[opa-nightly-tests] jam OPA_Daily_Tests_0706Thu_FAILED!!!
HDF Tester
hdftest at hdfgroup.org
Thu Jul 6 21:32:55 CDT 2017
*** OPA Tests on 0706Thu ***
Tests Summary
****FAILED quail: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail****
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
PASSED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Tests Time Summary
quail: Ran 1(0/1/0) tests, Grand total test time = 0m 1s
koala: Ran 1(1/0/0) tests, Grand total test time = 0m 34s
platypus: Ran 1(1/0/0) tests, Grand total test time = 0m 45s
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 0s
ostrich: Ran 2(2/0/0) tests, Grand total test time = 4m 43s
jam: Ran 5(0/0/0) hosts, Grand total test time = 5m 46s
Timekeeper log
Timekeeper started at Thu Jul 6 21:27:20 CDT 2017
Timekeeper sleeping for 720 seconds
Tests Failures
Dumping logfile of quail: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Last 50 lines of /Users/hdftest/snapshots-opa/log/quail_0706Thu_2127
checking whether gnumake sets $(MAKE)... yes
checking for style of include used by gnumake... GNU
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... /Users/hdftest/snapshots-opa/current/configure: line 3646: cannot create temp file for here document: No space left on device
/Users/hdftest/snapshots-opa/current/configure: line 3662: cannot create temp file for here document: No space left on device
no
checking for gcc option to accept ISO C89... /Users/hdftest/snapshots-opa/current/configure: line 3707: cannot create temp file for here document: No space left on device
/Users/hdftest/snapshots-opa/current/configure: line 1535: conftest.err: No space left on device
sed: conftest.c: No such file or directory
unsupported
checking dependency style of gcc... mkdir: conftest.dir: No space left on device
cp: conftest.dir: No space left on device
/Users/hdftest/snapshots-opa/current/configure: line 3814: cd: conftest.dir: No such file or directory
mkdir: sub: No space left on device
/Users/hdftest/snapshots-opa/current/configure: line 3825: ./depcomp: No such file or directory
none
checking for ar... ar
checking the archiver (ar) interface... /Users/hdftest/snapshots-opa/current/configure: line 4033: cannot create temp file for here document: No space left on device
ar
checking build system type... mkdir: /var/folders/z6/3ppqwg7d6391tvvxflm75638000ts5/T//cg8270-9186: No space left on device
mkdir: /var/folders/z6/3ppqwg7d6391tvvxflm75638000ts5/T//cg-8270: No space left on device
config.guess: cannot create a temporary directory in /var/folders/z6/3ppqwg7d6391tvvxflm75638000ts5/T/
configure: error: cannot guess build type; you must specify one
sort: fflush failed: standard output: No space left on device
sort: write error
/Users/hdftest/snapshots-opa/current/configure: line 374: echo: write error: No space left on device
/Users/hdftest/snapshots-opa/current/configure: line 402: printf: write error: No space left on device
Failed running configure
===== Exit bin/snapshot with status=1: Thu Jul 6 21:27:45 CDT 2017 =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
21:26:59 up 353 days, 8:09, 16 users, load average: 1.35, 1.34, 0.91
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 18910536 11189656 63% /
/dev/sda1 101086 17532 78335 19% /boot
/dev/sda2 31738420 218104 29882088 1% /tmp
/dev/sda6 31738392 6257276 23842892 21% /var
/dev/sda7 31738392 18542628 11557540 62% /usr
/dev/sda8 124991068 192216 118347152 1% /var/tmp
/dev/mapper/VolGroup00-home
198351840 100748620 87364860 54% /home
/dev/sdc1 961432072 840488460 72105612 93% /mnt/scr1
/dev/sdd1 961432072 877011468 35582604 97% /mnt/hdf
tmpfs 8313628 0 8313628 0% /dev/shm
gumund:/data/ftp 480719104 352625280 103674624 78% /mnt/ftp
gumund:/data/web 480719104 352625280 103674624 78% /mnt/web
10.10.10.15:/volume1/hdf2
1437485440 450495360 986887680 32% /mnt/hdf2
10.10.10.15:/volume1/hdf3
1437485440 450495360 986887680 32% /mnt/hdf3
10.10.10.15:/volume1/readonly
1437485440 450495360 986887680 32% /mnt/readonly
1437485440 450495360 986887680 32% /mnt/ro-src
1437485440 450495360 986887680 32% /mnt/rw-src
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0706Thu
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0706Thu.21788: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0706Thu.21788': No such file or directory
*** launching tests from jam ***
TESTHOST is jam
koala
platypus
ostrich
quail
Fork off timekeeper 12
Testing jam
ssh -o ConnectTimeout=60 jam -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
21:27:25 up 353 days, 8:09, 16 users, load average: 1.50, 1.37, 0.93
/dev/sda2 31738420 218212 29881980 1% /tmp
/dev/sda6 31738392 6257344 23842824 21% /var
/dev/sdc1 961432072 840488488 72105584 93% /mnt/scr1
/dev/sdd1 961432072 877011500 35582572 97% /mnt/hdf
Extract source and run autogen if .
