_FAILED!!!
HDF Tester hdftest at hdfgroup.org
Sun Oct 7 13:05:50 CDT 2018
*** OPA Tests on 1007Sun ***
   Tests Summary
****FAILED kite: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite****
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED moohan: standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
PASSED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
PASSED osx1010test: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy osx1010test
PASSED osx1011test: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy osx1011test
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
   Tests Time Summary
koala: Ran 1(1/0/0) tests, Grand total test time =  0m 53s
jam: Ran 1(1/0/0) tests, Grand total test time =  1m 2s
platypus: Ran 1(1/0/0) tests, Grand total test time =  1m 1s
moohan: Ran 1(1/0/0) tests, Grand total test time =  1m 27s
ostrich: Ran 2(2/0/0) tests, Grand total test time =  5m 33s
osx1011test: Ran 1(1/0/0) tests, Grand total test time =  1m 49s
osx1010test: Ran 1(1/0/0) tests, Grand total test time =  1m 47s
kite: Ran 1(0/1/0) tests, Grand total test time =  648m 0s
jam: Ran 8(0/0/0) hosts, Grand total test time =  751m 56s
   Timekeeper log
Timekeeper started at Sun Oct  7 00:34:06 CDT 2018
Timekeeper sleeping for 720 seconds
Timekeeper woke up at Sun Oct  7 00:46:06 CDT 2018, looking for processes to terminate...
Timekeeper ended at Sun Oct  7 00:46:06 CDT 2018
   Tests Failures
Dumping logfile of kite: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
Last 50 lines of /Users/hdftest/snapshots-opa/log/kite_1007Sun_0231
HDF5_AUTOMAKE=/mnt/hdf/packages/AUTOTOOLS/automake/1.15/Darwin/bin/automake-1.15
HDF5_LIBTOOL=/mnt/hdf/packages/AUTOTOOLS/libtool/2.4.6/Darwin/bin/libtool
HOME=/Users/hdftest
HOST=kite.ad.hdfgroup.org
HOSTTYPE=unknown
LANG=en_US.UTF-8
LOGNAME=hdftest
MACHTYPE=x86_64
MAIL=/var/mail/hdftest
MAKE=gnumake
OSTYPE=darwin
PATH=/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/hdf/bin:/opt/local/bin:/opt/X11/bin
PWD=/Users/hdftest/snapshots-opa
SET_PATH=yes
SHELL=/bin/tcsh
SHLVL=3
SSH_CLIENT=10.10.10.86 41247 22
SSH_CONNECTION=10.10.10.86 41247 10.10.10.87 22
SVNROOT=http://svn.hdfgroup.uiuc.edu
TMPDIR=/var/folders/z6/3ppqwg7d6391tvvxflm75638000ts5/T/
USER=hdftest
VENDOR=apple
_=/usr/bin/printenv
===Done Dumping environment variables after option parsing ===
===== Run Tests: Sun Oct  7 02:49:36 CDT 2018 =====
Remove contents of kite.
/usr/bin/diff: /Users/hdftest/snapshots-opa/previous/MANIFEST: No such file or directory
/usr/bin/diff: /Users/hdftest/snapshots-opa/current/MANIFEST: No such file or directory
===== configure: Sun Oct  7 02:51:56 CDT 2018 =====
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /Users/hdftest/snapshots-opa/current/confdb/install-sh -c -d
checking for gawk... no
checking for mawk... no
checking for nawk... no
checking for awk... awk
checking whether gnumake sets $(MAKE)... yes
checking for style of include used by gnumake... GNU
checking for gcc... gcc
checking whether the C compiler works... no
configure: error: in `/Volumes/Milvinae/scr/hdftest/snapshots-opa/kite':
configure: error: C compiler cannot create executables
See `config.log' for more details
Failed running configure
Test failed.  Test directory and files from failed test were saved in
/Volumes/Milvinae/scr/hdftest/snapshots-opa/kite_1007Sun_0245.
