[opa-nightly-tests] jam OPA_Daily_Tests_0810Mon
HDF Tester hdftest at hdfgroup.org
Mon Aug 10 23:59:43 CDT 2015
*** OPA Tests on 0810Mon ***
   Tests Summary
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
PASSED kite: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
PASSED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
   Tests Time Summary
koala: Ran 1(1/0/0) tests, Grand total test time =  0m 33s
platypus: Ran 1(1/0/0) tests, Grand total test time =  0m 45s
kite: Ran 1(1/0/0) tests, Grand total test time =  0m 48s
jam: Ran 1(1/0/0) tests, Grand total test time =  1m 1s
ostrich: Ran 2(2/0/0) tests, Grand total test time =  4m 50s
jam: Ran 7(0/0/0) hosts, Grand total test time =  12m 42s
   Timekeeper log
Timekeeper started at Mon Aug 10 23:47:13 CDT 2015
Timekeeper sleeping for 720 seconds
Timekeeper woke up at Mon Aug 10 23:59:13 CDT 2015, looking for processes to terminate...
terminating process PID.emu_emu (31774)
Remote shell command ended.  But some processes might still be
running in the remote machine.  Login there to verify.
Timekeeper ended at Mon Aug 10 23:59:13 CDT 2015
   Tests Failures
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 23:46:51 up 5 days, 10:43, 15 users,  load average: 0.01, 0.02, 0.06
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda3             31738420   8459868  21640324  29% /
/dev/sda1               101086     17532     78335  19% /boot
/dev/sda2             31738420    389588  29710604   2% /tmp
/dev/sda6             31738392   5193360  24906808  18% /var
/dev/sda7             31738392  18478512  11621656  62% /usr
/dev/sda8            124991068    192764 118346604   1% /var/tmp
/dev/mapper/VolGroup00-home
                     198351840  51971288 136142192  28% /home
/dev/sde1            565688764 414037396 122452432  78% /scr
/dev/sdc1            961432072 871351380  41242692  96% /mnt/scr1
/dev/sdd1            961432072 866362660  46231412  95% /mnt/hdf
tmpfs                  8313628         0   8313628   0% /dev/shm
gumund:/data/ftp     480719104 360454016  95845888  79% /mnt/ftp
gumund:/data/web     480719104 360454016  95845888  79% /mnt/web
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0810Mon
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0810Mon.30090: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0810Mon.30090': No such file or directory
*** launching tests from jam ***
TESTHOST is emu
jam
koala
platypus
ostrich
quail
kite
    Fork off timekeeper 12
Testing emu
ssh -o ConnectTimeout=60 emu -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname emu
 11:47pm  up 43 day(s),  8:52,  2 users,  load average: 0.01, 0.38, 2.36
/                  (rpool/ROOT/solaris):444608303 blocks 444608303 files
/devices           (/devices          ):       0 blocks        0 files
/dev               (/dev              ):       0 blocks        0 files
/system/contract   (ctfs              ):       0 blocks 2147483588 files
/proc              (proc              ):       0 blocks    29924 files
/etc/mnttab        (mnttab            ):       0 blocks        0 files
/system/volatile   (swap              ):15558320 blocks  2220826 files
/system/object     (objfs             ):       0 blocks 2147483465 files
/etc/dfs/sharetab  (sharefs           ):       0 blocks 2147483646 files
/dev/fd            (fd                ):       0 blocks        0 files
/var               (rpool/ROOT/solaris/var):444608303 blocks 444608303 files
/tmp               (swap              ):15558320 blocks  2220826 files
/var/share         (rpool/VARSHARE    ):444608303 blocks 444608303 files
/rpool             (rpool             ):444608303 blocks 444608303 files
/export            (rpool/export      ):444608303 blocks 444608303 files
/export/home       (rpool/export/home ):444608303 blocks 444608303 files
/export/home/kurz  (rpool/export/home/kurz):444608303 blocks 444608303 files
/home              (jam.ad.hdfgroup.org:/home):292761104 blocks 50532436 files
/mnt/hdf           (jam.ad.hdfgroup.org:/mnt/hdf):190138824 blocks 111979663 files
/mnt/scr1          (jam.ad.hdfgroup.org:/mnt/scr1):180161328 blocks 117954828 files
TEST_TYPES=setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64
Monday, August 10, 2015 11:47:48 PM CDT
*** starting setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64 tests in emu ***
Uname -a: SunOS emu 5.11 11.1 sun4v sparc sun4v
Running snapshot with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/emu_0810Mon_2347
	****INCOMPLETE emu: snaptest did not complete****
Testing jam
ssh -o ConnectTimeout=60 jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
 23:47:20 up 5 days, 10:44, 15 users,  load average: 0.14, 0.05, 0.07
/dev/sda2             31738420    389696  29710496   2% /tmp
/dev/sda6             31738392   5193428  24906740  18% /var
/dev/sdc1            961432072 871351416  41242656  96% /mnt/scr1
Mon Aug 10 23:47:30 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/jam_0810Mon_2347