Thu Jul 6 21:27:35 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/jam_0706Thu_2127
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Thu Jul 6 21:28:35 CDT 2017
Total time = 1m 0s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
21:27:27 up 272 days, 7:46, 1 user, load average: 0.03, 0.42, 0.52
/dev/sda7 22292052 4427720 16713680 21% /
/dev/sda5 12192608 386868 11176396 4% /tmp
/dev/sda3 12192636 1009480 10553812 9% /var
/dev/sda1 101086 18614 77253 20% /boot
/dev/sdc1 41279536 26323756 12858900 68% /usr
/dev/sdb 152754284 69885848 75108976 49% /scr
tmpfs 6149552 0 6149552 0% /dev/shm
10.10.10.86:/home 198351872 100748288 87365632 54% /home
10.10.10.86:/mnt/hdf 961432576 877011968 35582976 97% /mnt/hdf
10.10.10.86:/mnt/scr1
961432576 840488960 72105984 93% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Thu Jul 6 21:27:37 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-409.el5 #1 SMP Tue Mar 15 18:13:50 EDT 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/koala_0706Thu_2127
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Thu Jul 6 21:28:11 CDT 2017
Total time = 0m 34s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
21:27:30 up 272 days, 7:38, 3 users, load average: 0.51, 0.79, 0.69
/dev/sda6 54205540 34280424 17164976 67% /
tmpfs 6099068 0 6099068 0% /dev/shm
/dev/sda1 194241 48310 135691 27% /boot
/dev/sda2 12850716 61384 12129876 1% /tmp
/dev/sda3 12850716 6044032 6147228 50% /var
/dev/sdd 152623212 125057576 19806176 87% /scr
10.10.10.86:/mnt/hdf 961432576 877015040 35578880 97% /mnt/hdf
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Thu Jul 6 21:27:40 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.22.1.el6.x86_64 #1 SMP Wed Mar 23 03:35:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/platypus_0706Thu_2127
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Thu Jul 6 21:28:25 CDT 2017
Total time = 0m 45s
*** finished tests in platypus ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
21:27:32 up 220 days, 8:05, 1 user, load average: 0.16, 0.70, 0.55
/dev/mapper/vg_ostrich-lv_root
140479384 24286384 109053956 19% /
tmpfs 7821568 0 7821568 0% /dev/shm
/dev/sda2 487652 100521 361531 22% /boot
/dev/sdb2 124477364 98189400 19958212 84% /scr
jam:/home 198351872 100748288 87365632 54% /home
jam:/mnt/hdf 961432576 877020160 35574784 97% /mnt/hdf
jam:/mnt/scr1 961432576 840488960 72105984 93% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Thu Jul 6 21:27:42 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-573.18.1.el6.ppc64 #1 SMP Wed Jan 6 11:15:06 EST 2016 ppc64 ppc64 ppc64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0706Thu_2127
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Thu Jul 6 21:29:20 CDT 2017
Total time = 1m 38s
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich ***
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0706Thu_2129
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich ***
Thu Jul 6 21:32:25 CDT 2017
Total time = 3m 5s
*** finished tests in ostrich ***
Testing quail
ssh -o ConnectTimeout=60 quail -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname quail
21:27 up 161 days, 4:46, 2 users, load averages: 1.28 1.67 2.11
Filesystem 512-blocks Used Available Capacity iused ifree %iused Mounted on
/dev/disk0s2 488555536 488043672 0 100% 61069440 0 100% /
devfs 364 364 0 100% 631 0 100% /dev
map auto_nfs 0 0 0 100% 0 0 100% /home
map auto_nfs 0 0 0 100% 0 0 100% /mnt/hdf
map auto_nfs 0 0 0 100% 0 0 100% /mnt/scr1
jam.ad.hdfgroup.org:/mnt/scr1 1922864144 1680977032 144211112 93% 4045019 118064933 3% /mnt/scr1
jam.ad.hdfgroup.org:/home 396703680 201497240 174729720 54% 1036074 50180310 2% /home
jam.ad.hdfgroup.org:/mnt/hdf 1922864144 1754047480 71140664 97% 11693575 110416377 10% /mnt/hdf
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Thu Jul 6 21:27:44 CDT 2017
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests in quail ***
Uname -a: Darwin quail.ad.hdfgroup.org 13.4.0 Darwin Kernel Version 13.4.0: Mon Jan 11 18:17:34 PST 2016; root:xnu-2422.115.15~1/RELEASE_X86_64 x86_64
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests for quail ***
Total time = 0m 1s
*** finished tests in quail ***
****SYSTEM ERROR quail: Abnormal exit from runtest ****
****SYSTEM ERROR quail: runtest command failed ****
More information about the opa-nightly-tests
