[opa-nightly-tests] jam OPA_Daily_Tests_1029Thu_FAILED!!!
HDF Tester hdftest at hdfgroup.org
Thu Oct 29 01:03:30 CDT 2015
*** OPA Tests on 1029Thu ***
   Tests Summary
****FAILED emu: standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32****
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
PASSED kite: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
PASSED quail: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
   Tests Time Summary
emu: Ran 1(0/1/0) tests, Grand total test time =  0m 3s
koala: Ran 1(1/0/0) tests, Grand total test time =  0m 34s
platypus: Ran 1(1/0/0) tests, Grand total test time =  0m 52s
kite: Ran 1(1/0/0) tests, Grand total test time =  0m 45s
jam: Ran 1(1/0/0) tests, Grand total test time =  1m 3s
quail: Ran 1(1/0/0) tests, Grand total test time =  0m 57s
jam: Ran 7(0/0/0) hosts, Grand total test time =  12m 47s
   Timekeeper log
Timekeeper started at Thu Oct 29 00:50:59 CDT 2015
Timekeeper sleeping for 720 seconds
Timekeeper woke up at Thu Oct 29 01:02:59 CDT 2015, looking for processes to terminate...
terminating process PID.kite_kite (24189)
Remote shell command ended.  But some processes might still be
running in the remote machine.  Login there to verify.
terminating process PID.ostrich_ostrich (23192)
Timekeeper ended at Thu Oct 29 01:03:00 CDT 2015
   Tests Failures
Dumping logfile of emu: standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/emu_1029Thu_0050
GROUP=hdf
HDF5_ACLOCAL=/mnt/hdf/packages/AUTOTOOLS/automake/1.15/sun4v/bin/aclocal-1.15
HDF5_AUTOCONF=/mnt/hdf/packages/AUTOTOOLS/autoconf/2.69/sun4v/bin/autoconf
HDF5_AUTOHEADER=/mnt/hdf/packages/AUTOTOOLS/autoconf/2.69/sun4v/bin/autoheader
HDF5_AUTOMAKE=/mnt/hdf/packages/AUTOTOOLS/automake/1.15/sun4v/bin/automake-1.15
HDF5_LIBTOOL=/mnt/hdf/packages/AUTOTOOLS/libtool/2.4.6/sun4v/bin/libtool
HDF5_M4=/mnt/hdf/packages/AUTOTOOLS/m4/1.4.17/sun4v/bin/m4
HDF5TestExpress=yes
HOME=/home/hdftest
HOST=emu
HOSTTYPE=sun4
JAVA_HOME=/usr/lib/jvm/jre-1.6.0
LANG=en_US.UTF-8
LC_ALL=
LC_COLLATE=
LC_CTYPE=
LC_MESSAGES=
LC_MONETARY=
LC_NUMERIC=
LC_TIME=
LOGNAME=hdftest
MACHTYPE=sparc
MAIL=/var/mail/hdftest
MAKE=gmake
NLSPATH=/usr/share/locale/%L/LC_MESSAGES/%N.cat
OSTYPE=solaris
PATH=/home/hdftest/bin:/usr/hdf/bin:/home/hdftest/bin:/usr/hdf/bin:/usr/bin:/usr/sbin:/opt/solarisstudio/bin:/opt/cmake/bin:/opt/svn/bin:/mnt/hdf/ec2-api-tools/bin
PWD=/mnt/scr1/SnapTest/snapshots-opa
REMOTEHOST=
SET_PATH=yes
SHELL=/bin/tcsh
SHLVL=3
SSH_CLIENT=10.10.10.86 52892 22
SSH_CONNECTION=10.10.10.86 52892 10.10.10.84 22
SVNROOT=http://svn.hdfgroup.uiuc.edu
TZ=localtime
USER=hdftest
VENDOR=sun
===Done Dumping environment variables after option parsing ===
===== Run Tests: Thursday, October 29, 2015 12:50:33 AM CDT =====
Remove contents of emu.
diff: /home/hdftest/snapshots-opa/previous/MANIFEST: No such file or directory
===== configure: Thursday, October 29, 2015 12:50:33 AM CDT =====
checking for a BSD-compatible install... /usr/bin/ginstall -c
checking whether build environment is sane... configure: error: newly created file is older than distributed files!
