[opa-nightly-tests] jam OPA_Daily_Tests_1129Sun_FAILED!!!
Larry Knox lrknox at hdfgroup.org
Mon Nov 30 08:22:19 CST 2015
System clock on emu wandered too far from clock on jam.
Larry
-----Original Message-----
From: opa-nightly-tests-bounces at lists.mcs.anl.gov [mailto:opa-nightly-tests-bounces at lists.mcs.anl.gov] On Behalf Of HDF Tester
Sent: Sunday, November 29, 2015 8:32 PM
To: opa-nightly-tests at lists.mcs.anl.gov
Subject: [opa-nightly-tests] jam OPA_Daily_Tests_1129Sun_FAILED!!!
*** OPA Tests on 1129Sun ***
   Tests Summary
****FAILED emu: setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64****
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam PASSED kite: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich PASSED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus PASSED quail: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
   Tests Time Summary
emu: Ran 1(0/1/0) tests, Grand total test time =  0m 2s
koala: Ran 1(1/0/0) tests, Grand total test time =  0m 33s
platypus: Ran 1(1/0/0) tests, Grand total test time =  0m 43s
kite: Ran 1(1/0/0) tests, Grand total test time =  0m 48s
quail: Ran 1(1/0/0) tests, Grand total test time =  0m 52s
jam: Ran 1(1/0/0) tests, Grand total test time =  1m 3s
ostrich: Ran 2(2/0/0) tests, Grand total test time =  4m 37s
jam: Ran 7(0/0/0) hosts, Grand total test time =  5m 43s
   Timekeeper log
Timekeeper started at Sun Nov 29 20:26:45 CST 2015 Timekeeper sleeping for 720 seconds
   Tests Failures
Dumping logfile of emu: setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64 Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/emu_1129Sun_2026
GROUP=hdf
HDF5_ACLOCAL=/mnt/hdf/packages/AUTOTOOLS/automake/1.15/sun4v/bin/aclocal-1.15
HDF5_AUTOCONF=/mnt/hdf/packages/AUTOTOOLS/autoconf/2.69/sun4v/bin/autoconf
HDF5_AUTOHEADER=/mnt/hdf/packages/AUTOTOOLS/autoconf/2.69/sun4v/bin/autoheader
HDF5_AUTOMAKE=/mnt/hdf/packages/AUTOTOOLS/automake/1.15/sun4v/bin/automake-1.15
HDF5_LIBTOOL=/mnt/hdf/packages/AUTOTOOLS/libtool/2.4.6/sun4v/bin/libtool
HDF5_M4=/mnt/hdf/packages/AUTOTOOLS/m4/1.4.17/sun4v/bin/m4
HDF5TestExpress=yes
HOME=/home/hdftest
HOST=emu
HOSTTYPE=sun4
JAVA_HOME=/usr/lib/jvm/jre-1.6.0
LANG=en_US.UTF-8
LC_ALL=
LC_COLLATE=
LC_CTYPE=
LC_MESSAGES=
LC_MONETARY=
LC_NUMERIC=
LC_TIME=
LOGNAME=hdftest
MACHTYPE=sparc
MAIL=/var/mail/hdftest
MAKE=gmake
NLSPATH=/usr/share/locale/%L/LC_MESSAGES/%N.cat
OSTYPE=solaris
PATH=/home/hdftest/bin:/usr/hdf/bin:/home/hdftest/bin:/usr/hdf/bin:/usr/bin:/usr/sbin:/opt/solarisstudio/bin:/opt/cmake/bin:/opt/svn/bin:/mnt/hdf/ec2-api-tools/bin
PWD=/mnt/scr1/SnapTest/snapshots-opa
REMOTEHOST=
SET_PATH=yes
SHELL=/bin/tcsh
SHLVL=3
SSH_CLIENT=10.10.10.86 37722 22
SSH_CONNECTION=10.10.10.86 37722 10.10.10.84 22 SVNROOT=http://svn.hdfgroup.uiuc.edu
TZ=localtime
USER=hdftest
VENDOR=sun
===Done Dumping environment variables after option parsing === ===== Run Tests: Sunday, November 29, 2015 08:26:07 PM CST ===== Remove contents of emu.
diff: /home/hdftest/snapshots-opa/previous/MANIFEST: No such file or directory ===== configure: Sunday, November 29, 2015 08:26:07 PM CST ===== checking for a BSD-compatible install... /usr/bin/ginstall -c checking whether build environment is sane... configure: error: newly created file is older than distributed files!
