[opa-nightly-tests] jam OPA_Daily_Tests_1209Sun_FAILED!!!
HDF Tester
hdftest at hdfgroup.org
Sun Dec 9 21:54:43 CST 2012
*** OPA Tests on 1209Sun ***
Tests Summary
****FAILED ostrich: standard****
PASSED jam: standard
PASSED koala: standard
PASSED linew: standard
Tests Time Summary
koala: Ran 1(1/0/0) tests, Grand total test time = 0m 31s
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 0s
ostrich: Ran 1(0/1/0) tests, Grand total test time = 1m 31s
linew: Ran 1(1/0/0) tests, Grand total test time = 2m 46s
jam: Ran 4(0/0/0) hosts, Grand total test time = 3m 42s
Timekeeper log
Timekeeper started at Sun Dec 9 21:51:11 CST 2012
Timekeeper sleeping for 720 seconds
Tests Failures
Dumping logfile of ostrich: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_1209Sun_2151
Testing integer compare-and-swap fairness with 100 threads PASSED
Testing pointer compare-and-swap fairness with 100 threads PASSED
Testing integer swap with 100 threads PASSED
Testing pointer swap with 100 threads PASSED
Testing integer LL/SC stack with 100 threads PASSED
Testing pointer LL/SC stack with 100 threads PASSED
***** 1 PRIMITIVES TEST FAILED! *****
FAIL: test_primitives
Testing memory barrier sanity PASSED
Testing memory barriers with linear array with 2 threads PASSED
Testing memory barriers with local variables with 2 threads PASSED
Testing memory barriers with scattered array with 2 threads PASSED
Testing memory barriers with linear array with 4 threads PASSED
Testing memory barriers with local variables with 4 threads PASSED
Testing memory barriers with scattered array with 4 threads PASSED
Testing memory barriers with linear array with 10 threads PASSED
Testing memory barriers with local variables with 10 threads PASSED
Testing memory barriers with scattered array with 10 threads PASSED
Testing memory barriers with linear array with 100 threads PASSED
Testing memory barriers with local variables with 100 threads PASSED
Testing memory barriers with scattered array with 100 threads PASSED
All barriers tests passed.
PASS: test_barriers
Testing queue sanity PASSED
Testing multithreaded queue with 2 threads PASSED
Testing multithreaded queue (empty queue) with 2 threads PASSED
Testing multithreaded queue (full queue) with 2 threads PASSED
Testing multithreaded queue with 4 threads PASSED
Testing multithreaded queue (empty queue) with 4 threads PASSED
Testing multithreaded queue (full queue) with 4 threads PASSED
Testing multithreaded queue with 10 threads PASSED
Testing multithreaded queue (empty queue) with 10 threads PASSED
Testing multithreaded queue (full queue) with 10 threads PASSED
Testing multithreaded queue with 100 threads PASSED
Testing multithreaded queue (empty queue) with 100 threads PASSED
Testing multithreaded queue (full queue) with 100 threads PASSED
All queue tests passed.
PASS: test_queue
1 of 4 tests failed
Please report to https://trac.mcs.anl.gov/projects/openpa/newticket
gmake[2]: *** [check-TESTS] Error 1
gmake[2]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/ostrich/test'
gmake[1]: *** [check-am] Error 2
gmake[1]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/ostrich/test'
gmake: *** [check-recursive] Error 1
Failed running make check
===== Exit bin/snapshot with status=2: Sun Dec 9 21:53:05 CST 2012 =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
21:50:51 up 4 days, 12:44, 36 users, load average: 0.25, 0.56, 0.76
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 3798224 26301968 13% /
/dev/sda1 101086 23185 72682 25% /boot
/dev/sda2 31738420 432568 29667624 2% /tmp
/dev/sda6 31738392 8538220 21561948 29% /var
/dev/sda7 31738392 14867544 15232624 50% /usr
/dev/sda8 124991068 1133296 117406072 1% /var/tmp
/dev/mapper/VolGroup00-home
198351840 17666692 170446788 10% /home
/dev/sde1 565688764 408238428 128251400 77% /scr
/dev/sdc1 961432072 818515476 94078596 90% /mnt/scr1
/dev/sdd1 961432072 759944308 152649764 84% /mnt/hdf
tmpfs 8313628 16 8313612 1% /dev/shm
gumund:/data/ftp 480719104 363560832 92739072 80% /mnt/ftp
gumund:/data/web 480719104 363560832 92739072 80% /mnt/web
