[opa-nightly-tests] jam OPA_Daily_Tests_0810Thu
HDF Tester hdftest at hdfgroup.org
Thu Aug 10 18:02:48 CDT 2017
*** OPA Tests on 0810Thu ***
   Tests Summary
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED moohan: standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
PASSED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
PASSED quail: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
   Tests Time Summary
koala: Ran 1(1/0/0) tests, Grand total test time =  0m 34s
platypus: Ran 1(1/0/0) tests, Grand total test time =  0m 44s
jam: Ran 1(1/0/0) tests, Grand total test time =  1m 2s
quail: Ran 1(1/0/0) tests, Grand total test time =  0m 56s
moohan: Ran 1(1/0/0) tests, Grand total test time =  1m 19s
ostrich: Ran 2(2/0/0) tests, Grand total test time =  4m 43s
jam: Ran 7(0/0/0) hosts, Grand total test time =  5m 49s
   Timekeeper log
Timekeeper started at Thu Aug 10 17:57:10 CDT 2017
Timekeeper sleeping for 720 seconds
   Tests Failures
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 17:56:49 up 388 days,  4:38, 14 users,  load average: 0.08, 0.34, 0.49
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda3             31738420  18910540  11189652  63% /
/dev/sda1               101086     17532     78335  19% /boot
/dev/sda2             31738420    208052  29892140   1% /tmp
/dev/sda6             31738392   6169044  23931124  21% /var
/dev/sda7             31738392  18542628  11557540  62% /usr
/dev/sda8            124991068    192220 118347148   1% /var/tmp
/dev/mapper/VolGroup00-home
                     198351840 102311384  85802096  55% /home
/dev/sdc1            961432072 823313380  89280692  91% /mnt/scr1
/dev/sdd1            961432072 884584272  28009800  97% /mnt/hdf
tmpfs                  8313628         0   8313628   0% /dev/shm
gumund:/data/ftp     480719104 361397632  94902272  80% /mnt/ftp
gumund:/data/web     480719104 361397632  94902272  80% /mnt/web
10.10.10.15:/volume1/hdf2
                     1437485440 450495360 986887680  32% /mnt/hdf2
10.10.10.15:/volume1/hdf3
                     1437485440 450495360 986887680  32% /mnt/hdf3
10.10.10.15:/volume1/readonly
                     1437485440 450495360 986887680  32% /mnt/readonly
                     1437485440 450495360 986887680  32% /mnt/ro-src
                     1437485440 450495360 986887680  32% /mnt/rw-src
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0810Thu
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0810Thu.26910: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0810Thu.26910': No such file or directory
*** launching tests from jam ***
TESTHOST is jam
koala
platypus
moohan
ostrich
quail
kite
    Fork off timekeeper 12
Testing jam
ssh -o ConnectTimeout=60 jam -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
 17:57:15 up 388 days,  4:39, 14 users,  load average: 0.19, 0.34, 0.48
/dev/sda2             31738420    208160  29892032   1% /tmp
/dev/sda6             31738392   6169096  23931072  21% /var
/dev/sdc1            961432072 823313408  89280664  91% /mnt/scr1
Extract source and run autogen if .
Thu Aug 10 17:57:25 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
Running snapshot with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/jam_0810Thu_1757
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Thu Aug 10 17:58:27 CDT 2017
Total time = 1m 2s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
 17:57:17 up 307 days,  4:16,  1 user,  load average: 0.02, 0.05, 0.16
/dev/sda7             22292052   4427724  16713676  21% /
/dev/sda5             12192608    381044  11182220   4% /tmp
/dev/sda3             12192636   1012400  10550892   9% /var
/dev/sda1               101086     18614     77253  20% /boot
/dev/sdc1             41279536  26323756  12858900  68% /usr
/dev/sdb             152754284  69842580  75152244  49% /scr
tmpfs                  6149552         0   6149552   0% /dev/shm
10.10.10.86:/home    198351872 102310912  85803008  55% /home
10.10.10.86:/mnt/hdf 961432576 884584448  28010496  97% /mnt/hdf
10.10.10.86:/mnt/scr1
                     961432576 823313408  89281536  91% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Thu Aug 10 17:57:27 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-409.el5 #1 SMP Tue Mar 15 18:13:50 EDT 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/koala_0810Thu_1757
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Thu Aug 10 17:58:01 CDT 2017
Total time = 0m 34s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
 17:57:20 up 307 days,  4:07,  3 users,  load average: 0.38, 0.74, 0.67
/dev/sda6             54205540  34305904  17139496  67% /
tmpfs                  6099068         0   6099068   0% /dev/shm
/dev/sda1               194241     48310    135691  27% /boot
/dev/sda2             12850716    134084  12057176   2% /tmp
/dev/sda3             12850716   5703472   6487788  47% /var
/dev/sdd             152623212 125125356  19738396  87% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Thu Aug 10 17:57:30 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.22.1.el6.x86_64 #1 SMP Wed Mar 23 03:35:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/platypus_0810Thu_1757
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Thu Aug 10 17:58:14 CDT 2017
Total time = 0m 44s