Check your system clock
Failed running configure
===== Exit bin/snapshot with status=1: Sunday, November 29, 2015 08:26:08 PM CST ===== Sunday, November 29, 2015 08:26:08 PM CST ========================= Dumping done =========================
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 20:26:24 up 60 days,  8:19, 19 users,  load average: 2.90, 2.27, 1.45
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda3             31738420   8756464  21343728  30% /
/dev/sda1               101086     17532     78335  19% /boot
/dev/sda2             31738420    218896  29881296   1% /tmp
/dev/sda6             31738392   5642808  24457360  19% /var
/dev/sda7             31738392  18498412  11601756  62% /usr
/dev/sda8            124991068    250360 118289008   1% /var/tmp
/dev/mapper/VolGroup00-home
                     198351840  94981660  93131820  51% /home
/dev/sde1            565688764 453738764  82751064  85% /scr
/dev/sdc1            961432072 799170112 113423960  88% /mnt/scr1
/dev/sdd1            961432072 866260644  46333428  95% /mnt/hdf
tmpfs                  8313628         0   8313628   0% /dev/shm
gumund:/data/ftp     480719104 404919808  51380096  89% /mnt/ftp
gumund:/data/web     480719104 404919808  51380096  89% /mnt/web
10.10.10.15:/volume1/hdf2
                     1437485440 257106944 1180276096  18% /mnt/hdf2
10.10.10.15:/volume1/hdf3
                     1437485440 257106944 1180276096  18% /mnt/hdf3 10.10.10.15:/volume1/readonly
                     1437485440 257106944 1180276096  18% /mnt/rw-src 10.10.10.15:/volume1/readonly
                     1437485440 257106944 1180276096  18% /mnt/ro-src 10.10.10.15:/volume1/readonly
                     1437485440 257106944 1180276096  18% /mnt/readonly STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_1129Sun
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1129Sun.1091: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1129Sun.1091': No such file or directory
*** launching tests from jam ***
TESTHOST is emu
jam
koala
platypus
ostrich
quail
kite
    Fork off timekeeper 12
Testing emu
ssh -o ConnectTimeout=60 emu -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname emu
  8:25pm  up 154 day(s),  6:30,  2 users,  load average: 0.03, 0.54, 1.36
/                  (rpool/ROOT/solaris):401220692 blocks 401220692 files
/devices           (/devices          ):       0 blocks        0 files
/dev               (/dev              ):       0 blocks        0 files
/system/contract   (ctfs              ):       0 blocks 2147483585 files
/proc              (proc              ):       0 blocks    29913 files
/etc/mnttab        (mnttab            ):       0 blocks        0 files
/system/volatile   (swap              ): 5461056 blocks  2192511 files
/system/object     (objfs             ):       0 blocks 2147483462 files
/etc/dfs/sharetab  (sharefs           ):       0 blocks 2147483646 files
/dev/fd            (fd                ):       0 blocks        0 files
/var               (rpool/ROOT/solaris/var):401220692 blocks 401220692 files
/tmp               (swap              ): 5461056 blocks  2192511 files
/var/share         (rpool/VARSHARE    ):401220692 blocks 401220692 files
/rpool             (rpool             ):401220692 blocks 401220692 files
/export            (rpool/export      ):401220692 blocks 401220692 files
/export/home       (rpool/export/home ):401220692 blocks 401220692 files
/export/home/kurz  (rpool/export/home/kurz):401220692 blocks 401220692 files
/home              (jam.ad.hdfgroup.org:/home):206740360 blocks 50204241 files
/mnt/hdf           (jam.ad.hdfgroup.org:/mnt/hdf):190342856 blocks 111503024 files
/mnt/scr1          (jam.ad.hdfgroup.org:/mnt/scr1):324523864 blocks 117887279 files
/mnt/ro-src        (10.10.10.15:/volume1/readonly):2360756936 blocks 91151560 files
/mnt/ftp           (gumund.ad.hdfgroup.org:/mnt/ftp):151598440 blocks 60880185 files
/mnt/web           (gumund.ad.hdfgroup.org:/mnt/web):151598440 blocks 60880185 files
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa TEST_TYPES=setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64
Extract source and run autogen if .
