[opa-nightly-tests] jam OPA_Daily_Tests_0819Sat
HDF Tester
hdftest at hdfgroup.org
Sat Aug 19 18:07:01 CDT 2017
*** OPA Tests on 0819Sat ***
Tests Summary
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED moohan: standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
PASSED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
PASSED quail: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Tests Time Summary
koala: Ran 1(1/0/0) tests, Grand total test time = 0m 34s
platypus: Ran 1(1/0/0) tests, Grand total test time = 0m 44s
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 2s
moohan: Ran 1(1/0/0) tests, Grand total test time = 1m 18s
quail: Ran 1(1/0/0) tests, Grand total test time = 2m 36s
ostrich: Ran 2(2/0/0) tests, Grand total test time = 4m 35s
jam: Ran 7(0/0/0) hosts, Grand total test time = 5m 42s
Timekeeper log
Timekeeper started at Sat Aug 19 18:01:30 CDT 2017
Timekeeper sleeping for 720 seconds
Tests Failures
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
18:01:09 up 397 days, 4:43, 15 users, load average: 0.16, 0.25, 0.45
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 18910540 11189652 63% /
/dev/sda1 101086 17532 78335 19% /boot
/dev/sda2 31738420 206176 29894016 1% /tmp
/dev/sda6 31738392 6321396 23778772 22% /var
/dev/sda7 31738392 18542628 11557540 62% /usr
/dev/sda8 124991068 192220 118347148 1% /var/tmp
/dev/mapper/VolGroup00-home
198351840 101440012 86673468 54% /home
/dev/sdc1 961432072 839846068 72748004 93% /mnt/scr1
/dev/sdd1 961432072 886661072 25933000 98% /mnt/hdf
tmpfs 8313628 0 8313628 0% /dev/shm
gumund:/data/ftp 480719104 361646208 94653696 80% /mnt/ftp
gumund:/data/web 480719104 361646208 94653696 80% /mnt/web
10.10.10.15:/volume1/hdf2
1437485440 450495360 986887680 32% /mnt/hdf2
10.10.10.15:/volume1/hdf3
1437485440 450495360 986887680 32% /mnt/hdf3
10.10.10.15:/volume1/readonly
1437485440 450495360 986887680 32% /mnt/readonly
1437485440 450495360 986887680 32% /mnt/ro-src
1437485440 450495360 986887680 32% /mnt/rw-src
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0819Sat
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0819Sat.6844: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0819Sat.6844': No such file or directory
*** launching tests from jam ***
TESTHOST is jam
koala
platypus
moohan
ostrich
quail
kite
Fork off timekeeper 12
Testing jam
ssh -o ConnectTimeout=60 jam -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
18:01:35 up 397 days, 4:43, 15 users, load average: 0.25, 0.26, 0.45
/dev/sda2 31738420 206284 29893908 1% /tmp
/dev/sda6 31738392 6321368 23778800 22% /var
/dev/sdc1 961432072 839846164 72747908 93% /mnt/scr1
Extract source and run autogen if .
Sat Aug 19 18:01:45 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/jam_0819Sat_1801
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Sat Aug 19 18:02:47 CDT 2017
Total time = 1m 2s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
18:01:37 up 316 days, 4:20, 1 user, load average: 0.06, 0.03, 0.09
/dev/sda7 22292052 4427724 16713676 21% /
/dev/sda5 12192608 380896 11182368 4% /tmp
/dev/sda3 12192636 1010620 10552672 9% /var
/dev/sda1 101086 18614 77253 20% /boot
/dev/sdc1 41279536 26323756 12858900 68% /usr
/dev/sdb 152754284 69845400 75149424 49% /scr
tmpfs 6149552 0 6149552 0% /dev/shm
10.10.10.86:/home 198351872 101439488 86674432 54% /home
10.10.10.86:/mnt/hdf 961432576 886661120 25933824 98% /mnt/hdf
10.10.10.86:/mnt/scr1
961432576 839845888 72748032 93% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Sat Aug 19 18:01:47 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-409.el5 #1 SMP Tue Mar 15 18:13:50 EDT 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/koala_0819Sat_1801
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Sat Aug 19 18:02:21 CDT 2017
Total time = 0m 34s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
18:01:40 up 316 days, 4:12, 4 users, load average: 0.13, 0.49, 0.52
/dev/sda6 54205540 34305904 17139496 67% /
tmpfs 6099068 0 6099068 0% /dev/shm
/dev/sda1 194241 48310 135691 27% /boot
/dev/sda2 12850716 131548 12059712 2% /tmp
/dev/sda3 12850716 5395012 6796248 45% /var
/dev/sdd 152623212 126926028 17937724 88% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Sat Aug 19 18:01:50 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.22.1.el6.x86_64 #1 SMP Wed Mar 23 03:35:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/platypus_0819Sat_1801
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Sat Aug 19 18:02:34 CDT 2017
