[opa-nightly-tests] jam OPA_Daily_Tests_1117Mon_FAILED!!!
HDF Tester
hdftest at hdfgroup.org
Mon Nov 17 23:44:56 CST 2014
*** OPA Tests on 1117Mon ***
Tests Summary
****FAILED kite: standard op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite****
PASSED emu: setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Tests Time Summary
kite: Ran 1(0/1/0) tests, Grand total test time = 0m 9s
koala: Ran 1(1/0/0) tests, Grand total test time = 0m 33s
platypus: Ran 1(1/0/0) tests, Grand total test time = 0m 42s
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 2s
ostrich: Ran 1(1/0/0) tests, Grand total test time = 1m 41s
emu: Ran 1(1/0/0) tests, Grand total test time = 8m 46s
jam: Ran 6(0/0/0) hosts, Grand total test time = 9m 43s
Timekeeper log
Timekeeper started at Mon Nov 17 23:35:25 CST 2014
Timekeeper sleeping for 720 seconds
Tests Failures
Dumping logfile of kite: standard op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
Last 50 lines of /Users/hdftest/snapshots-opa/log/kite_1117Mon_2335
checking for atomic.h... no
checking intrin.h usability... no
checking intrin.h presence... no
checking for intrin.h... no
checking for inttypes.h... (cached) yes
checking for stdint.h... (cached) yes
checking stddef.h usability... yes
checking stddef.h presence... yes
checking for stddef.h... yes
checking for C/C++ restrict keyword... __restrict
checking for inline... inline
checking for an ANSI C-conforming const... yes
checking for pthread_create in -lpthread... yes
checking for pthread_yield... no
checking sched.h usability... yes
checking sched.h presence... yes
checking for sched.h... yes
checking for sched_yield... yes
checking if 100 threads can be run at once... yes
checking size of void *... 8
checking size of int... 4
checking whether __attribute__ allowed... yes
checking whether __attribute__((format)) allowed... yes
checking if compiler rejects bogus asm statements... yes
checking for support for gcc x86/x86_64 primitives... yes
checking for support for gcc x86 primitives for pre-Pentium 4... yes
checking for support for gcc ia64 primitives... no
checking for support for gcc PowerPC atomics... no
checking for support for gcc ARM atomics... no
checking for support for gcc SiCortex atomics... no
checking for support for gcc atomic intrinsics... yes
checking for support for Windows NT atomic intrinsics... no
checking for support for Sun atomic operations library... no
checking whether to enable strict fairness checks... no
checking that generated files are newer than configure... done
configure: creating ./config.status
config.status: creating Makefile
config.status: creating src/Makefile
config.status: creating test/Makefile
config.status: creating openpa.pc
config.status: creating src/config.h
config.status: executing depfiles commands
config.status: executing libtool commands
config.status: executing src/opa_config.h commands
config.status: creating src/opa_config.h - prefix OPA for src/config.h defines
===== make: Mon Nov 17 23:36:00 CST 2014 =====
bin/snapshot: line 574: gmake: command not found
Failed running make
===== Exit bin/snapshot with status=127: Mon Nov 17 23:36:01 CST 2014 =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
23:35:03 up 46 days, 17:21, 5 users, load average: 0.04, 0.03, 0.06
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 5773900 24326292 20% /
/dev/sda1 101086 17532 78335 19% /boot
/dev/sda2 31738420 481412 29618780 2% /tmp
/dev/sda6 31738392 8011028 22089140 27% /var
/dev/sda7 31738392 18490936 11609232 62% /usr
/dev/sda8 124991068 3278508 115260860 3% /var/tmp
/dev/mapper/VolGroup00-home
198351840 24800144 163313336 14% /home
/dev/sde1 565688764 393311204 143178624 74% /scr
/dev/sdc1 961432072 841936052 70658020 93% /mnt/scr1
/dev/sdd1 961432072 742344280 170249792 82% /mnt/hdf
tmpfs 8313628 0 8313628 0% /dev/shm
gumund:/data/ftp 480719104 294062464 162237440 65% /mnt/ftp
gumund:/data/web 480719104 294062464 162237440 65% /mnt/web
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_1117Mon
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1117Mon.3300: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1117Mon.3300': No such file or directory
*** launching tests from jam ***
TESTHOST is emu
jam
koala
platypus
ostrich
kite
Fork off timekeeper 12
Testing emu
ssh -o ConnectTimeout=60 emu -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname emu
11:35pm up 122 day(s), 9:16, 1 user, load average: 0.01, 0.01, 0.01
/ (rpool/ROOT/solaris):488156431 blocks 488156431 files
/devices (/devices ): 0 blocks 0 files
/dev (/dev ): 0 blocks 0 files
/system/contract (ctfs ): 0 blocks 2147483593 files
/proc (proc ): 0 blocks 29930 files
/etc/mnttab (mnttab ): 0 blocks 0 files
/system/volatile (swap ):24932816 blocks 2229051 files
/system/object (objfs ): 0 blocks 2147483466 files
/etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
/dev/fd (fd ): 0 blocks 0 files
/var (rpool/ROOT/solaris/var):488156431 blocks 488156431 files
/tmp (swap ):24932816 blocks 2229051 files
/var/share (rpool/VARSHARE ):488156431 blocks 488156431 files
/export (rpool/export ):488156431 blocks 488156431 files
