[opa-nightly-tests] jam OPA_Daily_Tests_1017Tue
HDF Tester hdftest at hdfgroup.org
Tue Oct 17 19:27:08 CDT 2017
*** OPA Tests on 1017Tue ***
   Tests Summary
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED moohan: standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
PASSED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
PASSED quail: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
   Tests Time Summary
koala: Ran 1(1/0/0) tests, Grand total test time =  0m 34s
platypus: Ran 1(1/0/0) tests, Grand total test time =  0m 43s
jam: Ran 1(1/0/0) tests, Grand total test time =  1m 0s
quail: Ran 1(1/0/0) tests, Grand total test time =  0m 54s
moohan: Ran 1(1/0/0) tests, Grand total test time =  1m 10s
ostrich: Ran 2(2/0/0) tests, Grand total test time =  4m 41s
jam: Ran 7(0/0/0) hosts, Grand total test time =  5m 48s
   Timekeeper log
Timekeeper started at Tue Oct 17 19:21:32 CDT 2017
Timekeeper sleeping for 720 seconds
   Tests Failures
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 19:21:10 up 456 days,  6:03, 14 users,  load average: 1.05, 0.95, 0.76
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda3             31738420  18910544  11189648  63% /
/dev/sda1               101086     17532     78335  19% /boot
/dev/sda2             31738420    235276  29864916   1% /tmp
/dev/sda6             31738392   6587492  23512676  22% /var
/dev/sda7             31738392  18542628  11557540  62% /usr
/dev/sda8            124991068    192220 118347148   1% /var/tmp
/dev/mapper/VolGroup00-home
                     198351840 100212448  87901032  54% /home
/dev/sdc1            961432072 840771900  71822172  93% /mnt/scr1
/dev/sdd1            961432072 858723824  53870248  95% /mnt/hdf
tmpfs                  8313628         0   8313628   0% /dev/shm
gumund:/data/ftp     480719104 370022400  86277504  82% /mnt/ftp
gumund:/data/web     480719104 370022400  86277504  82% /mnt/web
10.10.10.15:/volume1/hdf2
                     1437485440 503923584 933459456  36% /mnt/hdf2
10.10.10.15:/volume1/readonly
                     1437485440 503923584 933459456  36% /mnt/readonly
                     1437485440 503923584 933459456  36% /mnt/ro-src
                     1437485440 503923584 933459456  36% /mnt/rw-src
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_1017Tue
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1017Tue.21854: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1017Tue.21854': No such file or directory
*** launching tests from jam ***
TESTHOST is jam
koala
platypus
moohan
ostrich
quail
kite
    Fork off timekeeper 12
Testing jam
ssh -o ConnectTimeout=60 jam -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
 19:21:36 up 456 days,  6:03, 14 users,  load average: 1.17, 0.99, 0.78
/dev/sda2             31738420    235940  29864252   1% /tmp
/dev/sda6             31738392   6587504  23512664  22% /var
/dev/sdc1            961432072 840771928  71822144  93% /mnt/scr1
/dev/sdd1            961432072 858618272  53975800  95% /mnt/hdf
Extract source and run autogen if .
Tue Oct 17 19:21:47 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
Running snapshot with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/jam_1017Tue_1921
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Tue Oct 17 19:22:46 CDT 2017
Total time = 0m 59s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
 19:21:38 up 375 days,  5:40,  1 user,  load average: 0.08, 0.43, 0.47
/dev/sda7             22292052   4427732  16713668  21% /
/dev/sda5             12192608    384556  11178708   4% /tmp
/dev/sda3             12192636   1010180  10553112   9% /var
/dev/sda1               101086     18614     77253  20% /boot
/dev/sdc1             41279536  26323756  12858900  68% /usr
/dev/sdb             152754284  69921948  75072876  49% /scr
tmpfs                  6149552         0   6149552   0% /dev/shm
10.10.10.86:/home    198351872 100211712  87901184  54% /home
10.10.10.86:/mnt/hdf 961432576 858646528  53948416  95% /mnt/hdf
10.10.10.86:/mnt/scr1
                     961432576 840771584  71822336  93% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Tue Oct 17 19:21:49 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-409.el5 #1 SMP Tue Mar 15 18:13:50 EDT 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/koala_1017Tue_1921
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Tue Oct 17 19:22:22 CDT 2017
Total time = 0m 33s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
 19:21:41 up 375 days,  5:32,  0 users,  load average: 0.71, 0.92, 0.94
/dev/sda6             54205540  34305904  17139496  67% /
tmpfs                  6099068         0   6099068   0% /dev/shm
/dev/sda1               194241     48310    135691  27% /boot
/dev/sda2             12850716    155508  12035752   2% /tmp
/dev/sda3             12850716   5663116   6528144  47% /var
/dev/sdd             152623212 128252836  16610916  89% /scr
10.10.10.86:/mnt/hdf 961432576 858704896  53890048  95% /mnt/hdf
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Tue Oct 17 19:21:51 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.22.1.el6.x86_64 #1 SMP Wed Mar 23 03:35:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/platypus_1017Tue_1921
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Tue Oct 17 19:22:34 CDT 2017