Total time = 0m 44s
*** finished tests in platypus ***
Testing moohan
ssh -o ConnectTimeout=60 moohan -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname moohan
18:01:43 up 261 days, 3:57, 4 users, load average: 0.01, 0.24, 0.44
/dev/mapper/centos_moohan-root 52196352 9572676 42623676 19% /
devtmpfs 3923072 0 3923072 0% /dev
tmpfs 3939844 84 3939760 1% /dev/shm
tmpfs 3939844 427136 3512708 11% /run
tmpfs 3939844 0 3939844 0% /sys/fs/cgroup
/dev/md126p1 506752 312612 194140 62% /boot
/dev/mapper/centos_moohan-scr 858065536 355300716 502764820 42% /scr
/dev/mapper/centos_moohan-tmp 16371712 228548 16143164 2% /tmp
/dev/mapper/centos_moohan-var 16371712 5828132 10543580 36% /var
jam:/mnt/scr1 961432576 839845888 72748032 93% /mnt/scr1
jam:/home 198351872 101439488 86674432 54% /home
jam:/mnt/hdf 961432576 886661120 25933824 98% /mnt/hdf
10.10.10.15:/volume1/readonly 1437485440 450495360 986887680 32% /mnt/ro-src
tmpfs 787972 12 787960 1% /run/user/42
tmpfs 787972 0 787972 0% /run/user/2519
tmpfs 787972 0 787972 0% /run/user/0
tmpfs 787972 0 787972 0% /run/user/29138
tmpfs 787972 0 787972 0% /run/user/17929
tmpfs 787972 0 787972 0% /run/user/27429
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
Sat Aug 19 18:01:53 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests in moohan ***
Uname -a: Linux moohan.ad.hdfgroup.org 3.10.0-327.10.1.el7.x86_64 #1 SMP Tue Feb 16 17:03:50 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/moohan_0819Sat_1801
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests for moohan ***
Sat Aug 19 18:03:11 CDT 2017
Total time = 1m 18s
*** finished tests in moohan ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
18:01:46 up 264 days, 4:40, 0 users, load average: 0.05, 0.40, 0.43
/dev/mapper/vg_ostrich-lv_root
140479384 24656124 108684216 19% /
tmpfs 7821568 0 7821568 0% /dev/shm
/dev/sda2 487652 100521 361531 22% /boot
/dev/sdb2 124477364 97747068 20400544 83% /scr
jam:/mnt/scr1 961432576 839845888 72749056 93% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Sat Aug 19 18:01:56 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-573.18.1.el6.ppc64 #1 SMP Wed Jan 6 11:15:06 EST 2016 ppc64 ppc64 ppc64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0819Sat_1801
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Sat Aug 19 18:03:28 CDT 2017
Total time = 1m 32s
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich ***
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0819Sat_1803
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich ***
Sat Aug 19 18:06:31 CDT 2017
Total time = 3m 3s
*** finished tests in ostrich ***
Testing quail
ssh -o ConnectTimeout=60 quail -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname quail
18:01 up 37 days, 8:32, 0 users, load averages: 5.68 3.19 2.49
Filesystem 512-blocks Used Available Capacity iused ifree %iused Mounted on
/dev/disk0s2 488555536 290365672 197677864 60% 36359707 24709733 60% /
devfs 361 361 0 100% 626 0 100% /dev
map auto_nfs 0 0 0 100% 0 0 100% /home
map auto_nfs 0 0 0 100% 0 0 100% /mnt/hdf
map auto_nfs 0 0 0 100% 0 0 100% /mnt/scr1
jam.ad.hdfgroup.org:/mnt/scr1 1922864144 1679691552 145496592 93% 4033873 118076079 3% /mnt/scr1
jam.ad.hdfgroup.org:/home 396703680 202880024 173346936 54% 1081833 50134551 2% /home
jam.ad.hdfgroup.org:/mnt/hdf 1922864144 1773322144 51866000 98% 11687422 110422530 10% /mnt/hdf
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Sat Aug 19 18:01:58 CDT 2017
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests in quail ***
Uname -a: Darwin quail.ad.hdfgroup.org 13.4.0 Darwin Kernel Version 13.4.0: Mon Jan 11 18:17:34 PST 2016; root:xnu-2422.115.15~1/RELEASE_X86_64 x86_64
/Users/hdftest/snapshots-opa/log/quail_0819Sat_1801
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests for quail ***
Sat Aug 19 18:04:33 CDT 2017
Total time = 2m 35s
*** finished tests in quail ***
Sat Aug 19 18:04:34 CDT 2017
Testing kite
ssh -o ConnectTimeout=60 kite -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
snapshots-opa: No such file or directory.
BASEDIR (/Users/hdftest/snapshots-) does not exist
****SYSTEM ERROR kite: BASEDIR (/Users/hdftest/snapshots-) does not exist
/mnt/scr1/SnapTest/snapshots-opa/bin/runtest: line 128: $SYSERRLOG: ambiguous redirect
****SYSTEM ERROR kite: Abnormal exit from runtest ****
****SYSTEM ERROR kite: runtest command failed ****
More information about the opa-nightly-tests
