[opa-nightly-tests] jam OPA_Daily_Tests_0804Fri
HDF Tester hdftest at hdfgroup.org
Fri Aug 4 21:55:12 CDT 2017
*** OPA Tests on 0804Fri ***
   Tests Summary
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED moohan: standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
PASSED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
PASSED quail: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
   Tests Time Summary
koala: Ran 1(1/0/0) tests, Grand total test time =  0m 33s
platypus: Ran 1(1/0/0) tests, Grand total test time =  0m 44s
jam: Ran 1(1/0/0) tests, Grand total test time =  1m 1s
quail: Ran 1(1/0/0) tests, Grand total test time =  0m 54s
moohan: Ran 1(1/0/0) tests, Grand total test time =  1m 16s
ostrich: Ran 2(2/0/0) tests, Grand total test time =  4m 39s
jam: Ran 7(0/0/0) hosts, Grand total test time =  5m 45s
   Timekeeper log
Timekeeper started at Fri Aug  4 21:49:38 CDT 2017
Timekeeper sleeping for 720 seconds
   Tests Failures
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 21:49:17 up 382 days,  8:31,  9 users,  load average: 0.99, 0.88, 0.98
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda3             31738420  18910540  11189652  63% /
/dev/sda1               101086     17532     78335  19% /boot
/dev/sda2             31738420    227912  29872280   1% /tmp
/dev/sda6             31738392   6351500  23748668  22% /var
/dev/sda7             31738392  18542628  11557540  62% /usr
/dev/sda8            124991068    192224 118347144   1% /var/tmp
/dev/mapper/VolGroup00-home
                     198351840 100630996  87482484  54% /home
/dev/sdc1            961432072 825349104  87244968  91% /mnt/scr1
/dev/sdd1            961432072 887541980  25052092  98% /mnt/hdf
tmpfs                  8313628         0   8313628   0% /dev/shm
gumund:/data/ftp     480719104 358623872  97676032  79% /mnt/ftp
gumund:/data/web     480719104 358623872  97676032  79% /mnt/web
10.10.10.15:/volume1/hdf2
                     1437485440 450495360 986887680  32% /mnt/hdf2
10.10.10.15:/volume1/hdf3
                     1437485440 450495360 986887680  32% /mnt/hdf3
10.10.10.15:/volume1/readonly
                     1437485440 450495360 986887680  32% /mnt/readonly
                     1437485440 450495360 986887680  32% /mnt/ro-src
                     1437485440 450495360 986887680  32% /mnt/rw-src
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0804Fri
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0804Fri.6301: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0804Fri.6301': No such file or directory
*** launching tests from jam ***
TESTHOST is jam
koala
platypus
moohan
ostrich
quail
kite
    Fork off timekeeper 12
Testing jam
ssh -o ConnectTimeout=60 jam -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
 21:49:42 up 382 days,  8:31,  9 users,  load average: 1.05, 0.91, 0.99
/dev/sda2             31738420    228024  29872168   1% /tmp
/dev/sda6             31738392   6351476  23748692  22% /var
/dev/sdc1            961432072 825349132  87244940  91% /mnt/scr1
/dev/sdd1            961432072 887596672  24997400  98% /mnt/hdf
Extract source and run autogen if .
Fri Aug  4 21:49:53 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
Running snapshot with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/jam_0804Fri_2149
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Fri Aug  4 21:50:53 CDT 2017
Total time = 1m 0s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
 21:49:44 up 301 days,  8:08,  1 user,  load average: 0.15, 0.37, 0.48
/dev/sda7             22292052   4427724  16713676  21% /
/dev/sda5             12192608    386872  11176392   4% /tmp
/dev/sda3             12192636   1017428  10545864   9% /var
/dev/sda1               101086     18614     77253  20% /boot
/dev/sdc1             41279536  26323756  12858900  68% /usr
/dev/sdb             152754284  69893044  75101780  49% /scr
tmpfs                  6149552         0   6149552   0% /dev/shm
10.10.10.86:/home    198351872 100630528  87483392  54% /home
10.10.10.86:/mnt/hdf 961432576 887601152  24993792  98% /mnt/hdf
10.10.10.86:/mnt/scr1
                     961432576 825349120  87245824  91% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Fri Aug  4 21:49:55 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-409.el5 #1 SMP Tue Mar 15 18:13:50 EDT 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/koala_0804Fri_2149
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Fri Aug  4 21:50:27 CDT 2017
Total time = 0m 32s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
 21:49:47 up 301 days,  8:00,  3 users,  load average: 0.46, 0.77, 0.67
/dev/sda6             54205540  34305904  17139496  67% /
tmpfs                  6099068         0   6099068   0% /dev/shm
/dev/sda1               194241     48310    135691  27% /boot
/dev/sda2             12850716     61792  12129468   1% /tmp
/dev/sda3             12850716   5627560   6563700  47% /var
/dev/sdd             152623212 128099056  16764696  89% /scr
10.10.10.86:/mnt/hdf 961432576 887606272  24987648  98% /mnt/hdf
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Fri Aug  4 21:49:57 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.22.1.el6.x86_64 #1 SMP Wed Mar 23 03:35:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/platypus_0804Fri_2149
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Fri Aug  4 21:50:41 CDT 2017
