[opa-nightly-tests] jam OPA_Daily_Tests_0730Sun
HDF Tester
hdftest at hdfgroup.org
Sun Jul 30 21:45:02 CDT 2017
*** OPA Tests on 0730Sun ***
Tests Summary
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED moohan: standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
PASSED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
PASSED quail: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Tests Time Summary
koala: Ran 1(1/0/0) tests, Grand total test time = 0m 33s
platypus: Ran 1(1/0/0) tests, Grand total test time = 0m 45s
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 1s
quail: Ran 1(1/0/0) tests, Grand total test time = 0m 55s
moohan: Ran 1(1/0/0) tests, Grand total test time = 1m 19s
ostrich: Ran 2(2/0/0) tests, Grand total test time = 5m 16s
jam: Ran 7(0/0/0) hosts, Grand total test time = 6m 22s
Timekeeper log
Timekeeper started at Sun Jul 30 21:38:51 CDT 2017
Timekeeper sleeping for 720 seconds
Tests Failures
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
21:38:30 up 377 days, 8:20, 9 users, load average: 0.27, 0.79, 0.88
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 18910540 11189652 63% /
/dev/sda1 101086 17532 78335 19% /boot
/dev/sda2 31738420 218772 29881420 1% /tmp
/dev/sda6 31738392 5966624 24133544 20% /var
/dev/sda7 31738392 18542628 11557540 62% /usr
/dev/sda8 124991068 192220 118347148 1% /var/tmp
/dev/mapper/VolGroup00-home
198351840 100614588 87498892 54% /home
/dev/sdc1 961432072 853420732 59173340 94% /mnt/scr1
/dev/sdd1 961432072 886899560 25694512 98% /mnt/hdf
tmpfs 8313628 0 8313628 0% /dev/shm
gumund:/data/ftp 480719104 355878016 100421888 78% /mnt/ftp
gumund:/data/web 480719104 355878016 100421888 78% /mnt/web
10.10.10.15:/volume1/hdf2
1437485440 450495360 986887680 32% /mnt/hdf2
10.10.10.15:/volume1/hdf3
1437485440 450495360 986887680 32% /mnt/hdf3
10.10.10.15:/volume1/readonly
1437485440 450495360 986887680 32% /mnt/readonly
1437485440 450495360 986887680 32% /mnt/ro-src
1437485440 450495360 986887680 32% /mnt/rw-src
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0730Sun
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0730Sun.13959: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0730Sun.13959': No such file or directory
*** launching tests from jam ***
TESTHOST is jam
koala
platypus
moohan
ostrich
quail
kite
Fork off timekeeper 12
Testing jam
ssh -o ConnectTimeout=60 jam -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
21:38:56 up 377 days, 8:21, 9 users, load average: 0.40, 0.77, 0.87
/dev/sda2 31738420 218880 29881312 1% /tmp
/dev/sda6 31738392 5966588 24133580 20% /var
/dev/sdc1 961432072 853420760 59173312 94% /mnt/scr1
Extract source and run autogen if .
Sun Jul 30 21:39:06 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/jam_0730Sun_2139
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Sun Jul 30 21:40:07 CDT 2017
Total time = 1m 1s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
21:38:58 up 296 days, 7:58, 1 user, load average: 0.99, 0.73, 0.54
/dev/sda7 22292052 4427724 16713676 21% /
/dev/sda5 12192608 389620 11173644 4% /tmp
/dev/sda3 12192636 1010764 10552528 9% /var
/dev/sda1 101086 18614 77253 20% /boot
/dev/sdc1 41279536 26323756 12858900 68% /usr
/dev/sdb 152754284 70333204 74661620 49% /scr
tmpfs 6149552 0 6149552 0% /dev/shm
10.10.10.86:/home 198351872 100614144 87499776 54% /home
10.10.10.86:/mnt/hdf 961432576 886899712 25695232 98% /mnt/hdf
10.10.10.86:/mnt/scr1
961432576 853421056 59173888 94% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Sun Jul 30 21:39:08 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-409.el5 #1 SMP Tue Mar 15 18:13:50 EDT 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/koala_0730Sun_2139
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Sun Jul 30 21:39:41 CDT 2017
Total time = 0m 33s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
21:39:01 up 296 days, 7:49, 3 users, load average: 0.25, 0.46, 0.61
/dev/sda6 54205540 34305904 17139496 67% /
tmpfs 6099068 0 6099068 0% /dev/shm
/dev/sda1 194241 48310 135691 27% /boot
/dev/sda2 12850716 65900 12125360 1% /tmp
/dev/sda3 12850716 5731816 6459444 48% /var
/dev/sdd 152623212 128534944 16328808 89% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Sun Jul 30 21:39:11 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.22.1.el6.x86_64 #1 SMP Wed Mar 23 03:35:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/platypus_0730Sun_2139
