[opa-nightly-tests] jam OPA_Daily_Tests_0417Thu_FAILED!!!
Larry Knox lrknox at hdfgroup.org
Fri Apr 18 12:33:00 CDT 2014
I checked this morning and my recollection is that  the difference was about 40 seconds.
Les said they had a notice from CITES in the last couple of weeks asking us to turn off NTP servers, which emu was running.  When they did that, it also turned off the NTP client.  He has revised the configuration so the client is running again.
Larry
-----Original Message-----
Sent: Friday, April 18, 2014 12:26 PM
To: Larry Knox
Cc: hdftest; opa-nightly-tests at lists.mcs.anl.gov
Subject: Re: [opa-nightly-tests] jam OPA_Daily_Tests_0417Thu_FAILED!!!
I noticed emu's clock was more than 10 seconds but less than a minute different from Jam.
That was two days ago (the day when quail failed daily test because of NFS failures that due to clock difference).
I thought Emu was within tolerance. Did the clock drift even further apart?
On Apr 18, 2014, at 6:30 AM, Larry Knox <lrknox at hdfgroup.org> wrote:
> Emu system clock is out of sync.  We'll get it corrected today.
> Larry
> From: opa-nightly-tests-bounces at lists.mcs.anl.gov [mailto:opa-nightly-tests-bounces at lists.mcs.anl.gov] On Behalf Of HDF Tester
> Sent: Thursday, April 17, 2014 11:24 PM
> To: opa-nightly-tests at lists.mcs.anl.gov
> Subject: [opa-nightly-tests] jam OPA_Daily_Tests_0417Thu_FAILED!!!
> *** OPA Tests on 0417Thu ***
>   Tests Summary
> ****FAILED emu: standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32****
> PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam PASSED kite: standard op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
>   Tests Time Summary
> emu: Ran 1(0/1/0) tests, Grand total test time =  0m 2s
> koala: Ran 1(1/0/0) tests, Grand total test time =  0m 33s
> platypus: Ran 1(1/0/0) tests, Grand total test time =  0m 46s
> jam: Ran 1(1/0/0) tests, Grand total test time =  0m 58s
> kite: Ran 1(1/0/0) tests, Grand total test time =  0m 55s
> ostrich: Ran 1(1/0/0) tests, Grand total test time =  1m 39s
> jam: Ran 6(0/0/0) hosts, Grand total test time =  2m 45s
>   Timekeeper log
> Timekeeper started at Thu Apr 17 23:21:49 CDT 2014 Timekeeper sleeping for 720 seconds
>   Tests Failures
> Dumping logfile of emu: standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32 Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/emu_0417Thu_2321
> A__z="*SHLVL
> CCACHE_DISABLE=yes
> CVSROOT=/mnt/hdf/cvs
> EC2_CERT=/home/hdftest/.ec2/cert-6HKISUOM3HT2PWDQB4PLG67KTWOVVKOK.pem
> EC2_HOME=/mnt/hdf/ec2-api-tools
> EC2_PRIVATE_KEY=/home/hdftest/.ec2/pk-6HKISUOM3HT2PWDQB4PLG67KTWOVVKOK.pem
> GROUP=hdf
> HDF5TestExpress=yes
> HOME=/home/hdftest
> HOST=emu.hdfgroup.uiuc.edu
> HOSTTYPE=sun4
> JAVA_HOME=/usr/lib/jvm/jre-1.6.0
> LANG=en_US.UTF-8
> LC_ALL=
> LC_COLLATE=
> LC_CTYPE=
> LC_MESSAGES=
> LC_MONETARY=
> LC_NUMERIC=
> LC_TIME=
> LOGNAME=hdftest
> MACHTYPE=sparc
> MAIL=/var/mail/hdftest
> MAKE=gmake -j 8
> NLSPATH=/usr/share/locale/%L/LC_MESSAGES/%N.cat
> OSTYPE=solaris
> PATH=/home/hdftest/bin:/usr/hdf/bin:/home/hdftest/bin:/usr/hdf/bin:/usr/bin:/usr/sbin:/opt/solarisstudio/bin:/opt/cmake/bin:/opt/svn/bin:/mnt/hdf/ec2-api-tools/bin
> PWD=/mnt/scr1/SnapTest/snapshots-opa
> REMOTEHOST=
> SET_PATH=yes
> SHELL=/bin/tcsh
> SHLVL=3
> SSH_CLIENT=72.36.68.242 42514 22
> SSH_CONNECTION=72.36.68.242 42514 72.36.68.177 22 SVNROOT=http://svn.hdfgroup.uiuc.edu
> TZ=localtime
> USER=hdftest
> VENDOR=sun
> ===Done Dumping environment variables after option parsing === ===== Run Tests: Thursday, April 17, 2014 11:21:44 PM CDT ===== Remove contents of emu.
> diff: /home/hdftest/snapshots-opa/previous/MANIFEST: No such file or directory ===== configure: Thursday, April 17, 2014 11:21:44 PM CDT ===== checking for a BSD-compatible install... /usr/bin/ginstall -c checking whether build environment is sane... configure: error: newly created file is older than distributed files!
> Check your system clock
> Failed running configure
> ===== Exit bin/snapshot with status=1: Thursday, April 17, 2014 11:21:45 PM CDT ===== Thursday, April 17, 2014 11:21:45 PM CDT ========================= Dumping done =========================
> Runtest did not exit normally.
>   Watchers List
> OPA Daily test features/platforms watchers and procedure
> Procedure:
> The watcher will investigate and report the cause of failure by 11am.
> The developer who checked in the error code may report so by then too.
> The watcher or the developer should get the failure fixed and report it by 3pm.
> Watcher for OPA:	 	Neil
> updated: 2009/05/05
More information about the opa-nightly-tests mailing list
