[opa-nightly-tests] jam OPA_Daily_Tests_0318Sun_FAILED!!!
HDF Tester
hdftest at hdfgroup.org
Sun Mar 18 00:15:18 CDT 2012
*** OPA Tests on 0318Sun ***
Tests Summary
****FAILED ostrich: standard****
PASSED freedom: standard
PASSED jam: standard
PASSED koala: standard
PASSED linew: standard
PASSED loyalty: standard
Tests Time Summary
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 21s
koala: Ran 1(1/0/0) tests, Grand total test time = 1m 23s
freedom: Ran 1(1/0/0) tests, Grand total test time = 1m 19s
loyalty: Ran 1(1/0/0) tests, Grand total test time = 1m 25s
ostrich: Ran 1(0/1/0) tests, Grand total test time = 2m 36s
linew: Ran 1(1/0/0) tests, Grand total test time = 3m 47s
jam: Ran 6(0/0/0) hosts, Grand total test time = 4m 48s
Timekeeper log
Timekeeper started at Sun Mar 18 00:10:45 CDT 2012
Timekeeper sleeping for 1800 seconds
Tests Failures
Dumping logfile of ostrich: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0318Sun_0011
Testing integer swap with 100 threads PASSED
Testing pointer swap with 100 threads PASSED
Testing integer LL/SC stack with 100 threads *WARNING*
Only 969994/970000 pushes succeeded. There may be an issue with fairness.
Testing pointer LL/SC stack with 100 threads *WARNING*
Only 969997/970000 pushes succeeded. There may be an issue with fairness.
***** 1 PRIMITIVES TEST FAILED! *****
FAIL: test_primitives
Testing memory barrier sanity PASSED
Testing memory barriers with linear array with 2 threads PASSED
Testing memory barriers with local variables with 2 threads PASSED
Testing memory barriers with scattered array with 2 threads PASSED
Testing memory barriers with linear array with 4 threads PASSED
Testing memory barriers with local variables with 4 threads PASSED
Testing memory barriers with scattered array with 4 threads PASSED
Testing memory barriers with linear array with 10 threads PASSED
Testing memory barriers with local variables with 10 threads PASSED
Testing memory barriers with scattered array with 10 threads PASSED
Testing memory barriers with linear array with 100 threads PASSED
Testing memory barriers with local variables with 100 threads PASSED
Testing memory barriers with scattered array with 100 threads PASSED
All barriers tests passed.
PASS: test_barriers
Testing queue sanity PASSED
Testing multithreaded queue with 2 threads PASSED
Testing multithreaded queue (empty queue) with 2 threads PASSED
Testing multithreaded queue (full queue) with 2 threads PASSED
Testing multithreaded queue with 4 threads PASSED
Testing multithreaded queue (empty queue) with 4 threads PASSED
Testing multithreaded queue (full queue) with 4 threads PASSED
Testing multithreaded queue with 10 threads PASSED
Testing multithreaded queue (empty queue) with 10 threads PASSED
Testing multithreaded queue (full queue) with 10 threads PASSED
Testing multithreaded queue with 100 threads PASSED
Testing multithreaded queue (empty queue) with 100 threads PASSED
Testing multithreaded queue (full queue) with 100 threads PASSED
All queue tests passed.
