[opa-nightly-tests] jam OPA_Daily_Tests_0222Sun
HDF Tester hdftest at hdfgroup.org
Sun Feb 22 19:54:57 CST 2015
*** OPA Tests on 0222Sun ***
   Tests Summary
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
PASSED kite: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
PASSED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
   Tests Time Summary
koala: Ran 1(1/0/0) tests, Grand total test time =  0m 35s
platypus: Ran 1(1/0/0) tests, Grand total test time =  0m 41s
kite: Ran 1(1/0/0) tests, Grand total test time =  0m 45s
jam: Ran 1(1/0/0) tests, Grand total test time =  1m 1s
ostrich: Ran 2(2/0/0) tests, Grand total test time =  4m 40s
jam: Ran 7(0/0/0) hosts, Grand total test time =  12m 41s
   Timekeeper log
Timekeeper started at Sun Feb 22 19:42:27 CST 2015
Timekeeper sleeping for 720 seconds
Timekeeper woke up at Sun Feb 22 19:54:27 CST 2015, looking for processes to terminate...
terminating process PID.emu_emu (13473)
Remote shell command ended.  But some processes might still be
running in the remote machine.  Login there to verify.
Timekeeper ended at Sun Feb 22 19:54:27 CST 2015
   Tests Failures
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 19:42:06 up 19 days, 12:07, 13 users,  load average: 0.02, 1.05, 2.02
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda3             31738420   6905836  23194356  23% /
/dev/sda1               101086     17532     78335  19% /boot
/dev/sda2             31738420    373632  29726560   2% /tmp
/dev/sda6             31738392   7088728  23011440  24% /var
/dev/sda7             31738392  18490204  11609964  62% /usr
/dev/sda8            124991068    264788 118274580   1% /var/tmp
tmpfs                  8313628         0   8313628   0% /dev/shm
gumund:/data/ftp     480719104 329448320 126851584  73% /mnt/ftp
gumund:/data/web     480719104 329448320 126851584  73% /mnt/web
/dev/mapper/VolGroup00-home
                     198351840  43512652 144600828  24% /home
/dev/sde1            565688764 397930632 138559196  75% /scr
/dev/sdc1            961432072 856819784  55774288  94% /mnt/scr1
/dev/sdd1            961432072 853029288  59564784  94% /mnt/hdf
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0222Sun
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0222Sun.11794: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0222Sun.11794': No such file or directory
*** launching tests from jam ***
TESTHOST is emu
jam
koala
platypus
ostrich
kite
quail
    Fork off timekeeper 12
Testing emu
ssh -o ConnectTimeout=60 emu -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname emu
  7:42pm  up 219 day(s),  5:23,  4 users,  load average: 1.02, 0.69, 0.34
/                  (rpool/ROOT/solaris):476052403 blocks 476052403 files
/devices           (/devices          ):       0 blocks        0 files
/dev               (/dev              ):       0 blocks        0 files
/system/contract   (ctfs              ):       0 blocks 2147483590 files
/proc              (proc              ):       0 blocks    29913 files
/etc/mnttab        (mnttab            ):       0 blocks        0 files
/system/volatile   (swap              ):13641600 blocks  2228751 files
/system/object     (objfs             ):       0 blocks 2147483462 files
/etc/dfs/sharetab  (sharefs           ):       0 blocks 2147483646 files
/dev/fd            (fd                ):       0 blocks        0 files
/var               (rpool/ROOT/solaris/var):476052403 blocks 476052403 files
/tmp               (swap              ):13641600 blocks  2228751 files
/var/share         (rpool/VARSHARE    ):476052403 blocks 476052403 files
/export            (rpool/export      ):476052403 blocks 476052403 files
/export/home       (rpool/export/home ):476052403 blocks 476052403 files
/export/home/kurz  (rpool/export/home/kurz):476052403 blocks 476052403 files
/rpool             (rpool             ):476052403 blocks 476052403 files
/home              (jam:/home         ):309678376 blocks 50559308 files
/mnt/hdf           (jam:/mnt/hdf      ):216805568 blocks 113065931 files
/mnt/ftp           (gumund:/mnt/ftp   ):302541336 blocks 60891309 files
/mnt/web           (gumund:/mnt/web   ):302541336 blocks 60891309 files
/mnt/scr1          (jam:/mnt/scr1     ):209221440 blocks 118432826 files
TEST_TYPES=setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64
Sunday, February 22, 2015 07:42:43 PM CST
*** starting setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64 tests in emu ***
Uname -a: SunOS emu.hdfgroup.uiuc.edu 5.11 11.1 sun4v sparc sun4v
Running snapshot with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/emu_0222Sun_1942
	****INCOMPLETE emu: snaptest did not complete****
Testing jam
ssh -o ConnectTimeout=60 jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
 19:42:35 up 19 days, 12:08, 13 users,  load average: 0.28, 1.01, 1.98
/dev/sda2             31738420    373740  29726452   2% /tmp
/dev/sda6             31738392   7088720  23011448  24% /var
