[opa-nightly-tests] jam OPA_Daily_Tests_0521Sat
HDF Tester hdftest at hdfgroup.org
Sat May 21 21:24:34 CDT 2016
*** OPA Tests on 0521Sat ***
   Tests Summary
PASSED emu: standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
PASSED kite: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
PASSED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
   Tests Time Summary
koala: Ran 1(1/0/0) tests, Grand total test time =  0m 35s
platypus: Ran 1(1/0/0) tests, Grand total test time =  0m 44s
kite: Ran 1(1/0/0) tests, Grand total test time =  0m 47s
jam: Ran 1(1/0/0) tests, Grand total test time =  1m 2s
ostrich: Ran 2(2/0/0) tests, Grand total test time =  4m 41s
emu: Ran 1(1/0/0) tests, Grand total test time =  11m 33s
jam: Ran 7(0/0/0) hosts, Grand total test time =  12m 29s
   Timekeeper log
Timekeeper started at Sat May 21 21:12:16 CDT 2016
Timekeeper sleeping for 720 seconds
Timekeeper woke up at Sat May 21 21:24:16 CDT 2016, looking for processes to terminate...
Timekeeper ended at Sat May 21 21:24:16 CDT 2016
   Tests Failures
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 21:11:55 up 93 days, 12:11, 24 users,  load average: 0.04, 0.17, 0.26
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda3             31738420  10366820  19733372  35% /
/dev/sda1               101086     17532     78335  19% /boot
/dev/sda2             31738420    216068  29884124   1% /tmp
/dev/sda6             31738392   5790144  24310024  20% /var
/dev/sda7             31738392  18539068  11561100  62% /usr
/dev/sda8            124991068    192216 118347152   1% /var/tmp
tmpfs                  8313628         0   8313628   0% /dev/shm
10.10.10.15:/volume1/hdf2
                     1437485440 295837312 1141545728  21% /mnt/hdf2
10.10.10.15:/volume1/hdf3
                     1437485440 295837312 1141545728  21% /mnt/hdf3
10.10.10.15:/volume1/readonly
                     1437485440 295837312 1141545728  21% /mnt/readonly
                     1437485440 295837312 1141545728  21% /mnt/ro-src
                     1437485440 295837312 1141545728  21% /mnt/rw-src
/dev/mapper/VolGroup00-home
                     198351840  99683288  88430192  53% /home
/dev/sde1            565688764 431978424 104511404  81% /scr
/dev/sdc1            961432072 850035400  62558672  94% /mnt/scr1
/dev/sdd1            961432072 889049296  23544776  98% /mnt/hdf
gumund:/data/ftp     480719104 267480576 188819328  59% /mnt/ftp
gumund:/data/web     480719104 267480576 188819328  59% /mnt/web
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0521Sat
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0521Sat.23877: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0521Sat.23877': No such file or directory
*** launching tests from jam ***
TESTHOST is emu
jam
koala
platypus
ostrich
quail
kite
    Fork off timekeeper 12
Testing emu
ssh -o ConnectTimeout=60 emu -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname emu
  9:12pm  up 156 day(s),  3:23,  0 users,  load average: 0.02, 0.75, 1.50
/                  (rpool/ROOT/solaris):340373387 blocks 340373387 files
/devices           (/devices          ):       0 blocks        0 files
/dev               (/dev              ):       0 blocks        0 files
/system/contract   (ctfs              ):       0 blocks 2147483592 files
/proc              (proc              ):       0 blocks    29933 files
/etc/mnttab        (mnttab            ):       0 blocks        0 files
/system/volatile   (swap              ):20545536 blocks  2154487 files
/system/object     (objfs             ):       0 blocks 2147483467 files
/etc/dfs/sharetab  (sharefs           ):       0 blocks 2147483646 files
/dev/fd            (fd                ):       0 blocks        0 files
/var               (rpool/ROOT/solaris/var):340373387 blocks 340373387 files
/tmp               (swap              ):20545536 blocks  2154487 files
/var/share         (rpool/VARSHARE    ):340373387 blocks 340373387 files
/export            (rpool/export      ):340373387 blocks 340373387 files
/export/home       (rpool/export/home ):340373387 blocks 340373387 files
/export/home/kurz  (rpool/export/home/kurz):340373387 blocks 340373387 files
/rpool             (rpool             ):340373387 blocks 340373387 files
/home              (jam.ad.hdfgroup.org:/home):197337104 blocks 50195760 files
/mnt/web           (gumund.ad.hdfgroup.org:/mnt/web):426476904 blocks 60873944 files
/mnt/ftp           (gumund.ad.hdfgroup.org:/mnt/ftp):426476904 blocks 60873944 files
/mnt/scr1          (jam.ad.hdfgroup.org:/mnt/scr1):222793288 blocks 117853034 files
/mnt/hdf           (jam.ad.hdfgroup.org:/mnt/hdf):144765552 blocks 111083864 files
/mnt/ro-src        (10.10.10.15:/volume1/readonly):2283296184 blocks 91105902 files
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32
Extract source and run autogen if .
