[opa-nightly-tests] jam OPA_Daily_Tests_0808Mon_FAILED!!!
HDF Tester
hdftest at hdfgroup.org
Mon Aug 8 00:24:14 CDT 2016
*** OPA Tests on 0808Mon ***
Tests Summary
****FAILED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich****
PASSED emu: setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
PASSED kite: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
PASSED quail: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Tests Time Summary
koala: Ran 1(1/0/0) tests, Grand total test time = 0m 32s
kite: Ran 1(1/0/0) tests, Grand total test time = 0m 47s
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 1s
quail: Ran 1(1/0/0) tests, Grand total test time = 0m 55s
platypus: Ran 1(1/0/0) tests, Grand total test time = 1m 31s
emu: Ran 1(1/0/0) tests, Grand total test time = 9m 8s
ostrich: Ran 2(1/1/0) tests, Grand total test time = 10m 1s
jam: Ran 7(0/0/0) hosts, Grand total test time = 11m 6s
Timekeeper log
Timekeeper started at Mon Aug 8 00:13:18 CDT 2016
Timekeeper sleeping for 720 seconds
Tests Failures
Dumping logfile of ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0808Mon_0013
Testing pointer swap with 100 threads PASSED
Testing integer LL/SC stack with 100 threads PASSED
Testing pointer LL/SC stack with 100 threads PASSED
All primitives tests passed.
PASS: test_primitives
Testing memory barrier sanity PASSED
Testing memory barriers with linear array with 2 threads PASSED
Testing memory barriers with local variables with 2 threads PASSED
Testing memory barriers with scattered array with 2 threads PASSED
Testing memory barriers with linear array with 4 threads PASSED
Testing memory barriers with local variables with 4 threads PASSED
Testing memory barriers with scattered array with 4 threads PASSED
Testing memory barriers with linear array with 10 threads PASSED
Testing memory barriers with local variables with 10 threads PASSED
Testing memory barriers with scattered array with 10 threads PASSED
Testing memory barriers with linear array with 100 threads PASSED
Testing memory barriers with local variables with 100 threads PASSED
Testing memory barriers with scattered array with 100 threads PASSED
All barriers tests passed.
PASS: test_barriers
Testing queue sanity PASSED
Testing multithreaded queue with 2 threads PASSED
Testing multithreaded queue (empty queue) with 2 threads Incorrect number of elements dequeued: 168013 Expected: 500000
*FAILED*
at /home/hdftest/snapshots-opa/current/test/test_queue.c:399 in test_queue_threaded()...
Unexpected return from 1 thread
Testing multithreaded queue (full queue) with 2 threads PASSED
Testing multithreaded queue with 4 threads PASSED
Testing multithreaded queue (empty queue) with 4 threads PASSED
Testing multithreaded queue (full queue) with 4 threads PASSED
Testing multithreaded queue with 10 threads PASSED
Testing multithreaded queue (empty queue) with 10 threads PASSED
Testing multithreaded queue (full queue) with 10 threads PASSED
Testing multithreaded queue with 100 threads PASSED
Testing multithreaded queue (empty queue) with 100 threads PASSED
Testing multithreaded queue (full queue) with 100 threads PASSED
***** 1 QUEUE TEST FAILED! *****
FAIL: test_queue
1 of 4 tests failed
Please report to https://trac.mcs.anl.gov/projects/openpa/newticket
gmake[2]: *** [check-TESTS] Error 1
gmake[2]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/ostrich/test'
gmake[1]: *** [check-am] Error 2
gmake[1]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/ostrich/test'
gmake: *** [check-recursive] Error 1
Failed running make check
===== Exit bin/snapshot with status=2: Mon Aug 8 00:20:34 CDT 2016 =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
00:12:57 up 20 days, 10:55, 18 users, load average: 1.39, 1.00, 0.52
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 22591060 7509132 76% /
/dev/sda1 101086 17532 78335 19% /boot
/dev/sda2 31738420 181300 29918892 1% /tmp
/dev/sda6 31738392 5274276 24825892 18% /var
/dev/sda7 31738392 18534740 11565428 62% /usr
/dev/sda8 124991068 251356 118288012 1% /var/tmp
/dev/mapper/VolGroup00-home
198351840 117491512 70621968 63% /home
/dev/sdc1 961432072 881030112 31563960 97% /mnt/scr1
/dev/sdd1 961432072 851939024 60655048 94% /mnt/hdf
tmpfs 8313628 0 8313628 0% /dev/shm