/export/home (rpool/export/home ):488156431 blocks 488156431 files
/export/home/kurz (rpool/export/home/kurz):488156431 blocks 488156431 files
/rpool (rpool ):488156431 blocks 488156431 files
/home (jam:/home ):347103392 blocks 50673077 files
/mnt/hdf (jam:/mnt/hdf ):438175584 blocks 113702307 files
/mnt/ftp (gumund:/mnt/ftp ):373313272 blocks 60892322 files
/mnt/web (gumund:/mnt/web ):373313272 blocks 60892322 files
/mnt/scr1 (jam:/mnt/scr1 ):238991984 blocks 118602592 files
TEST_TYPES=setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64
Monday, November 17, 2014 11:35:40 PM CST
*** starting setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64 tests in emu ***
Uname -a: SunOS emu.hdfgroup.uiuc.edu 5.11 11.1 sun4v sparc sun4v
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/emu_1117Mon_2335
*** finished setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64 tests for emu ***
Monday, November 17, 2014 11:44:26 PM CST
Total time = 8m 46s
*** finished tests in emu ***
Testing jam
ssh -o ConnectTimeout=60 jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
23:35:32 up 46 days, 17:22, 5 users, load average: 0.15, 0.06, 0.07
/dev/sda2 31738420 481520 29618672 2% /tmp
/dev/sda6 31738392 8011080 22089088 27% /var
/dev/sdc1 961432072 841936088 70657984 93% /mnt/scr1
Mon Nov 17 23:35:42 CST 2014
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/jam_1117Mon_2335
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Mon Nov 17 23:36:44 CST 2014
Total time = 1m 2s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
23:35:34 up 48 days, 14:46, 1 user, load average: 0.01, 0.02, 0.03
/dev/sda7 22292052 4057516 17083884 20% /
/dev/sda5 12192608 545296 11017968 5% /tmp
/dev/sda3 12192636 2201540 9361752 20% /var
/dev/sda1 101086 18597 77270 20% /boot
/dev/sdc1 41279536 26241184 12941472 67% /usr
/dev/sdb 152754284 103441540 41553284 72% /scr
tmpfs 6149552 0 6149552 0% /dev/shm
jam:/mnt/hdf 961432576 742344704 170250240 82% /mnt/hdf
jam:/mnt/scr1 961432576 841935872 70658048 93% /mnt/scr1
jam:/home 198351872 24799232 163313664 14% /home
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Mon Nov 17 23:35:44 CST 2014
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-398.el5 #1 SMP Tue Sep 16 20:50:52 EDT 2014 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/koala_1117Mon_2335
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Mon Nov 17 23:36:17 CST 2014
Total time = 0m 33s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
23:35:37 up 26 days, 12:13, 2 users, load average: 0.00, 0.00, 0.00
/dev/sda6 54205540 12828676 38616724 25% /
tmpfs 6099124 0 6099124 0% /dev/shm
/dev/sda1 194241 45819 138182 25% /boot
/dev/sda2 12850716 283504 11907756 3% /tmp
/dev/sda3 12850716 4813556 7377704 40% /var
/dev/sdd 152623212 109249664 35614088 76% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Mon Nov 17 23:35:47 CST 2014
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-504.el6.x86_64 #1 SMP Wed Oct 15 04:27:16 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/platypus_1117Mon_2335
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Mon Nov 17 23:36:29 CST 2014
Total time = 0m 42s
*** finished tests in platypus ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
23:35:39 up 28 days, 10:25, 1 user, load average: 0.00, 0.00, 0.24
/dev/mapper/vg_ostrich-lv_root
140479384 15066788 118273552 12% /
tmpfs 7821632 0 7821632 0% /dev/shm
/dev/sda2 487652 88435 373617 20% /boot
/dev/sdb2 124477364 70262496 47885116 60% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
Mon Nov 17 23:35:49 CST 2014
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-504.el6.ppc64 #1 SMP Tue Sep 16 01:52:45 EDT 2014 ppc64 ppc64 ppc64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_1117Mon_2335
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Mon Nov 17 23:37:30 CST 2014
Total time = 1m 41s
*** finished tests in ostrich ***
Testing kite
ssh -o ConnectTimeout=60 kite -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
23:35 up 6 days, 10:23, 2 users, load averages: 0.05 0.09 0.12
Filesystem 512-blocks Used Available Capacity iused ifree %iused Mounted on
/dev/disk0s2 1951845952 195180936 1756153016 11% 24461615 219519127 10% /
devfs 373 373 0 100% 646 0 100% /dev
/dev/disk1s2 1952853344 1296736 1951556608 1% 162090 243944576 0% /Volumes/Milvinae
72.36.68.242:/mnt/hdf 1922864144 1484688560 340499584 82% 8407645 113702307 7% /mnt/hdf
72.36.68.242:/mnt/scr1 1922864144 1683872240 141315904 93% 3507370 118602582 3% /mnt/scr1
72.36.68.242:/home 396703680 49600288 326626672 14% 543307 50673077 1% /mnt/home
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
Mon Nov 17 23:35:52 CST 2014
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests in kite ***
Uname -a: Darwin kite.ad.hdfgroup.uiuc.edu 12.5.0 Darwin Kernel Version 12.5.0: Sun Sep 29 13:33:47 PDT 2013; root:xnu-2050.48.12~1/RELEASE_X86_64 x86_64
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests for kite ***
Total time = 0m 9s
*** finished tests in kite ***
****SYSTEM ERROR kite: Abnormal exit from runtest ****
****SYSTEM ERROR kite: runtest command failed ****
More information about the opa-nightly-tests