/dev/sdc1            961432072 856821512  55772560  94% /mnt/scr1
Sun Feb 22 19:42:45 CST 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/jam_0222Sun_1942
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Sun Feb 22 19:43:46 CST 2015
Total time = 1m 1s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
 19:42:37 up 23 days,  7:09,  0 users,  load average: 1.00, 0.80, 0.80
/dev/sda7             22292052   4057552  17083848  20% /
/dev/sda5             12192608    550896  11012368   5% /tmp
/dev/sda3             12192636   2023224   9540068  18% /var
/dev/sda1               101086     18613     77254  20% /boot
/dev/sdc1             41279536  26241804  12940852  67% /usr
/dev/sdb             152754284 117143668  27851156  81% /scr
tmpfs                  6149552         0   6149552   0% /dev/shm
jam:/home            198351872  43511808 144601088  24% /home
jam:/mnt/hdf         961432576 853028864  59565056  94% /mnt/hdf
jam:/mnt/scr1        961432576 856821760  55773184  94% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Sun Feb 22 19:42:47 CST 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-400.1.1.el5 #1 SMP Thu Dec 18 00:59:53 EST 2014 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/koala_0222Sun_1942
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Sun Feb 22 19:43:22 CST 2015
Total time = 0m 35s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
 19:42:40 up 24 days,  3:39,  1 user,  load average: 0.00, 0.00, 0.15
/dev/sda6         54205540  13671508  37773892  27% /
tmpfs              6099132         0   6099132   0% /dev/shm
/dev/sda1           194241     47728    136273  26% /boot
/dev/sda2         12850716     96368  12094892   1% /tmp
/dev/sda3         12850716   5376184   6815076  45% /var
/dev/sdd         152623212 109231908  35631844  76% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Sun Feb 22 19:42:50 CST 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-504.8.1.el6.x86_64 #1 SMP Wed Jan 28 21:11:36 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/platypus_0222Sun_1942
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Sun Feb 22 19:43:31 CST 2015
Total time = 0m 41s
*** finished tests in platypus ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
 19:42:42 up 23 days,  6:39,  1 user,  load average: 0.40, 1.21, 2.34
/dev/mapper/vg_ostrich-lv_root
                     140479384  16171976 117168364  13% /
tmpfs                  7821632         0   7821632   0% /dev/shm
/dev/sda2               487652     92973    369079  21% /boot
/dev/sdb2            124477364  92492956  25654656  79% /scr
jam:/mnt/scr1        961432576 856821760  55772160  94% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Sun Feb 22 19:42:52 CST 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-504.8.1.el6.ppc64 #1 SMP Fri Dec 19 12:10:45 EST 2014 ppc64 ppc64 ppc64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0222Sun_1942
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Sun Feb 22 19:44:23 CST 2015
Total time = 1m 31s
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich ***
   /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0222Sun_1944
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich ***
Sun Feb 22 19:47:32 CST 2015
Total time = 3m 9s
*** finished tests in ostrich ***
Testing kite
ssh -o ConnectTimeout=60 kite -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
19:42  up 24 days, 11:29, 0 users, load averages: 0.00 0.05 0.06
Filesystem             512-blocks       Used  Available Capacity  iused     ifree %iused  Mounted on
/dev/disk0s2           1951845952  208076744 1743257208    11% 26073591 217907151   11%   /
devfs                         372        372          0   100%      644         0  100%   /dev
/dev/disk1s2           1952853344    1296784 1951556560     1%   162096 243944570    0%   /Volumes/Milvinae
72.36.68.242:/home      396703680   87025304  289201656    24%   657076  50559308    1%   /mnt/home
72.36.68.242:/mnt/hdf  1922864144 1706058576  119129568    94%  9044021 113065931    7%   /mnt/hdf
72.36.68.242:/mnt/scr1 1922864144 1713644312  111543832    94%  3677154 118432798    3%   /mnt/scr1
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
Sun Feb 22 19:42:59 CST 2015
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests in kite ***
Uname -a: Darwin kite.ad.hdfgroup.uiuc.edu 12.6.0 Darwin Kernel Version 12.6.0: Wed Dec 17 19:11:40 PST 2014; root:xnu-2050.48.15~1/RELEASE_X86_64 x86_64
   /Users/hdftest/snapshots-opa/log/kite_0222Sun_1942
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests for kite ***
Sun Feb 22 19:43:43 CST 2015
Total time = 0m 44s
*** finished tests in kite ***
Testing quail
ssh -o ConnectTimeout=60 quail -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname quail
/home/hdftest/snapshots-opa: No such file or directory.
****SYSTEM ERROR quail: Abnormal exit from runtest ****
	****SYSTEM ERROR quail: runtest command failed ****
More information about the opa-nightly-tests mailing list
