[opa-nightly-tests] jam OPA_Daily_Tests_1001Sun
HDF Tester hdftest at hdfgroup.org
Sun Oct 1 18:12:11 CDT 2017
*** OPA Tests on 1001Sun ***
   Tests Summary
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED moohan: standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
PASSED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
PASSED quail: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
   Tests Time Summary
koala: Ran 1(1/0/0) tests, Grand total test time =  0m 33s
platypus: Ran 1(1/0/0) tests, Grand total test time =  0m 43s
jam: Ran 1(1/0/0) tests, Grand total test time =  1m 2s
quail: Ran 1(1/0/0) tests, Grand total test time =  0m 56s
moohan: Ran 1(1/0/0) tests, Grand total test time =  1m 19s
ostrich: Ran 2(2/0/0) tests, Grand total test time =  4m 34s
jam: Ran 7(0/0/0) hosts, Grand total test time =  5m 41s
   Timekeeper log
Timekeeper started at Sun Oct  1 18:06:41 CDT 2017
Timekeeper sleeping for 720 seconds
   Tests Failures
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 18:06:20 up 440 days,  4:48,  3 users,  load average: 0.05, 0.29, 0.45
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda3             31738420  18910540  11189652  63% /
/dev/sda1               101086     17532     78335  19% /boot
/dev/sda2             31738420   4762412  25337780  16% /tmp
/dev/sda6             31738392   6357380  23742788  22% /var
/dev/sda7             31738392  18542628  11557540  62% /usr
/dev/sda8            124991068    192208 118347160   1% /var/tmp
/dev/mapper/VolGroup00-home
                     198351840 100818196  87295284  54% /home
/dev/sdc1            961432072 853553316  59040756  94% /mnt/scr1
/dev/sdd1            961432072 901913008  10681064  99% /mnt/hdf
tmpfs                  8313628         0   8313628   0% /dev/shm
gumund:/data/ftp     480719104 364644352  91655552  80% /mnt/ftp
gumund:/data/web     480719104 364644352  91655552  80% /mnt/web
10.10.10.15:/volume1/hdf2
                     1437485440 450589824 986793216  32% /mnt/hdf2
10.10.10.15:/volume1/readonly
                     1437485440 450589824 986793216  32% /mnt/readonly
                     1437485440 450589824 986793216  32% /mnt/ro-src
                     1437485440 450589824 986793216  32% /mnt/rw-src
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_1001Sun
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1001Sun.5710: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1001Sun.5710': No such file or directory
*** launching tests from jam ***
TESTHOST is jam
koala
platypus
moohan
ostrich
quail
kite
    Fork off timekeeper 12
Testing jam
ssh -o ConnectTimeout=60 jam -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
 18:06:45 up 440 days,  4:48,  3 users,  load average: 0.17, 0.30, 0.45
/dev/sda2             31738420   4762520  25337672  16% /tmp
/dev/sda6             31738392   6357384  23742784  22% /var
/dev/sdc1            961432072 853553344  59040728  94% /mnt/scr1
Extract source and run autogen if .
Sun Oct  1 18:06:55 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
Running snapshot with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/jam_1001Sun_1806
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Sun Oct  1 18:07:57 CDT 2017
Total time = 1m 2s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
 18:06:47 up 359 days,  4:25,  1 user,  load average: 0.00, 0.00, 0.06
/dev/sda7             22292052   4427732  16713668  21% /
/dev/sda5             12192608    383800  11179464   4% /tmp
/dev/sda3             12192636   1005412  10557880   9% /var
/dev/sda1               101086     18614     77253  20% /boot
/dev/sdc1             41279536  26323756  12858900  68% /usr
/dev/sdb             152754284  69858420  75136404  49% /scr
tmpfs                  6149552         0   6149552   0% /dev/shm
10.10.10.86:/home    198351872 100817920  87296000  54% /home
10.10.10.86:/mnt/hdf 961432576 901912576  10681344  99% /mnt/hdf
10.10.10.86:/mnt/scr1
                     961432576 853553152  59040768  94% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Sun Oct  1 18:06:58 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-409.el5 #1 SMP Tue Mar 15 18:13:50 EDT 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/koala_1001Sun_1806
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Sun Oct  1 18:07:30 CDT 2017
Total time = 0m 32s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
 18:06:50 up 359 days,  4:17,  0 users,  load average: 0.32, 0.75, 0.67
/dev/sda6             54205540  34305904  17139496  67% /
tmpfs                  6099068         0   6099068   0% /dev/shm
/dev/sda1               194241     48310    135691  27% /boot
/dev/sda2             12850716    151932  12039328   2% /tmp
/dev/sda3             12850716   5781556   6409704  48% /var
/dev/sdd             152623212 130188912  14674840  90% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Sun Oct  1 18:07:00 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.22.1.el6.x86_64 #1 SMP Wed Mar 23 03:35:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/platypus_1001Sun_1807
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Sun Oct  1 18:07:43 CDT 2017
Total time = 0m 43s
*** finished tests in platypus ***
Testing moohan
