[opa-nightly-tests] jam OPA_Daily_Tests_1213Sun
HDF Tester
hdftest at hdfgroup.org
Sun Dec 13 21:38:29 CST 2015
*** OPA Tests on 1213Sun ***
Tests Summary
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
PASSED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
PASSED quail: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Tests Time Summary
koala: Ran 1(1/0/0) tests, Grand total test time = 0m 33s
platypus: Ran 1(1/0/0) tests, Grand total test time = 0m 43s
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 2s
quail: Ran 1(1/0/0) tests, Grand total test time = 0m 56s
ostrich: Ran 2(2/0/0) tests, Grand total test time = 4m 43s
jam: Ran 7(0/0/0) hosts, Grand total test time = 12m 41s
Timekeeper log
Timekeeper started at Sun Dec 13 21:25:59 CST 2015
Timekeeper sleeping for 720 seconds
Timekeeper woke up at Sun Dec 13 21:37:59 CST 2015, looking for processes to terminate...
terminating process PID.emu_emu (18190)
Remote shell command ended. But some processes might still be
running in the remote machine. Login there to verify.
Timekeeper ended at Sun Dec 13 21:37:59 CST 2015
Tests Failures
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
21:25:38 up 74 days, 9:18, 13 users, load average: 2.80, 1.67, 0.97
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 8721992 21378200 29% /
/dev/sda1 101086 17532 78335 19% /boot
/dev/sda2 31738420 367760 29732432 2% /tmp
/dev/sda6 31738392 5731980 24368188 20% /var
/dev/sda7 31738392 18498412 11601756 62% /usr
/dev/sda8 124991068 251020 118288348 1% /var/tmp
/dev/mapper/VolGroup00-home
198351840 94849872 93263608 51% /home
/dev/sde1 565688764 450642680 85847148 84% /scr
/dev/sdc1 961432072 804544056 108050016 89% /mnt/scr1
/dev/sdd1 961432072 871940320 40653752 96% /mnt/hdf
tmpfs 8313628 0 8313628 0% /dev/shm
gumund:/data/ftp 480719104 405888768 50411136 89% /mnt/ftp
gumund:/data/web 480719104 405888768 50411136 89% /mnt/web
10.10.10.15:/volume1/hdf2
1437485440 257110144 1180272896 18% /mnt/hdf2
10.10.10.15:/volume1/hdf3
1437485440 257110144 1180272896 18% /mnt/hdf3
10.10.10.15:/volume1/readonly
1437485440 257110144 1180272896 18% /mnt/rw-src
1437485440 257110144 1180272896 18% /mnt/ro-src
1437485440 257110144 1180272896 18% /mnt/readonly
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_1213Sun
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1213Sun.16505: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1213Sun.16505': No such file or directory
*** launching tests from jam ***
TESTHOST is emu
jam
koala
platypus
ostrich
quail
kite
Fork off timekeeper 12
Testing emu
ssh -o ConnectTimeout=60 emu -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname emu
9:26pm up 168 day(s), 7:30, 4 users, load average: 0.05, 0.55, 1.06
/ (rpool/ROOT/solaris):389720917 blocks 389720917 files
/devices (/devices ): 0 blocks 0 files
/dev (/dev ): 0 blocks 0 files
/system/contract (ctfs ): 0 blocks 2147483583 files
/proc (proc ): 0 blocks 29905 files
/etc/mnttab (mnttab ): 0 blocks 0 files
/system/volatile (swap ): 5378944 blocks 2190915 files
/system/object (objfs ): 0 blocks 2147483462 files
/etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
/dev/fd (fd ): 0 blocks 0 files
/var (rpool/ROOT/solaris/var):389720917 blocks 389720917 files
/tmp (swap ): 5378944 blocks 2190915 files
/var/share (rpool/VARSHARE ):389720917 blocks 389720917 files
/rpool (rpool ):389720917 blocks 389720917 files
/export (rpool/export ):389720917 blocks 389720917 files
/export/home (rpool/export/home ):389720917 blocks 389720917 files
/export/home/kurz (rpool/export/home/kurz):389720917 blocks 389720917 files
/home (jam.ad.hdfgroup.org:/home):207003936 blocks 50209712 files
/mnt/hdf (jam.ad.hdfgroup.org:/mnt/hdf):178983504 blocks 111382872 files
/mnt/scr1 (jam.ad.hdfgroup.org:/mnt/scr1):313775976 blocks 117855149 files
/mnt/ro-src (10.10.10.15:/volume1/readonly):2360750536 blocks 91151539 files
/mnt/ftp (gumund.ad.hdfgroup.org:/mnt/ftp):149660672 blocks 60880136 files
/mnt/web (gumund.ad.hdfgroup.org:/mnt/web):149660672 blocks 60880136 files
TEST_TYPES=setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64
Extract source and run autogen if .