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Mon Aug 10 23:48:31 CDT 2015
Total time = 1m 1s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
 23:47:22 up 42 days, 14:57,  1 user,  load average: 0.00, 0.00, 0.00
/dev/sda7             22292052   4429248  16712152  21% /
/dev/sda5             12192608    433144  11130120   4% /tmp
/dev/sda3             12192636   1062020  10501272  10% /var
/dev/sda1               101086     18614     77253  20% /boot
/dev/sdc1             41279536  26230136  12952520  67% /usr
/dev/sdb             152754284  73502736  71492088  51% /scr
tmpfs                  6149552         0   6149552   0% /dev/shm
10.10.10.86:/mnt/hdf 961432576 866362368  46231552  95% /mnt/hdf
10.10.10.86:/mnt/scr1
                     961432576 871351296  41243648  96% /mnt/scr1
10.10.10.86:/home    198351872  51971072 136142848  28% /home
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Mon Aug 10 23:47:32 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-402.el5 #1 SMP Tue Feb 10 17:49:04 EST 2015 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/koala_0810Mon_2347
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Mon Aug 10 23:48:05 CDT 2015
Total time = 0m 33s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
 23:50:05 up 25 days, 15:32,  5 users,  load average: 1.01, 1.73, 2.56
/dev/sda6             54205540  20071548  31373852  40% /
tmpfs                  6099128         0   6099128   0% /dev/shm
/dev/sda1               194241     48100    135901  27% /boot
/dev/sda2             12850716    183572  12007688   2% /tmp
/dev/sda3             12850716   3371920   8819340  28% /var
/dev/sdd             152623212  88050380  56813372  61% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Mon Aug 10 23:50:15 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-504.16.2.el6.x86_64 #1 SMP Wed Apr 22 06:48:29 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/platypus_0810Mon_2350
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Mon Aug 10 23:51:00 CDT 2015
Total time = 0m 45s
*** finished tests in platypus ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
 23:48:17 up 33 days, 10:36,  0 users,  load average: 0.00, 0.00, 0.29
/dev/mapper/vg_ostrich-lv_root
                     140479384  16277456 117062884  13% /
tmpfs                  7821632         0   7821632   0% /dev/shm
/dev/sda2               487652     92973    369079  21% /boot
/dev/sdb2            124477364  78489264  39658348  67% /scr
jam:/home            198351872  51971072 136142848  28% /home
jam:/mnt/hdf         961432576 866362368  46231552  95% /mnt/hdf
jam:/mnt/scr1        961432576 871351296  41243648  96% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Mon Aug 10 23:48:27 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-504.8.1.el6.ppc64 #1 SMP Fri Dec 19 12:10:45 EST 2014 ppc64 ppc64 ppc64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0810Mon_2348
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Mon Aug 10 23:50:06 CDT 2015
Total time = 1m 39s
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich ***
   /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0810Mon_2350
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich ***
Mon Aug 10 23:53:17 CDT 2015
Total time = 3m 11s
*** finished tests in ostrich ***
Testing quail
ssh -o ConnectTimeout=60 quail -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname quail
/home/hdftest/snapshots-opa: No such file or directory.
****SYSTEM ERROR quail: Abnormal exit from runtest ****
	****SYSTEM ERROR quail: runtest command failed ****
Testing kite
ssh -o ConnectTimeout=60 kite -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
23:47  up 6 days,  7:46, 0 users, load averages: 0.53 0.50 0.47
Filesystem            512-blocks       Used  Available Capacity  iused     ifree %iused  Mounted on
/dev/disk0s2          1951845952  213241288 1738092664    11% 26719159 217261583   11%   /
devfs                        372        372          0   100%      644         0  100%   /dev
/dev/disk1s2          1952853344    1296624 1951556720     1%   162076 243944590    0%   /Volumes/Milvinae
10.10.10.86:/home      396703680  103942576  272284384    28%   683948  50532436    1%   /mnt/home
10.10.10.86:/mnt/hdf  1922864144 1732725320   92462824    95% 10130289 111979663    8%   /mnt/hdf
10.10.10.86:/mnt/scr1 1922864144 1742702944   82485200    96%  4155138 117954814    3%   /mnt/scr1
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
Mon Aug 10 23:47:53 CDT 2015
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests in kite ***
Uname -a: Darwin kite.ad.hdfgroup.org 12.6.0 Darwin Kernel Version 12.6.0: Wed Mar 18 16:23:48 PDT 2015; root:xnu-2050.48.19~1/RELEASE_X86_64 x86_64
   /Users/hdftest/snapshots-opa/log/kite_0810Mon_2347
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests for kite ***
Mon Aug 10 23:48:40 CDT 2015
Total time = 0m 47s
*** finished tests in kite ***
More information about the opa-nightly-tests mailing list
