[opa-nightly-tests] jam OPA_Daily_Tests_0627Mon
HDF Tester
hdftest at hdfgroup.org
Mon Jun 27 21:20:43 CDT 2016
*** OPA Tests on 0627Mon ***
Tests Summary
PASSED emu: setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
PASSED kite: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
PASSED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Tests Time Summary
koala: Ran 1(1/0/0) tests, Grand total test time = 0m 33s
platypus: Ran 1(1/0/0) tests, Grand total test time = 0m 44s
kite: Ran 1(1/0/0) tests, Grand total test time = 0m 47s
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 1s
ostrich: Ran 2(2/0/0) tests, Grand total test time = 4m 29s
emu: Ran 1(1/0/0) tests, Grand total test time = 11m 36s
jam: Ran 7(0/0/0) hosts, Grand total test time = 12m 32s
Timekeeper log
Timekeeper started at Mon Jun 27 21:08:22 CDT 2016
Timekeeper sleeping for 720 seconds
Timekeeper woke up at Mon Jun 27 21:20:22 CDT 2016, looking for processes to terminate...
Timekeeper ended at Mon Jun 27 21:20:22 CDT 2016
Tests Failures
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
21:08:01 up 130 days, 12:07, 15 users, load average: 0.37, 0.43, 0.32
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 10956916 19143276 37% /
/dev/sda1 101086 17532 78335 19% /boot
/dev/sda2 31738420 231616 29868576 1% /tmp
/dev/sda6 31738392 5895564 24204604 20% /var
/dev/sda7 31738392 18539068 11561100 62% /usr
/dev/sda8 124991068 192216 118347152 1% /var/tmp
tmpfs 8313628 0 8313628 0% /dev/shm
10.10.10.15:/volume1/hdf2
1437485440 299300480 1138082560 21% /mnt/hdf2
10.10.10.15:/volume1/hdf3
1437485440 299300480 1138082560 21% /mnt/hdf3
10.10.10.15:/volume1/readonly
1437485440 299300480 1138082560 21% /mnt/readonly
1437485440 299300480 1138082560 21% /mnt/ro-src
1437485440 299300480 1138082560 21% /mnt/rw-src
/dev/mapper/VolGroup00-home
198351840 117157176 70956304 63% /home
/dev/sde1 565688764 434487304 102002524 81% /scr
/dev/sdc1 961432072 861947736 50646336 95% /mnt/scr1
/dev/sdd1 961432072 841940816 70653256 93% /mnt/hdf
gumund:/data/ftp 480719104 273177344 183122560 60% /mnt/ftp
gumund:/data/web 480719104 273177344 183122560 60% /mnt/web
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0627Mon
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0627Mon.11598: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0627Mon.11598': No such file or directory
*** launching tests from jam ***
TESTHOST is emu
jam
koala
platypus
ostrich
quail
kite
Fork off timekeeper 12
Testing emu
ssh -o ConnectTimeout=60 emu -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname emu
9:08pm up 193 day(s), 3:20, 1 user, load average: 0.77, 1.73, 1.92
/ (rpool/ROOT/solaris):335279892 blocks 335279892 files
/devices (/devices ): 0 blocks 0 files
/dev (/dev ): 0 blocks 0 files
/system/contract (ctfs ): 0 blocks 2147483591 files
/proc (proc ): 0 blocks 29930 files
/etc/mnttab (mnttab ): 0 blocks 0 files
/system/volatile (swap ):17119168 blocks 2146136 files
/system/object (objfs ): 0 blocks 2147483467 files
/etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
/dev/fd (fd ): 0 blocks 0 files
/var (rpool/ROOT/solaris/var):335279892 blocks 335279892 files
/tmp (swap ):17119168 blocks 2146136 files
/var/share (rpool/VARSHARE ):335279892 blocks 335279892 files
/export (rpool/export ):335279892 blocks 335279892 files
/export/home (rpool/export/home ):335279892 blocks 335279892 files
/export/home/kurz (rpool/export/home/kurz):335279892 blocks 335279892 files
/rpool (rpool ):335279892 blocks 335279892 files
/home (jam.ad.hdfgroup.org:/home):162389328 blocks 49945155 files
/mnt/web (gumund.ad.hdfgroup.org:/mnt/web):415083472 blocks 60871765 files
/mnt/ftp (gumund.ad.hdfgroup.org:/mnt/ftp):415083472 blocks 60871765 files
/mnt/scr1 (jam.ad.hdfgroup.org:/mnt/scr1):198968568 blocks 117858646 files
/mnt/hdf (jam.ad.hdfgroup.org:/mnt/hdf):238982512 blocks 110847585 files
/mnt/ro-src (10.10.10.15:/volume1/readonly):2276369904 blocks 91105837 files
TEST_TYPES=setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64
Extract source and run autogen if .
