[opa-nightly-tests] jam OPA_Daily_Tests_0926Tue
HDF Tester
hdftest at hdfgroup.org
Tue Sep 26 18:06:31 CDT 2017
*** OPA Tests on 0926Tue ***
Tests Summary
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED moohan: standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
PASSED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
PASSED quail: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Tests Time Summary
koala: Ran 1(1/0/0) tests, Grand total test time = 0m 33s
platypus: Ran 1(1/0/0) tests, Grand total test time = 0m 42s
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 3s
quail: Ran 1(1/0/0) tests, Grand total test time = 0m 56s
moohan: Ran 1(1/0/0) tests, Grand total test time = 1m 19s
ostrich: Ran 2(2/0/0) tests, Grand total test time = 4m 43s
jam: Ran 7(0/0/0) hosts, Grand total test time = 5m 50s
Timekeeper log
Timekeeper started at Tue Sep 26 18:00:53 CDT 2017
Timekeeper sleeping for 720 seconds
Tests Failures
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
18:00:31 up 435 days, 4:42, 12 users, load average: 0.03, 0.23, 0.44
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 18910540 11189652 63% /
/dev/sda1 101086 17532 78335 19% /boot
/dev/sda2 31738420 237164 29863028 1% /tmp
/dev/sda6 31738392 6748100 23352068 23% /var
/dev/sda7 31738392 18542628 11557540 62% /usr
/dev/sda8 124991068 192212 118347156 1% /var/tmp
/dev/mapper/VolGroup00-home
198351840 100792304 87321176 54% /home
/dev/sdc1 961432072 850453384 62140688 94% /mnt/scr1
/dev/sdd1 961432072 900615064 11979008 99% /mnt/hdf
tmpfs 8313628 0 8313628 0% /dev/shm
gumund:/data/ftp 480719104 364697344 91602560 80% /mnt/ftp
gumund:/data/web 480719104 364697344 91602560 80% /mnt/web
10.10.10.15:/volume1/hdf2
1437485440 450495360 986887680 32% /mnt/hdf2
10.10.10.15:/volume1/readonly
1437485440 450495360 986887680 32% /mnt/readonly
1437485440 450495360 986887680 32% /mnt/ro-src
1437485440 450495360 986887680 32% /mnt/rw-src
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0926Tue
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0926Tue.4665: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0926Tue.4665': No such file or directory
*** launching tests from jam ***
TESTHOST is jam
koala
platypus
moohan
ostrich
quail
kite
Fork off timekeeper 12
Testing jam
ssh -o ConnectTimeout=60 jam -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
18:00:57 up 435 days, 4:43, 12 users, load average: 0.16, 0.24, 0.44
/dev/sda2 31738420 237276 29862916 1% /tmp
/dev/sda6 31738392 6748136 23352032 23% /var
/dev/sdc1 961432072 850453412 62140660 94% /mnt/scr1
Extract source and run autogen if .
Tue Sep 26 18:01:07 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/jam_0926Tue_1801
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Tue Sep 26 18:02:10 CDT 2017
Total time = 1m 3s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
18:00:59 up 354 days, 4:20, 1 user, load average: 0.01, 0.00, 0.09
/dev/sda7 22292052 4427732 16713668 21% /
/dev/sda5 12192608 380884 11182380 4% /tmp
/dev/sda3 12192636 1006704 10556588 9% /var
/dev/sda1 101086 18614 77253 20% /boot
/dev/sdc1 41279536 26323756 12858900 68% /usr
/dev/sdb 152754284 69857472 75137352 49% /scr
tmpfs 6149552 0 6149552 0% /dev/shm
10.10.10.86:/home 198351872 100792320 87321600 54% /home
10.10.10.86:/mnt/hdf 961432576 900615168 11979776 99% /mnt/hdf
10.10.10.86:/mnt/scr1
961432576 850453504 62141440 94% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Tue Sep 26 18:01:09 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-409.el5 #1 SMP Tue Mar 15 18:13:50 EDT 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/koala_0926Tue_1801
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Tue Sep 26 18:01:42 CDT 2017
Total time = 0m 33s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
18:01:02 up 354 days, 4:11, 0 users, load average: 0.44, 0.86, 0.79
/dev/sda6 54205540 34305904 17139496 67% /
tmpfs 6099068 0 6099068 0% /dev/shm
/dev/sda1 194241 48310 135691 27% /boot
/dev/sda2 12850716 179624 12011636 2% /tmp
/dev/sda3 12850716 5752832 6438428 48% /var
/dev/sdd 152623212 127280456 17583296 88% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Tue Sep 26 18:01:12 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.22.1.el6.x86_64 #1 SMP Wed Mar 23 03:35:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/platypus_0926Tue_1801