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Sun Jul 30 21:39:56 CDT 2017
Total time = 0m 45s
*** finished tests in platypus ***
Testing moohan
ssh -o ConnectTimeout=60 moohan -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname moohan
21:39:03 up 241 days, 7:34, 2 users, load average: 0.02, 0.27, 0.50
/dev/mapper/centos_moohan-root 52196352 9572676 42623676 19% /
devtmpfs 3923072 0 3923072 0% /dev
tmpfs 3939844 84 3939760 1% /dev/shm
tmpfs 3939844 443460 3496384 12% /run
tmpfs 3939844 0 3939844 0% /sys/fs/cgroup
/dev/md126p1 506752 312612 194140 62% /boot
/dev/mapper/centos_moohan-scr 858065536 357274872 500790664 42% /scr
/dev/mapper/centos_moohan-tmp 16371712 98652 16273060 1% /tmp
/dev/mapper/centos_moohan-var 16371712 5893960 10477752 37% /var
jam:/mnt/scr1 961432576 853421056 59173888 94% /mnt/scr1
jam:/home 198351872 100614144 87499776 54% /home
jam:/mnt/hdf 961432576 886899712 25695232 98% /mnt/hdf
10.10.10.15:/volume1/readonly 1437485440 450495360 986887680 32% /mnt/ro-src
tmpfs 787972 12 787960 1% /run/user/42
tmpfs 787972 0 787972 0% /run/user/2519
tmpfs 787972 0 787972 0% /run/user/0
tmpfs 787972 0 787972 0% /run/user/29138
tmpfs 787972 0 787972 0% /run/user/27429
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
Sun Jul 30 21:39:14 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests in moohan ***
Uname -a: Linux moohan.ad.hdfgroup.org 3.10.0-327.10.1.el7.x86_64 #1 SMP Tue Feb 16 17:03:50 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/moohan_0730Sun_2139
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests for moohan ***
Sun Jul 30 21:40:32 CDT 2017
Total time = 1m 18s
*** finished tests in moohan ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
21:39:06 up 244 days, 8:17, 4 users, load average: 22.09, 22.08, 21.35
/dev/mapper/vg_ostrich-lv_root
140479384 24800560 108539780 19% /
tmpfs 7821568 0 7821568 0% /dev/shm
/dev/sda2 487652 100521 361531 22% /boot
/dev/sdb2 124477364 99403072 18744540 85% /scr
jam:/mnt/scr1 961432576 853420032 59173888 94% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Sun Jul 30 21:39:16 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-573.18.1.el6.ppc64 #1 SMP Wed Jan 6 11:15:06 EST 2016 ppc64 ppc64 ppc64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0730Sun_2139
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Sun Jul 30 21:41:00 CDT 2017
Total time = 1m 44s
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich ***
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0730Sun_2141
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich ***
Sun Jul 30 21:44:32 CDT 2017
Total time = 3m 32s
*** finished tests in ostrich ***
Testing quail
ssh -o ConnectTimeout=60 quail -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname quail
21:39 up 17 days, 12:08, 0 users, load averages: 1.80 1.72 1.66
Filesystem 512-blocks Used Available Capacity iused ifree %iused Mounted on
/dev/disk0s2 488555536 285495056 202548480 59% 35750880 25318560 59% /
devfs 362 362 0 100% 628 0 100% /dev
map auto_nfs 0 0 0 100% 0 0 100% /home
map auto_nfs 0 0 0 100% 0 0 100% /mnt/hdf
map auto_nfs 0 0 0 100% 0 0 100% /mnt/scr1
jam.ad.hdfgroup.org:/mnt/hdf 1922864144 1773799120 51389024 98% 11696973 110412979 10% /mnt/hdf
jam.ad.hdfgroup.org:/mnt/scr1 1922864144 1706840648 118347496 94% 4042167 118067785 3% /mnt/scr1
jam.ad.hdfgroup.org:/home 396703680 201229176 174997784 54% 1044724 50171660 2% /home
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Sun Jul 30 21:39:18 CDT 2017
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests in quail ***
Uname -a: Darwin quail.ad.hdfgroup.org 13.4.0 Darwin Kernel Version 13.4.0: Mon Jan 11 18:17:34 PST 2016; root:xnu-2422.115.15~1/RELEASE_X86_64 x86_64
/Users/hdftest/snapshots-opa/log/quail_0730Sun_2139
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests for quail ***
Sun Jul 30 21:40:13 CDT 2017
Total time = 0m 55s
*** finished tests in quail ***
Testing kite
ssh -o ConnectTimeout=60 kite -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
snapshots-opa: No such file or directory.
BASEDIR (/Users/hdftest/snapshots-) does not exist
****SYSTEM ERROR kite: BASEDIR (/Users/hdftest/snapshots-) does not exist
/mnt/scr1/SnapTest/snapshots-opa/bin/runtest: line 128: $SYSERRLOG: ambiguous redirect
****SYSTEM ERROR kite: Abnormal exit from runtest ****
****SYSTEM ERROR kite: runtest command failed ****
More information about the opa-nightly-tests