*** finished tests in platypus ***
Testing moohan
ssh -o ConnectTimeout=60 moohan -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname moohan
 17:57:23 up 252 days,  3:52,  2 users,  load average: 0.04, 0.33, 0.51
/dev/mapper/centos_moohan-root   52196352   9572676  42623676  19% /
devtmpfs                          3923072         0   3923072   0% /dev
tmpfs                             3939844        84   3939760   1% /dev/shm
tmpfs                             3939844    435268   3504576  12% /run
tmpfs                             3939844         0   3939844   0% /sys/fs/cgroup
/dev/md126p1                       506752    312612    194140  62% /boot
/dev/mapper/centos_moohan-scr   858065536 354505480 503560056  42% /scr
/dev/mapper/centos_moohan-tmp    16371712    268864  16102848   2% /tmp
/dev/mapper/centos_moohan-var    16371712   5746272  10625440  36% /var
jam:/mnt/scr1                   961432576 823313408  89281536  91% /mnt/scr1
jam:/home                       198351872 102310912  85803008  55% /home
jam:/mnt/hdf                    961432576 884584448  28010496  97% /mnt/hdf
10.10.10.15:/volume1/readonly  1437485440 450495360 986887680  32% /mnt/ro-src
tmpfs                              787972        12    787960   1% /run/user/42
tmpfs                              787972         0    787972   0% /run/user/2519
tmpfs                              787972         0    787972   0% /run/user/0
tmpfs                              787972         0    787972   0% /run/user/29138
tmpfs                              787972         0    787972   0% /run/user/27429
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
Thu Aug 10 17:57:33 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests in moohan ***
Uname -a: Linux moohan.ad.hdfgroup.org 3.10.0-327.10.1.el7.x86_64 #1 SMP Tue Feb 16 17:03:50 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/moohan_0810Thu_1757
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests for moohan ***
Thu Aug 10 17:58:52 CDT 2017
Total time = 1m 19s
*** finished tests in moohan ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
 17:57:25 up 255 days,  4:35,  2 users,  load average: 10.18, 10.33, 10.38
/dev/mapper/vg_ostrich-lv_root
                      140479384  24592052 108748288  19% /
tmpfs                   7821568         0   7821568   0% /dev/shm
/dev/sda2                487652    100521    361531  22% /boot
/dev/sdb2             124477364  97608428  20539184  83% /scr
jam:/mnt/scr1         961432576 823312384  89281536  91% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Thu Aug 10 17:57:36 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-573.18.1.el6.ppc64 #1 SMP Wed Jan 6 11:15:06 EST 2016 ppc64 ppc64 ppc64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0810Thu_1757
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Thu Aug 10 17:59:10 CDT 2017
Total time = 1m 34s
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich ***
   /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0810Thu_1759
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich ***
Thu Aug 10 18:02:18 CDT 2017
Total time = 3m 8s
*** finished tests in ostrich ***
Testing quail
ssh -o ConnectTimeout=60 quail -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname quail
17:57  up 28 days,  8:27, 0 users, load averages: 1.28 1.43 1.43
Filesystem                    512-blocks       Used Available Capacity  iused     ifree %iused  Mounted on
/dev/disk0s2                   488555536  285899488 202144048    59% 35801434  25268006   59%   /
devfs                                362        362         0   100%      627         0  100%   /dev
map auto_nfs                           0          0         0   100%        0         0  100%   /home
map auto_nfs                           0          0         0   100%        0         0  100%   /mnt/hdf
map auto_nfs                           0          0         0   100%        0         0  100%   /mnt/scr1
jam.ad.hdfgroup.org:/mnt/scr1 1922864144 1646625824 178562320    91%  4033246 118076706    3%   /mnt/scr1
jam.ad.hdfgroup.org:/home      396703680  204622768 171604192    55%  1081578  50134806    2%   /home
jam.ad.hdfgroup.org:/mnt/hdf  1922864144 1769168544  56019600    97% 11666263 110443689   10%   /mnt/hdf
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Thu Aug 10 17:57:38 CDT 2017
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests in quail ***
Uname -a: Darwin quail.ad.hdfgroup.org 13.4.0 Darwin Kernel Version 13.4.0: Mon Jan 11 18:17:34 PST 2016; root:xnu-2422.115.15~1/RELEASE_X86_64 x86_64
   /Users/hdftest/snapshots-opa/log/quail_0810Thu_1757
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests for quail ***
Thu Aug 10 17:58:34 CDT 2017
Total time = 0m 56s
*** finished tests in quail ***
Testing kite
ssh -o ConnectTimeout=60 kite -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
snapshots-opa: No such file or directory.
BASEDIR (/Users/hdftest/snapshots-) does not exist
	****SYSTEM ERROR kite: BASEDIR (/Users/hdftest/snapshots-) does not exist
/mnt/scr1/SnapTest/snapshots-opa/bin/runtest: line 128: $SYSERRLOG: ambiguous redirect
****SYSTEM ERROR kite: Abnormal exit from runtest ****
	****SYSTEM ERROR kite: runtest command failed ****
More information about the opa-nightly-tests mailing list