===== Exit bin/snapshot with status=77: Sun Oct  7 12:53:05 CDT 2018 =====
Sun Oct  7 12:56:32 CDT 2018
Dumping done
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 00:33:44 up 810 days, 11:15,  1 user,  load average: 4.02, 5.13, 5.81
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda3             31738420  18912132  11188060  63% /
/dev/sda1               101086     17532     78335  19% /boot
/dev/sda2             31738420    186500  29913692   1% /tmp
/dev/sda6             31738392   6424068  23676100  22% /var
/dev/sda7             31738392  18571012  11529156  62% /usr
/dev/sda8            124991068    192208 118347160   1% /var/tmp
/dev/mapper/VolGroup00-home
                     198351840  91721720  96391760  49% /home
/dev/sdc1            961432072 859273232  53320840  95% /mnt/scr1
/dev/sdd1            961432072 886921520  25672552  98% /mnt/hdf
tmpfs                  8313628         0   8313628   0% /dev/shm
gumund:/data/ftp     480719104 398968576  57331328  88% /mnt/ftp
gumund:/data/web     480719104 398968576  57331328  88% /mnt/web
10.10.10.15:/volume1/hdf2
                     1437485440 596939264 840443776  42% /mnt/hdf2
10.10.10.15:/volume1/readonly
                     1437485440 596939264 840443776  42% /mnt/readonly
                     1437485440 596939264 840443776  42% /mnt/ro-src
                     1437485440 596939264 840443776  42% /mnt/rw-src
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_1007Sun
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1007Sun.10555: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1007Sun.10555': No such file or directory
*** launching tests from jam ***
TESTHOST is jam
koala
platypus
moohan
ostrich
kite
osx1011test
osx1010test
    Fork off timekeeper 12
Testing jam
ssh -o ConnectTimeout=60 jam -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
 00:34:10 up 810 days, 11:16,  1 user,  load average: 4.55, 5.16, 5.80
/dev/sda2             31738420    186612  29913580   1% /tmp
/dev/sda6             31738392   6424200  23675968  22% /var
                     198351840  91723840  96389640  49% /home
/dev/sdc1            961432072 859326264  53267808  95% /mnt/scr1
Extract source and run autogen if .
Sun Oct  7 00:34:21 CDT 2018
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
Running snapshot with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/jam_1007Sun_0034
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Sun Oct  7 00:35:23 CDT 2018
Total time = 1m 2s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
 00:34:14 up 729 days, 10:53,  1 user,  load average: 0.06, 0.02, 0.00
/dev/sda7             22292052   4427784  16713616  21% /
/dev/sda5             12192608    371680  11191584   4% /tmp
/dev/sda3             12192636   1003620  10559672   9% /var
/dev/sda1               101086     18614     77253  20% /boot
/dev/sdc1             41279536  26323756  12858900  68% /usr
/dev/sdb             152754284  70047040  74947784  49% /scr
tmpfs                  6149552         0   6149552   0% /dev/shm
10.10.10.86:/home    198351872  91723776  96390144  49% /home
10.10.10.86:/mnt/hdf 961432576 886921216  25672704  98% /mnt/hdf
10.10.10.86:/mnt/scr1
                     961432576 859329536  53265408  95% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Sun Oct  7 00:34:24 CDT 2018
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-409.el5 #1 SMP Tue Mar 15 18:13:50 EDT 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/koala_1007Sun_0034
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Sun Oct  7 00:35:17 CDT 2018
Total time = 0m 53s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
 00:34:17 up 729 days, 10:44,  0 users,  load average: 1.63, 1.62, 1.80
/dev/sda6             54205540  34428088  17017312  67% /
tmpfs                  6099068         0   6099068   0% /dev/shm
/dev/sda1               194241     48310    135691  27% /boot
/dev/sda2             12850716     83800  12107460   1% /tmp