Sunday, November 29, 2015 08:26:06 PM CST
*** starting setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64 tests in emu *** Uname -a: SunOS emu 5.11 11.1 sun4v sparc sun4v Running snapshot with output saved in
*** finished setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64 tests for emu *** Sunday, November 29, 2015 08:26:08 PM CST Total time = 0m 2s
*** finished tests in emu ***
****SYSTEM ERROR emu: Abnormal exit from runtest ****
	Sun Nov 29 20:32:17 CST 2015
	****SYSTEM ERROR emu: runtest command failed ****
Testing jam
ssh -o ConnectTimeout=60 jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
 20:26:53 up 60 days,  8:20, 19 users,  load average: 1.89, 2.08, 1.42
/dev/sda2             31738420    219008  29881184   1% /tmp
/dev/sde1            565688764 452923944  83565884  85% /scr
/dev/sdc1            961432072 799170148 113423924  88% /mnt/scr1
Sun Nov 29 20:27:03 CST 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam *** Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux Running snapshot with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/jam_1129Sun_2027
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam *** Sun Nov 29 20:28:06 CST 2015 Total time = 1m 3s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
 20:26:55 up 95 days,  8:35,  1 user,  load average: 0.00, 0.00, 0.00
/dev/sda7             22292052   4436552  16704848  21% /
/dev/sda5             12192608    382024  11181240   4% /tmp
/dev/sda3             12192636   1006980  10556312   9% /var
/dev/sda1               101086     18614     77253  20% /boot
/dev/sdc1             41279536  26278272  12904384  68% /usr
/dev/sdb             152754284  67321284  77673540  47% /scr
tmpfs                  6149552         0   6149552   0% /dev/shm
10.10.10.86:/home    198351872  94981120  93132800  51% /home
10.10.10.86:/mnt/hdf 961432576 866260992  46333952  95% /mnt/hdf
10.10.10.86:/mnt/scr1
                     961432576 799170560 113424384  88% /mnt/scr1 10.10.10.15:/volume1/readonly
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Sun Nov 29 20:27:05 CST 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala *** Uname -a: Linux koala 2.6.18-406.el5 #1 SMP Tue Jun 2 17:25:57 EDT 2015 x86_64 x86_64 x86_64 GNU/Linux Running snapshot with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/koala_1129Sun_2027
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala *** Sun Nov 29 20:27:38 CST 2015 Total time = 0m 33s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
 20:26:58 up 93 days, 10:53,  1 user,  load average: 0.20, 0.33, 0.61
/dev/sda6             54205540  23050080  28395320  45% /
tmpfs                  6099072         0   6099072   0% /dev/shm
/dev/sda1               194241     48551    135450  27% /boot
/dev/sda2             12850716    211840  11979420   2% /tmp
/dev/sda3             12850716   4385656   7805604  36% /var
/dev/sdd             152623212 109301336  35562416  76% /scr
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Sun Nov 29 20:27:08 CST 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus *** Uname -a: Linux platypus 2.6.32-573.3.1.el6.x86_64 #1 SMP Thu Aug 13 22:55:16 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux Running snapshot with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/platypus_1129Sun_2027
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus *** Sun Nov 29 20:27:51 CST 2015 Total time = 0m 43s
*** finished tests in platypus ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
 20:27:00 up 144 days,  8:13,  3 users,  load average: 1.44, 2.18, 2.72
/dev/mapper/vg_ostrich-lv_root
                      140479384  23349136  109991204  18% /
tmpfs                   7821632         0    7821632   0% /dev/shm
/dev/sda2                487652     92973     369079  21% /boot
/dev/sdb2             124477364  86411748   31735864  74% /scr
jam:/home             198351872  94981120   93132800  51% /home
jam:/mnt/hdf          961432576 866260992   46333952  95% /mnt/hdf
