[opa-nightly-tests] jam OPA_Daily_Tests_0604Sat
HDF Tester hdftest at hdfgroup.org
Sat Jun 4 21:26:12 CDT 2016
*** OPA Tests on 0604Sat ***
   Tests Summary
PASSED emu: standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
PASSED kite: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
PASSED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
   Tests Time Summary
koala: Ran 1(1/0/0) tests, Grand total test time =  0m 34s
platypus: Ran 1(1/0/0) tests, Grand total test time =  0m 56s
kite: Ran 1(1/0/0) tests, Grand total test time =  0m 48s
jam: Ran 1(1/0/0) tests, Grand total test time =  1m 2s
ostrich: Ran 2(2/0/0) tests, Grand total test time =  4m 41s
emu: Ran 1(1/0/0) tests, Grand total test time =  11m 35s
jam: Ran 7(0/0/0) hosts, Grand total test time =  12m 31s
   Timekeeper log
Timekeeper started at Sat Jun  4 21:13:52 CDT 2016
Timekeeper sleeping for 720 seconds
Timekeeper woke up at Sat Jun  4 21:25:52 CDT 2016, looking for processes to terminate...
Timekeeper ended at Sat Jun  4 21:25:52 CDT 2016
   Tests Failures
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 21:13:31 up 107 days, 12:13, 33 users,  load average: 0.04, 0.12, 0.20
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda3             31738420  10523420  19576772  35% /
/dev/sda1               101086     17532     78335  19% /boot
/dev/sda2             31738420    215072  29885120   1% /tmp
/dev/sda6             31738392   5991708  24108460  20% /var
/dev/sda7             31738392  18539068  11561100  62% /usr
/dev/sda8            124991068    192232 118347136   1% /var/tmp
tmpfs                  8313628         0   8313628   0% /dev/shm
10.10.10.15:/volume1/hdf2
                     1437485440 295873152 1141509888  21% /mnt/hdf2
10.10.10.15:/volume1/hdf3
                     1437485440 295873152 1141509888  21% /mnt/hdf3
10.10.10.15:/volume1/readonly
                     1437485440 295873152 1141509888  21% /mnt/readonly
                     1437485440 295873152 1141509888  21% /mnt/ro-src
                     1437485440 295873152 1141509888  21% /mnt/rw-src
/dev/mapper/VolGroup00-home
                     198351840  99772708  88340772  54% /home
/dev/sde1            565688764 432189484 104300344  81% /scr
/dev/sdc1            961432072 857544100  55049972  94% /mnt/scr1
/dev/sdd1            961432072 886515884  26078188  98% /mnt/hdf
gumund:/data/ftp     480719104 267766400 188533504  59% /mnt/ftp
gumund:/data/web     480719104 267766400 188533504  59% /mnt/web
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0604Sat
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0604Sat.15058: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0604Sat.15058': No such file or directory
*** launching tests from jam ***
TESTHOST is emu
jam
koala
platypus
ostrich
quail
kite
    Fork off timekeeper 12
Testing emu
ssh -o ConnectTimeout=60 emu -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname emu
  9:13pm  up 170 day(s),  3:25,  0 users,  load average: 0.02, 0.75, 1.50
/                  (rpool/ROOT/solaris):330774526 blocks 330774526 files
/devices           (/devices          ):       0 blocks        0 files
/dev               (/dev              ):       0 blocks        0 files
/system/contract   (ctfs              ):       0 blocks 2147483592 files
/proc              (proc              ):       0 blocks    29933 files
/etc/mnttab        (mnttab            ):       0 blocks        0 files
/system/volatile   (swap              ):20701984 blocks  2151208 files
/system/object     (objfs             ):       0 blocks 2147483467 files
/etc/dfs/sharetab  (sharefs           ):       0 blocks 2147483646 files
/dev/fd            (fd                ):       0 blocks        0 files
/var               (rpool/ROOT/solaris/var):330774526 blocks 330774526 files
/tmp               (swap              ):20701984 blocks  2151208 files
/var/share         (rpool/VARSHARE    ):330774526 blocks 330774526 files
/export            (rpool/export      ):330774526 blocks 330774526 files
/export/home       (rpool/export/home ):330774526 blocks 330774526 files
/export/home/kurz  (rpool/export/home/kurz):330774526 blocks 330774526 files
/rpool             (rpool             ):330774526 blocks 330774526 files
/home              (jam.ad.hdfgroup.org:/home):197158264 blocks 50194551 files
/mnt/web           (gumund.ad.hdfgroup.org:/mnt/web):425905200 blocks 60870977 files
/mnt/ftp           (gumund.ad.hdfgroup.org:/mnt/ftp):425905200 blocks 60870977 files
/mnt/scr1          (jam.ad.hdfgroup.org:/mnt/scr1):207775888 blocks 117840936 files
/mnt/hdf           (jam.ad.hdfgroup.org:/mnt/hdf):149832376 blocks 111068292 files
/mnt/ro-src        (10.10.10.15:/volume1/readonly):2283224544 blocks 91105876 files
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32
Extract source and run autogen if .
