[opa-nightly-tests] jam OPA_Daily_Tests_0920Wed
HDF Tester hdftest at hdfgroup.org
Wed Sep 20 22:20:50 CDT 2017
*** OPA Tests on 0920Wed ***
   Tests Summary
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED moohan: standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
PASSED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
PASSED quail: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
   Tests Time Summary
koala: Ran 1(1/0/0) tests, Grand total test time =  0m 32s
platypus: Ran 1(1/0/0) tests, Grand total test time =  0m 45s
jam: Ran 1(1/0/0) tests, Grand total test time =  0m 59s
quail: Ran 1(1/0/0) tests, Grand total test time =  0m 53s
moohan: Ran 1(1/0/0) tests, Grand total test time =  1m 18s
ostrich: Ran 2(2/0/0) tests, Grand total test time =  4m 48s
jam: Ran 7(0/0/0) hosts, Grand total test time =  5m 54s
   Timekeeper log
Timekeeper started at Wed Sep 20 22:15:07 CDT 2017
Timekeeper sleeping for 720 seconds
   Tests Failures
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 22:14:46 up 429 days,  8:56, 26 users,  load average: 1.23, 1.17, 1.01
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda3             31738420  18910544  11189648  63% /
/dev/sda1               101086     17532     78335  19% /boot
/dev/sda2             31738420    251768  29848424   1% /tmp
/dev/sda6             31738392   6758180  23341988  23% /var
/dev/sda7             31738392  18542628  11557540  62% /usr
/dev/sda8            124991068    192224 118347144   1% /var/tmp
/dev/mapper/VolGroup00-home
                     198351840 100508040  87605440  54% /home
/dev/sdc1            961432072 851338016  61256056  94% /mnt/scr1
/dev/sdd1            961432072 894330664  18263408  98% /mnt/hdf
tmpfs                  8313628         0   8313628   0% /dev/shm
gumund:/data/ftp     480719104 364963584  91336320  80% /mnt/ftp
gumund:/data/web     480719104 364963584  91336320  80% /mnt/web
10.10.10.15:/volume1/hdf2
                     1437485440 450495360 986887680  32% /mnt/hdf2
10.10.10.15:/volume1/readonly
                     1437485440 450495360 986887680  32% /mnt/readonly
                     1437485440 450495360 986887680  32% /mnt/ro-src
                     1437485440 450495360 986887680  32% /mnt/rw-src
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0920Wed
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0920Wed.16405: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0920Wed.16405': No such file or directory
*** launching tests from jam ***
TESTHOST is jam
koala
platypus
moohan
ostrich
quail
kite
    Fork off timekeeper 12
Testing jam
ssh -o ConnectTimeout=60 jam -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
 22:15:11 up 429 days,  8:57, 26 users,  load average: 1.29, 1.18, 1.01
/dev/sda2             31738420    251880  29848312   1% /tmp
/dev/sda6             31738392   6758296  23341872  23% /var
/dev/sdc1            961432072 851338044  61256028  94% /mnt/scr1
/dev/sdd1            961432072 894383208  18210864  99% /mnt/hdf
Extract source and run autogen if .
Wed Sep 20 22:15:22 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
Running snapshot with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/jam_0920Wed_2215
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Wed Sep 20 22:16:20 CDT 2017
Total time = 0m 58s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
 22:15:14 up 348 days,  8:34,  1 user,  load average: 0.02, 0.02, 0.07
/dev/sda7             22292052   4427728  16713672  21% /
/dev/sda5             12192608    386068  11177196   4% /tmp
/dev/sda3             12192636   1011724  10551568   9% /var
/dev/sda1               101086     18614     77253  20% /boot
/dev/sdc1             41279536  26323756  12858900  68% /usr
/dev/sdb             152754284  69856180  75138644  49% /scr
tmpfs                  6149552         0   6149552   0% /dev/shm
10.10.10.86:/home    198351872 100507648  87606272  54% /home
10.10.10.86:/mnt/hdf 961432576 894387200  18206720  99% /mnt/hdf
10.10.10.86:/mnt/scr1
                     961432576 851338240  61256704  94% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Wed Sep 20 22:15:24 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-409.el5 #1 SMP Tue Mar 15 18:13:50 EDT 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/koala_0920Wed_2215
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Wed Sep 20 22:15:56 CDT 2017
Total time = 0m 32s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
 22:15:16 up 348 days,  8:25,  0 users,  load average: 0.30, 0.75, 0.67
/dev/sda6             54205540  34305904  17139496  67% /
tmpfs                  6099068         0   6099068   0% /dev/shm
/dev/sda1               194241     48310    135691  27% /boot
/dev/sda2             12850716     62972  12128288   1% /tmp
/dev/sda3             12850716   5836364   6354896  48% /var
/dev/sdd             152623212 127867400  16996352  89% /scr
10.10.10.86:/mnt/hdf 961432576 894393344  18201600  99% /mnt/hdf
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Wed Sep 20 22:15:27 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.22.1.el6.x86_64 #1 SMP Wed Mar 23 03:35:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/platypus_0920Wed_2215
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Wed Sep 20 22:16:11 CDT 2017
Total time = 0m 44s
