[opa-nightly-tests] jam OPA_Daily_Tests_0401Wed_FAILED!!!
HDF Tester
hdftest at hdfgroup.org
Wed Apr 1 23:02:38 CDT 2015
*** OPA Tests on 0401Wed ***
Tests Summary
****FAILED emu: setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64****
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
PASSED kite: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
PASSED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
PASSED quail: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Tests Time Summary
emu: Ran 1(0/1/0) tests, Grand total test time = 0m 2s
koala: Ran 1(1/0/0) tests, Grand total test time = 0m 32s
platypus: Ran 1(1/0/0) tests, Grand total test time = 0m 42s
kite: Ran 1(1/0/0) tests, Grand total test time = 0m 49s
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 2s
quail: Ran 1(1/0/0) tests, Grand total test time = 0m 59s
ostrich: Ran 2(2/0/0) tests, Grand total test time = 4m 36s
jam: Ran 7(0/0/0) hosts, Grand total test time = 5m 42s
Timekeeper log
Timekeeper started at Wed Apr 1 22:57:06 CDT 2015
Timekeeper sleeping for 720 seconds
Tests Failures
Dumping logfile of emu: setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/emu_0401Wed_2257
CC= cc -m64
CCACHE_DISABLE=yes
CVSROOT=/mnt/hdf/cvs
EC2_CERT=/home/hdftest/.ec2/cert-6HKISUOM3HT2PWDQB4PLG67KTWOVVKOK.pem
EC2_HOME=/mnt/hdf/ec2-api-tools
EC2_PRIVATE_KEY=/home/hdftest/.ec2/pk-6HKISUOM3HT2PWDQB4PLG67KTWOVVKOK.pem
GROUP=hdf
HDF5TestExpress=yes
HOME=/home/hdftest
HOST=emu.hdfgroup.uiuc.edu
HOSTTYPE=sun4
JAVA_HOME=/usr/lib/jvm/jre-1.6.0
LANG=en_US.UTF-8
LC_ALL=
LC_COLLATE=
LC_CTYPE=
LC_MESSAGES=
LC_MONETARY=
LC_NUMERIC=
LC_TIME=
LOGNAME=hdftest
MACHTYPE=sparc
MAIL=/var/mail/hdftest
MAKE=gmake
NLSPATH=/usr/share/locale/%L/LC_MESSAGES/%N.cat
OSTYPE=solaris
PATH=/home/hdftest/bin:/usr/hdf/bin:/home/hdftest/bin:/usr/hdf/bin:/usr/bin:/usr/sbin:/opt/solarisstudio/bin:/opt/cmake/bin:/opt/svn/bin:/mnt/hdf/ec2-api-tools/bin
PWD=/mnt/scr1/SnapTest/snapshots-opa
REMOTEHOST=
SET_PATH=yes
SHELL=/bin/tcsh
SHLVL=3
SSH_CLIENT=72.36.68.242 59854 22
SSH_CONNECTION=72.36.68.242 59854 72.36.68.177 22
SVNROOT=http://svn.hdfgroup.uiuc.edu
TZ=localtime
USER=hdftest
VENDOR=sun
===Done Dumping environment variables after option parsing ===
===== Run Tests: Wednesday, April 1, 2015 10:57:01 PM CDT =====
Remove contents of emu.
diff: /home/hdftest/snapshots-opa/previous/MANIFEST: No such file or directory
===== configure: Wednesday, April 1, 2015 10:57:01 PM CDT =====
checking for a BSD-compatible install... /usr/bin/ginstall -c
checking whether build environment is sane... configure: error: newly created file is older than distributed files!
