[opa-nightly-tests] jam OPA_Daily_Tests_1023Mon
HDF Tester
hdftest at hdfgroup.org
Mon Oct 23 23:09:31 CDT 2017
*** OPA Tests on 1023Mon ***
Tests Summary
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED moohan: standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
PASSED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Tests Time Summary
koala: Ran 1(1/0/0) tests, Grand total test time = 0m 32s
platypus: Ran 1(1/0/0) tests, Grand total test time = 0m 43s
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 2s
moohan: Ran 1(1/0/0) tests, Grand total test time = 1m 21s
ostrich: Ran 2(2/0/0) tests, Grand total test time = 4m 40s
jam: Ran 7(0/0/0) hosts, Grand total test time = 5m 46s
Timekeeper log
Timekeeper started at Mon Oct 23 23:03:56 CDT 2017
Timekeeper sleeping for 720 seconds
Tests Failures
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
23:03:35 up 462 days, 9:45, 23 users, load average: 0.28, 0.64, 0.74
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 18910548 11189644 63% /
/dev/sda1 101086 17532 78335 19% /boot
/dev/sda2 31738420 246568 29853624 1% /tmp
/dev/sda6 31738392 6547628 23552540 22% /var
/dev/sda7 31738392 18542628 11557540 62% /usr
/dev/sda8 124991068 192220 118347148 1% /var/tmp
/dev/mapper/VolGroup00-home
198351840 100222096 87891384 54% /home
/dev/sdc1 961432072 843202756 69391316 93% /mnt/scr1
/dev/sdd1 961432072 867448504 45145568 96% /mnt/hdf
tmpfs 8313628 0 8313628 0% /dev/shm
gumund:/data/ftp 480719104 376482176 79817728 83% /mnt/ftp
gumund:/data/web 480719104 376482176 79817728 83% /mnt/web
10.10.10.15:/volume1/hdf2
1437485440 503923584 933459456 36% /mnt/hdf2
10.10.10.15:/volume1/readonly
1437485440 503923584 933459456 36% /mnt/readonly
1437485440 503923584 933459456 36% /mnt/ro-src
1437485440 503923584 933459456 36% /mnt/rw-src
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_1023Mon
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1023Mon.3364: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1023Mon.3364': No such file or directory
*** launching tests from jam ***
TESTHOST is jam
koala
platypus
moohan
ostrich
quail
kite
Fork off timekeeper 12
Testing jam
ssh -o ConnectTimeout=60 jam -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
23:04:01 up 462 days, 9:46, 23 users, load average: 0.33, 0.62, 0.73
/dev/sda2 31738420 246676 29853516 1% /tmp
/dev/sda6 31738392 6547636 23552532 22% /var
/dev/sdc1 961432072 843202532 69391540 93% /mnt/scr1
Extract source and run autogen if .
Mon Oct 23 23:04:11 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/jam_1023Mon_2304
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Mon Oct 23 23:05:13 CDT 2017
Total time = 1m 2s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
23:04:03 up 381 days, 9:23, 1 user, load average: 0.02, 0.08, 0.09
/dev/sda7 22292052 4427736 16713664 21% /
/dev/sda5 12192608 389296 11173968 4% /tmp
/dev/sda3 12192636 1013896 10549396 9% /var
/dev/sda1 101086 18614 77253 20% /boot
/dev/sdc1 41279536 26323756 12858900 68% /usr
/dev/sdb 152754284 69869192 75125632 49% /scr
tmpfs 6149552 0 6149552 0% /dev/shm
10.10.10.86:/home 198351872 100221952 87891968 54% /home
10.10.10.86:/mnt/hdf 961432576 867448832 45146112 96% /mnt/hdf
10.10.10.86:/mnt/scr1
961432576 843202560 69392384 93% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Mon Oct 23 23:04:13 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-409.el5 #1 SMP Tue Mar 15 18:13:50 EDT 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/koala_1023Mon_2304
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Mon Oct 23 23:04:45 CDT 2017
Total time = 0m 32s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
23:04:06 up 381 days, 9:14, 0 users, load average: 0.85, 1.06, 1.03