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_1209Sun
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1209Sun.25208: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1209Sun.25208': No such file or directory
*** launching tests from jam ***
TESTHOST is linew
jam
koala
ostrich
Fork off timekeeper 12
Testing linew
ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname linew
9:51pm up 4 day(s), 5:22, 0 users, load average: 0.06, 0.66, 0.98
/ (/dev/dsk/c1t0d0s0 ):40910480 blocks 8210845 files
/devices (/devices ): 0 blocks 0 files
/system/contract (ctfs ): 0 blocks 2147483604 files
/proc (proc ): 0 blocks 29935 files
/etc/mnttab (mnttab ): 0 blocks 0 files
/etc/svc/volatile (swap ):20940336 blocks 1180596 files
/system/object (objfs ): 0 blocks 2147483491 files
/etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
/platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):40910480 blocks 8210845 files
/platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):40910480 blocks 8210845 files
/dev/fd (fd ): 0 blocks 0 files
/tmp (swap ):20940336 blocks 1180596 files
/var/run (swap ):20940336 blocks 1180596 files
/scr (/dev/dsk/c1t1d0s0 ):851558496 blocks 226655709 files
/home (jam:/home ):361370296 blocks 50834195 files
/mnt/hdf (jam:/mnt/hdf ):402975528 blocks 114380606 files
/mnt/scr1 (jam:/mnt/scr1 ):285833136 blocks 118422508 files
/mnt/web (gumund:/mnt/web ):234316328 blocks 60869923 files
/mnt/ftp (gumund:/mnt/ftp ):234316328 blocks 60869923 files
TEST_TYPES=standard
Sun Dec 9 21:51:27 CST 2012
*** starting standard tests in linew ***
Uname -a: SunOS linew.hdfgroup.uiuc.edu 5.10 Generic_147440-27 sun4u sparc SUNW,A70
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/linew_1209Sun_2151
*** finished standard tests for linew ***
Sun Dec 9 21:54:13 CST 2012
Total time = 2m 46s
*** finished tests in linew ***
Testing jam
ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
21:51:19 up 4 days, 12:45, 36 users, load average: 0.30, 0.54, 0.74
/dev/sda2 31738420 432668 29667524 2% /tmp
/dev/sda6 31738392 8538588 21561580 29% /var
/dev/sdc1 961432072 818515512 94078560 90% /mnt/scr1
TEST_TYPES=standard
Sun Dec 9 21:51:29 CST 2012
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/jam_1209Sun_2151
*** finished standard tests for jam ***
Sun Dec 9 21:52:29 CST 2012
Total time = 1m 0s
*** finished tests in jam ***
Testing koala
ssh koala -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
21:51:21 up 4 days, 12:59, 0 users, load average: 0.06, 0.08, 0.04
/dev/sda7 22292052 1684988 19456412 8% /
/dev/sda5 12192608 602532 10960732 6% /tmp
/dev/sda3 12192636 5388236 6175056 47% /var
/dev/sda1 101086 24789 71078 26% /boot
/dev/sdb1 41279536 24781428 14401228 64% /usr
/dev/sdc1 76581768 52086936 20604668 72% /scr
tmpfs 6149560 0 6149560 0% /dev/shm
jam:/home 198351872 17666048 170446848 10% /home
jam:/mnt/hdf 961432576 759944192 152650752 84% /mnt/hdf
jam:/mnt/scr1 961432576 818515968 94078976 90% /mnt/scr1
TEST_TYPES=standard
Sun Dec 9 21:51:31 CST 2012
*** starting standard tests in koala ***
Uname -a: Linux koala 2.6.18-308.20.1.el5 #1 SMP Tue Nov 13 10:15:12 EST 2012 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/koala_1209Sun_2151
*** finished standard tests for koala ***
Sun Dec 9 21:52:02 CST 2012
Total time = 0m 31s
*** finished tests in koala ***
Testing ostrich
ssh ostrich -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
21:51:24 up 4 days, 11:52, 1 user, load average: 0.00, 0.15, 0.18
/dev/mapper/vg_ostrich-lv_root
140610456 11089008 122382404 9% /
tmpfs 7821696 0 7821696 0% /dev/shm
/dev/sda2 495844 132234 338010 29% /boot
/dev/sdb2 124608436 11960604 106318080 11% /scr
TEST_TYPES=standard
Sun Dec 9 21:51:34 CST 2012
*** starting standard tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-279.14.1.el6.ppc64 #1 SMP Mon Oct 15 13:45:24 EDT 2012 ppc64 ppc64 ppc64 GNU/Linux
*** finished standard tests for ostrich ***
Total time = 1m 31s
*** finished tests in ostrich ***
****SYSTEM ERROR ostrich: Abnormal exit from runtest ****
****SYSTEM ERROR ostrich: runtest command failed ****
More information about the opa-nightly-tests