Check your system clock
Failed running configure
===== Exit bin/snapshot with status=1: Thursday, October 29, 2015 12:50:35 AM CDT =====
Dumping done
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 00:50:33 up 28 days, 11:44, 12 users,  load average: 2.08, 1.76, 1.53
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda3             31738420   8841456  21258736  30% /
/dev/sda1               101086     17532     78335  19% /boot
/dev/sda2             31738420    182232  29917960   1% /tmp
/dev/sda6             31738392   5305968  24794200  18% /var
/dev/sda7             31738392  18498412  11601756  62% /usr
/dev/sda8            124991068    350356 118189012   1% /var/tmp
/dev/mapper/VolGroup00-home
                     198351840  94668048  93445432  51% /home
/dev/sde1            565688764 438716124  97773704  82% /scr
/dev/sdc1            961432072 775495812 137098260  85% /mnt/scr1
/dev/sdd1            961432072 879559528  33034544  97% /mnt/hdf
tmpfs                  8313628         0   8313628   0% /dev/shm
gumund:/data/ftp     480719104 401780864  54519040  89% /mnt/ftp
gumund:/data/web     480719104 401780864  54519040  89% /mnt/web
10.10.10.15:/volume1/hdf2
                     1437485440 239150464 1198232576  17% /mnt/hdf2
10.10.10.15:/volume1/hdf3
                     1437485440 239150464 1198232576  17% /mnt/hdf3
10.10.10.15:/volume1/readonly
                     1437485440 239150464 1198232576  17% /mnt/rw-src
                     1437485440 239150464 1198232576  17% /mnt/ro-src
                     1437485440 239150464 1198232576  17% /mnt/readonly
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_1029Thu
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1029Thu.21374: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1029Thu.21374': No such file or directory
*** launching tests from jam ***
TESTHOST is emu
jam
koala
platypus
ostrich
quail
kite
    Fork off timekeeper 12
Testing emu
ssh -o ConnectTimeout=60 emu -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname emu
 12:50am  up 122 day(s),  9:55,  1 user,  load average: 8.88, 8.50, 8.15
/                  (rpool/ROOT/solaris):427428686 blocks 427428686 files
/devices           (/devices          ):       0 blocks        0 files
/dev               (/dev              ):       0 blocks        0 files
/system/contract   (ctfs              ):       0 blocks 2147483583 files
/proc              (proc              ):       0 blocks    29852 files
/etc/mnttab        (mnttab            ):       0 blocks        0 files
/system/volatile   (swap              ):25206416 blocks  2195019 files
/system/object     (objfs             ):       0 blocks 2147483464 files
/etc/dfs/sharetab  (sharefs           ):       0 blocks 2147483646 files
/dev/fd            (fd                ):       0 blocks        0 files
/var               (rpool/ROOT/solaris/var):427428686 blocks 427428686 files
/tmp               (swap              ):25206416 blocks  2195019 files
/var/share         (rpool/VARSHARE    ):427428686 blocks 427428686 files
/rpool             (rpool             ):427428686 blocks 427428686 files
/export            (rpool/export      ):427428686 blocks 427428686 files
/export/home       (rpool/export/home ):427428686 blocks 427428686 files
/export/home/kurz  (rpool/export/home/kurz):427428686 blocks 427428686 files
/home              (jam.ad.hdfgroup.org:/home):207367584 blocks 50206655 files
/mnt/hdf           (jam.ad.hdfgroup.org:/mnt/hdf):163745088 blocks 111443419 files
/mnt/scr1          (jam.ad.hdfgroup.org:/mnt/scr1):371856104 blocks 117865203 files
/mnt/ro-src        (10.10.10.15:/volume1/readonly):2396669944 blocks 91175554 files
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32
Extract source and run autogen if .
