[opa-nightly-tests] jam OPA_Daily_Tests_0519Thu
HDF Tester hdftest at hdfgroup.org
Thu May 19 21:26:32 CDT 2016
*** OPA Tests on 0519Thu ***
   Tests Summary
PASSED emu: standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
PASSED kite: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
PASSED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
   Tests Time Summary
koala: Ran 1(1/0/0) tests, Grand total test time =  0m 35s
kite: Ran 1(1/0/0) tests, Grand total test time =  0m 44s
jam: Ran 1(1/0/0) tests, Grand total test time =  0m 58s
platypus: Ran 1(1/0/0) tests, Grand total test time =  1m 3s
ostrich: Ran 2(2/0/0) tests, Grand total test time =  4m 34s
emu: Ran 1(1/0/0) tests, Grand total test time =  11m 34s
jam: Ran 7(0/0/0) hosts, Grand total test time =  12m 29s
   Timekeeper log
Timekeeper started at Thu May 19 21:14:14 CDT 2016
Timekeeper sleeping for 720 seconds
Timekeeper woke up at Thu May 19 21:26:14 CDT 2016, looking for processes to terminate...
Timekeeper ended at Thu May 19 21:26:14 CDT 2016
   Tests Failures
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 21:13:53 up 91 days, 12:13, 17 users,  load average: 1.02, 1.14, 1.25
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda3             31738420  10340188  19760004  35% /
/dev/sda1               101086     17532     78335  19% /boot
/dev/sda2             31738420    222908  29877284   1% /tmp
/dev/sda6             31738392   5783064  24317104  20% /var
/dev/sda7             31738392  18539068  11561100  62% /usr
/dev/sda8            124991068    192216 118347152   1% /var/tmp
tmpfs                  8313628         0   8313628   0% /dev/shm
10.10.10.15:/volume1/hdf2
                     1437485440 295837312 1141545728  21% /mnt/hdf2
10.10.10.15:/volume1/hdf3
                     1437485440 295837312 1141545728  21% /mnt/hdf3
10.10.10.15:/volume1/readonly
                     1437485440 295837312 1141545728  21% /mnt/readonly
                     1437485440 295837312 1141545728  21% /mnt/ro-src
                     1437485440 295837312 1141545728  21% /mnt/rw-src
/dev/mapper/VolGroup00-home
                     198351840  99673836  88439644  53% /home
/dev/sde1            565688764 432379728 104110100  81% /scr
/dev/sdc1            961432072 848007568  64586504  93% /mnt/scr1
/dev/sdd1            961432072 888706192  23887880  98% /mnt/hdf
gumund:/data/ftp     480719104 267319680 188980224  59% /mnt/ftp
gumund:/data/web     480719104 267319680 188980224  59% /mnt/web
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0519Thu
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0519Thu.656: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0519Thu.656': No such file or directory
*** launching tests from jam ***
TESTHOST is emu
jam
koala
platypus
ostrich
quail
kite
    Fork off timekeeper 12
Testing emu
ssh -o ConnectTimeout=60 emu -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname emu
  9:14pm  up 154 day(s),  3:25,  0 users,  load average: 0.02, 0.73, 1.48
/                  (rpool/ROOT/solaris):337622147 blocks 337622147 files
/devices           (/devices          ):       0 blocks        0 files
/dev               (/dev              ):       0 blocks        0 files
/system/contract   (ctfs              ):       0 blocks 2147483592 files
/proc              (proc              ):       0 blocks    29933 files
/etc/mnttab        (mnttab            ):       0 blocks        0 files
/system/volatile   (swap              ):21648320 blocks  2154981 files
/system/object     (objfs             ):       0 blocks 2147483467 files
/etc/dfs/sharetab  (sharefs           ):       0 blocks 2147483646 files
/dev/fd            (fd                ):       0 blocks        0 files
/var               (rpool/ROOT/solaris/var):337622147 blocks 337622147 files
/tmp               (swap              ):21648320 blocks  2154981 files
/var/share         (rpool/VARSHARE    ):337622147 blocks 337622147 files
/export            (rpool/export      ):337622147 blocks 337622147 files
/export/home       (rpool/export/home ):337622147 blocks 337622147 files
/export/home/kurz  (rpool/export/home/kurz):337622147 blocks 337622147 files
/rpool             (rpool             ):337622147 blocks 337622147 files
/home              (jam.ad.hdfgroup.org:/home):197356008 blocks 50196154 files
/mnt/web           (gumund.ad.hdfgroup.org:/mnt/web):426798680 blocks 60873945 files
/mnt/ftp           (gumund.ad.hdfgroup.org:/mnt/ftp):426798680 blocks 60873945 files
/mnt/scr1          (jam.ad.hdfgroup.org:/mnt/scr1):226841024 blocks 117853543 files
/mnt/hdf           (jam.ad.hdfgroup.org:/mnt/hdf):145451760 blocks 111095720 files
/mnt/ro-src        (10.10.10.15:/volume1/readonly):2283296184 blocks 91105902 files
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32
Extract source and run autogen if .
