[opa-nightly-tests] jam OPA_Daily_Tests_0801Fri_FAILED!!!
HDF Tester hdftest at hdfgroup.org
Fri Aug 1 23:25:15 CDT 2014
*** OPA Tests on 0801Fri ***
   Tests Summary
****FAILED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich****
****FAILED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus****
PASSED emu: setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
PASSED kite: standard op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
   Tests Time Summary
platypus: Ran 1(0/1/0) tests, Grand total test time =  0m 2s
ostrich: Ran 1(0/1/0) tests, Grand total test time =  0m 1s
koala: Ran 1(1/0/0) tests, Grand total test time =  0m 32s
kite: Ran 1(1/0/0) tests, Grand total test time =  0m 47s
jam: Ran 1(1/0/0) tests, Grand total test time =  1m 1s
emu: Ran 1(1/0/0) tests, Grand total test time =  8m 42s
jam: Ran 6(0/0/0) hosts, Grand total test time =  9m 38s
   Timekeeper log
Timekeeper started at Fri Aug  1 23:15:48 CDT 2014
Timekeeper sleeping for 720 seconds
   Tests Failures
Dumping logfile of platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/platypus_0801Fri_2311
===Done Dumping environment variables before option parsing ===
===Dumping environment variables after option parsing ===
CCACHE_DISABLE=yes
CVSROOT=/mnt/hdf/cvs
CVS_RSH=ssh
EC2_CERT=/home/hdftest/.ec2/cert-6HKISUOM3HT2PWDQB4PLG67KTWOVVKOK.pem
EC2_HOME=/mnt/hdf/ec2-api-tools
EC2_PRIVATE_KEY=/home/hdftest/.ec2/pk-6HKISUOM3HT2PWDQB4PLG67KTWOVVKOK.pem
G_BROKEN_FILENAMES=1
GROUP=hdf
HDF5TestExpress=yes
HOME=/home/hdftest
HOST=platypus
HOSTTYPE=x86_64-linux
JAVA_HOME=/usr/lib/jvm/jre-1.6.0
LANG=en_US.UTF-8
LESSOPEN=|/usr/bin/lesspipe.sh %s
LOGNAME=hdftest
LS_COLORS=
MACHTYPE=x86_64
MAIL=/var/spool/mail/hdftest
MAKE=gmake -j 4
MANPATH=/usr/local/man:/usr/share/man:/usr/kerberos/man
OSTYPE=linux
PATH=/home/hdftest/bin:/usr/hdf/bin:/home/hdftest/bin:/usr/hdf/bin:/usr/local/bin:/bin:/usr/bin:/usr/kerberos/bin:/mnt/hdf/ec2-api-tools/bin
PWD=/mnt/scr1/SnapTest/snapshots-opa
SELINUX_LEVEL_REQUESTED=
SELINUX_ROLE_REQUESTED=
SELINUX_USE_CURRENT_RANGE=
SET_PATH=yes
SHELL=/bin/tcsh
SHLVL=3
SSH_CLIENT=72.36.68.242 37376 22
SSH_CONNECTION=72.36.68.242 37376 72.36.68.205 22
SVNROOT=http://svn.hdfgroup.uiuc.edu
USER=hdftest
_=/usr/bin/printenv
VENDOR=unknown
===Done Dumping environment variables after option parsing ===
===== Run Tests: Fri Aug  1 23:11:39 CDT 2014 =====
Remove contents of platypus.\n
/usr/bin/diff: /home/hdftest/snapshots-opa/previous/MANIFEST: No such file or directory
/usr/bin/diff: /home/hdftest/snapshots-opa/current/MANIFEST: No such file or directory
===== configure: Fri Aug  1 23:11:39 CDT 2014 =====
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... configure: error: newly created file is older than distributed files!