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32 tests in emu ***
Uname -a: SunOS emu 5.11 11.1 sun4v sparc sun4v
Running snapshot with output saved in
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32 tests for emu ***
Total time = 0m 2s
*** finished tests in emu ***
****SYSTEM ERROR emu: Abnormal exit from runtest ****
	****SYSTEM ERROR emu: runtest command failed ****
Testing jam
ssh -o ConnectTimeout=60 jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
 00:51:08 up 28 days, 11:45, 12 users,  load average: 2.17, 1.82, 1.55
/dev/sda2             31738420    182344  29917848   1% /tmp
/dev/sda6             31738392   5306072  24794096  18% /var
/dev/sdc1            961432072 775504044 137090028  85% /mnt/scr1
Thu Oct 29 00:51:18 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/jam_1029Thu_0051
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Thu Oct 29 00:52:21 CDT 2015
Total time = 1m 3s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
 00:51:10 up 63 days, 12:00,  1 user,  load average: 0.00, 0.00, 0.00
/dev/sda7             22292052   4436560  16704840  21% /
/dev/sda5             12192608    371680  11191584   4% /tmp
/dev/sda3             12192636    965560  10597732   9% /var
/dev/sda1               101086     18614     77253  20% /boot
/dev/sdc1             41279536  26278272  12904384  68% /usr
/dev/sdb             152754284  67318820  77676004  47% /scr
tmpfs                  6149552         0   6149552   0% /dev/shm
10.10.10.86:/home    198351872  94667776  93446144  51% /home
10.10.10.86:/mnt/hdf 961432576 879559680  33035264  97% /mnt/hdf
10.10.10.86:/mnt/scr1
                     961432576 775503872 137090048  85% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Thu Oct 29 00:51:20 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-406.el5 #1 SMP Tue Jun 2 17:25:57 EDT 2015 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/koala_1029Thu_0051
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Thu Oct 29 00:51:54 CDT 2015
Total time = 0m 34s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
 00:51:14 up 61 days, 14:18,  2 users,  load average: 2.74, 2.16, 1.93
/dev/sda6             54205540  22884068  28561332  45% /
tmpfs                  6099072         0   6099072   0% /dev/shm
/dev/sda1               194241     48551    135450  27% /boot
/dev/sda2             12850716    128056  12063204   2% /tmp
/dev/sda3             12850716   4226672   7964588  35% /var
/dev/sdd             152623212 112857084  32006668  78% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Thu Oct 29 00:51:25 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.3.1.el6.x86_64 #1 SMP Thu Aug 13 22:55:16 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/platypus_1029Thu_0051
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Thu Oct 29 00:52:16 CDT 2015
Total time = 0m 51s
*** finished tests in platypus ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
 00:51:16 up 112 days, 11:38,  0 users,  load average: 8.36, 8.17, 7.37
/dev/mapper/vg_ostrich-lv_root
                      140479384  19357528  113982812  15% /
tmpfs                   7821632         0    7821632   0% /dev/shm
/dev/sda2                487652     92973     369079  21% /boot
/dev/sdb2             124477364  87016784   31130828  74% /scr
jam:/home             198351872  94667776   93446144  51% /home
jam:/mnt/hdf          961432576 879559680   33035264  97% /mnt/hdf
jam:/mnt/scr1         961432576 775503872  137090048  85% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Thu Oct 29 00:51:27 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-504.8.1.el6.ppc64 #1 SMP Fri Dec 19 12:10:45 EST 2014 ppc64 ppc64 ppc64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_1029Thu_0051
	****INCOMPLETE ostrich: snaptest did not complete****
Testing quail
ssh -o ConnectTimeout=60 quail -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname quail
 0:51  up 61 days, 14:32, 3 users, load averages: 3.46 4.35 4.37
Filesystem                    512-blocks       Used Available Capacity  iused     ifree %iused  Mounted on
/dev/disk0s2                   488555536  227148408 260895128    47% 28457549  32611891   47%   /
devfs                                364        364         0   100%      630         0  100%   /dev
map auto_nfs                           0          0         0   100%        0         0  100%   /mnt/hdf
map auto_nfs                           0          0         0   100%        0         0  100%   /mnt/scr1
map auto_nfs                           0          0         0   100%        0         0  100%   /home
jam.ad.hdfgroup.org:/home      396703680  189336096 186890864    51%  1009729  50206655    2%   /home
jam.ad.hdfgroup.org:/mnt/hdf  1922864144 1759119056  66069088    97% 10666533 111443419    9%   /mnt/hdf
jam.ad.hdfgroup.org:/mnt/scr1 1922864144 1551008280 274179864    85%  4244760 117865192    3%   /mnt/scr1
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Thu Oct 29 00:51:29 CDT 2015
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests in quail ***
Uname -a: Darwin quail.ad.hdfgroup.org 13.4.0 Darwin Kernel Version 13.4.0: Wed Mar 18 16:20:14 PDT 2015; root:xnu-2422.115.14~1/RELEASE_X86_64 x86_64
   /Users/hdftest/snapshots-opa/log/quail_1029Thu_0051
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests for quail ***
Thu Oct 29 00:52:25 CDT 2015
Total time = 0m 56s
*** finished tests in quail ***
Testing kite
ssh -o ConnectTimeout=60 kite -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
 0:51  up 61 days, 14:30, 0 users, load averages: 0.22 0.18 0.25
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
Thu Oct 29 00:51:31 CDT 2015
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests in kite ***
Uname -a: Darwin kite.ad.hdfgroup.org 12.6.0 Darwin Kernel Version 12.6.0: Wed Mar 18 16:23:48 PDT 2015; root:xnu-2050.48.19~1/RELEASE_X86_64 x86_64
   /Users/hdftest/snapshots-opa/log/kite_1029Thu_0051
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests for kite ***
Total time = 0m 45s
*** finished tests in kite ***
More information about the opa-nightly-tests mailing list
