[opa-nightly-tests] jam OPA_Daily_Tests_0330Wed_FAILED!!!
HDF Tester
hdftest at hdfgroup.org
Wed Mar 30 00:19:16 CDT 2011
*** OPA Tests on 0330Wed ***
Tests Summary
****FAILED duty: standard****
PASSED amani: standard
PASSED heiwa: standard
PASSED jam: standard
PASSED linew: standard
Tests Time Summary
duty: Ran 1(0/1/0) tests, Grand total test time = 0m 29s
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 20s
amani: Ran 1(1/0/0) tests, Grand total test time = 1m 48s
heiwa: Ran 1(1/0/0) tests, Grand total test time = 5m 32s
linew: Ran 1(1/0/0) tests, Grand total test time = 7m 58s
jam: Ran 6(0/0/0) hosts, Grand total test time = 8m 56s
Timekeeper log
Timekeeper started at Wed Mar 30 00:10:30 CDT 2011
Timekeeper sleeping for 1800 seconds
Tests Failures
Dumping logfile of duty: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/duty_0330Wed_0010
/bin/sh ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c -o opa_primitives.lo /home/hdftest/snapshots-opa/current/src/opa_primitives.c
/bin/sh ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c -o opa_queue.lo /home/hdftest/snapshots-opa/current/src/opa_queue.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_primitives.c -o opa_primitives.o
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_queue.c -o opa_queue.o
In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.h:10,
from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/home/hdftest/snapshots-opa/current/src/opa_primitives.h:114:2: #error no primitives implementation specified
mv -f .deps/opa_primitives.Tpo .deps/opa_primitives.Plo
In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/home/hdftest/snapshots-opa/current/src/opa_queue.h:56: error: syntax error before "OPA_ptr_t"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_rel_to_abs':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: warning: initialization makes pointer from integer without a cast
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: `size_t' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: (Each undeclared identifier is reported only once
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: for each function it appears in.)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: syntax error before "offset"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_abs_to_rel':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: `size_t' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: syntax error before "a"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_swap_rel':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:82: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_cas_rel_null':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:92: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_is_empty':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:165: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:166: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:171: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_peek_head':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:196: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:197: error: `NULL' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_init':
/home/hdftest/snapshots-opa/current/src/opa_queue.c:31: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c:32: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c:33: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_header_init':
/home/hdftest/snapshots-opa/current/src/opa_queue.c:38: error: structure has no member named `offset'
gmake[2]: *** [opa_queue.lo] Error 1
gmake[2]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
gmake[1]: *** [all] Error 2
gmake[1]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
gmake: *** [all-recursive] Error 1
Failed running make
===== Exit bin/snapshot with status=0: Wed Mar 30 00:11:23 CDT 2011 =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
00:10:10 up 54 days, 14:42, 92 users, load average: 1.15, 1.03, 1.08
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 3988156 26112036 14% /
/dev/sda1 101086 22885 72982 24% /boot
/dev/sda2 31738420 213780 29886412 1% /tmp
/dev/sda6 31738392 5954056 24146112 20% /var
/dev/sda7 31738392 30261088 0 100% /usr
/dev/sda8 124991068 4263892 114275476 4% /var/tmp
/dev/mapper/VolGroup00-home
198351840 15140232 172973248 9% /home
/dev/sde1 565688764 380381448 156108380 71% /scr
/dev/sdc1 961432072 809119480 103474592 89% /mnt/scr1
/dev/sdd1 961432072 879481456 33112616 97% /mnt/hdf
tmpfs 8313848 16 8313832 1% /dev/shm
gumund:/data/ftp 480719072 285388128 170911744 63% /mnt/ftp
gumund:/data/web 480719072 285388128 170911744 63% /mnt/web
amani:/mnt/rw-src 288451232 179573408 94225344 66% /mnt/ro-src
amani:/mnt/rw-src 288451232 179573408 94225344 66% /mnt/rw-src
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0330Wed
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0330Wed.29253: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0330Wed.29253': No such file or directory
*** launching tests from jam ***
TESTHOST is linew
jam
amani
heiwa
duty
liberty
Fork off timekeeper 30
cannot remote command with liberty
Testing linew
ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname linew
12:10am up 18 day(s), 6:07, 2 users, load average: 1.20, 0.94, 0.49
/ (/dev/dsk/c1t0d0s0 ):71326714 blocks 8272033 files
/devices (/devices ): 0 blocks 0 files