PASS: test_queue
1 of 4 tests failed
Please report to https://trac.mcs.anl.gov/projects/openpa/newticket
gmake[2]: *** [check-TESTS] Error 1
gmake[2]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/ostrich/test'
gmake[1]: *** [check-am] Error 2
gmake[1]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/ostrich/test'
gmake: *** [check-recursive] Error 1
Failed running make check
===== Exit bin/snapshot with status=2: Sun Mar 18 00:13:43 CDT 2012 =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
00:10:20 up 22 days, 14:27, 47 users, load average: 2.14, 1.83, 2.33
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 4006240 26093952 14% /
/dev/sda1 101086 34368 61499 36% /boot
/dev/sda2 31738420 180896 29919296 1% /tmp
/dev/sda6 31738392 4355512 25744656 15% /var
/dev/sda7 31738392 26806416 3293752 90% /usr
/dev/sda8 124991068 421008 118118360 1% /var/tmp
/dev/mapper/VolGroup00-home
198351840 14811112 173302368 8% /home
/dev/sde1 565688764 429278520 107211308 81% /scr
/dev/sdc1 961432072 741400352 171193720 82% /mnt/scr1
/dev/sdd1 961432072 765862624 146731448 84% /mnt/hdf
tmpfs 8313848 0 8313848 0% /dev/shm
gumund:/data/ftp 480719072 326305056 129994816 72% /mnt/ftp
gumund:/data/web 480719072 326305056 129994816 72% /mnt/web
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0318Sun
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0318Sun.1778: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0318Sun.1778': No such file or directory
*** launching tests from jam ***
TESTHOST is linew
jam
koala
ostrich
loyalty
freedom
Fork off timekeeper 30
Testing linew
ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname linew
12:10am up 3 day(s), 12:48, 0 users, load average: 0.08, 0.04, 0.03
/ (/dev/dsk/c1t0d0s0 ):51866354 blocks 8227912 files
/devices (/devices ): 0 blocks 0 files
/system/contract (ctfs ): 0 blocks 2147483605 files
/proc (proc ): 0 blocks 29945 files
/etc/mnttab (mnttab ): 0 blocks 0 files
/etc/svc/volatile (swap ):20949568 blocks 1180625 files
/system/object (objfs ): 0 blocks 2147483488 files
/etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
/platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):51866354 blocks 8227912 files
/platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):51866354 blocks 8227912 files
/dev/fd (fd ): 0 blocks 0 files
/tmp (swap ):20949568 blocks 1180625 files
/var/run (swap ):20949568 blocks 1180625 files
/scr (/dev/dsk/c1t1d0s0 ):853614006 blocks 226671705 files
/home (jam:/home ):367081456 blocks 50906530 files
/mnt/hdf (jam:/mnt/hdf ):391138896 blocks 113515295 files
/mnt/scr1 (jam:/mnt/scr1 ):440061392 blocks 118692528 files
/mnt/web (gumund:/mnt/web ):308828016 blocks 60877837 files
/mnt/ftp (gumund:/mnt/ftp ):308828016 blocks 60877837 files
TEST_TYPES=standard
Sun Mar 18 00:11:01 CDT 2012
*** starting standard tests in linew ***
Uname -a: SunOS linew 5.10 Generic_147440-13 sun4u sparc SUNW,A70
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/linew_0318Sun_0011
*** finished standard tests for linew ***
Sun Mar 18 00:14:48 CDT 2012
Total time = 3m 47s
*** finished tests in linew ***
Testing jam
ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
00:10:53 up 22 days, 14:28, 47 users, load average: 2.29, 1.89, 2.33
/dev/sda2 31738420 181016 29919176 1% /tmp
/dev/sda6 31738392 4355516 25744652 15% /var
/dev/sdc1 961432072 741401404 171192668 82% /mnt/scr1
TEST_TYPES=standard
Sun Mar 18 00:11:03 CDT 2012
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-194.3.1.el5PAE #1 SMP Thu May 13 13:48:44 EDT 2010 i686 i686 i386 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/jam_0318Sun_0011
*** finished standard tests for jam ***
Sun Mar 18 00:12:23 CDT 2012
Total time = 1m 20s
*** finished tests in jam ***
Sun Mar 18 00:12:24 CDT 2012
Testing koala
ssh koala -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
00:10:56 up 32 days, 14:05, 1 user, load average: 3.29, 2.48, 2.43
/dev/sda7 22292052 17545824 3595576 83% /
