[opa-nightly-tests] jam OPA_Daily_Tests_0823Wed
HDF Tester
hdftest at hdfgroup.org
Wed Aug 23 18:04:04 CDT 2017
*** OPA Tests on 0823Wed ***
Tests Summary
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED moohan: standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
PASSED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
PASSED quail: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Tests Time Summary
koala: Ran 1(1/0/0) tests, Grand total test time = 0m 32s
platypus: Ran 1(1/0/0) tests, Grand total test time = 0m 46s
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 3s
quail: Ran 1(1/0/0) tests, Grand total test time = 0m 56s
moohan: Ran 1(1/0/0) tests, Grand total test time = 1m 18s
ostrich: Ran 2(2/0/0) tests, Grand total test time = 4m 41s
jam: Ran 7(0/0/0) hosts, Grand total test time = 5m 48s
Timekeeper log
Timekeeper started at Wed Aug 23 17:58:27 CDT 2017
Timekeeper sleeping for 720 seconds
Tests Failures
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
17:58:06 up 401 days, 4:40, 15 users, load average: 0.01, 0.32, 0.54
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 18910540 11189652 63% /
/dev/sda1 101086 17532 78335 19% /boot
/dev/sda2 31738420 213272 29886920 1% /tmp
/dev/sda6 31738392 6344248 23755920 22% /var
/dev/sda7 31738392 18542628 11557540 62% /usr
/dev/sda8 124991068 192220 118347148 1% /var/tmp
/dev/mapper/VolGroup00-home
198351840 101444012 86669468 54% /home
/dev/sdc1 961432072 845735828 66858244 93% /mnt/scr1
/dev/sdd1 961432072 888505712 24088360 98% /mnt/hdf
tmpfs 8313628 0 8313628 0% /dev/shm
gumund:/data/ftp 480719104 361702400 94597504 80% /mnt/ftp
gumund:/data/web 480719104 361702400 94597504 80% /mnt/web
10.10.10.15:/volume1/hdf2
1437485440 450495360 986887680 32% /mnt/hdf2
10.10.10.15:/volume1/hdf3
1437485440 450495360 986887680 32% /mnt/hdf3
10.10.10.15:/volume1/readonly
1437485440 450495360 986887680 32% /mnt/readonly
1437485440 450495360 986887680 32% /mnt/ro-src
1437485440 450495360 986887680 32% /mnt/rw-src
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0823Wed
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0823Wed.12406: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0823Wed.12406': No such file or directory
*** launching tests from jam ***
TESTHOST is jam
koala
platypus
moohan
ostrich
quail
kite
Fork off timekeeper 12
Testing jam
ssh -o ConnectTimeout=60 jam -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
17:58:32 up 401 days, 4:40, 15 users, load average: 0.15, 0.33, 0.54
/dev/sda2 31738420 213384 29886808 1% /tmp
/dev/sdc1 961432072 845735856 66858216 93% /mnt/scr1
Extract source and run autogen if .
Wed Aug 23 17:58:42 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/jam_0823Wed_1758
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Wed Aug 23 17:59:45 CDT 2017
Total time = 1m 3s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
17:58:34 up 320 days, 4:17, 1 user, load average: 0.00, 0.02, 0.12
/dev/sda7 22292052 4427724 16713676 21% /
/dev/sda5 12192608 380968 11182296 4% /tmp
/dev/sda3 12192636 1013116 10550176 9% /var
/dev/sda1 101086 18614 77253 20% /boot
/dev/sdc1 41279536 26323756 12858900 68% /usr
/dev/sdb 152754284 69846584 75148240 49% /scr
tmpfs 6149552 0 6149552 0% /dev/shm
10.10.10.86:/home 198351872 101443584 86670336 54% /home
10.10.10.86:/mnt/hdf 961432576 888505344 24088576 98% /mnt/hdf
10.10.10.86:/mnt/scr1
961432576 845735936 66859008 93% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Wed Aug 23 17:58:44 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-409.el5 #1 SMP Tue Mar 15 18:13:50 EDT 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/koala_0823Wed_1758
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Wed Aug 23 17:59:16 CDT 2017
Total time = 0m 32s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
17:58:37 up 320 days, 4:09, 5 users, load average: 0.42, 0.73, 0.68
/dev/sda6 54205540 34305904 17139496 67% /
tmpfs 6099068 0 6099068 0% /dev/shm
/dev/sda1 194241 48310 135691 27% /boot
/dev/sda2 12850716 157680 12033580 2% /tmp
/dev/sda3 12850716 5361672 6829588 44% /var
/dev/sdd 152623212 131687712 13176040 91% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Wed Aug 23 17:58:47 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.22.1.el6.x86_64 #1 SMP Wed Mar 23 03:35:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/platypus_0823Wed_1758