/dev/sda3             12850716   5903156   6288104  49% /var
/dev/sdd             152623212 118747520  26116232  82% /scr
                     961432576 859331584  53262336  95% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Sun Oct  7 00:34:28 CDT 2018
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.22.1.el6.x86_64 #1 SMP Wed Mar 23 03:35:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/platypus_1007Sun_0034
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Sun Oct  7 00:35:29 CDT 2018
Total time = 1m 1s
*** finished tests in platypus ***
Testing moohan
ssh -o ConnectTimeout=60 moohan -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname moohan
 00:34:22 up 348 days, 13:02,  2 users,  load average: 5.18, 3.86, 3.67
/dev/mapper/centos_moohan-root   52196352   9619820  42576532  19% /
devtmpfs                          3923072         0   3923072   0% /dev
tmpfs                             3939844        84   3939760   1% /dev/shm
tmpfs                             3939844    402696   3537148  11% /run
tmpfs                             3939844         0   3939844   0% /sys/fs/cgroup
/dev/md126p1                       506752    312612    194140  62% /boot
/dev/mapper/centos_moohan-var    16371712   6115940  10255772  38% /var
/dev/mapper/centos_moohan-tmp    16371712    301448  16070264   2% /tmp
/dev/mapper/centos_moohan-scr   858065536 377259752 480805784  44% /scr
jam:/mnt/hdf                    961432576 886921216  25672704  98% /mnt/hdf
jam:/home                       198351872  91723776  96390144  49% /home
jam:/mnt/scr1                   961432576 859334656  53260288  95% /mnt/scr1
10.10.10.15:/volume1/readonly  1437485440 596939264 840443776  42% /mnt/ro-src
tmpfs                              787972        12    787960   1% /run/user/42
tmpfs                              787972         0    787972   0% /run/user/10057
tmpfs                              787972         0    787972   0% /run/user/2519
tmpfs                              787972         0    787972   0% /run/user/27429
tmpfs                              787972         0    787972   0% /run/user/29138
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
Sun Oct  7 00:34:33 CDT 2018
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests in moohan ***
Uname -a: Linux moohan.ad.hdfgroup.org 3.10.0-327.10.1.el7.x86_64 #1 SMP Tue Feb 16 17:03:50 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/moohan_1007Sun_0034
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests for moohan ***
Sun Oct  7 00:35:58 CDT 2018
Total time = 1m 25s
*** finished tests in moohan ***
Sun Oct  7 00:35:59 CDT 2018
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
 00:34:25 up 253 days,  9:45,  0 users,  load average: 4.18, 4.61, 4.81
/dev/mapper/vg_ostrich-lv_root
                     140479384  26891520 106448820  21% /
tmpfs                  7821504         0   7821504   0% /dev/shm
/dev/sda2               487652     99804    362248  22% /boot
/dev/sdb2            124477364  88032188  30115424  75% /scr
jam:/mnt/scr1        961432576 859337728  53257216  95% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Sun Oct  7 00:34:35 CDT 2018
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-696.16.1.el6.ppc64 #1 SMP Sun Oct 8 09:38:44 EDT 2017 ppc64 ppc64 ppc64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_1007Sun_0034
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Sun Oct  7 00:36:42 CDT 2018
Total time = 2m 7s
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich ***
   /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_1007Sun_0036
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich ***
Sun Oct  7 00:40:08 CDT 2018
Total time = 3m 26s
*** finished tests in ostrich ***
Testing kite
ssh -o ConnectTimeout=60 kite -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
 2:15  up 39 days,  9:48, 0 users, load averages: 1.72 1.71 1.72