Check your system clock
Failed running configure
===== Exit bin/snapshot with status=1: Fri Aug  1 23:11:41 CDT 2014 =====
Dumping done
Dumping logfile of ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0801Fri_2311
CCACHE_DISABLE=yes
CVS_RSH=ssh
GROUP=hdf
HDF5TestExpress=yes
HOME=/home/hdftest
HOST=ostrich
HOSTTYPE=powerpc64-linux
LANG=en_US.UTF-8
LOGNAME=hdftest
LS_COLORS=
MACHTYPE=powerpc64
MAKE=gmake -j 32
OSTYPE=linux
PATH=/home/hdftest/bin:/usr/hdf/bin:/home/hdftest/bin:/usr/lib64/qt-3.3/bin:/usr/hdf/bin:/usr/local/bin:/bin:/usr/bin:/usr/kerberos/bin:/mnt/hdf/ec2-api-tools/bin
QTDIR=/usr/lib64/qt-3.3
QTINC=/usr/lib64/qt-3.3/include
QTLIB=/usr/lib64/qt-3.3/lib
SET_PATH=yes
SHELL=/bin/tcsh
SHLVL=3
SSH_ASKPASS=/usr/libexec/openssh/gnome-ssh-askpass
SSH_CLIENT=72.36.68.242 46345 22
SSH_CONNECTION=72.36.68.242 46345 72.36.68.90 22
USER=hdftest
_=/usr/bin/printenv
VENDOR=unknown
===== Run Tests: Fri Aug  1 23:11:42 CDT 2014 =====
Remove contents of ostrich.\n
===== configure: Fri Aug  1 23:11:42 CDT 2014 =====
===== Exit bin/snapshot with status=1: Fri Aug  1 23:11:43 CDT 2014 =====
Dumping done
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 23:15:27 up 141 days, 14:04,  7 users,  load average: 0.05, 0.05, 0.08
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda3             31738420   5769280  24330912  20% /
/dev/sda1               101086     17515     78352  19% /boot
/dev/sda2             31738420    381440  29718752   2% /tmp
/dev/sda6             31738392   7070968  23029200  24% /var
/dev/sda7             31738392  18354208  11745960  61% /usr
/dev/sda8            124991068   2354084 116185284   2% /var/tmp
/dev/sde1            565688764 497944860  38544968  93% /scr
tmpfs                  8313628         0   8313628   0% /dev/shm
/dev/mapper/VolGroup00-home
                     198351840  24719700 163393780  14% /home
/dev/sdc1            961432072 868610992  43983080  96% /mnt/scr1
/dev/sdd1            961432072 864880480  47713592  95% /mnt/hdf
sloth.hdfgroup.uiuc.edu:/volume1/hdf2
                     1437485440 126198784 1311184256   9% /mnt/hdf2
gumund:/data/ftp     480719104 431409408  24890496  95% /mnt/ftp
gumund:/data/web     480719104 431409408  24890496  95% /mnt/web
STANDARD_OPT=deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0801Fri
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0801Fri.6015: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0801Fri.6015': No such file or directory
*** launching tests from jam ***
TESTHOST is emu
jam
koala
platypus
ostrich
kite
    Fork off timekeeper 12
Testing emu
ssh -o ConnectTimeout=60 emu -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname emu
 11:15pm  up 14 day(s),  7:56,  0 users,  load average: 0.01, 0.01, 0.01
/                  (rpool/ROOT/solaris):488419210 blocks 488419210 files
/devices           (/devices          ):       0 blocks        0 files
/dev               (/dev              ):       0 blocks        0 files
/system/contract   (ctfs              ):       0 blocks 2147483594 files
/proc              (proc              ):       0 blocks    29935 files
/etc/mnttab        (mnttab            ):       0 blocks        0 files
/system/volatile   (swap              ):12345776 blocks  2229303 files
/system/object     (objfs             ):       0 blocks 2147483468 files
/etc/dfs/sharetab  (sharefs           ):       0 blocks 2147483646 files
/dev/fd            (fd                ):       0 blocks        0 files
/var               (rpool/ROOT/solaris/var):488419210 blocks 488419210 files
/tmp               (swap              ):12345776 blocks  2229303 files
/var/share         (rpool/VARSHARE    ):488419210 blocks 488419210 files
/export            (rpool/export      ):488419210 blocks 488419210 files
/export/home       (rpool/export/home ):488419210 blocks 488419210 files
/export/home/kurz  (rpool/export/home/kurz):488419210 blocks 488419210 files
/rpool             (rpool             ):488419210 blocks 488419210 files
/home              (jam:/home         ):347264280 blocks 50667540 files
/mnt/web           (gumund:/mnt/web   ):98619208 blocks 60887959 files
/mnt/hdf           (jam:/mnt/hdf      ):193103184 blocks 113227845 files
/mnt/ftp           (gumund:/mnt/ftp   ):98619208 blocks 60887959 files
/mnt/scr1          (jam:/mnt/scr1     ):185642104 blocks 118575293 files
TEST_TYPES=setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64
Friday, August  1, 2014 11:16:03 PM CDT
*** starting setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64 tests in emu ***
Uname -a: SunOS emu.hdfgroup.uiuc.edu 5.11 11.1 sun4v sparc sun4v
Running snapshot with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/emu_0801Fri_2316