Total time = 0m 44s
*** finished tests in platypus ***
Testing moohan
ssh -o ConnectTimeout=60 moohan -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname moohan
 21:49:50 up 246 days,  7:45,  3 users,  load average: 0.10, 0.46, 0.54
/dev/mapper/centos_moohan-root   52196352   9572676  42623676  19% /
devtmpfs                          3923072         0   3923072   0% /dev
tmpfs                             3939844        84   3939760   1% /dev/shm
tmpfs                             3939844    410720   3529124  11% /run
tmpfs                             3939844         0   3939844   0% /sys/fs/cgroup
/dev/md126p1                       506752    312612    194140  62% /boot
/dev/mapper/centos_moohan-scr   858065536 357789524 500276012  42% /scr
/dev/mapper/centos_moohan-tmp    16371712    152624  16219088   1% /tmp
/dev/mapper/centos_moohan-var    16371712   5781760  10589952  36% /var
jam:/mnt/scr1                   961432576 825349120  87245824  91% /mnt/scr1
jam:/home                       198351872 100630528  87483392  54% /home
jam:/mnt/hdf                    961432576 887612416  24982528  98% /mnt/hdf
10.10.10.15:/volume1/readonly  1437485440 450495360 986887680  32% /mnt/ro-src
tmpfs                              787972        12    787960   1% /run/user/42
tmpfs                              787972         0    787972   0% /run/user/2519
tmpfs                              787972         0    787972   0% /run/user/0
tmpfs                              787972         0    787972   0% /run/user/29138
tmpfs                              787972         0    787972   0% /run/user/27429
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
Fri Aug  4 21:50:00 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests in moohan ***
Uname -a: Linux moohan.ad.hdfgroup.org 3.10.0-327.10.1.el7.x86_64 #1 SMP Tue Feb 16 17:03:50 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/moohan_0804Fri_2150
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests for moohan ***
Fri Aug  4 21:51:15 CDT 2017
Total time = 1m 15s
*** finished tests in moohan ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
 21:49:53 up 249 days,  8:28,  0 users,  load average: 0.61, 0.99, 0.69
/dev/mapper/vg_ostrich-lv_root
                      140479384  24732504 108607836  19% /
tmpfs                   7821568         0   7821568   0% /dev/shm
/dev/sda2                487652    100521    361531  22% /boot
/dev/sdb2             124477364  99119140  19028472  84% /scr
jam:/mnt/hdf          961432576 887617536  24976384  98% /mnt/hdf
jam:/mnt/scr1         961432576 825348096  87245824  91% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Fri Aug  4 21:50:03 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-573.18.1.el6.ppc64 #1 SMP Wed Jan 6 11:15:06 EST 2016 ppc64 ppc64 ppc64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0804Fri_2150
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Fri Aug  4 21:51:43 CDT 2017
Total time = 1m 40s
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich ***
   /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0804Fri_2151
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich ***
Fri Aug  4 21:54:42 CDT 2017
Total time = 2m 59s
*** finished tests in ostrich ***
Testing quail
ssh -o ConnectTimeout=60 quail -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname quail
21:49  up 22 days, 12:19, 0 users, load averages: 1.19 1.23 1.33
Filesystem                    512-blocks       Used Available Capacity  iused     ifree %iused  Mounted on
/dev/disk0s2                   488555536  286855008 201188528    59% 35920874  25148566   59%   /
devfs                                362        362         0   100%      627         0  100%   /dev
map auto_nfs                           0          0         0   100%        0         0  100%   /home
map auto_nfs                           0          0         0   100%        0         0  100%   /mnt/hdf
map auto_nfs                           0          0         0   100%        0         0  100%   /mnt/scr1
jam.ad.hdfgroup.org:/mnt/hdf  1922864144 1775243008  49945136    98% 11702589 110407363   10%   /mnt/hdf
jam.ad.hdfgroup.org:/mnt/scr1 1922864144 1650697272 174490872    91%  4032783 118077169    3%   /mnt/scr1
jam.ad.hdfgroup.org:/home      396703680  201261992 174964968    54%  1044859  50171525    2%   /home
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Fri Aug  4 21:50:05 CDT 2017
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests in quail ***
Uname -a: Darwin quail.ad.hdfgroup.org 13.4.0 Darwin Kernel Version 13.4.0: Mon Jan 11 18:17:34 PST 2016; root:xnu-2422.115.15~1/RELEASE_X86_64 x86_64
   /Users/hdftest/snapshots-opa/log/quail_0804Fri_2150
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests for quail ***
Fri Aug  4 21:50:59 CDT 2017
Total time = 0m 54s
*** finished tests in quail ***
Testing kite
ssh -o ConnectTimeout=60 kite -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
snapshots-opa: No such file or directory.
BASEDIR (/Users/hdftest/snapshots-) does not exist
	****SYSTEM ERROR kite: BASEDIR (/Users/hdftest/snapshots-) does not exist
/mnt/scr1/SnapTest/snapshots-opa/bin/runtest: line 128: $SYSERRLOG: ambiguous redirect
****SYSTEM ERROR kite: Abnormal exit from runtest ****
	****SYSTEM ERROR kite: runtest command failed ****
More information about the opa-nightly-tests mailing list