gumund:/data/ftp 480719104 277559936 178739968 61% /mnt/ftp
gumund:/data/web 480719104 277559936 178739968 61% /mnt/web
10.10.10.15:/volume1/hdf2
1437485440 299302272 1138080768 21% /mnt/hdf2
10.10.10.15:/volume1/hdf3
1437485440 299302272 1138080768 21% /mnt/hdf3
10.10.10.15:/volume1/readonly
1437485440 299302272 1138080768 21% /mnt/readonly
1437485440 299302272 1138080768 21% /mnt/ro-src
1437485440 299302272 1138080768 21% /mnt/rw-src
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0808Mon
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0808Mon.19322: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0808Mon.19322': No such file or directory
*** launching tests from jam ***
TESTHOST is emu
jam
koala
platypus
ostrich
quail
kite
Fork off timekeeper 12
Testing emu
ssh -o ConnectTimeout=60 emu -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname emu
12:13am up 234 day(s), 6:24, 0 users, load average: 1.14, 0.89, 0.55
/ (rpool/ROOT/solaris):336891551 blocks 336891551 files
/devices (/devices ): 0 blocks 0 files
/dev (/dev ): 0 blocks 0 files
/system/contract (ctfs ): 0 blocks 2147483591 files
/proc (proc ): 0 blocks 29926 files
/etc/mnttab (mnttab ): 0 blocks 0 files
/system/volatile (swap ):16405712 blocks 2139681 files
/system/object (objfs ): 0 blocks 2147483465 files
/etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
/dev/fd (fd ): 0 blocks 0 files
/var (rpool/ROOT/solaris/var):336891551 blocks 336891551 files
/tmp (swap ):16405712 blocks 2139681 files
/var/share (rpool/VARSHARE ):336891551 blocks 336891551 files
/export (rpool/export ):336891551 blocks 336891551 files
/export/home (rpool/export/home ):336891551 blocks 336891551 files
/export/home/kurz (rpool/export/home/kurz):336891551 blocks 336891551 files
/rpool (rpool ):336891551 blocks 336891551 files
/home (jam.ad.hdfgroup.org:/home):161720656 blocks 49942520 files
/mnt/web (gumund.ad.hdfgroup.org:/mnt/web):406318192 blocks 60871708 files
/mnt/ftp (gumund.ad.hdfgroup.org:/mnt/ftp):406318192 blocks 60871708 files
/mnt/scr1 (jam.ad.hdfgroup.org:/mnt/scr1):160802304 blocks 117712758 files
/mnt/hdf (jam.ad.hdfgroup.org:/mnt/hdf):218986096 blocks 110661224 files
/mnt/ro-src (10.10.10.15:/volume1/readonly):2276366104 blocks 91105822 files
TEST_TYPES=setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64
Extract source and run autogen if .
Monday, August 8, 2016 12:13:33 AM CDT
*** starting setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64 tests in emu ***
Uname -a: SunOS emu 5.11 11.1 sun4v sparc sun4v
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/emu_0808Mon_0013
*** finished setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64 tests for emu ***
Monday, August 8, 2016 12:22:41 AM CDT
Total time = 9m 8s
*** finished tests in emu ***
Testing jam
ssh -o ConnectTimeout=60 jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
00:13:25 up 20 days, 10:55, 18 users, load average: 1.40, 1.03, 0.54
/dev/sda2 31738420 181408 29918784 1% /tmp
/dev/sda6 31738392 5274380 24825788 18% /var
/dev/sdc1 961432072 881030964 31563108 97% /mnt/scr1
Mon Aug 8 00:13:35 CDT 2016
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/jam_0808Mon_0013
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Mon Aug 8 00:14:36 CDT 2016
Total time = 1m 1s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
00:13:27 up 132 days, 12:34, 0 users, load average: 0.00, 0.00, 0.00
/dev/sda7 22292052 4427656 16713744 21% /
/dev/sda5 12192608 371580 11191684 4% /tmp
/dev/sda3 12192636 985104 10578188 9% /var
/dev/sda1 101086 18614 77253 20% /boot
/dev/sdc1 41279536 26315936 12866720 68% /usr
/dev/sdb 152754284 68398044 76596780 48% /scr
tmpfs 6149552 0 6149552 0% /dev/shm
10.10.10.86:/home 198351872 117490688 70622208 63% /home
10.10.10.86:/mnt/hdf 961432576 851939328 60655616 94% /mnt/hdf
10.10.10.86:/mnt/scr1
961432576 881031168 31563776 97% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Mon Aug 8 00:13:37 CDT 2016
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-409.el5 #1 SMP Tue Mar 15 18:13:50 EDT 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/koala_0808Mon_0013
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Mon Aug 8 00:14:09 CDT 2016
Total time = 0m 32s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