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Tue Sep 26 18:01:54 CDT 2017
Total time = 0m 42s
*** finished tests in platypus ***
Testing moohan
ssh -o ConnectTimeout=60 moohan -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname moohan
18:01:05 up 299 days, 3:56, 2 users, load average: 0.02, 0.34, 0.53
/dev/mapper/centos_moohan-root 52196352 9572676 42623676 19% /
devtmpfs 3923072 0 3923072 0% /dev
tmpfs 3939844 84 3939760 1% /dev/shm
tmpfs 3939844 427044 3512800 11% /run
tmpfs 3939844 0 3939844 0% /sys/fs/cgroup
/dev/md126p1 506752 312612 194140 62% /boot
/dev/mapper/centos_moohan-scr 858065536 360634528 497431008 43% /scr
/dev/mapper/centos_moohan-tmp 16371712 247108 16124604 2% /tmp
/dev/mapper/centos_moohan-var 16371712 5886956 10484756 36% /var
jam:/mnt/scr1 961432576 850453504 62141440 94% /mnt/scr1
jam:/home 198351872 100792320 87321600 54% /home
jam:/mnt/hdf 961432576 900615168 11979776 99% /mnt/hdf
10.10.10.15:/volume1/readonly 1437485440 450495360 986887680 32% /mnt/ro-src
tmpfs 787972 12 787960 1% /run/user/42
tmpfs 787972 0 787972 0% /run/user/2519
tmpfs 787972 0 787972 0% /run/user/0
tmpfs 787972 0 787972 0% /run/user/27429
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
Tue Sep 26 18:01:15 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests in moohan ***
Uname -a: Linux moohan.ad.hdfgroup.org 3.10.0-327.10.1.el7.x86_64 #1 SMP Tue Feb 16 17:03:50 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/moohan_0926Tue_1801
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests for moohan ***
Tue Sep 26 18:02:34 CDT 2017
Total time = 1m 19s
*** finished tests in moohan ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
18:01:08 up 302 days, 4:39, 1 user, load average: 0.18, 0.66, 0.79
/dev/mapper/vg_ostrich-lv_root
140479384 25556032 107784308 20% /
tmpfs 7821568 0 7821568 0% /dev/shm
/dev/sda2 487652 100521 361531 22% /boot
/dev/sdb2 124477364 97825944 20321668 83% /scr
jam:/mnt/scr1 961432576 850452480 62141440 94% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Tue Sep 26 18:01:18 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-573.18.1.el6.ppc64 #1 SMP Wed Jan 6 11:15:06 EST 2016 ppc64 ppc64 ppc64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0926Tue_1801
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Tue Sep 26 18:02:51 CDT 2017
Total time = 1m 33s
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich ***
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0926Tue_1802
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich ***
Tue Sep 26 18:06:01 CDT 2017
Total time = 3m 10s
*** finished tests in ostrich ***
Testing quail
ssh -o ConnectTimeout=60 quail -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname quail
18:01 up 75 days, 8:33, 0 users, load averages: 1.21 1.40 1.48
Filesystem 512-blocks Used Available Capacity iused ifree %iused Mounted on
/dev/disk0s2 488555536 294424672 193618864 61% 36867082 24202358 60% /
devfs 362 362 0 100% 627 0 100% /dev
map auto_nfs 0 0 0 100% 0 0 100% /home
map auto_nfs 0 0 0 100% 0 0 100% /mnt/hdf
map auto_nfs 0 0 0 100% 0 0 100% /mnt/scr1
jam.ad.hdfgroup.org:/mnt/scr1 1922864144 1700906944 124281200 94% 4042930 118067022 3% /mnt/scr1
jam.ad.hdfgroup.org:/mnt/hdf 1922864144 1801230128 23958016 99% 11779377 110330575 10% /mnt/hdf
jam.ad.hdfgroup.org:/home 396703680 201584608 174642352 54% 1057634 50158750 2% /home
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Tue Sep 26 18:01:21 CDT 2017
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests in quail ***
Uname -a: Darwin quail.ad.hdfgroup.org 13.4.0 Darwin Kernel Version 13.4.0: Mon Jan 11 18:17:34 PST 2016; root:xnu-2422.115.15~1/RELEASE_X86_64 x86_64
/Users/hdftest/snapshots-opa/log/quail_0926Tue_1801
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests for quail ***
Tue Sep 26 18:02:17 CDT 2017
Total time = 0m 56s
*** finished tests in quail ***
Testing kite
ssh -o ConnectTimeout=60 kite -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
snapshots-opa: No such file or directory.
BASEDIR (/Users/hdftest/snapshots-) does not exist
Tue Sep 26 18:01:13 CDT 2017
****SYSTEM ERROR kite: BASEDIR (/Users/hdftest/snapshots-) does not exist
/mnt/scr1/SnapTest/snapshots-opa/bin/runtest: line 128: $SYSERRLOG: ambiguous redirect
****SYSTEM ERROR kite: Abnormal exit from runtest ****
****SYSTEM ERROR kite: runtest command failed ****
More information about the opa-nightly-tests