/dev/sda6 54205540 34305352 17140048 67% /
tmpfs 6099068 0 6099068 0% /dev/shm
/dev/sda1 194241 48310 135691 27% /boot
/dev/sda2 12850716 74020 12117240 1% /tmp
/dev/sda3 12850716 5714604 6476656 47% /var
/dev/sdd 152623212 131456384 13407368 91% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Mon Oct 23 23:04:16 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.22.1.el6.x86_64 #1 SMP Wed Mar 23 03:35:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/platypus_1023Mon_2304
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Mon Oct 23 23:04:59 CDT 2017
Total time = 0m 43s
*** finished tests in platypus ***
Testing moohan
ssh -o ConnectTimeout=60 moohan -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname moohan
23:04:08 up 11:31, 1 user, load average: 0.28, 0.93, 0.87
/dev/mapper/centos_moohan-root 52196352 9572864 42623488 19% /
devtmpfs 3923072 0 3923072 0% /dev
tmpfs 3939844 84 3939760 1% /dev/shm
tmpfs 3939844 17432 3922412 1% /run
tmpfs 3939844 0 3939844 0% /sys/fs/cgroup
/dev/md126p1 506752 312612 194140 62% /boot
/dev/mapper/centos_moohan-var 16371712 5890636 10481076 36% /var
/dev/mapper/centos_moohan-tmp 16371712 470524 15901188 3% /tmp
/dev/mapper/centos_moohan-scr 858065536 365334832 492730704 43% /scr
jam:/mnt/hdf 961432576 867448832 45146112 96% /mnt/hdf
jam:/home 198351872 100221952 87891968 54% /home
jam:/mnt/scr1 961432576 843202560 69392384 93% /mnt/scr1
10.10.10.15:/volume1/readonly 1437485440 503923584 933459456 36% /mnt/ro-src
tmpfs 787972 12 787960 1% /run/user/42
tmpfs 787972 0 787972 0% /run/user/27429
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
Mon Oct 23 23:04:18 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests in moohan ***
Uname -a: Linux moohan.ad.hdfgroup.org 3.10.0-327.10.1.el7.x86_64 #1 SMP Tue Feb 16 17:03:50 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/moohan_1023Mon_2304
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests for moohan ***
Mon Oct 23 23:05:39 CDT 2017
Total time = 1m 21s
*** finished tests in moohan ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
23:04:11 up 6 days, 7:06, 1 user, load average: 0.52, 1.04, 0.76
/dev/mapper/vg_ostrich-lv_root
140479384 27218024 106122316 21% /
tmpfs 7821504 0 7821504 0% /dev/shm
/dev/sdb2 487652 107028 355024 24% /boot
/dev/sda2 124477364 113262008 4885604 96% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Mon Oct 23 23:04:21 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-696.13.2.el6.ppc64 #1 SMP Fri Sep 22 12:25:47 EDT 2017 ppc64 ppc64 ppc64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_1023Mon_2304
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Mon Oct 23 23:05:55 CDT 2017
Total time = 1m 34s
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich ***
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_1023Mon_2305
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich ***
Mon Oct 23 23:09:01 CDT 2017
Total time = 3m 6s
*** finished tests in ostrich ***
Testing quail
ssh -o ConnectTimeout=60 quail -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname quail
snapshots-opa: No such file or directory.
****SYSTEM ERROR quail: Abnormal exit from runtest ****
****SYSTEM ERROR quail: runtest command failed ****
Testing kite
ssh -o ConnectTimeout=60 kite -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
BASEDIR (/Users/hdftest/snapshots-) does not exist
Mon Oct 23 23:04:15 CDT 2017
****SYSTEM ERROR kite: BASEDIR (/Users/hdftest/snapshots-) does not exist
/mnt/scr1/SnapTest/snapshots-opa/bin/runtest: line 128: $SYSERRLOG: ambiguous redirect
****SYSTEM ERROR kite: Abnormal exit from runtest ****
****SYSTEM ERROR kite: runtest command failed ****
More information about the opa-nightly-tests