00:13:30 up 132 days, 9:35, 0 users, load average: 2.32, 0.88, 0.46
/dev/sda6 54205540 23413492 28031908 46% /
tmpfs 6099068 0 6099068 0% /dev/shm
/dev/sda1 194241 48310 135691 27% /boot
/dev/sda2 12850716 153228 12038032 2% /tmp
/dev/sda3 12850716 5085060 7106200 42% /var
/dev/sdd 152623212 116562432 28301320 81% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Mon Aug 8 00:13:40 CDT 2016
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.22.1.el6.x86_64 #1 SMP Wed Mar 23 03:35:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/platypus_0808Mon_0013
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Mon Aug 8 00:15:11 CDT 2016
Total time = 1m 31s
*** finished tests in platypus ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
00:13:32 up 172 days, 8:06, 1 user, load average: 11.21, 8.57, 7.11
/dev/mapper/vg_ostrich-lv_root
140479384 23312376 110027964 18% /
tmpfs 7821568 0 7821568 0% /dev/shm
/dev/sda2 487652 100521 361531 22% /boot
/dev/sdb2 124477364 90587048 27560564 77% /scr
jam:/home 198351872 117490688 70622208 63% /home
jam:/mnt/hdf 961432576 851939328 60655616 94% /mnt/hdf
jam:/mnt/scr1 961432576 881031168 31563776 97% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Mon Aug 8 00:13:46 CDT 2016
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-573.18.1.el6.ppc64 #1 SMP Wed Jan 6 11:15:06 EST 2016 ppc64 ppc64 ppc64 GNU/Linux
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Total time = 6m 48s
Mon Aug 8 00:20:35 CDT 2016
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich ***
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0808Mon_0020
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich ***
Mon Aug 8 00:23:43 CDT 2016
Total time = 3m 9s
*** finished tests in ostrich ***
****SYSTEM ERROR ostrich: Abnormal exit from runtest ****
Mon Aug 8 00:24:13 CDT 2016
****SYSTEM ERROR ostrich: runtest command failed ****
Testing quail
ssh -o ConnectTimeout=60 quail -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname quail
0:13 up 75 days, 7:42, 1 user, load averages: 4.69 2.49 1.89
Filesystem 512-blocks Used Available Capacity iused ifree %iused Mounted on
/dev/disk0s2 488555536 257290184 230753352 53% 32225271 28844169 53% /
devfs 361 361 0 100% 626 0 100% /dev
map auto_nfs 0 0 0 100% 0 0 100% /home
map auto_nfs 0 0 0 100% 0 0 100% /mnt/hdf
map auto_nfs 0 0 0 100% 0 0 100% /mnt/scr1
jam.ad.hdfgroup.org:/mnt/scr1 1922864144 1762062232 63125912 97% 4397205 117712747 4% /mnt/scr1
jam.ad.hdfgroup.org:/mnt/hdf 1922864144 1703878048 121310096 94% 11448728 110661224 9% /mnt/hdf
jam.ad.hdfgroup.org:/home 396703680 234983024 141243936 63% 1273864 49942520 2% /home
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Mon Aug 8 00:13:45 CDT 2016
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests in quail ***
Uname -a: Darwin quail.ad.hdfgroup.org 13.4.0 Darwin Kernel Version 13.4.0: Mon Jan 11 18:17:34 PST 2016; root:xnu-2422.115.15~1/RELEASE_X86_64 x86_64
/Users/hdftest/snapshots-opa/log/quail_0808Mon_0013
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests for quail ***
Mon Aug 8 00:14:40 CDT 2016
Total time = 0m 55s
*** finished tests in quail ***
Testing kite
ssh -o ConnectTimeout=60 kite -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
0:13 up 172 days, 7:52, 0 users, load averages: 3.89 1.10 0.44
/dev/disk0s2 1951845952 257292056 1694041896 14% 32225505 211755237 13% /
devfs 372 372 0 100% 645 0 100% /dev
/dev/disk1s2 1952853344 1296608 1951556736 1% 162074 243944592 0% /Volumes/Milvinae
10.10.10.86:/mnt/hdf 1922864144 1703878048 121310096 94% 11448728 110661224 9% /mnt/hdf
10.10.10.86:/mnt/scr1 1922864144 1762061384 63126760 97% 4397191 117712761 4% /mnt/scr1
10.10.10.86:/home 396703680 234983024 141243936 63% 1273864 49942520 2% /home
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
Mon Aug 8 00:13:47 CDT 2016
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests in kite ***
Uname -a: Darwin kite.ad.hdfgroup.org 12.6.0 Darwin Kernel Version 12.6.0: Wed Mar 18 16:23:48 PDT 2015; root:xnu-2050.48.19~1/RELEASE_X86_64 x86_64
/Users/hdftest/snapshots-opa/log/kite_0808Mon_0013
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests for kite ***
Mon Aug 8 00:14:33 CDT 2016
Total time = 0m 46s
*** finished tests in kite ***
More information about the opa-nightly-tests
