[opa-nightly-tests] jam OPA_Daily_Tests_1213Thu_FAILED!!!
HDF Tester
hdftest at hdfgroup.org
Thu Dec 13 22:42:03 CST 2012
*** OPA Tests on 1213Thu ***
Tests Summary
****FAILED ostrich: standard****
PASSED jam: standard
PASSED koala: standard
PASSED linew: standard
Tests Time Summary
koala: Ran 1(1/0/0) tests, Grand total test time = 0m 32s
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 0s
ostrich: Ran 1(0/1/0) tests, Grand total test time = 1m 30s
linew: Ran 1(1/0/0) tests, Grand total test time = 2m 47s
jam: Ran 4(0/0/0) hosts, Grand total test time = 3m 44s
Timekeeper log
Timekeeper started at Thu Dec 13 22:38:30 CST 2012
Timekeeper sleeping for 720 seconds
Tests Failures
Dumping logfile of ostrich: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_1213Thu_2238
Testing integer compare-and-swap fairness with 100 threads PASSED
Testing pointer compare-and-swap fairness with 100 threads PASSED
Testing integer swap with 100 threads PASSED
Testing pointer swap with 100 threads PASSED
Testing integer LL/SC stack with 100 threads PASSED
Testing pointer LL/SC stack with 100 threads PASSED
***** 1 PRIMITIVES TEST FAILED! *****
FAIL: test_primitives
Testing memory barrier sanity PASSED
Testing memory barriers with linear array with 2 threads PASSED
Testing memory barriers with local variables with 2 threads PASSED
Testing memory barriers with scattered array with 2 threads PASSED
Testing memory barriers with linear array with 4 threads PASSED
Testing memory barriers with local variables with 4 threads PASSED
Testing memory barriers with scattered array with 4 threads PASSED
Testing memory barriers with linear array with 10 threads PASSED
Testing memory barriers with local variables with 10 threads PASSED
Testing memory barriers with scattered array with 10 threads PASSED
Testing memory barriers with linear array with 100 threads PASSED
Testing memory barriers with local variables with 100 threads PASSED
Testing memory barriers with scattered array with 100 threads PASSED
All barriers tests passed.
PASS: test_barriers
Testing queue sanity PASSED
Testing multithreaded queue with 2 threads PASSED
Testing multithreaded queue (empty queue) with 2 threads PASSED
Testing multithreaded queue (full queue) with 2 threads PASSED
Testing multithreaded queue with 4 threads PASSED
Testing multithreaded queue (empty queue) with 4 threads PASSED
Testing multithreaded queue (full queue) with 4 threads PASSED
Testing multithreaded queue with 10 threads PASSED
Testing multithreaded queue (empty queue) with 10 threads PASSED
Testing multithreaded queue (full queue) with 10 threads PASSED
Testing multithreaded queue with 100 threads PASSED
Testing multithreaded queue (empty queue) with 100 threads PASSED
Testing multithreaded queue (full queue) with 100 threads PASSED
All queue tests passed.
PASS: test_queue
1 of 4 tests failed
Please report to https://trac.mcs.anl.gov/projects/openpa/newticket
gmake[2]: *** [check-TESTS] Error 1
gmake[2]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/ostrich/test'
gmake[1]: *** [check-am] Error 2
gmake[1]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/ostrich/test'
gmake: *** [check-recursive] Error 1
Failed running make check
===== Exit bin/snapshot with status=2: Thu Dec 13 22:40:23 CST 2012 =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
22:38:09 up 8 days, 13:31, 55 users, load average: 0.02, 0.08, 0.07
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 3797792 26302400 13% /
/dev/sda1 101086 23185 72682 25% /boot
/dev/sda2 31738420 500380 29599812 2% /tmp
/dev/sda6 31738392 11857084 18243084 40% /var
/dev/sda7 31738392 14885664 15214504 50% /usr
/dev/sda8 124991068 1195192 117344176 2% /var/tmp
/dev/mapper/VolGroup00-home
198351840 17701088 170412392 10% /home
/dev/sde1 565688764 408207396 128282432 77% /scr
/dev/sdc1 961432072 827990064 84604008 91% /mnt/scr1
/dev/sdd1 961432072 762738900 149855172 84% /mnt/hdf
tmpfs 8313628 16 8313612 1% /dev/shm
gumund:/data/ftp 480719104 363442944 92856960 80% /mnt/ftp
gumund:/data/web 480719104 363442944 92856960 80% /mnt/web
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_1213Thu