Thursday, May 19, 2016 09:14:29 PM CDT
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32 tests in emu ***
Uname -a: SunOS emu 5.11 11.1 sun4v sparc sun4v
Running snapshot with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/emu_0519Thu_2114
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32 tests for emu ***
Thursday, May 19, 2016 09:26:02 PM CDT
Total time = 11m 33s
*** finished tests in emu ***
Testing jam
ssh -o ConnectTimeout=60 jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
 21:14:21 up 91 days, 12:13, 17 users,  load average: 1.15, 1.16, 1.25
/dev/sda2             31738420    223016  29877176   1% /tmp
/dev/sda6             31738392   5783136  24317032  20% /var
/dev/sdc1            961432072 848011700  64582372  93% /mnt/scr1
Thu May 19 21:14:31 CDT 2016
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/jam_0519Thu_2114
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Thu May 19 21:15:29 CDT 2016
Total time = 0m 58s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
 21:14:23 up 52 days,  9:35,  0 users,  load average: 0.90, 0.45, 0.42
/dev/sda7             22292052   4427644  16713756  21% /
/dev/sda5             12192608    383656  11179608   4% /tmp
/dev/sda3             12192636   1007544  10555748   9% /var
/dev/sda1               101086     18614     77253  20% /boot
/dev/sdc1             41279536  26315936  12866720  68% /usr
/dev/sdb             152754284  68551860  76442964  48% /scr
tmpfs                  6149552         0   6149552   0% /dev/shm
10.10.10.86:/home    198351872  99673088  88439808  53% /home
10.10.10.86:/mnt/hdf 961432576 888706048  23888896  98% /mnt/hdf
10.10.10.86:/mnt/scr1
                     961432576 848011264  64582656  93% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Thu May 19 21:14:33 CDT 2016
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-409.el5 #1 SMP Tue Mar 15 18:13:50 EDT 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/koala_0519Thu_2114
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Thu May 19 21:15:07 CDT 2016
Total time = 0m 34s
*** finished tests in koala ***
Thu May 19 21:15:08 CDT 2016
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
 21:14:26 up 52 days,  6:36,  2 users,  load average: 0.00, 0.22, 0.66
/dev/sda6             54205540  23413492  28031908  46% /
tmpfs                  6099068         0   6099068   0% /dev/shm
/dev/sda1               194241     48310    135691  27% /boot
/dev/sda2             12850716    350668  11840592   3% /tmp
/dev/sda3             12850716   7694600   4496660  64% /var
/dev/sdd             152623212 121480820  23382932  84% /scr
                     961432576 848012288  64582656  93% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Thu May 19 21:14:36 CDT 2016
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.22.1.el6.x86_64 #1 SMP Wed Mar 23 03:35:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/platypus_0519Thu_2114
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Thu May 19 21:15:39 CDT 2016
Total time = 1m 3s
*** finished tests in platypus ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
 21:14:28 up 92 days,  5:07,  0 users,  load average: 0.39, 0.90, 0.93
/dev/mapper/vg_ostrich-lv_root
                      140479384  24275176  109065164  19% /
tmpfs                   7821568         0    7821568   0% /dev/shm
/dev/sda2                487652    100521     361531  22% /boot
/dev/sdb2             124477364  91501048   26646564  78% /scr
jam:/home             198351872  99673088   88439808  53% /home
jam:/mnt/hdf          961432576 888706048   23888896  98% /mnt/hdf
jam:/mnt/scr1         961432576 848012288   64581632  93% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Thu May 19 21:14:38 CDT 2016
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-573.18.1.el6.ppc64 #1 SMP Wed Jan 6 11:15:06 EST 2016 ppc64 ppc64 ppc64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0519Thu_2114
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Thu May 19 21:16:11 CDT 2016
Total time = 1m 33s
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich ***
   /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0519Thu_2116
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich ***
Thu May 19 21:19:12 CDT 2016
Total time = 3m 1s
*** finished tests in ostrich ***
Testing quail
ssh -o ConnectTimeout=60 quail -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname quail
/home/hdftest/snapshots-opa: No such file or directory.
****SYSTEM ERROR quail: Abnormal exit from runtest ****
	****SYSTEM ERROR quail: runtest command failed ****
Testing kite
ssh -o ConnectTimeout=60 kite -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
21:14  up 92 days,  4:53, 0 users, load averages: 0.11 0.04 0.06
Filesystem            512-blocks       Used  Available Capacity  iused     ifree %iused  Mounted on
/dev/disk0s2          1951845952  260059080 1691274872    14% 32571383 211409359   13%   /
devfs                        372        372          0   100%      644         0  100%   /dev
/dev/disk1s2          1952853344    1296608 1951556736     1%   162074 243944592    0%   /Volumes/Milvinae
10.10.10.86:/mnt/hdf  1922864144 1777412384   47775760    98% 11014232 111095720    9%   /mnt/hdf
10.10.10.86:/mnt/scr1 1922864144 1696025856  129162288    93%  4256422 117853530    3%   /mnt/scr1
10.10.10.86:/home      396703680  199347672  176879288    53%  1020230  50196154    2%   /home
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
Thu May 19 21:14:43 CDT 2016
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests in kite ***
Uname -a: Darwin kite.ad.hdfgroup.org 12.6.0 Darwin Kernel Version 12.6.0: Wed Mar 18 16:23:48 PDT 2015; root:xnu-2050.48.19~1/RELEASE_X86_64 x86_64
   /Users/hdftest/snapshots-opa/log/kite_0519Thu_2114
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests for kite ***
Thu May 19 21:15:27 CDT 2016
Total time = 0m 44s
*** finished tests in kite ***
More information about the opa-nightly-tests mailing list
