[opa-nightly-tests] jam OPA_Daily_Tests_0319Sun_FAILED!!!
HDF Tester
hdftest at hdfgroup.org
Sun Mar 19 19:18:30 CDT 2017
*** OPA Tests on 0319Sun ***
Tests Summary
****FAILED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam****
PASSED kite: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
PASSED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
PASSED quail: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Tests Time Summary
jam: Ran 1(0/1/0) tests, Grand total test time = 0m 6s
koala: Ran 1(1/0/0) tests, Grand total test time = 0m 33s
platypus: Ran 1(1/0/0) tests, Grand total test time = 0m 43s
kite: Ran 1(1/0/0) tests, Grand total test time = 0m 46s
quail: Ran 1(1/0/0) tests, Grand total test time = 0m 56s
ostrich: Ran 2(2/0/0) tests, Grand total test time = 4m 47s
jam: Ran 6(0/0/0) hosts, Grand total test time = 5m 50s
Timekeeper log
Timekeeper started at Sun Mar 19 19:12:50 CDT 2017
Timekeeper sleeping for 720 seconds
Tests Failures
Dumping logfile of jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/jam_0319Sun_1913
checking for support for gcc atomic intrinsics... no
checking for support for Windows NT atomic intrinsics... no
checking for support for Sun atomic operations library... no
checking whether to enable strict fairness checks... no
checking that generated files are newer than configure... done
configure: creating ./config.status
config.status: creating Makefile
config.status: creating src/Makefile
config.status: creating test/Makefile
config.status: creating openpa.pc
config.status: creating src/config.h
config.status: executing depfiles commands
config.status: executing libtool commands
sed: couldn't write 6 items to stdout: No space left on device
cp: writing `libtoolT': No space left on device
sed: couldn't write 48 items to stdout: No space left on device
config.status: WARNING: Unable to substitute extended shell functions in libtool
config.status: executing src/opa_config.h commands
config.status: creating src/opa_config.h - prefix OPA for src/config.h defines
./config.status: line 2085: printf: write error: No space left on device
./config.status: line 2086: printf: write error: No space left on device
./config.status: line 2087: printf: write error: No space left on device
./config.status: line 2088: printf: write error: No space left on device
./config.status: line 2089: printf: write error: No space left on device
./config.status: line 2090: printf: write error: No space left on device
./config.status: line 2091: printf: write error: No space left on device
./config.status: line 2092: printf: write error: No space left on device
./config.status: line 2094: printf: write error: No space left on device
./config.status: line 2095: printf: write error: No space left on device
./config.status: line 2096: printf: write error: No space left on device
./config.status: line 2097: printf: write error: No space left on device
sed: couldn't write 54 items to stdout: No space left on device
./config.status: line 2100: echo: write error: No space left on device
./config.status: line 2101: echo: write error: No space left on device
./config.status: line 2102: echo: write error: No space left on device
===== make: Sun Mar 19 19:13:10 CDT 2017 =====
Making all in src
gmake[1]: Entering directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/jam/src'
gmake all-am
gmake[2]: Entering directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/jam/src'
CC opa_primitives.lo
mv: cannot stat `.deps/opa_primitives.Tpo': No such file or directory
gmake[2]: *** [opa_primitives.lo] Error 1
gmake[2]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/jam/src'
gmake[1]: *** [all] Error 2