Saturday, June  4, 2016 09:14:07 PM CDT
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32 tests in emu ***
Uname -a: SunOS emu 5.11 11.1 sun4v sparc sun4v
Running snapshot with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/emu_0604Sat_2114
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32 tests for emu ***
Saturday, June  4, 2016 09:25:42 PM CDT
Total time = 11m 35s
*** finished tests in emu ***
Testing jam
ssh -o ConnectTimeout=60 jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
 21:13:59 up 107 days, 12:13, 33 users,  load average: 0.17, 0.14, 0.20
/dev/sda2             31738420    215180  29885012   1% /tmp
/dev/sdc1            961432072 857544136  55049936  94% /mnt/scr1
Sat Jun  4 21:14:09 CDT 2016
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/jam_0604Sat_2114
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Sat Jun  4 21:15:11 CDT 2016
Total time = 1m 2s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
 21:14:01 up 68 days,  9:34,  0 users,  load average: 0.99, 0.58, 0.45
/dev/sda7             22292052   4427648  16713752  21% /
/dev/sda5             12192608    383396  11179868   4% /tmp
/dev/sda3             12192636   1004796  10558496   9% /var
/dev/sda1               101086     18614     77253  20% /boot
/dev/sdc1             41279536  26315936  12866720  68% /usr
/dev/sdb             152754284  68668420  76326404  48% /scr
tmpfs                  6149552         0   6149552   0% /dev/shm
10.10.10.86:/home    198351872  99772416  88341504  54% /home
10.10.10.86:/mnt/hdf 961432576 886515712  26078208  98% /mnt/hdf
10.10.10.86:/mnt/scr1
                     961432576 857543680  55050240  94% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Sat Jun  4 21:14:12 CDT 2016
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-409.el5 #1 SMP Tue Mar 15 18:13:50 EDT 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/koala_0604Sat_2114
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Sat Jun  4 21:14:45 CDT 2016
Total time = 0m 33s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
 21:14:04 up 68 days,  6:36,  2 users,  load average: 0.00, 0.23, 0.66
/dev/sda6             54205540  23413492  28031908  46% /
tmpfs                  6099068         0   6099068   0% /dev/shm
/dev/sda1               194241     48310    135691  27% /boot
/dev/sda2             12850716    208196  11983064   2% /tmp
/dev/sda3             12850716   7148276   5042984  59% /var
/dev/sdd             152623212 122373720  22490032  85% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Sat Jun  4 21:14:14 CDT 2016
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.22.1.el6.x86_64 #1 SMP Wed Mar 23 03:35:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/platypus_0604Sat_2114
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Sat Jun  4 21:15:10 CDT 2016
Total time = 0m 56s
*** finished tests in platypus ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
 21:14:07 up 108 days,  5:07,  1 user,  load average: 0.31, 0.83, 0.86
/dev/mapper/vg_ostrich-lv_root
                      140479384  24202300  109138040  19% /
tmpfs                   7821568         0    7821568   0% /dev/shm
/dev/sda2                487652    100521     361531  22% /boot
/dev/sdb2             124477364  91063844   27083768  78% /scr
jam:/home             198351872  99772416   88341504  54% /home
jam:/mnt/hdf          961432576 886515712   26078208  98% /mnt/hdf
jam:/mnt/scr1         961432576 857543680   55050240  94% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Sat Jun  4 21:14:17 CDT 2016
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-573.18.1.el6.ppc64 #1 SMP Wed Jan 6 11:15:06 EST 2016 ppc64 ppc64 ppc64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0604Sat_2114
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Sat Jun  4 21:15:50 CDT 2016
Total time = 1m 33s
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich ***
   /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0604Sat_2115
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich ***
Sat Jun  4 21:18:58 CDT 2016
Total time = 3m 8s
*** finished tests in ostrich ***
Testing quail
ssh -o ConnectTimeout=60 quail -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname quail
/home/hdftest/snapshots-opa: No such file or directory.
****SYSTEM ERROR quail: Abnormal exit from runtest ****
	****SYSTEM ERROR quail: runtest command failed ****
Testing kite
ssh -o ConnectTimeout=60 kite -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
21:14  up 108 days,  4:52, 0 users, load averages: 0.23 0.17 0.17
Filesystem            512-blocks       Used  Available Capacity  iused     ifree %iused  Mounted on
/dev/disk0s2          1951845952  256665160 1694668792    14% 32147143 211833599   13%   /
devfs                        372        372          0   100%      644         0  100%   /dev
/dev/disk1s2          1952853344    1296608 1951556736     1%   162074 243944592    0%   /Volumes/Milvinae
10.10.10.86:/mnt/hdf  1922864144 1773031768   52156376    98% 11041660 111068292    9%   /mnt/hdf
10.10.10.86:/mnt/scr1 1922864144 1715088400  110099744    94%  4269030 117840922    3%   /mnt/scr1
10.10.10.86:/home      396703680  199545416  176681544    54%  1021833  50194551    2%   /home
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
Sat Jun  4 21:14:22 CDT 2016
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests in kite ***
Uname -a: Darwin kite.ad.hdfgroup.org 12.6.0 Darwin Kernel Version 12.6.0: Wed Mar 18 16:23:48 PDT 2015; root:xnu-2050.48.19~1/RELEASE_X86_64 x86_64
   /Users/hdftest/snapshots-opa/log/kite_0604Sat_2114
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests for kite ***
Total time = 0m 48s
*** finished tests in kite ***
More information about the opa-nightly-tests mailing list