Check your system clock
Failed running configure
===== Exit bin/snapshot with status=1: Wednesday, April 1, 2015 10:57:02 PM CDT =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
22:56:45 up 57 days, 14:22, 13 users, load average: 0.00, 0.01, 0.45
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 7536212 22563980 26% /
/dev/sda1 101086 17532 78335 19% /boot
/dev/sda2 31738420 441180 29659012 2% /tmp
/dev/sda6 31738392 7926500 22173668 27% /var
/dev/sda7 31738392 18488460 11611708 62% /usr
/dev/sda8 124991068 192220 118347148 1% /var/tmp
tmpfs 8313628 0 8313628 0% /dev/shm
gumund:/data/ftp 480719104 333302272 122997632 74% /mnt/ftp
gumund:/data/web 480719104 333302272 122997632 74% /mnt/web
/dev/mapper/VolGroup00-home
198351840 44081704 144031776 24% /home
/dev/sde1 565688764 406594664 129895164 76% /scr
/dev/sdc1 961432072 880616036 31978036 97% /mnt/scr1
/dev/sdd1 961432072 872168364 40425708 96% /mnt/hdf
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0401Wed
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0401Wed.4563: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0401Wed.4563': No such file or directory
*** launching tests from jam ***
TESTHOST is emu
jam
koala
platypus
ostrich
quail
kite
Fork off timekeeper 12
Testing emu
ssh -o ConnectTimeout=60 emu -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname emu
10:56pm up 30 day(s), 5:36, 1 user, load average: 0.01, 0.01, 0.02
/ (rpool/ROOT/solaris):485943779 blocks 485943779 files
/devices (/devices ): 0 blocks 0 files
/dev (/dev ): 0 blocks 0 files
/system/contract (ctfs ): 0 blocks 2147483593 files
/proc (proc ): 0 blocks 29920 files
/etc/mnttab (mnttab ): 0 blocks 0 files
/system/volatile (swap ):20000352 blocks 2229232 files
/system/object (objfs ): 0 blocks 2147483423 files
/etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
/dev/fd (fd ): 0 blocks 0 files
/var (rpool/ROOT/solaris/var):485943779 blocks 485943779 files
/tmp (swap ):20000352 blocks 2229232 files
/var/share (rpool/VARSHARE ):485943779 blocks 485943779 files
/export (rpool/export ):485943779 blocks 485943779 files
/export/home (rpool/export/home ):485943779 blocks 485943779 files
/export/home/kurz (rpool/export/home/kurz):485943779 blocks 485943779 files
/rpool (rpool ):485943779 blocks 485943779 files
/home (jam:/home ):308540272 blocks 50540719 files
/mnt/ftp (gumund:/mnt/ftp ):294833584 blocks 60891214 files
/mnt/web (gumund:/mnt/web ):294833584 blocks 60891214 files
/mnt/hdf (jam:/mnt/hdf ):178527416 blocks 112850398 files
/mnt/scr1 (jam:/mnt/scr1 ):161632016 blocks 118252437 files
TEST_TYPES=setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64
Wednesday, April 1, 2015 10:57:00 PM CDT
*** starting setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64 tests in emu ***
Uname -a: SunOS emu.hdfgroup.uiuc.edu 5.11 11.1 sun4v sparc sun4v
Running snapshot with output saved in
*** finished setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64 tests for emu ***
Total time = 0m 2s
*** finished tests in emu ***
****SYSTEM ERROR emu: Abnormal exit from runtest ****
Wed Apr 1 23:02:37 CDT 2015
****SYSTEM ERROR emu: runtest command failed ****
Testing jam
ssh -o ConnectTimeout=60 jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
22:57:14 up 57 days, 14:22, 13 users, load average: 0.29, 0.07, 0.46
/dev/sda2 31738420 441292 29658900 2% /tmp
/dev/sda6 31738392 7926552 22173616 27% /var
/dev/sdc1 961432072 880616072 31978000 97% /mnt/scr1
Wed Apr 1 22:57:24 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/jam_0401Wed_2257
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Wed Apr 1 22:58:26 CDT 2015
Total time = 1m 2s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
22:57:16 up 1 day, 13:11, 0 users, load average: 0.00, 0.08, 0.24
/dev/sda7 22292052 4052024 17089376 20% /
/dev/sda5 12192608 552192 11011072 5% /tmp
/dev/sda3 12192636 2093648 9469644 19% /var
/dev/sda1 101086 18614 77253 20% /boot
/dev/sdc1 41279536 26229508 12953148 67% /usr
/dev/sdb 152754284 117257416 27737408 81% /scr
tmpfs 6149552 0 6149552 0% /dev/shm
jam:/home 198351872 44081152 144032768 24% /home
jam:/mnt/hdf 961432576 872168448 40426496 96% /mnt/hdf