*** finished setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64 tests for emu ***
Friday, August  1, 2014 11:24:45 PM CDT
Total time = 8m 42s
*** finished tests in emu ***
Testing jam
ssh -o ConnectTimeout=60 jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
 23:15:55 up 141 days, 14:05,  7 users,  load average: 0.17, 0.08, 0.09
/dev/sda2             31738420    381548  29718644   2% /tmp
/dev/sdc1            961432072 868611028  43983044  96% /mnt/scr1
Fri Aug  1 23:16:05 CDT 2014
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/jam_0801Fri_2316
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Fri Aug  1 23:17:06 CDT 2014
Total time = 1m 1s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
 23:11:27 up 141 days, 10:54,  0 users,  load average: 0.15, 0.11, 0.10
/dev/sda7             22292052   4050572  17090828  20% /
/dev/sda5             12192608    547240  11016024   5% /tmp
/dev/sda3             12192636   2087768   9475524  19% /var
/dev/sda1               101086     18578     77289  20% /boot
/dev/sdc1             41279536  26143172  13039484  67% /usr
/dev/sdb             152754284 100542124  44452700  70% /scr
tmpfs                  6149552         0   6149552   0% /dev/shm
jam:/home            198351872  24719360 163394560  14% /home
jam:/mnt/hdf         961432576 864880640  47714304  95% /mnt/hdf
jam:/mnt/scr1        961432576 868611072  43983872  96% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Fri Aug  1 23:11:37 CDT 2014
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-371.6.1.el5 #1 SMP Wed Mar 12 20:03:51 EDT 2014 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/koala_0801Fri_2311
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Fri Aug  1 23:12:09 CDT 2014
Total time = 0m 32s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
 23:11:29 up 50 days,  5:54,  0 users,  load average: 0.08, 0.02, 0.01
/dev/sda6         54336612  12643548  38932924  25% /
tmpfs              1962216         0   1962216   0% /dev/shm
/dev/sda1           198337     50108    137989  27% /boot
/dev/sda2         12981788    229352  12092980   2% /tmp
/dev/sda3         12981788   5434836   6887496  45% /var
/dev/sdd         152754284  57772904  87221920  40% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-431.11.2.el6.x86_64 #1 SMP Tue Mar 25 19:59:55 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Total time = 0m 2s
*** finished tests in platypus ***
****SYSTEM ERROR platypus: Abnormal exit from runtest ****
	****SYSTEM ERROR platypus: runtest command failed ****
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
 23:11:32 up 32 days,  5:38,  0 users,  load average: 0.00, 0.00, 0.05
/dev/mapper/vg_ostrich-lv_root
                     140610456  14316728 119154684  11% /
tmpfs                  7821632         0   7821632   0% /dev/shm
/dev/sda2               495844     96919    373325  21% /boot
/dev/sdb2            124608436  55954236  62324448  48% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-431.11.2.el6.ppc64 #1 SMP Mon Mar 3 13:31:04 EST 2014 ppc64 ppc64 ppc64 GNU/Linux
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Total time = 0m 1s
*** finished tests in ostrich ***
****SYSTEM ERROR ostrich: Abnormal exit from runtest ****
	****SYSTEM ERROR ostrich: runtest command failed ****
Testing kite
ssh -o ConnectTimeout=60 kite -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
23:16  up 1 day, 10:56, 1 user, load averages: 0.04 0.04 0.07
Filesystem             512-blocks       Used  Available Capacity  iused     ifree %iused  Mounted on
/dev/disk0s2           1951845952  196980528 1754353424    11% 24686564 219294178   10%   /
devfs                         373        373          0   100%      646         0  100%   /dev
/dev/disk1s2           1952853344    1296608 1951556736     1%   162074 243944592    0%   /Volumes/Milvinae
72.36.68.242:/mnt/scr1 1922864144 1737222120   87966024    96%  3534669 118575283    3%   /mnt/scr1
72.36.68.242:/home      396703680   49439400  326787560    14%   548844  50667540    1%   /mnt/home
72.36.68.242:/mnt/hdf  1922864144 1729760960   95427184    95%  8882107 113227845    7%   /mnt/hdf
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
Fri Aug  1 23:16:15 CDT 2014
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests in kite ***
Uname -a: Darwin kite.ad.hdfgroup.uiuc.edu 12.5.0 Darwin Kernel Version 12.5.0: Sun Sep 29 13:33:47 PDT 2013; root:xnu-2050.48.12~1/RELEASE_X86_64 x86_64
   /Users/hdftest/snapshots-opa/log/kite_0801Fri_2316
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests for kite ***
Fri Aug  1 23:17:02 CDT 2014
Total time = 0m 47s
*** finished tests in kite ***
More information about the opa-nightly-tests mailing list