Sunday, December 13, 2015 09:26:20 PM CST
*** starting setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64 tests in emu ***
Uname -a: SunOS emu 5.11 11.1 sun4v sparc sun4v
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/emu_1213Sun_2126
****INCOMPLETE emu: snaptest did not complete****
Testing jam
ssh -o ConnectTimeout=60 jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
21:26:06 up 74 days, 9:19, 13 users, load average: 2.22, 1.64, 0.98
/dev/sda2 31738420 367872 29732320 2% /tmp
/dev/sda6 31738392 5732076 24368092 20% /var
/dev/sde1 565688764 450629724 85860104 84% /scr
/dev/sdc1 961432072 804544092 108049980 89% /mnt/scr1
Sun Dec 13 21:26:16 CST 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/jam_1213Sun_2126
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Sun Dec 13 21:27:18 CST 2015
Total time = 1m 2s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
21:26:08 up 109 days, 9:34, 0 users, load average: 0.07, 0.54, 0.56
/dev/sda7 22292052 4436584 16704816 21% /
/dev/sda5 12192608 384548 11178716 4% /tmp
/dev/sda3 12192636 1040276 10523016 9% /var
/dev/sda1 101086 18614 77253 20% /boot
/dev/sdc1 41279536 26278276 12904380 68% /usr
/dev/sdb 152754284 67389596 77605228 47% /scr
tmpfs 6149552 0 6149552 0% /dev/shm
10.10.10.86:/home 198351872 94849024 93263872 51% /home
10.10.10.86:/mnt/hdf 961432576 871940096 40653824 96% /mnt/hdf
10.10.10.86:/mnt/scr1
961432576 804544512 108050432 89% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Sun Dec 13 21:26:18 CST 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-406.el5 #1 SMP Tue Jun 2 17:25:57 EDT 2015 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/koala_1213Sun_2126
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Sun Dec 13 21:26:51 CST 2015
Total time = 0m 33s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
21:26:11 up 107 days, 11:52, 1 user, load average: 0.48, 0.49, 0.76
/dev/sda6 54205540 23118100 28327300 45% /
tmpfs 6099072 0 6099072 0% /dev/shm
/dev/sda1 194241 48551 135450 27% /boot
/dev/sda2 12850716 144620 12046640 2% /tmp
/dev/sda3 12850716 4305920 7885340 36% /var
/dev/sdd 152623212 127589936 17273816 89% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Sun Dec 13 21:26:21 CST 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.3.1.el6.x86_64 #1 SMP Thu Aug 13 22:55:16 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/platypus_1213Sun_2126
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Sun Dec 13 21:27:04 CST 2015
Total time = 0m 43s
*** finished tests in platypus ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
21:26:13 up 158 days, 9:12, 5 users, load average: 2.00, 2.27, 2.59
/dev/mapper/vg_ostrich-lv_root
140479384 23532744 109807596 18% /
tmpfs 7821632 0 7821632 0% /dev/shm
/dev/sda2 487652 92973 369079 21% /boot
/dev/sdb2 124477364 91242132 26905480 78% /scr
jam:/home 198351872 94849024 93263872 51% /home
jam:/mnt/hdf 961432576 871940096 40653824 96% /mnt/hdf
jam:/mnt/scr1 961432576 804544512 108050432 89% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Sun Dec 13 21:26:23 CST 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-504.8.1.el6.ppc64 #1 SMP Fri Dec 19 12:10:45 EST 2014 ppc64 ppc64 ppc64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_1213Sun_2126
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Sun Dec 13 21:28:02 CST 2015
Total time = 1m 39s
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich ***
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_1213Sun_2128
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich ***
Sun Dec 13 21:31:06 CST 2015
Total time = 3m 4s
*** finished tests in ostrich ***
Testing quail
ssh -o ConnectTimeout=60 quail -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname quail
21:26 up 24 days, 12:40, 4 users, load averages: 1.75 1.76 1.66
Filesystem 512-blocks Used Available Capacity iused ifree %iused Mounted on
/dev/disk0s2 488555536 225234176 262809360 47% 28218270 32851170 46% /
devfs 369 369 0 100% 639 0 100% /dev
map auto_nfs 0 0 0 100% 0 0 100% /home
map auto_nfs 0 0 0 100% 0 0 100% /mnt/hdf
map auto_nfs 0 0 0 100% 0 0 100% /mnt/scr1
jam.ad.hdfgroup.org:/mnt/scr1 1922864144 1609088264 216099880 89% 4254814 117855138 3% /mnt/scr1
jam.ad.hdfgroup.org:/home 396703680 189699744 186527216 51% 1006672 50209712 2% /home
jam.ad.hdfgroup.org:/mnt/hdf 1922864144 1743880640 81307504 96% 10727080 111382872 9% /mnt/hdf
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Sun Dec 13 21:26:26 CST 2015
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests in quail ***
Uname -a: Darwin quail.ad.hdfgroup.org 13.4.0 Darwin Kernel Version 13.4.0: Wed Mar 18 16:20:14 PDT 2015; root:xnu-2422.115.14~1/RELEASE_X86_64 x86_64
/Users/hdftest/snapshots-opa/log/quail_1213Sun_2126
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests for quail ***
Sun Dec 13 21:27:21 CST 2015
Total time = 0m 55s
*** finished tests in quail ***
Testing kite
ssh -o ConnectTimeout=60 kite -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
/home/hdftest/snapshots-opa: No such file or directory.
****SYSTEM ERROR kite: Abnormal exit from runtest ****
****SYSTEM ERROR kite: runtest command failed ****
More information about the opa-nightly-tests
