[opa-nightly-tests] jam OPA_Daily_Tests_1014Sat
HDF Tester hdftest at hdfgroup.org
Sat Oct 14 22:13:24 CDT 2017
*** OPA Tests on 1014Sat ***
   Tests Summary
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED moohan: standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
PASSED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
PASSED quail: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
   Tests Time Summary
koala: Ran 1(1/0/0) tests, Grand total test time =  0m 32s
platypus: Ran 1(1/0/0) tests, Grand total test time =  0m 44s
jam: Ran 1(1/0/0) tests, Grand total test time =  1m 3s
quail: Ran 1(1/0/0) tests, Grand total test time =  0m 57s
moohan: Ran 1(1/0/0) tests, Grand total test time =  1m 19s
ostrich: Ran 2(2/0/0) tests, Grand total test time =  4m 48s
jam: Ran 7(0/0/0) hosts, Grand total test time =  5m 54s
   Timekeeper log
Timekeeper started at Sat Oct 14 22:07:41 CDT 2017
Timekeeper sleeping for 720 seconds
   Tests Failures
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 22:07:20 up 453 days,  8:49,  9 users,  load average: 0.17, 0.42, 0.90
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda3             31738420  18910540  11189652  63% /
/dev/sda1               101086     17532     78335  19% /boot
/dev/sda2             31738420    224760  29875432   1% /tmp
/dev/sda6             31738392   7009076  23091092  24% /var
/dev/sda7             31738392  18542628  11557540  62% /usr
/dev/sda8            124991068    192216 118347152   1% /var/tmp
/dev/mapper/VolGroup00-home
                     198351840 100208328  87905152  54% /home
/dev/sdc1            961432072 837906576  74687496  92% /mnt/scr1
/dev/sdd1            961432072 909677956   2916116 100% /mnt/hdf
tmpfs                  8313628         0   8313628   0% /dev/shm
gumund:/data/ftp     480719104 366908928  89390976  81% /mnt/ftp
gumund:/data/web     480719104 366908928  89390976  81% /mnt/web
10.10.10.15:/volume1/hdf2
                     1437485440 450589824 986793216  32% /mnt/hdf2
10.10.10.15:/volume1/readonly
                     1437485440 450589824 986793216  32% /mnt/readonly
                     1437485440 450589824 986793216  32% /mnt/ro-src
                     1437485440 450589824 986793216  32% /mnt/rw-src
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_1014Sat
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1014Sat.13142: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1014Sat.13142': No such file or directory
*** launching tests from jam ***
TESTHOST is jam
koala
platypus
moohan
ostrich
quail
kite
    Fork off timekeeper 12
Testing jam
ssh -o ConnectTimeout=60 jam -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
 22:07:45 up 453 days,  8:49,  9 users,  load average: 0.46, 0.46, 0.90
/dev/sda2             31738420    224872  29875320   1% /tmp
/dev/sda6             31738392   7009096  23091072  24% /var
/dev/sdc1            961432072 837905440  74688632  92% /mnt/scr1
/dev/sdd1            961432072 909592112   3001960 100% /mnt/hdf
Extract source and run autogen if .
Sat Oct 14 22:07:55 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
Running snapshot with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/jam_1014Sat_2207
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Sat Oct 14 22:08:58 CDT 2017
Total time = 1m 3s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
 22:07:47 up 372 days,  8:26,  1 user,  load average: 0.00, 0.02, 0.13
/dev/sda7             22292052   4427732  16713668  21% /
/dev/sda5             12192608    385944  11177320   4% /tmp
/dev/sda3             12192636   1014804  10548488   9% /var
/dev/sda1               101086     18614     77253  20% /boot
/dev/sdc1             41279536  26323756  12858900  68% /usr
/dev/sdb             152754284  69863176  75131648  49% /scr
tmpfs                  6149552         0   6149552   0% /dev/shm
10.10.10.86:/home    198351872 100207616  87905280  54% /home
10.10.10.86:/mnt/hdf 961432576 909612032   2982912 100% /mnt/hdf
10.10.10.86:/mnt/scr1
                     961432576 837905408  74689536  92% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Sat Oct 14 22:07:57 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-409.el5 #1 SMP Tue Mar 15 18:13:50 EDT 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/koala_1014Sat_2207
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Sat Oct 14 22:08:29 CDT 2017
Total time = 0m 32s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
 22:07:50 up 372 days,  8:18,  0 users,  load average: 0.99, 0.89, 1.04
/dev/sda6             54205540  34305904  17139496  67% /
tmpfs                  6099068         0   6099068   0% /dev/shm
/dev/sda1               194241     48310    135691  27% /boot
/dev/sda2             12850716     64580  12126680   1% /tmp
/dev/sda3             12850716   5735088   6456172  48% /var
/dev/sdd             152623212 125543076  19320676  87% /scr
10.10.10.86:/mnt/hdf 961432576 909636608   2958336 100% /mnt/hdf
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Sat Oct 14 22:08:00 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.22.1.el6.x86_64 #1 SMP Wed Mar 23 03:35:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/platypus_1014Sat_2208
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Sat Oct 14 22:08:44 CDT 2017