Monday, June 27, 2016 09:08:37 PM CDT
*** starting setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64 tests in emu ***
Uname -a: SunOS emu 5.11 11.1 sun4v sparc sun4v
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/emu_0627Mon_2108
*** finished setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64 tests for emu ***
Monday, June 27, 2016 09:20:13 PM CDT
Total time = 11m 36s
*** finished tests in emu ***
Testing jam
ssh -o ConnectTimeout=60 jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
21:08:29 up 130 days, 12:08, 15 users, load average: 0.42, 0.43, 0.33
/dev/sda2 31738420 231724 29868468 1% /tmp
/dev/sda6 31738392 5895632 24204536 20% /var
/dev/sdc1 961432072 861947796 50646276 95% /mnt/scr1
Mon Jun 27 21:08:39 CDT 2016
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/jam_0627Mon_2108
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Mon Jun 27 21:09:40 CDT 2016
Total time = 1m 1s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
21:08:31 up 91 days, 9:29, 0 users, load average: 0.02, 0.20, 0.35
/dev/sda7 22292052 4427652 16713748 21% /
/dev/sda5 12192608 383456 11179808 4% /tmp
/dev/sda3 12192636 1004716 10558576 9% /var
/dev/sda1 101086 18614 77253 20% /boot
/dev/sdc1 41279536 26315936 12866720 68% /usr
/dev/sdb 152754284 68459108 76535716 48% /scr
tmpfs 6149552 0 6149552 0% /dev/shm
10.10.10.86:/home 198351872 117156864 70957056 63% /home
10.10.10.86:/mnt/hdf 961432576 841940992 70653952 93% /mnt/hdf
10.10.10.86:/mnt/scr1
961432576 861947904 50647040 95% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Mon Jun 27 21:08:41 CDT 2016
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-409.el5 #1 SMP Tue Mar 15 18:13:50 EDT 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/koala_0627Mon_2108
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Mon Jun 27 21:09:14 CDT 2016
Total time = 0m 33s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
21:08:34 up 91 days, 6:30, 1 user, load average: 0.20, 0.33, 0.57
/dev/sda6 54205540 23413492 28031908 46% /
tmpfs 6099068 0 6099068 0% /dev/shm
/dev/sda1 194241 48310 135691 27% /boot
/dev/sda2 12850716 193312 11997948 2% /tmp
/dev/sda3 12850716 6052116 6139144 50% /var
/dev/sdd 152623212 118947264 25916488 83% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Mon Jun 27 21:08:44 CDT 2016
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.22.1.el6.x86_64 #1 SMP Wed Mar 23 03:35:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/platypus_0627Mon_2108
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Mon Jun 27 21:09:28 CDT 2016
Total time = 0m 44s
*** finished tests in platypus ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
21:08:36 up 131 days, 5:01, 0 users, load average: 0.07, 0.59, 0.71
/dev/mapper/vg_ostrich-lv_root
140479384 23439576 109900764 18% /
tmpfs 7821568 0 7821568 0% /dev/shm
/dev/sda2 487652 100521 361531 22% /boot
/dev/sdb2 124477364 91780824 26366788 78% /scr
jam:/home 198351872 117156864 70957056 63% /home
jam:/mnt/hdf 961432576 841940992 70653952 93% /mnt/hdf
jam:/mnt/scr1 961432576 861947904 50647040 95% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Mon Jun 27 21:08:46 CDT 2016
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-573.18.1.el6.ppc64 #1 SMP Wed Jan 6 11:15:06 EST 2016 ppc64 ppc64 ppc64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0627Mon_2108
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Mon Jun 27 21:10:18 CDT 2016
Total time = 1m 32s
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich ***
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0627Mon_2110
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich ***
Mon Jun 27 21:13:15 CDT 2016
Total time = 2m 57s
*** finished tests in ostrich ***
Testing quail
ssh -o ConnectTimeout=60 quail -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname quail
/home/hdftest/snapshots-opa: No such file or directory.
****SYSTEM ERROR quail: Abnormal exit from runtest ****
****SYSTEM ERROR quail: runtest command failed ****
Testing kite
ssh -o ConnectTimeout=60 kite -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
21:08 up 131 days, 4:47, 0 users, load averages: 0.12 0.11 0.09
Filesystem 512-blocks Used Available Capacity iused ifree %iused Mounted on
/dev/disk0s2 1951845952 257446960 1693886992 14% 32244868 211735874 13% /
devfs 372 372 0 100% 645 0 100% /dev
/dev/disk1s2 1952853344 1296608 1951556736 1% 162074 243944592 0% /Volumes/Milvinae
10.10.10.86:/mnt/hdf 1922864144 1683881632 141306512 93% 11262367 110847585 9% /mnt/hdf
10.10.10.86:/mnt/scr1 1922864144 1723895744 101292400 95% 4251320 117858632 3% /mnt/scr1
10.10.10.86:/home 396703680 234314352 141912608 63% 1271229 49945155 2% /home
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
Mon Jun 27 21:08:52 CDT 2016
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests in kite ***
Uname -a: Darwin kite.ad.hdfgroup.org 12.6.0 Darwin Kernel Version 12.6.0: Wed Mar 18 16:23:48 PDT 2015; root:xnu-2050.48.19~1/RELEASE_X86_64 x86_64
/Users/hdftest/snapshots-opa/log/kite_0627Mon_2108
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests for kite ***
Mon Jun 27 21:09:39 CDT 2016
Total time = 0m 47s
*** finished tests in kite ***
More information about the opa-nightly-tests