*** finished tests in platypus ***
Testing moohan
ssh -o ConnectTimeout=60 moohan -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname moohan
 22:15:19 up 293 days,  8:10,  2 users,  load average: 0.06, 0.44, 0.56
/dev/mapper/centos_moohan-root   52196352   9572676  42623676  19% /
devtmpfs                          3923072         0   3923072   0% /dev
tmpfs                             3939844        84   3939760   1% /dev/shm
tmpfs                             3939844    443428   3496416  12% /run
tmpfs                             3939844         0   3939844   0% /sys/fs/cgroup
/dev/md126p1                       506752    312612    194140  62% /boot
/dev/mapper/centos_moohan-scr   858065536 359229920 498835616  42% /scr
/dev/mapper/centos_moohan-tmp    16371712    152256  16219456   1% /tmp
/dev/mapper/centos_moohan-var    16371712   5959212  10412500  37% /var
jam:/mnt/scr1                   961432576 851338240  61256704  94% /mnt/scr1
jam:/home                       198351872 100507648  87606272  54% /home
jam:/mnt/hdf                    961432576 894398464  18195456  99% /mnt/hdf
10.10.10.15:/volume1/readonly  1437485440 450495360 986887680  32% /mnt/ro-src
tmpfs                              787972        12    787960   1% /run/user/42
tmpfs                              787972         0    787972   0% /run/user/2519
tmpfs                              787972         0    787972   0% /run/user/0
tmpfs                              787972         0    787972   0% /run/user/27429
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
Wed Sep 20 22:15:30 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests in moohan ***
Uname -a: Linux moohan.ad.hdfgroup.org 3.10.0-327.10.1.el7.x86_64 #1 SMP Tue Feb 16 17:03:50 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/moohan_0920Wed_2215
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests for moohan ***
Wed Sep 20 22:16:48 CDT 2017
Total time = 1m 18s
*** finished tests in moohan ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
 22:15:22 up 296 days,  8:53,  0 users,  load average: 0.52, 1.08, 0.77
/dev/mapper/vg_ostrich-lv_root
                      140479384  24671136 108669204  19% /
tmpfs                   7821568         0   7821568   0% /dev/shm
/dev/sda2                487652    100521    361531  22% /boot
/dev/sdb2             124477364  98775528  19372084  84% /scr
jam:/mnt/hdf          961432576 894404608  18189312  99% /mnt/hdf
jam:/mnt/scr1         961432576 851337216  61256704  94% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Wed Sep 20 22:15:32 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-573.18.1.el6.ppc64 #1 SMP Wed Jan 6 11:15:06 EST 2016 ppc64 ppc64 ppc64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0920Wed_2215
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Wed Sep 20 22:17:12 CDT 2017
Total time = 1m 40s
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich ***
   /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0920Wed_2217
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich ***
Wed Sep 20 22:20:20 CDT 2017
Total time = 3m 8s
*** finished tests in ostrich ***
Testing quail
ssh -o ConnectTimeout=60 quail -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname quail
22:15  up 69 days, 12:47, 0 users, load averages: 1.44 1.35 1.39
Filesystem                    512-blocks       Used Available Capacity  iused     ifree %iused  Mounted on
/dev/disk0s2                   488555536  292221144 195822392    60% 36591641  24477799   60%   /
devfs                                362        362         0   100%      627         0  100%   /dev
map auto_nfs                           0          0         0   100%        0         0  100%   /home
map auto_nfs                           0          0         0   100%        0         0  100%   /mnt/hdf
map auto_nfs                           0          0         0   100%        0         0  100%   /mnt/scr1
jam.ad.hdfgroup.org:/mnt/scr1 1922864144 1702675120 122513024    94%  4039823 118070129    3%   /mnt/scr1
jam.ad.hdfgroup.org:/home      396703680  201016080 175210880    54%  1055226  50161158    2%   /home
jam.ad.hdfgroup.org:/mnt/hdf  1922864144 1788818240  36369904    99% 11755112 110354840   10%   /mnt/hdf
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Wed Sep 20 22:15:34 CDT 2017
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests in quail ***
Uname -a: Darwin quail.ad.hdfgroup.org 13.4.0 Darwin Kernel Version 13.4.0: Mon Jan 11 18:17:34 PST 2016; root:xnu-2422.115.15~1/RELEASE_X86_64 x86_64
   /Users/hdftest/snapshots-opa/log/quail_0920Wed_2215
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests for quail ***
Wed Sep 20 22:16:27 CDT 2017
Total time = 0m 53s
*** finished tests in quail ***
Testing kite
ssh -o ConnectTimeout=60 kite -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
snapshots-opa: No such file or directory.
BASEDIR (/Users/hdftest/snapshots-) does not exist
	Wed Sep 20 22:15:26 CDT 2017
	****SYSTEM ERROR kite: BASEDIR (/Users/hdftest/snapshots-) does not exist
/mnt/scr1/SnapTest/snapshots-opa/bin/runtest: line 128: $SYSERRLOG: ambiguous redirect
****SYSTEM ERROR kite: Abnormal exit from runtest ****
	****SYSTEM ERROR kite: runtest command failed ****
More information about the opa-nightly-tests mailing list