Total time = 0m 44s
*** finished tests in platypus ***
Testing moohan
ssh -o ConnectTimeout=60 moohan -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname moohan
 22:07:53 up 317 days,  8:03,  2 users,  load average: 0.35, 0.90, 0.92
/dev/mapper/centos_moohan-root   52196352   9572676  42623676  19% /
devtmpfs                          3923072         0   3923072   0% /dev
tmpfs                             3939844        84   3939760   1% /dev/shm
tmpfs                             3939844    443484   3496360  12% /run
tmpfs                             3939844         0   3939844   0% /sys/fs/cgroup
/dev/md126p1                       506752    312612    194140  62% /boot
/dev/mapper/centos_moohan-scr   858065536 360471280 497594256  43% /scr
/dev/mapper/centos_moohan-tmp    16371712    148912  16222800   1% /tmp
/dev/mapper/centos_moohan-var    16371712   5960772  10410940  37% /var
jam:/mnt/scr1                   961432576 837905408  74688512  92% /mnt/scr1
jam:/home                       198351872 100207616  87905280  54% /home
jam:/mnt/hdf                    961432576 909649920   2945024 100% /mnt/hdf
10.10.10.15:/volume1/readonly  1437485440 450589824 986793216  32% /mnt/ro-src
tmpfs                              787972        12    787960   1% /run/user/42
tmpfs                              787972         0    787972   0% /run/user/2519
tmpfs                              787972         0    787972   0% /run/user/0
tmpfs                              787972         0    787972   0% /run/user/27429
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
Sat Oct 14 22:08:03 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests in moohan ***
Uname -a: Linux moohan.ad.hdfgroup.org 3.10.0-327.10.1.el7.x86_64 #1 SMP Tue Feb 16 17:03:50 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/moohan_1014Sat_2208
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests for moohan ***
Sat Oct 14 22:09:22 CDT 2017
Total time = 1m 19s
*** finished tests in moohan ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
 22:07:56 up 320 days,  8:46,  2 users,  load average: 0.10, 0.55, 0.68
/dev/mapper/vg_ostrich-lv_root
                      140479384  26937880 106402460  21% /
tmpfs                   7821568         0   7821568   0% /dev/shm
/dev/sda2                487652    100521    361531  22% /boot
/dev/sdb2             124477364  89516632  28630980  76% /scr
jam:/mnt/hdf          961432576 909661184   2933760 100% /mnt/hdf
jam:/mnt/scr1         961432576 837905408  74689536  92% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Sat Oct 14 22:08:06 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-573.18.1.el6.ppc64 #1 SMP Wed Jan 6 11:15:06 EST 2016 ppc64 ppc64 ppc64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_1014Sat_2208
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Sat Oct 14 22:09:47 CDT 2017
Total time = 1m 41s
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich ***
   /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_1014Sat_2209
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich ***
Sat Oct 14 22:12:54 CDT 2017
Total time = 3m 7s
*** finished tests in ostrich ***
Testing quail
ssh -o ConnectTimeout=60 quail -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname quail
22:07  up 93 days, 12:40, 0 users, load averages: 1.28 1.42 1.47
Filesystem                    512-blocks       Used Available Capacity  iused     ifree %iused  Mounted on
/dev/disk0s2                   488555536  293300520 194743016    61% 36726563  24342877   60%   /
devfs                                362        362         0   100%      627         0  100%   /dev
map auto_nfs                           0          0         0   100%        0         0  100%   /home
map auto_nfs                           0          0         0   100%        0         0  100%   /mnt/hdf
map auto_nfs                           0          0         0   100%        0         0  100%   /mnt/scr1
jam.ad.hdfgroup.org:/mnt/scr1 1922864144 1675810128 149378016    92%  4079411 118030541    3%   /mnt/scr1
jam.ad.hdfgroup.org:/home      396703680  200416656 175810304    54%  1035432  50180952    2%   /home
jam.ad.hdfgroup.org:/mnt/hdf  1922864144 1819335768   5852376   100% 11832637 110277315   10%   /mnt/hdf
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Sat Oct 14 22:08:09 CDT 2017
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests in quail ***
Uname -a: Darwin quail.ad.hdfgroup.org 13.4.0 Darwin Kernel Version 13.4.0: Mon Jan 11 18:17:34 PST 2016; root:xnu-2422.115.15~1/RELEASE_X86_64 x86_64
   /Users/hdftest/snapshots-opa/log/quail_1014Sat_2208
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests for quail ***
Sat Oct 14 22:09:05 CDT 2017
Total time = 0m 56s
*** finished tests in quail ***
Testing kite
ssh -o ConnectTimeout=60 kite -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
snapshots-opa: No such file or directory.
BASEDIR (/Users/hdftest/snapshots-) does not exist
	****SYSTEM ERROR kite: BASEDIR (/Users/hdftest/snapshots-) does not exist
/mnt/scr1/SnapTest/snapshots-opa/bin/runtest: line 128: $SYSERRLOG: ambiguous redirect
****SYSTEM ERROR kite: Abnormal exit from runtest ****
	****SYSTEM ERROR kite: runtest command failed ****
More information about the opa-nightly-tests mailing list