Total time = 0m 43s
*** finished tests in platypus ***
Testing moohan
ssh -o ConnectTimeout=60 moohan -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname moohan
 19:21:44 up 320 days,  5:17,  2 users,  load average: 1.30, 0.75, 0.67
/dev/mapper/centos_moohan-root   52196352   9572676  42623676  19% /
devtmpfs                          3923072         0   3923072   0% /dev
tmpfs                             3939844        84   3939760   1% /dev/shm
tmpfs                             3939844    435264   3504580  12% /run
tmpfs                             3939844         0   3939844   0% /sys/fs/cgroup
/dev/md126p1                       506752    312612    194140  62% /boot
/dev/mapper/centos_moohan-scr   858065536 362890780 495174756  43% /scr
/dev/mapper/centos_moohan-tmp    16371712    337364  16034348   3% /tmp
/dev/mapper/centos_moohan-var    16371712   6004524  10367188  37% /var
jam:/mnt/scr1                   961432576 840771584  71822336  93% /mnt/scr1
jam:/home                       198351872 100211712  87901184  54% /home
jam:/mnt/hdf                    961432576 858715136  53879808  95% /mnt/hdf
10.10.10.15:/volume1/readonly  1437485440 503923584 933459456  36% /mnt/ro-src
tmpfs                              787972        12    787960   1% /run/user/42
tmpfs                              787972         0    787972   0% /run/user/2519
tmpfs                              787972         0    787972   0% /run/user/0
tmpfs                              787972         0    787972   0% /run/user/27429
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
Tue Oct 17 19:21:55 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests in moohan ***
Uname -a: Linux moohan.ad.hdfgroup.org 3.10.0-327.10.1.el7.x86_64 #1 SMP Tue Feb 16 17:03:50 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/moohan_1017Tue_1921
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests for moohan ***
Tue Oct 17 19:23:04 CDT 2017
Total time = 1m 10s
*** finished tests in moohan ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
 19:21:47 up  3:24,  2 users,  load average: 0.14, 0.66, 0.72
/dev/mapper/vg_ostrich-lv_root
                      140479384  27712168 105628172  21% /
tmpfs                   7821504         0   7821504   0% /dev/shm
/dev/sdb2                487652    107028    355024  24% /boot
/dev/sda2             124477364 113249992   4897620  96% /scr
jam:/mnt/hdf          961432576 858725376  53869568  95% /mnt/hdf
jam:/mnt/scr1         961432576 840771584  71823360  93% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Tue Oct 17 19:21:57 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-696.13.2.el6.ppc64 #1 SMP Fri Sep 22 12:25:47 EDT 2017 ppc64 ppc64 ppc64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_1017Tue_1921
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Tue Oct 17 19:23:38 CDT 2017
Total time = 1m 41s
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich ***
   /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_1017Tue_1923
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich ***
Tue Oct 17 19:26:38 CDT 2017
Total time = 3m 0s
*** finished tests in ostrich ***
Testing quail
ssh -o ConnectTimeout=60 quail -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname quail
19:21  up 96 days,  9:54, 0 users, load averages: 1.51 1.58 1.53
Filesystem                    512-blocks       Used Available Capacity  iused     ifree %iused  Mounted on
/dev/disk0s2                   488555536  295443560 192599976    61% 36994443  24074997   61%   /
devfs                                361        361         0   100%      626         0  100%   /dev
map auto_nfs                           0          0         0   100%        0         0  100%   /home
map auto_nfs                           0          0         0   100%        0         0  100%   /mnt/hdf
map auto_nfs                           0          0         0   100%        0         0  100%   /mnt/scr1
jam.ad.hdfgroup.org:/home      396703680  200424896 175802064    54%  1035440  50180944    2%   /home
jam.ad.hdfgroup.org:/mnt/hdf  1922864144 1717466200 107721944    95% 11045176 111064776    9%   /mnt/hdf
jam.ad.hdfgroup.org:/mnt/scr1 1922864144 1681542816 143645328    93%  4119107 117990845    3%   /mnt/scr1
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Tue Oct 17 19:21:59 CDT 2017
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests in quail ***
Uname -a: Darwin quail.ad.hdfgroup.org 13.4.0 Darwin Kernel Version 13.4.0: Mon Jan 11 18:17:34 PST 2016; root:xnu-2422.115.15~1/RELEASE_X86_64 x86_64
   /Users/hdftest/snapshots-opa/log/quail_1017Tue_1921
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests for quail ***
Tue Oct 17 19:22:53 CDT 2017
Total time = 0m 54s
*** finished tests in quail ***
Testing kite
ssh -o ConnectTimeout=60 kite -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
snapshots-opa: No such file or directory.
BASEDIR (/Users/hdftest/snapshots-) does not exist
	****SYSTEM ERROR kite: BASEDIR (/Users/hdftest/snapshots-) does not exist
/mnt/scr1/SnapTest/snapshots-opa/bin/runtest: line 128: $SYSERRLOG: ambiguous redirect
****SYSTEM ERROR kite: Abnormal exit from runtest ****
	****SYSTEM ERROR kite: runtest command failed ****
More information about the opa-nightly-tests mailing list
