[opa-nightly-tests] jam OPA_Daily_Tests_1005Thu
HDF Tester
hdftest at hdfgroup.org
Thu Oct 5 22:14:59 CDT 2017
*** OPA Tests on 1005Thu ***
Tests Summary
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED moohan: standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
PASSED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
PASSED quail: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Tests Time Summary
koala: Ran 1(1/0/0) tests, Grand total test time = 0m 33s
platypus: Ran 1(1/0/0) tests, Grand total test time = 0m 44s
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 0s
quail: Ran 1(1/0/0) tests, Grand total test time = 0m 53s
moohan: Ran 1(1/0/0) tests, Grand total test time = 1m 18s
ostrich: Ran 2(2/0/0) tests, Grand total test time = 4m 34s
jam: Ran 7(0/0/0) hosts, Grand total test time = 5m 39s
Timekeeper log
Timekeeper started at Thu Oct 5 22:09:31 CDT 2017
Timekeeper sleeping for 720 seconds
Tests Failures
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
22:09:10 up 444 days, 8:51, 11 users, load average: 1.08, 0.73, 0.83
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 18910540 11189652 63% /
/dev/sda1 101086 17532 78335 19% /boot
/dev/sda2 31738420 4780512 25319680 16% /tmp
/dev/sda6 31738392 6832168 23268000 23% /var
/dev/sda7 31738392 18542628 11557540 62% /usr
/dev/sda8 124991068 192212 118347156 1% /var/tmp
/dev/mapper/VolGroup00-home
198351840 100170904 87942576 54% /home
/dev/sdc1 961432072 853885704 58708368 94% /mnt/scr1
/dev/sdd1 961432072 908172504 4421568 100% /mnt/hdf
tmpfs 8313628 0 8313628 0% /dev/shm
gumund:/data/ftp 480719104 364900224 91399680 80% /mnt/ftp
gumund:/data/web 480719104 364900224 91399680 80% /mnt/web
10.10.10.15:/volume1/hdf2
1437485440 450589824 986793216 32% /mnt/hdf2
10.10.10.15:/volume1/readonly
1437485440 450589824 986793216 32% /mnt/readonly
1437485440 450589824 986793216 32% /mnt/ro-src
1437485440 450589824 986793216 32% /mnt/rw-src
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_1005Thu
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1005Thu.17338: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1005Thu.17338': No such file or directory
*** launching tests from jam ***
TESTHOST is jam
koala
platypus
moohan
ostrich
quail
kite
Fork off timekeeper 12
Testing jam
ssh -o ConnectTimeout=60 jam -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
22:09:35 up 444 days, 8:51, 11 users, load average: 1.40, 0.84, 0.86
/dev/sda2 31738420 4780620 25319572 16% /tmp
/dev/sda6 31738392 6832208 23267960 23% /var
/dev/sdc1 961432072 853885732 58708340 94% /mnt/scr1
Extract source and run autogen if .
Thu Oct 5 22:09:45 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/jam_1005Thu_2209
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Thu Oct 5 22:10:45 CDT 2017
Total time = 1m 0s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
22:09:37 up 363 days, 8:28, 1 user, load average: 0.00, 0.00, 0.10
/dev/sda7 22292052 4427732 16713668 21% /
/dev/sda5 12192608 386136 11177128 4% /tmp
/dev/sda3 12192636 1015820 10547472 9% /var
/dev/sda1 101086 18614 77253 20% /boot
/dev/sdc1 41279536 26323756 12858900 68% /usr
/dev/sdb 152754284 69860964 75133860 49% /scr
tmpfs 6149552 0 6149552 0% /dev/shm
10.10.10.86:/home 198351872 100170752 87943168 54% /home
10.10.10.86:/mnt/hdf 961432576 908172288 4421632 100% /mnt/hdf
10.10.10.86:/mnt/scr1
961432576 853885952 58708992 94% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Thu Oct 5 22:09:48 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-409.el5 #1 SMP Tue Mar 15 18:13:50 EDT 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/koala_1005Thu_2209
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Thu Oct 5 22:10:20 CDT 2017
Total time = 0m 32s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
22:09:40 up 363 days, 8:20, 0 users, load average: 0.37, 0.79, 0.72
/dev/sda6 54205540 34305904 17139496 67% /
tmpfs 6099068 0 6099068 0% /dev/shm
/dev/sda1 194241 48310 135691 27% /boot
/dev/sda2 12850716 59352 12131908 1% /tmp
/dev/sda3 12850716 5672612 6518648 47% /var
/dev/sdd 152623212 129443788 15419964 90% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Thu Oct 5 22:09:50 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.22.1.el6.x86_64 #1 SMP Wed Mar 23 03:35:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/platypus_1005Thu_2209