/dev/sda5 12192608 499212 11064052 5% /tmp
/dev/sda3 12192636 1062900 10500392 10% /var
/dev/sda1 101086 37215 58652 39% /boot
tmpfs 6149572 0 6149572 0% /dev/shm
/dev/sdd1 41279536 22176480 17006176 57% /usr
/dev/md0 48091528 42044008 3604592 93% /scr
jam:/home 198351840 14811104 173302368 8% /home
jam:/mnt/hdf 961432096 765862624 146731456 84% /mnt/hdf
jam:/mnt/scr1 961432096 741401536 171192576 82% /mnt/scr1
TEST_TYPES=standard
Sun Mar 18 00:11:10 CDT 2012
*** starting standard tests in koala ***
Uname -a: Linux koala 2.6.18-274.18.1.el5 #1 SMP Thu Feb 9 12:45:44 EST 2012 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/koala_0318Sun_0011
*** finished standard tests for koala ***
Sun Mar 18 00:12:29 CDT 2012
Total time = 1m 19s
*** finished tests in koala ***
Testing ostrich
ssh ostrich -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
00:10:57 up 9 days, 12:09, 0 users, load average: 0.00, 0.00, 0.48
/dev/mapper/vg_ostrich-lv_root
140610456 9013532 124457880 7% /
tmpfs 7821760 0 7821760 0% /dev/shm
/dev/sda2 495844 130248 339996 28% /boot
/dev/sdb2 124608436 1234668 117044016 2% /scr
jam:/mnt/scr1 961432096 741401600 171192512 82% /mnt/scr1
TEST_TYPES=standard
Sun Mar 18 00:11:08 CDT 2012
*** starting standard tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-220.7.1.el6.ppc64 #1 SMP Fri Feb 10 15:24:28 EST 2012 ppc64 ppc64 ppc64 GNU/Linux
*** finished standard tests for ostrich ***
Total time = 2m 35s
*** finished tests in ostrich ***
****SYSTEM ERROR ostrich: Abnormal exit from runtest ****
****SYSTEM ERROR ostrich: runtest command failed ****
Testing loyalty
ssh loyalty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname loyalty
grep: /proc/cpuinfo: No such file or directory
12:11AM up 9 days, 10:25, 0 users, load averages: 0.02, 0.01, 0.00
Filesystem 1K-blocks Used Avail Capacity Mounted on
/dev/da0s1a 507630 103648 363372 22% /
devfs 1 1 0 100% /dev
/dev/da0s1g 58896528 30328228 23856578 56% /local_home
/dev/da0s1f 16244334 4862524 10082264 33% /usr
/dev/da0s1d 1012974 202856 729082 22% /var
/dev/da0s1e 507630 16732 450288 4% /var/tmp
procfs 4 4 0 100% /proc
jam:/home 198351840 14811112 173302368 8% /home
jam:/mnt/hdf 961432072 765862624 146731448 84% /mnt/hdf
jam:/mnt/scr1 961432072 741401660 171192412 81% /mnt/scr1
gumund:/data/web 480719056 326305048 129994808 72% /mnt/web
gumund:/data/ftp 480719056 326305048 129994808 72% /mnt/ftp
devfs 1 1 0 100% /var/named/dev
/dev/md0 126702 18 116548 0% /tmp
TEST_TYPES=standard
*** starting standard tests in loyalty ***
Uname -a: FreeBSD loyalty.hdfgroup.uiuc.edu 8.2-STABLE FreeBSD 8.2-STABLE #0: Tue May 3 22:23:36 CDT 2011 sukoziol at loyalty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/LOYALTY i386
/mnt/scr1/SnapTest/snapshots-opa/log/loyalty_0318Sun_0011
*** finished standard tests for loyalty ***
Sun Mar 18 00:12:35 CDT 2012
Total time = 1m 25s
*** finished tests in loyalty ***
Testing freedom
ssh freedom -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname freedom
12:11AM up 9 days, 10:25, 1 user, load averages: 0.00, 0.01, 0.00
/dev/da0s1a 507630 116218 350802 25% /
/dev/da0s1g 45184754 29129220 12440754 70% /local_home
/dev/da0s1f 24372460 5411794 17010870 24% /usr
/dev/da0s1d 2026030 200842 1663106 11% /var
/dev/da0s1e 1012974 542144 389794 58% /var/tmp
jam:/home 198351840 14811112 173302368 8% /usr/home
jam:/mnt/scr1 961432072 741401768 171192304 81% /mnt/scr1
/dev/md0 126702 42 116524 0% /tmp
TEST_TYPES=standard
Sun Mar 18 00:11:13 CDT 2012
*** starting standard tests in freedom ***
Uname -a: FreeBSD freedom.hdfgroup.uiuc.edu 8.2-STABLE FreeBSD 8.2-STABLE #0: Tue May 3 22:26:37 CDT 2011 sukoziol at freedom.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/FREEDOM amd64
/mnt/scr1/SnapTest/snapshots-opa/log/freedom_0318Sun_0011
*** finished standard tests for freedom ***
Sun Mar 18 00:12:32 CDT 2012
Total time = 1m 19s
*** finished tests in freedom ***
More information about the opa-nightly-tests