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1213Thu.16596: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1213Thu.16596': No such file or directory
*** launching tests from jam ***
TESTHOST is linew
jam
koala
ostrich
Fork off timekeeper 12
Testing linew
ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname linew
10:38pm up 8 day(s), 6:10, 1 user, load average: 0.78, 1.43, 1.61
/ (/dev/dsk/c1t0d0s0 ):40911208 blocks 8210823 files
/devices (/devices ): 0 blocks 0 files
/system/contract (ctfs ): 0 blocks 2147483603 files
/proc (proc ): 0 blocks 29939 files
/etc/mnttab (mnttab ): 0 blocks 0 files
/etc/svc/volatile (swap ):20857168 blocks 1180577 files
/system/object (objfs ): 0 blocks 2147483491 files
/etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
/platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):40911208 blocks 8210823 files
/platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):40911208 blocks 8210823 files
/dev/fd (fd ): 0 blocks 0 files
/tmp (swap ):20857168 blocks 1180577 files
/var/run (swap ):20857168 blocks 1180577 files
/scr (/dev/dsk/c1t1d0s0 ):847961404 blocks 226655720 files
/home (jam:/home ):361301504 blocks 50833521 files
/mnt/hdf (jam:/mnt/hdf ):397386344 blocks 114353116 files
/mnt/scr1 (jam:/mnt/scr1 ):266883960 blocks 118362659 files
/mnt/web (gumund:/mnt/web ):234552296 blocks 60869941 files
/mnt/ftp (gumund:/mnt/ftp ):234552296 blocks 60869941 files
TEST_TYPES=standard
Thu Dec 13 22:38:46 CST 2012
*** starting standard tests in linew ***
Uname -a: SunOS linew.hdfgroup.uiuc.edu 5.10 Generic_147440-27 sun4u sparc SUNW,A70
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/linew_1213Thu_2238
*** finished standard tests for linew ***
Thu Dec 13 22:41:33 CST 2012
Total time = 2m 47s
*** finished tests in linew ***
Testing jam
ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
22:38:38 up 8 days, 13:32, 55 users, load average: 0.16, 0.10, 0.08
/dev/sda2 31738420 500480 29599712 2% /tmp
/dev/sda6 31738392 11857344 18242824 40% /var
/dev/sdc1 961432072 827990100 84603972 91% /mnt/scr1
TEST_TYPES=standard
Thu Dec 13 22:38:48 CST 2012
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/jam_1213Thu_2238
*** finished standard tests for jam ***
Thu Dec 13 22:39:48 CST 2012
Total time = 1m 0s
*** finished tests in jam ***
Testing koala
ssh koala -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
22:38:40 up 8 days, 13:46, 0 users, load average: 0.02, 0.02, 0.00
/dev/sda7 22292052 1684652 19456748 8% /
/dev/sda5 12192608 620904 10942360 6% /tmp
/dev/sda3 12192636 5479024 6084268 48% /var
/dev/sda1 101086 24789 71078 26% /boot
/dev/sdb1 41279536 24795692 14386964 64% /usr
/dev/sdc1 76581768 52224832 20466772 72% /scr
tmpfs 6149560 0 6149560 0% /dev/shm
jam:/home 198351872 17700864 170413056 10% /home
jam:/mnt/hdf 961432576 762738688 149855232 84% /mnt/hdf
jam:/mnt/scr1 961432576 827990016 84604928 91% /mnt/scr1
TEST_TYPES=standard
Thu Dec 13 22:38:50 CST 2012
*** starting standard tests in koala ***
Uname -a: Linux koala 2.6.18-308.20.1.el5 #1 SMP Tue Nov 13 10:15:12 EST 2012 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/koala_1213Thu_2238
*** finished standard tests for koala ***
Thu Dec 13 22:39:22 CST 2012
Total time = 0m 32s
*** finished tests in koala ***
Testing ostrich
ssh ostrich -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
22:38:43 up 8 days, 12:39, 0 users, load average: 0.13, 0.05, 0.01
/dev/mapper/vg_ostrich-lv_root
140610456 11180160 122291252 9% /
tmpfs 7821696 0 7821696 0% /dev/shm
/dev/sda2 495844 132234 338010 29% /boot
/dev/sdb2 124608436 12265656 106013028 11% /scr
TEST_TYPES=standard
Thu Dec 13 22:38:53 CST 2012
*** starting standard tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-279.14.1.el6.ppc64 #1 SMP Mon Oct 15 13:45:24 EDT 2012 ppc64 ppc64 ppc64 GNU/Linux
*** finished standard tests for ostrich ***
Total time = 1m 30s
*** finished tests in ostrich ***
****SYSTEM ERROR ostrich: Abnormal exit from runtest ****
****SYSTEM ERROR ostrich: runtest command failed ****
More information about the opa-nightly-tests