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Thu Oct 5 22:10:34 CDT 2017
Total time = 0m 44s
*** finished tests in platypus ***
Testing moohan
ssh -o ConnectTimeout=60 moohan -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname moohan
22:09:43 up 308 days, 8:05, 2 users, load average: 0.01, 0.29, 0.51
/dev/mapper/centos_moohan-root 52196352 9572676 42623676 19% /
devtmpfs 3923072 0 3923072 0% /dev
tmpfs 3939844 84 3939760 1% /dev/shm
tmpfs 3939844 418852 3520992 11% /run
tmpfs 3939844 0 3939844 0% /sys/fs/cgroup
/dev/md126p1 506752 312612 194140 62% /boot
/dev/mapper/centos_moohan-scr 858065536 361823312 496242224 43% /scr
/dev/mapper/centos_moohan-tmp 16371712 98480 16273232 1% /tmp
/dev/mapper/centos_moohan-var 16371712 5886136 10485576 36% /var
jam:/mnt/scr1 961432576 853885952 58708992 94% /mnt/scr1
jam:/home 198351872 100170752 87943168 54% /home
jam:/mnt/hdf 961432576 908172288 4421632 100% /mnt/hdf
10.10.10.15:/volume1/readonly 1437485440 450589824 986793216 32% /mnt/ro-src
tmpfs 787972 12 787960 1% /run/user/42
tmpfs 787972 0 787972 0% /run/user/2519
tmpfs 787972 0 787972 0% /run/user/0
tmpfs 787972 0 787972 0% /run/user/27429
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
Thu Oct 5 22:09:53 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests in moohan ***
Uname -a: Linux moohan.ad.hdfgroup.org 3.10.0-327.10.1.el7.x86_64 #1 SMP Tue Feb 16 17:03:50 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/moohan_1005Thu_2209
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests for moohan ***
Thu Oct 5 22:11:11 CDT 2017
Total time = 1m 18s
*** finished tests in moohan ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
22:09:45 up 311 days, 8:48, 2 users, load average: 0.15, 0.77, 0.73
/dev/mapper/vg_ostrich-lv_root
140479384 27082460 106257880 21% /
tmpfs 7821568 0 7821568 0% /dev/shm
/dev/sda2 487652 100521 361531 22% /boot
/dev/sdb2 124477364 80818824 37328788 69% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Thu Oct 5 22:09:55 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-573.18.1.el6.ppc64 #1 SMP Wed Jan 6 11:15:06 EST 2016 ppc64 ppc64 ppc64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_1005Thu_2209
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Thu Oct 5 22:11:28 CDT 2017
Total time = 1m 33s
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich ***
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_1005Thu_2211
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich ***
Thu Oct 5 22:14:29 CDT 2017
Total time = 3m 1s
*** finished tests in ostrich ***
Testing quail
ssh -o ConnectTimeout=60 quail -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname quail
22:09 up 84 days, 12:42, 0 users, load averages: 1.60 1.65 1.48
Filesystem 512-blocks Used Available Capacity iused ifree %iused Mounted on
/dev/disk0s2 488555536 295710328 192333208 61% 37027789 24041651 61% /
devfs 362 362 0 100% 627 0 100% /dev
map auto_nfs 0 0 0 100% 0 0 100% /home
map auto_nfs 0 0 0 100% 0 0 100% /mnt/hdf
map auto_nfs 0 0 0 100% 0 0 100% /mnt/scr1
jam.ad.hdfgroup.org:/home 396703680 200341808 175885152 54% 1030815 50185569 2% /home
jam.ad.hdfgroup.org:/mnt/hdf 1922864144 1816345152 8842992 100% 11803620 110306332 10% /mnt/hdf
jam.ad.hdfgroup.org:/mnt/scr1 1922864144 1707770440 117417704 94% 4069502 118040450 3% /mnt/scr1
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Thu Oct 5 22:09:58 CDT 2017
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests in quail ***
Uname -a: Darwin quail.ad.hdfgroup.org 13.4.0 Darwin Kernel Version 13.4.0: Mon Jan 11 18:17:34 PST 2016; root:xnu-2422.115.15~1/RELEASE_X86_64 x86_64
/Users/hdftest/snapshots-opa/log/quail_1005Thu_2209
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests for quail ***
Thu Oct 5 22:10:50 CDT 2017
Total time = 0m 52s
*** finished tests in quail ***
Testing kite
ssh -o ConnectTimeout=60 kite -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
snapshots-opa: No such file or directory.
BASEDIR (/Users/hdftest/snapshots-) does not exist
Thu Oct 5 22:09:49 CDT 2017
****SYSTEM ERROR kite: BASEDIR (/Users/hdftest/snapshots-) does not exist
/mnt/scr1/SnapTest/snapshots-opa/bin/runtest: line 128: $SYSERRLOG: ambiguous redirect
****SYSTEM ERROR kite: Abnormal exit from runtest ****
****SYSTEM ERROR kite: runtest command failed ****
More information about the opa-nightly-tests