ssh -o ConnectTimeout=60 moohan -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname moohan
 18:06:54 up 304 days,  4:02,  2 users,  load average: 0.07, 0.47, 0.58
/dev/mapper/centos_moohan-root   52196352   9572676  42623676  19% /
devtmpfs                          3923072         0   3923072   0% /dev
tmpfs                             3939844        84   3939760   1% /dev/shm
tmpfs                             3939844    435236   3504608  12% /run
tmpfs                             3939844         0   3939844   0% /sys/fs/cgroup
/dev/md126p1                       506752    312612    194140  62% /boot
/dev/mapper/centos_moohan-scr   858065536 361446008 496619528  43% /scr
/dev/mapper/centos_moohan-tmp    16371712    215488  16156224   2% /tmp
/dev/mapper/centos_moohan-var    16371712   5871688  10500024  36% /var
jam:/mnt/scr1                   961432576 853553152  59040768  94% /mnt/scr1
jam:/home                       198351872 100817920  87296000  54% /home
jam:/mnt/hdf                    961432576 901912576  10681344  99% /mnt/hdf
10.10.10.15:/volume1/readonly  1437485440 450589824 986793216  32% /mnt/ro-src
tmpfs                              787972        12    787960   1% /run/user/42
tmpfs                              787972         0    787972   0% /run/user/2519
tmpfs                              787972         0    787972   0% /run/user/0
tmpfs                              787972         0    787972   0% /run/user/27429
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
Sun Oct  1 18:07:04 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests in moohan ***
Uname -a: Linux moohan.ad.hdfgroup.org 3.10.0-327.10.1.el7.x86_64 #1 SMP Tue Feb 16 17:03:50 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/moohan_1001Sun_1807
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests for moohan ***
Sun Oct  1 18:08:23 CDT 2017
Total time = 1m 19s
*** finished tests in moohan ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
 18:06:57 up 307 days,  4:45,  0 users,  load average: 0.54, 0.98, 0.72
/dev/mapper/vg_ostrich-lv_root
                      140479384  25610384 107729956  20% /
tmpfs                   7821568         0   7821568   0% /dev/shm
/dev/sda2                487652    100521    361531  22% /boot
/dev/sdb2             124477364  80122932  38024680  68% /scr
jam:/mnt/scr1         961432576 853553152  59041792  94% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Sun Oct  1 18:07:07 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-573.18.1.el6.ppc64 #1 SMP Wed Jan 6 11:15:06 EST 2016 ppc64 ppc64 ppc64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_1001Sun_1807
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Sun Oct  1 18:08:39 CDT 2017
Total time = 1m 32s
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich ***
   /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_1001Sun_1808
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich ***
Sun Oct  1 18:11:41 CDT 2017
Total time = 3m 2s
*** finished tests in ostrich ***
Testing quail
ssh -o ConnectTimeout=60 quail -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname quail
18:06  up 80 days,  8:39, 0 users, load averages: 1.45 1.36 1.36
Filesystem                    512-blocks       Used Available Capacity  iused     ifree %iused  Mounted on
/dev/disk0s2                   488555536  292240240 195803296    60% 36594028  24475412   60%   /
devfs                                362        362         0   100%      627         0  100%   /dev
map auto_nfs                           0          0         0   100%        0         0  100%   /home
map auto_nfs                           0          0         0   100%        0         0  100%   /mnt/hdf
map auto_nfs                           0          0         0   100%        0         0  100%   /mnt/scr1
jam.ad.hdfgroup.org:/mnt/scr1 1922864144 1707106808 118081336    94%  4040370 118069582    3%   /mnt/scr1
jam.ad.hdfgroup.org:/mnt/hdf  1922864144 1803826016  21362128    99% 11781170 110328782   10%   /mnt/hdf
jam.ad.hdfgroup.org:/home      396703680  201636392 174590568    54%  1057661  50158723    2%   /home
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Sun Oct  1 18:07:09 CDT 2017
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests in quail ***
Uname -a: Darwin quail.ad.hdfgroup.org 13.4.0 Darwin Kernel Version 13.4.0: Mon Jan 11 18:17:34 PST 2016; root:xnu-2422.115.15~1/RELEASE_X86_64 x86_64
   /Users/hdftest/snapshots-opa/log/quail_1001Sun_1807
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests for quail ***
Sun Oct  1 18:08:05 CDT 2017
Total time = 0m 56s
*** finished tests in quail ***
Testing kite
ssh -o ConnectTimeout=60 kite -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
snapshots-opa: No such file or directory.
BASEDIR (/Users/hdftest/snapshots-) does not exist
	Sun Oct  1 18:07:03 CDT 2017
	****SYSTEM ERROR kite: BASEDIR (/Users/hdftest/snapshots-) does not exist
/mnt/scr1/SnapTest/snapshots-opa/bin/runtest: line 128: $SYSERRLOG: ambiguous redirect
****SYSTEM ERROR kite: Abnormal exit from runtest ****
	****SYSTEM ERROR kite: runtest command failed ****
More information about the opa-nightly-tests mailing list