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Wed Aug 23 17:59:33 CDT 2017
Total time = 0m 46s
*** finished tests in platypus ***
Testing moohan
ssh -o ConnectTimeout=60 moohan -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname moohan
17:58:40 up 265 days, 3:53, 2 users, load average: 0.20, 0.52, 0.59
/dev/mapper/centos_moohan-root 52196352 9572676 42623676 19% /
devtmpfs 3923072 0 3923072 0% /dev
tmpfs 3939844 84 3939760 1% /dev/shm
tmpfs 3939844 402500 3537344 11% /run
tmpfs 3939844 0 3939844 0% /sys/fs/cgroup
/dev/md126p1 506752 312612 194140 62% /boot
/dev/mapper/centos_moohan-scr 858065536 360078128 497987408 42% /scr
/dev/mapper/centos_moohan-tmp 16371712 219280 16152432 2% /tmp
/dev/mapper/centos_moohan-var 16371712 5846172 10525540 36% /var
jam:/mnt/scr1 961432576 845735936 66859008 93% /mnt/scr1
jam:/home 198351872 101443584 86670336 54% /home
jam:/mnt/hdf 961432576 888505344 24088576 98% /mnt/hdf
10.10.10.15:/volume1/readonly 1437485440 450495360 986887680 32% /mnt/ro-src
tmpfs 787972 12 787960 1% /run/user/42
tmpfs 787972 0 787972 0% /run/user/2519
tmpfs 787972 0 787972 0% /run/user/0
tmpfs 787972 0 787972 0% /run/user/29138
tmpfs 787972 0 787972 0% /run/user/27429
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
Wed Aug 23 17:58:50 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests in moohan ***
Uname -a: Linux moohan.ad.hdfgroup.org 3.10.0-327.10.1.el7.x86_64 #1 SMP Tue Feb 16 17:03:50 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/moohan_0823Wed_1758
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests for moohan ***
Wed Aug 23 18:00:08 CDT 2017
Total time = 1m 18s
*** finished tests in moohan ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
17:58:43 up 268 days, 4:37, 2 users, load average: 0.24, 0.85, 0.95
/dev/mapper/vg_ostrich-lv_root
140479384 24588684 108751656 19% /
tmpfs 7821568 0 7821568 0% /dev/shm
/dev/sda2 487652 100521 361531 22% /boot
/dev/sdb2 124477364 97586416 20561196 83% /scr
jam:/mnt/scr1 961432576 845734912 66859008 93% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Wed Aug 23 17:58:53 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-573.18.1.el6.ppc64 #1 SMP Wed Jan 6 11:15:06 EST 2016 ppc64 ppc64 ppc64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0823Wed_1758
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Wed Aug 23 18:00:27 CDT 2017
Total time = 1m 34s
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich ***
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0823Wed_1800
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich ***
Wed Aug 23 18:03:34 CDT 2017
Total time = 3m 7s
*** finished tests in ostrich ***
Testing quail
ssh -o ConnectTimeout=60 quail -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname quail
17:58 up 41 days, 8:29, 0 users, load averages: 1.35 1.54 1.63
Filesystem 512-blocks Used Available Capacity iused ifree %iused Mounted on
/dev/disk0s2 488555536 291070136 196973400 60% 36447765 24621675 60% /
devfs 362 362 0 100% 627 0 100% /dev
map auto_nfs 0 0 0 100% 0 0 100% /home
map auto_nfs 0 0 0 100% 0 0 100% /mnt/hdf
map auto_nfs 0 0 0 100% 0 0 100% /mnt/scr1
jam.ad.hdfgroup.org:/mnt/scr1 1922864144 1691470840 133717304 93% 4027281 118082671 3% /mnt/scr1
jam.ad.hdfgroup.org:/home 396703680 202888024 173338936 54% 1081810 50134574 2% /home
jam.ad.hdfgroup.org:/mnt/hdf 1922864144 1777011424 48176720 98% 11677403 110432549 10% /mnt/hdf
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Wed Aug 23 17:58:55 CDT 2017
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests in quail ***
Uname -a: Darwin quail.ad.hdfgroup.org 13.4.0 Darwin Kernel Version 13.4.0: Mon Jan 11 18:17:34 PST 2016; root:xnu-2422.115.15~1/RELEASE_X86_64 x86_64
/Users/hdftest/snapshots-opa/log/quail_0823Wed_1758
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests for quail ***
Wed Aug 23 17:59:50 CDT 2017
Total time = 0m 55s
*** finished tests in quail ***
Testing kite
ssh -o ConnectTimeout=60 kite -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
snapshots-opa: No such file or directory.
BASEDIR (/Users/hdftest/snapshots-) does not exist
****SYSTEM ERROR kite: BASEDIR (/Users/hdftest/snapshots-) does not exist
/mnt/scr1/SnapTest/snapshots-opa/bin/runtest: line 128: $SYSERRLOG: ambiguous redirect
****SYSTEM ERROR kite: Abnormal exit from runtest ****
****SYSTEM ERROR kite: runtest command failed ****
More information about the opa-nightly-tests