/system/contract (ctfs ): 0 blocks 2147483608 files
/proc (proc ): 0 blocks 29932 files
/etc/mnttab (mnttab ): 0 blocks 0 files
/etc/svc/volatile (swap ):20727456 blocks 1182206 files
/system/object (objfs ): 0 blocks 2147483493 files
/etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
/platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):71326714 blocks 8272033 files
/platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):71326714 blocks 8272033 files
/dev/fd (fd ): 0 blocks 0 files
/tmp (swap ):20727456 blocks 1182206 files
/var/run (swap ):20727456 blocks 1182206 files
/scr (/dev/dsk/c1t1d0s0 ):895017598 blocks 226811472 files
/home (jam:/home ):366423216 blocks 50914290 files
/mnt/hdf (jam:/mnt/hdf ):163901232 blocks 114242499 files
/mnt/scr1 (jam:/mnt/scr1 ):304623720 blocks 116153991 files
/mnt/web (gumund:/mnt/web ):390661872 blocks 60893609 files
/mnt/ftp (gumund:/mnt/ftp ):390661872 blocks 60893609 files
TEST_TYPES=standard
Wed Mar 30 00:10:52 CDT 2011
*** starting standard tests in linew ***
Uname -a: SunOS linew 5.10 Generic_144488-07 sun4u sparc SUNW,A70
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/linew_0330Wed_0010
*** finished standard tests for linew ***
Wed Mar 30 00:18:43 CDT 2011
Total time = 7m 52s
*** finished tests in linew ***
Testing jam
ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
00:10:38 up 54 days, 14:42, 92 users, load average: 1.29, 1.08, 1.09
/dev/sda2 31738420 213904 29886288 1% /tmp
/dev/sda6 31738392 5954060 24146108 20% /var
/dev/sdc1 961432072 809120304 103473768 89% /mnt/scr1
TEST_TYPES=standard
Wed Mar 30 00:10:48 CDT 2011
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-194.3.1.el5PAE #1 SMP Thu May 13 13:48:44 EDT 2010 i686 i686 i386 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/jam_0330Wed_0010
*** finished standard tests for jam ***
Wed Mar 30 00:12:08 CDT 2011
Total time = 1m 20s
*** finished tests in jam ***
Testing amani
ssh amani -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname amani
00:10:40 up 43 days, 10:40, 3 users, load average: 0.08, 0.02, 0.23
/dev/hda6 39021196 29761916 7245136 81% /
/dev/hda3 12192636 4125164 7438128 36% /var
/dev/hda2 12192636 162552 11400740 2% /tmp
/dev/hda1 101086 23784 72083 25% /boot
tmpfs 2057868 0 2057868 0% /dev/shm
jam:/home 198351840 15140224 172973248 9% /home
jam:/mnt/hdf 961432096 879481472 33112640 97% /mnt/hdf
jam:/mnt/scr1 961432096 809120352 103473728 89% /mnt/scr1
smirom:/scr 267601440 37497024 216291712 15% /mnt/tmp
/dev/sdb1 144221592 75539208 61356344 56% /scr
/dev/sda1 288451232 179573436 94225316 66% /mnt/rw-src
TEST_TYPES=standard
Wed Mar 30 00:10:50 CDT 2011
*** starting standard tests in amani ***
Uname -a: Linux amani 2.6.18-194.32.1.el5 #1 SMP Wed Jan 5 17:52:25 EST 2011 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/amani_0330Wed_0010
*** finished standard tests for amani ***
Wed Mar 30 00:12:38 CDT 2011
Total time = 1m 48s
*** finished tests in amani ***
Testing heiwa
ssh heiwa -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname heiwa
00:10:37 up 25 days, 11:41, 4 users, load average: 0.24, 0.23, 0.09
/dev/sdb8 35435232 2727748 30907444 9% /
tmpfs 2008144 0 2008144 0% /dev/shm
/dev/sdb4 198337 106660 81437 57% /boot
/dev/sdb6 12385456 1372992 10383320 12% /tmp
/dev/sdb7 12385456 3379556 8376756 29% /var
/dev/sda6 82573108 686812 77691728 1% /scr
jam:/mnt/scr1 961432096 809120512 103473600 89% /mnt/scr1
TEST_TYPES=standard
*** starting standard tests in heiwa ***
Uname -a: Linux heiwa 2.6.32.16-150.fc12.ppc64 #1 SMP Sat Jul 24 05:19:27 UTC 2010 ppc64 ppc64 ppc64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/heiwa_0330Wed_0010
*** finished standard tests for heiwa ***
Wed Mar 30 00:16:19 CDT 2011
Total time = 5m 31s
*** finished tests in heiwa ***
Testing duty
ssh duty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname duty
12:10AM up 90 days, 8:25, 0 users, load averages: 0.00, 0.00, 0.00
Filesystem 1K-blocks Used Avail Capacity Mounted on
/dev/aacd0s1a 507630 60986 406034 13% /
devfs 1 1 0 100% /dev
/dev/aacd0s1h 188433016 123604522 49753854 71% /data
/dev/aacd0s1g 32494668 24588244 5306852 82% /local_home
/dev/aacd0s1f 12186190 4125638 7085658 37% /usr
/dev/aacd0s1d 507630 50378 416642 11% /var
/dev/aacd0s1e 253678 178 233206 0% /var/tmp
procfs 4 4 0 100% /proc
jam:/home 198351840 15140232 172973248 8% /home
jam:/mnt/hdf 961432072 879481456 33112616 96% /mnt/hdf
jam:/mnt/scr1 961432072 809120532 103473540 89% /mnt/scr1
gumund:/data/web 480719056 285388120 170911736 63% /mnt/web
gumund:/data/ftp 480719056 285388120 170911736 63% /mnt/ftp
devfs 1 1 0 100% /var/named/dev
/dev/md0 126702 94 116472 0% /tmp
TEST_TYPES=standard
Wed Mar 30 00:10:54 CDT 2011
*** starting standard tests in duty ***
Uname -a: FreeBSD duty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:10:59 CDT 2008 sukoziol at duty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/DUTY i386
*** finished standard tests for duty ***
Total time = 0m 29s
*** finished tests in duty ***
****SYSTEM ERROR duty: Abnormal exit from runtest ****
****SYSTEM ERROR duty: runtest command failed ****
Testing liberty
liberty does not accept Remote Command (Wed Mar 30 00:11:18 CDT 2011)
****SYSTEM ERROR: liberty does not accept Remote Command (Wed Mar 30 00:11:18 CDT 2011)
****INCOMPLETE liberty: snaptest did not complete****
More information about the opa-nightly-tests