jam:/mnt/scr1 961432576 880616448 31978496 97% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Wed Apr 1 22:57:26 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-402.el5 #1 SMP Tue Feb 10 17:49:04 EST 2015 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/koala_0401Wed_2257
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Wed Apr 1 22:57:58 CDT 2015
Total time = 0m 32s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
22:57:19 up 62 days, 5:55, 2 users, load average: 0.00, 0.00, 0.10
/dev/sda6 54205540 13673800 37771600 27% /
tmpfs 6099132 0 6099132 0% /dev/shm
/dev/sda1 194241 47728 136273 26% /boot
/dev/sda2 12850716 7707764 4483496 64% /tmp
/dev/sda3 12850716 8717872 3473388 72% /var
/dev/sdd 152623212 74746440 70117312 52% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Wed Apr 1 22:57:29 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-504.8.1.el6.x86_64 #1 SMP Wed Jan 28 21:11:36 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/platypus_0401Wed_2257
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Wed Apr 1 22:58:11 CDT 2015
Total time = 0m 42s
*** finished tests in platypus ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
22:57:21 up 61 days, 8:53, 1 user, load average: 0.14, 0.96, 2.16
/dev/mapper/vg_ostrich-lv_root
140479384 16277148 117063192 13% /
tmpfs 7821632 0 7821632 0% /dev/shm
/dev/sda2 487652 92973 369079 21% /boot
/dev/sdb2 124477364 91942912 26204700 78% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Wed Apr 1 22:57:31 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-504.8.1.el6.ppc64 #1 SMP Fri Dec 19 12:10:45 EST 2014 ppc64 ppc64 ppc64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0401Wed_2257
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Wed Apr 1 22:59:05 CDT 2015
Total time = 1m 34s
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich ***
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0401Wed_2259
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich ***
Wed Apr 1 23:02:07 CDT 2015
Total time = 3m 2s
*** finished tests in ostrich ***
Testing quail
ssh -o ConnectTimeout=60 quail -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname quail
22:58 up 38 days, 8:25, 1 user, load averages: 1.63 1.54 1.51
Filesystem 512-blocks Used Available Capacity iused ifree %iused Mounted on
/dev/disk0s2 488555536 175254864 312788672 36% 21970856 39098584 36% /
devfs 363 363 0 100% 628 0 100% /dev
72.36.68.242:/home 396703680 88163408 288063552 24% 675665 50540719 1% /home
72.36.68.242:/mnt/hdf 1922864144 1744336728 80851416 96% 9259554 112850398 8% /mnt/hdf
72.36.68.242:/mnt/scr1 1922864144 1761232216 63955928 97% 3857526 118252426 3% /mnt/scr1
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Wed Apr 1 22:58:35 CDT 2015
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests in quail ***
Uname -a: Darwin quail.ad.hdfgroup.uiuc.edu 13.4.0 Darwin Kernel Version 13.4.0: Wed Dec 17 19:05:52 PST 2014; root:xnu-2422.115.10~1/RELEASE_X86_64 x86_64
/Users/hdftest/snapshots-opa/log/quail_0401Wed_2258
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests for quail ***
Wed Apr 1 22:59:34 CDT 2015
Total time = 0m 59s
*** finished tests in quail ***
Testing kite
ssh -o ConnectTimeout=60 kite -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
22:57 up 22 days, 7:34, 2 users, load averages: 0.10 0.09 0.10
/dev/disk0s2 1951845952 203035768 1748298184 11% 25443469 218537273 10% /
devfs 373 373 0 100% 646 0 100% /dev
/dev/disk1s2 1952853344 1296640 1951556704 1% 162078 243944588 0% /Volumes/Milvinae
72.36.68.242:/mnt/scr1 1922864144 1761232264 63955880 97% 3857531 118252421 3% /mnt/scr1
72.36.68.242:/home 396703680 88163408 288063552 24% 675665 50540719 1% /mnt/home
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
Wed Apr 1 22:57:40 CDT 2015
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests in kite ***
Uname -a: Darwin kite.ad.hdfgroup.uiuc.edu 12.6.0 Darwin Kernel Version 12.6.0: Wed Dec 17 19:11:40 PST 2014; root:xnu-2050.48.15~1/RELEASE_X86_64 x86_64
/Users/hdftest/snapshots-opa/log/kite_0401Wed_2257
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests for kite ***
Wed Apr 1 22:58:29 CDT 2015
Total time = 0m 49s
*** finished tests in kite ***
More information about the opa-nightly-tests