gmake[1]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/jam/src'
gmake: *** [all-recursive] Error 1
Failed running make
===== Exit bin/snapshot with status=2: Sun Mar 19 19:13:10 CDT 2017 =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
19:12:29 up 244 days, 5:54, 21 users, load average: 0.18, 0.35, 0.50
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 18910596 11189596 63% /
/dev/sda1 101086 17532 78335 19% /boot
/dev/sda2 31738420 201260 29898932 1% /tmp
/dev/sda6 31738392 6123828 23976340 21% /var
/dev/sda7 31738392 18544232 11555936 62% /usr
/dev/sda8 124991068 251336 118288032 1% /var/tmp
/dev/mapper/VolGroup00-home
198351840 96152660 91960820 52% /home
/dev/sdc1 961432072 912593896 176 100% /mnt/scr1
/dev/sdd1 961432072 863002912 49591160 95% /mnt/hdf
tmpfs 8313628 0 8313628 0% /dev/shm
gumund:/data/ftp 480719104 335524864 120775040 74% /mnt/ftp
gumund:/data/web 480719104 335524864 120775040 74% /mnt/web
10.10.10.15:/volume1/hdf2
1437485440 423727616 1013655424 30% /mnt/hdf2
10.10.10.15:/volume1/hdf3
1437485440 423727616 1013655424 30% /mnt/hdf3
10.10.10.15:/volume1/readonly
1437485440 423727616 1013655424 30% /mnt/readonly
1437485440 423727616 1013655424 30% /mnt/ro-src
1437485440 423727616 1013655424 30% /mnt/rw-src
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0319Sun
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0319Sun.19570: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0319Sun.19570': No such file or directory
*** launching tests from jam ***
TESTHOST is jam
koala
platypus
ostrich
quail
kite
Fork off timekeeper 12
Testing jam
ssh -o ConnectTimeout=60 jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
19:12:54 up 244 days, 5:55, 21 users, load average: 0.26, 0.35, 0.49
/dev/sda2 31738420 201368 29898824 1% /tmp
/dev/sda6 31738392 6123812 23976356 21% /var
/dev/sdc1 961432072 912593924 148 100% /mnt/scr1
Extract source and run autogen if .
Sun Mar 19 19:13:04 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
Running snapshot with output saved in
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Total time = 0m 6s
*** finished tests in jam ***
****SYSTEM ERROR jam: Abnormal exit from runtest ****
Sun Mar 19 19:18:29 CDT 2017
****SYSTEM ERROR jam: runtest command failed ****
Testing koala
ssh -o ConnectTimeout=60 koala -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
19:12:57 up 163 days, 5:32, 1 user, load average: 1.03, 0.67, 0.46
/dev/sda7 22292052 4427696 16713704 21% /
/dev/sda5 12192608 385156 11178108 4% /tmp
/dev/sda3 12192636 1009260 10554032 9% /var
/dev/sda1 101086 18614 77253 20% /boot
/dev/sdc1 41279536 26316696 12865960 68% /usr
/dev/sdb 152754284 68408420 76586404 48% /scr
tmpfs 6149552 0 6149552 0% /dev/shm
10.10.10.86:/home 198351872 96152576 91961344 52% /home
10.10.10.86:/mnt/hdf 961432576 863002624 49591296 95% /mnt/hdf
10.10.10.86:/mnt/scr1
961432576 912593920 1024 100% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Sun Mar 19 19:13:07 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-409.el5 #1 SMP Tue Mar 15 18:13:50 EDT 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/koala_0319Sun_1913
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Sun Mar 19 19:13:40 CDT 2017
Total time = 0m 33s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
19:12:59 up 163 days, 5:23, 4 users, load average: 0.48, 0.88, 0.97
/dev/sda6 54205540 29781956 21663444 58% /
tmpfs 6099068 0 6099068 0% /dev/shm
/dev/sda1 194241 48310 135691 27% /boot
/dev/sda2 12850716 240524 11950736 2% /tmp
/dev/sda3 12850716 5339180 6852080 44% /var
/dev/sdd 152623212 131673764 13189988 91% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.22.1.el6.x86_64 #1 SMP Wed Mar 23 03:35:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/platypus_0319Sun_1913