jam:/mnt/scr1         961432576 799170560  113424384  88% /mnt/scr1
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Sun Nov 29 20:27:10 CST 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich *** Uname -a: Linux ostrich 2.6.32-504.8.1.el6.ppc64 #1 SMP Fri Dec 19 12:10:45 EST 2014 ppc64 ppc64 ppc64 GNU/Linux Running snapshot with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_1129Sun_2027
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich *** Sun Nov 29 20:28:43 CST 2015 Total time = 1m 33s
Sun Nov 29 20:28:44 CST 2015
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich *** Uname -a: Linux ostrich 2.6.32-504.8.1.el6.ppc64 #1 SMP Fri Dec 19 12:10:45 EST 2014 ppc64 ppc64 ppc64 GNU/Linux Running snapshot with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_1129Sun_2028
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich *** Sun Nov 29 20:31:47 CST 2015 Total time = 3m 4s
*** finished tests in ostrich ***
Testing quail
ssh -o ConnectTimeout=60 quail -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname quail
20:27  up 10 days, 11:40, 2 users, load averages: 1.76 1.85 1.80
Filesystem                    512-blocks       Used Available Capacity  iused     ifree %iused  Mounted on
/dev/disk0s2                   488555536  227955704 260087832    47% 28558461  32510979   47%   /
devfs                                363        363         0   100%      628         0  100%   /dev
map auto_nfs                           0          0         0   100%        0         0  100%   /home
map auto_nfs                           0          0         0   100%        0         0  100%   /mnt/hdf
map auto_nfs                           0          0         0   100%        0         0  100%   /mnt/scr1
jam.ad.hdfgroup.org:/home      396703680  189963320 186263640    51%  1012143  50204241    2%   /home
jam.ad.hdfgroup.org:/mnt/scr1 1922864144 1598340368 226847776    88%  4222684 117887268    3%   /mnt/scr1
jam.ad.hdfgroup.org:/mnt/hdf  1922864144 1732521288  92666856    95% 10606928 111503024    9%   /mnt/hdf
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Sun Nov 29 20:27:12 CST 2015
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests in quail *** Uname -a: Darwin quail.ad.hdfgroup.org 13.4.0 Darwin Kernel Version 13.4.0: Wed Mar 18 16:20:14 PDT 2015; root:xnu-2422.115.14~1/RELEASE_X86_64 x86_64 Running snapshot with output saved in
   /Users/hdftest/snapshots-opa/log/quail_1129Sun_2027
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests for quail *** Sun Nov 29 20:28:04 CST 2015 Total time = 0m 52s
*** finished tests in quail ***
Testing kite
ssh -o ConnectTimeout=60 kite -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
20:27  up 31 days, 10:03, 0 users, load averages: 0.43 0.41 0.35
/dev/disk0s2          1951845952  253828136 1697505816    14% 31792515 212188227   13%   /
devfs                        372        372          0   100%      644         0  100%   /dev
/dev/disk1s2          1952853344    1296720 1951556624     1%   162088 243944578    0%   /Volumes/Milvinae
10.10.10.86:/mnt/hdf  1922864144 1732521288   92666856    95% 10606928 111503024    9%   /mnt/hdf
10.10.10.86:/mnt/scr1 1922864144 1598340424  226847720    88%  4222689 117887263    3%   /mnt/scr1
10.10.10.86:/home      396703680  189963320  186263640    51%  1012143  50204241    2%   /home
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
Sun Nov 29 20:27:15 CST 2015
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests in kite *** Uname -a: Darwin kite.ad.hdfgroup.org 12.6.0 Darwin Kernel Version 12.6.0: Wed Mar 18 16:23:48 PDT 2015; root:xnu-2050.48.19~1/RELEASE_X86_64 x86_64 Running snapshot with output saved in
   /Users/hdftest/snapshots-opa/log/kite_1129Sun_2027
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests for kite *** Sun Nov 29 20:28:03 CST 2015 Total time = 0m 48s
*** finished tests in kite ***
opa-nightly-tests mailing list
https://lists.mcs.anl.gov/mailman/listinfo/opa-nightly-tests
More information about the opa-nightly-tests mailing list