Filesystem                    512-blocks       Used  Available Capacity iused      ifree %iused  Mounted on
/dev/disk0s2                  1951845952  141863696 1809470256     8% 1037434 4293929845    0%   /
devfs                                363        363          0   100%     629          0  100%   /dev
/dev/disk1s2                  1952853344   32610304 1920243040     2%  169041 4294798238    0%   /Volumes/Milvinae
map auto_nfs                           0          0          0   100%       0          0  100%   /home
map auto_nfs                           0          0          0   100%       0          0  100%   /mnt/hdf
map auto_nfs                           0          0          0   100%       0          0  100%   /mnt/scr1
jam.ad.hdfgroup.org:/mnt/scr1 1922864144 1723378384  101809760    95% 3970678  118139274    3%   /mnt/scr1
10.10.10.86:/home              396703680  184750984  191475976    50% 1040459   50175925    2%   /home
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
Sun Oct  7 02:29:25 CDT 2018
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests in kite ***
Uname -a: Darwin kite.ad.hdfgroup.org 16.7.0 Darwin Kernel Version 16.7.0: Tue Jan 30 11:27:06 PST 2018; root:xnu-3789.73.11~1/RELEASE_X86_64 x86_64
	Sun Oct  7 13:00:32 CDT 2018
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests for kite ***
Sun Oct  7 13:05:15 CDT 2018
Total time = 641m 42s
*** finished tests in kite ***
Sun Oct  7 13:05:16 CDT 2018
****SYSTEM ERROR kite: Abnormal exit from runtest ****
	****SYSTEM ERROR kite: runtest command failed ****
Testing osx1011test
ssh -o ConnectTimeout=60 osx1011test -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname osx1011test
 1:14  up 501 days,  9:10, 0 users, load averages: 1.37 2.38 2.47
/dev/disk1                    1951137792  181620360 1769005432    10% 22766543 221125679    9%   /
devfs                                357        357          0   100%      619         0  100%   /dev
jam.ad.hdfgroup.org:/mnt/scr1 1922864144 1724147944  101040200    95%  3971028 118138924    3%   /mnt/scr1
jam.ad.hdfgroup.org:/home      396703680  184750984  191475976    50%  1040459  50175925    2%   /home
jam.ad.hdfgroup.org:/mnt/hdf  1922864144 1773843184   51344960    98% 11434782 110675170    9%   /mnt/hdf
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy osx1011test
Sun Oct  7 01:14:21 CDT 2018
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy osx1011test tests in osx1011test ***
Uname -a: Darwin osx1011test.ad.hdfgroup.org 15.6.0 Darwin Kernel Version 15.6.0: Thu Jun 23 18:25:34 PDT 2016; root:xnu-3248.60.10~1/RELEASE_X86_64 x86_64
   /Users/hdftest/snapshots-opa/log/osx1011test_1007Sun_0114
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy osx1011test tests for osx1011test ***
Sun Oct  7 01:16:10 CDT 2018
Total time = 1m 49s
*** finished tests in osx1011test ***
Testing osx1010test
ssh -o ConnectTimeout=60 osx1010test -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname osx1010test
 1:14  up 26 days, 21:26, 0 users, load averages: 1.00 1.57 1.96
/dev/disk1                    1951825920  290421608 1660892312    15% 36366699 207611539   15%   /
devfs                                359        359          0   100%      622         0  100%   /dev
jam.ad.hdfgroup.org:/mnt/scr1 1922864144 1724145464  101042680    95%  3971029 118138923    3%   /mnt/scr1
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy osx1010test
Sun Oct  7 01:14:25 CDT 2018
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy osx1010test tests in osx1010test ***
Uname -a: Darwin osx1010test.ad.hdfgroup.org 14.5.0 Darwin Kernel Version 14.5.0: Mon Jan 11 18:48:35 PST 2016; root:xnu-2782.50.2~1/RELEASE_X86_64 x86_64
   /Users/hdftest/snapshots-opa/log/osx1010test_1007Sun_0114
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy osx1010test tests for osx1010test ***
Sun Oct  7 01:16:12 CDT 2018
Total time = 1m 47s
*** finished tests in osx1010test ***
More information about the opa-nightly-tests mailing list