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Sun Mar 19 19:13:52 CDT 2017
Total time = 0m 43s
*** finished tests in platypus ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
19:13:02 up 111 days, 5:51, 1 user, load average: 0.60, 1.04, 0.94
/dev/mapper/vg_ostrich-lv_root
140479384 23869980 109470360 18% /
tmpfs 7821568 0 7821568 0% /dev/shm
/dev/sda2 487652 100521 361531 22% /boot
/dev/sdb2 124477364 95869712 22277900 82% /scr
jam:/home 198351872 96152576 91961344 52% /home
jam:/mnt/hdf 961432576 863002624 49591296 95% /mnt/hdf
jam:/mnt/scr1 961432576 912593920 1024 100% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Sun Mar 19 19:13:12 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-573.18.1.el6.ppc64 #1 SMP Wed Jan 6 11:15:06 EST 2016 ppc64 ppc64 ppc64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0319Sun_1913
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Sun Mar 19 19:14:51 CDT 2017
Total time = 1m 39s
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich ***
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0319Sun_1914
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich ***
Sun Mar 19 19:17:59 CDT 2017
Total time = 3m 8s
*** finished tests in ostrich ***
Testing quail
ssh -o ConnectTimeout=60 quail -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname quail
19:13 up 52 days, 2:27, 1 user, load averages: 1.75 1.66 1.73
Filesystem 512-blocks Used Available Capacity iused ifree %iused Mounted on
/dev/disk0s2 488555536 305325768 182717768 63% 38229719 22839721 63% /
devfs 364 364 0 100% 630 0 100% /dev
map auto_nfs 0 0 0 100% 0 0 100% /home
map auto_nfs 0 0 0 100% 0 0 100% /mnt/hdf
map auto_nfs 0 0 0 100% 0 0 100% /mnt/scr1
jam.ad.hdfgroup.org:/mnt/scr1 1922864144 1825187912 232 100% 4168046 117941906 3% /mnt/scr1
jam.ad.hdfgroup.org:/home 396703680 192305320 183921640 52% 1046220 50170164 2% /home
jam.ad.hdfgroup.org:/mnt/hdf 1922864144 1726005824 99182320 95% 11488083 110621869 9% /mnt/hdf
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Sun Mar 19 19:13:13 CDT 2017
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests in quail ***
Uname -a: Darwin quail.ad.hdfgroup.org 13.4.0 Darwin Kernel Version 13.4.0: Mon Jan 11 18:17:34 PST 2016; root:xnu-2422.115.15~1/RELEASE_X86_64 x86_64
/Users/hdftest/snapshots-opa/log/quail_0319Sun_1913
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests for quail ***
Sun Mar 19 19:14:09 CDT 2017
Total time = 0m 56s
*** finished tests in quail ***
Testing kite
ssh -o ConnectTimeout=60 kite -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
19:13 up 3 days, 8:09, 0 users, load averages: 0.23 0.57 0.55
/dev/disk0s2 1951845952 261955080 1689378872 14% 32808383 211172359 13% /
devfs 372 372 0 100% 645 0 100% /dev
/dev/disk1s2 1952853344 1296624 1951556720 1% 162076 243944590 0% /Volumes/Milvinae
10.10.10.86:/mnt/scr1 1922864144 1825186824 1320 100% 4168034 117941918 3% /mnt/scr1
10.10.10.86:/home 396703680 192305320 183921640 52% 1046220 50170164 2% /home
10.10.10.86:/mnt/hdf 1922864144 1726005824 99182320 95% 11488083 110621869 9% /mnt/hdf
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
Sun Mar 19 19:13:16 CDT 2017
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests in kite ***
Uname -a: Darwin kite.ad.hdfgroup.org 12.6.0 Darwin Kernel Version 12.6.0: Wed Mar 18 16:23:48 PDT 2015; root:xnu-2050.48.19~1/RELEASE_X86_64 x86_64
/Users/hdftest/snapshots-opa/log/kite_0319Sun_1913
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests for kite ***
Sun Mar 19 19:14:02 CDT 2017
Total time = 0m 46s
*** finished tests in kite ***
More information about the opa-nightly-tests
