[opa-nightly-tests] jam OPA_Daily_Tests_0221Fri
HDF Tester
hdftest at hdfgroup.org
Fri Feb 21 20:53:16 CST 2014
*** OPA Tests on 0221Fri ***
Tests Summary
PASSED emu: setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
Tests Time Summary
koala: Ran 1(1/0/0) tests, Grand total test time = 0m 34s
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 2s
ostrich: Ran 1(1/0/0) tests, Grand total test time = 1m 30s
emu: Ran 1(1/0/0) tests, Grand total test time = 8m 42s
jam: Ran 5(0/0/0) hosts, Grand total test time = 9m 40s
Timekeeper log
Timekeeper started at Fri Feb 21 20:43:47 CST 2014
Timekeeper sleeping for 720 seconds
Tests Failures
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
20:43:26 up 161 days, 12:33, 18 users, load average: 0.00, 0.00, 0.25
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 5510764 24589428 19% /
/dev/sda1 101086 17507 78360 19% /boot
/dev/sda2 31738420 404164 29696028 2% /tmp
/dev/sda6 31738392 16065460 14034708 54% /var
/dev/sda7 31738392 18334804 11765364 61% /usr
/dev/sda8 124991068 1021116 117518252 1% /var/tmp
/dev/mapper/VolGroup00-home
198351840 17982608 170130872 10% /home
/dev/sde1 565688764 261288212 275201616 49% /scr
/dev/sdc1 961432072 839233964 73360108 92% /mnt/scr1
/dev/sdd1 961432072 875360016 37234056 96% /mnt/hdf
tmpfs 8313628 16 8313612 1% /dev/shm
gumund:/data/ftp 480719104 369501440 86798464 81% /mnt/ftp
gumund:/data/web 480719104 369501440 86798464 81% /mnt/web
STANDARD_OPT=deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0221Fri
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0221Fri.3476: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0221Fri.3476': No such file or directory
*** launching tests from jam ***
TESTHOST is emu
jam
koala
ostrich
wren
Fork off timekeeper 12
Testing emu
ssh -o ConnectTimeout=60 emu -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname emu
8:43pm up 378 day(s), 4:10, 0 users, load average: 0.01, 0.01, 0.06
/ (rpool/ROOT/solaris):491464353 blocks 491464353 files
/devices (/devices ): 0 blocks 0 files
/dev (/dev ): 0 blocks 0 files
/system/contract (ctfs ): 0 blocks 2147483586 files
/proc (proc ): 0 blocks 29922 files
/etc/mnttab (mnttab ): 0 blocks 0 files
/system/volatile (swap ):11560720 blocks 2225078 files
/system/object (objfs ): 0 blocks 2147483423 files
/etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
/dev/fd (fd ): 0 blocks 0 files
/var (rpool/ROOT/solaris/var):491464353 blocks 491464353 files
/tmp (swap ):11560720 blocks 2225078 files
/var/share (rpool/VARSHARE ):491464353 blocks 491464353 files
/export (rpool/export ):491464353 blocks 491464353 files
/export/home (rpool/export/home ):491464353 blocks 491464353 files
/export/home/kurz (rpool/export/home/kurz):491464353 blocks 491464353 files
/rpool (rpool ):491464353 blocks 491464353 files
/mnt/scr1 (jam:/mnt/scr1 ):244396160 blocks 118687347 files
/home (jam:/home ):360738464 blocks 50794460 files
/mnt/hdf (jam:/mnt/hdf ):172144112 blocks 113284442 files
/mnt/web (gumund:/mnt/web ):222435184 blocks 60884644 files
/mnt/ftp (gumund:/mnt/ftp ):222435184 blocks 60884644 files
TEST_TYPES=setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64
Friday, February 21, 2014 08:44:03 PM CST
*** starting setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64 tests in emu ***
Uname -a: SunOS emu.hdfgroup.uiuc.edu 5.11 11.1 sun4v sparc sun4v
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/emu_0221Fri_2044
*** finished setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64 tests for emu ***
Friday, February 21, 2014 08:52:45 PM CST
Total time = 8m 42s
*** finished tests in emu ***
Testing jam
ssh -o ConnectTimeout=60 jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
20:43:55 up 161 days, 12:34, 18 users, load average: 0.14, 0.03, 0.26
/dev/sda2 31738420 404268 29695924 2% /tmp
/dev/sda6 31738392 16065840 14034328 54% /var
/dev/sdc1 961432072 839234000 73360072 92% /mnt/scr1
Fri Feb 21 20:44:05 CST 2014
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/jam_0221Fri_2044
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Fri Feb 21 20:45:07 CST 2014
Total time = 1m 2s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
20:43:57 up 73 days, 11:06, 2 users, load average: 0.08, 0.02, 0.12
/dev/sda7 22292052 4047972 17093428 20% /
/dev/sda5 12192608 522704 11040560 5% /tmp
/dev/sda3 12192636 1883660 9679632 17% /var
/dev/sda1 101086 18571 77296 20% /boot
/dev/sdc1 41279536 26141260 13041396 67% /usr
/dev/sdb 152754284 23234904 121759920 17% /scr
tmpfs 6149552 16 6149536 1% /dev/shm
jam:/home 198351872 17982464 170131456 10% /home
jam:/mnt/hdf 961432576 875360256 37234688 96% /mnt/hdf
jam:/mnt/scr1 961432576 839233536 73360384 92% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Fri Feb 21 20:44:07 CST 2014
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-371.3.1.el5 #1 SMP Thu Dec 5 12:47:02 EST 2013 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/koala_0221Fri_2044
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Fri Feb 21 20:44:41 CST 2014
Total time = 0m 34s
*** finished tests in koala ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
20:43:59 up 163 days, 9:51, 4 users, load average: 0.06, 0.05, 0.40
/dev/mapper/vg_ostrich-lv_root
140610456 11729788 121741624 9% /
tmpfs 7821696 128 7821568 1% /dev/shm
/dev/sda2 495844 92936 377308 20% /boot
/dev/sdb2 124608436 42234760 76043924 36% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
Fri Feb 21 20:44:09 CST 2014
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-358.18.1.el6.ppc64 #1 SMP Fri Aug 2 17:07:40 EDT 2013 ppc64 ppc64 ppc64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0221Fri_2044
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Fri Feb 21 20:45:39 CST 2014
Total time = 1m 30s
*** finished tests in ostrich ***
Testing wren
ssh -o ConnectTimeout=60 wren -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname wren
/home/hdftest/snapshots-opa: No such file or directory.
****SYSTEM ERROR wren: Abnormal exit from runtest ****
****SYSTEM ERROR wren: runtest command failed ****
More information about the opa-nightly-tests