Saturday, May 21, 2016 09:12:31 PM CDT
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32 tests in emu ***
Uname -a: SunOS emu 5.11 11.1 sun4v sparc sun4v
Running snapshot with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/emu_0521Sat_2112
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32 tests for emu ***
Saturday, May 21, 2016 09:24:04 PM CDT
Total time = 11m 33s
*** finished tests in emu ***
Testing jam
ssh -o ConnectTimeout=60 jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
 21:12:23 up 93 days, 12:11, 24 users,  load average: 0.15, 0.18, 0.26
/dev/sda2             31738420    216176  29884016   1% /tmp
/dev/sda6             31738392   5790240  24309928  20% /var
/dev/sdc1            961432072 850035436  62558636  94% /mnt/scr1
Sat May 21 21:12:33 CDT 2016
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/jam_0521Sat_2112
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Sat May 21 21:13:35 CDT 2016
Total time = 1m 2s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
 21:12:25 up 54 days,  9:33,  0 users,  load average: 0.90, 0.45, 0.40
/dev/sda7             22292052   4427644  16713756  21% /
/dev/sda5             12192608    383404  11179860   4% /tmp
/dev/sda3             12192636   1008392  10554900   9% /var
/dev/sda1               101086     18614     77253  20% /boot
/dev/sdc1             41279536  26315936  12866720  68% /usr
/dev/sdb             152754284  68521976  76472848  48% /scr
tmpfs                  6149552         0   6149552   0% /dev/shm
10.10.10.86:/home    198351872  99682304  88430592  53% /home
10.10.10.86:/mnt/hdf 961432576 889049088  23544832  98% /mnt/hdf
10.10.10.86:/mnt/scr1
                     961432576 850035712  62559232  94% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Sat May 21 21:12:35 CDT 2016
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-409.el5 #1 SMP Tue Mar 15 18:13:50 EDT 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/koala_0521Sat_2112
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Sat May 21 21:13:10 CDT 2016
Total time = 0m 35s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
 21:12:28 up 54 days,  6:34,  3 users,  load average: 0.20, 0.36, 0.72
/dev/sda6             54205540  23413492  28031908  46% /
tmpfs                  6099068         0   6099068   0% /dev/shm
/dev/sda1               194241     48310    135691  27% /boot
/dev/sda2             12850716    337292  11853968   3% /tmp
/dev/sda3             12850716   7608192   4583068  63% /var
/dev/sdd             152623212 121346072  23517680  84% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Sat May 21 21:12:38 CDT 2016
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.22.1.el6.x86_64 #1 SMP Wed Mar 23 03:35:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/platypus_0521Sat_2112
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Sat May 21 21:13:22 CDT 2016
Total time = 0m 44s
*** finished tests in platypus ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
 21:12:30 up 94 days,  5:05,  0 users,  load average: 0.39, 0.97, 0.95
/dev/mapper/vg_ostrich-lv_root
                      140479384  24273320  109067020  19% /
tmpfs                   7821568         0    7821568   0% /dev/shm
/dev/sda2                487652    100521     361531  22% /boot
/dev/sdb2             124477364  91501048   26646564  78% /scr
jam:/home             198351872  99682304   88430592  53% /home
jam:/mnt/hdf          961432576 889049088   23544832  98% /mnt/hdf
jam:/mnt/scr1         961432576 850035712   62559232  94% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Sat May 21 21:12:41 CDT 2016
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-573.18.1.el6.ppc64 #1 SMP Wed Jan 6 11:15:06 EST 2016 ppc64 ppc64 ppc64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0521Sat_2112
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Sat May 21 21:14:12 CDT 2016
Total time = 1m 31s
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich ***
   /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0521Sat_2114
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich ***
Sat May 21 21:17:21 CDT 2016
Total time = 3m 9s
*** finished tests in ostrich ***
Testing quail
ssh -o ConnectTimeout=60 quail -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname quail
/home/hdftest/snapshots-opa: No such file or directory.
****SYSTEM ERROR quail: Abnormal exit from runtest ****
	****SYSTEM ERROR quail: runtest command failed ****
Testing kite
ssh -o ConnectTimeout=60 kite -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
21:12  up 94 days,  4:51, 2 users, load averages: 0.05 0.01 0.04
Filesystem            512-blocks       Used  Available Capacity  iused     ifree %iused  Mounted on
/dev/disk0s2          1951845952  258894096 1692439856    14% 32425760 211554982   13%   /
devfs                        375        375          0   100%      649         0  100%   /dev
/dev/disk1s2          1952853344    1296608 1951556736     1%   162074 243944592    0%   /Volumes/Milvinae
10.10.10.86:/mnt/hdf  1922864144 1778098592   47089552    98% 11026088 111083864    9%   /mnt/hdf
10.10.10.86:/mnt/scr1 1922864144 1700062696  125125448    94%  4256932 117853020    3%   /mnt/scr1
10.10.10.86:/home      396703680  199366576  176860384    53%  1020624  50195760    2%   /home
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
Sat May 21 21:12:46 CDT 2016
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests in kite ***
Uname -a: Darwin kite.ad.hdfgroup.org 12.6.0 Darwin Kernel Version 12.6.0: Wed Mar 18 16:23:48 PDT 2015; root:xnu-2050.48.19~1/RELEASE_X86_64 x86_64
   /Users/hdftest/snapshots-opa/log/kite_0521Sat_2112
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests for kite ***
Sat May 21 21:13:32 CDT 2016
Total time = 0m 46s
*** finished tests in kite ***
More information about the opa-nightly-tests mailing list
