[opa-nightly-tests] jam OPA_Daily_Tests_0328Mon_FAILED!!!
HDF Tester hdftest at hdfgroup.org
Mon Mar 28 00:20:17 CDT 2011
*** OPA Tests on 0328Mon ***
   Tests Summary
****FAILED duty: standard****
PASSED amani: standard
PASSED heiwa: standard
PASSED jam: standard
PASSED linew: standard
   Tests Time Summary
duty: Ran 1(0/1/0) tests, Grand total test time =  0m 27s
jam: Ran 1(1/0/0) tests, Grand total test time =  1m 21s
amani: Ran 1(1/0/0) tests, Grand total test time =  1m 49s
heiwa: Ran 1(1/0/0) tests, Grand total test time =  5m 31s
linew: Ran 1(1/0/0) tests, Grand total test time =  8m 58s
jam: Ran 6(0/0/0) hosts, Grand total test time =  9m 58s
   Timekeeper log
Timekeeper started at Mon Mar 28 00:10:31 CDT 2011
Timekeeper sleeping for 1800 seconds
   Tests Failures
Dumping logfile of duty: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/duty_0328Mon_0010
/bin/sh ../libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src      -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c -o opa_primitives.lo /home/hdftest/snapshots-opa/current/src/opa_primitives.c
/bin/sh ../libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src      -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c -o opa_queue.lo /home/hdftest/snapshots-opa/current/src/opa_queue.c
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_queue.c -o opa_queue.o
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_primitives.c -o opa_primitives.o
In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.h:10,
                 from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/home/hdftest/snapshots-opa/current/src/opa_primitives.h:114:2: #error no primitives implementation specified
In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/home/hdftest/snapshots-opa/current/src/opa_queue.h:56: error: syntax error before "OPA_ptr_t"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_rel_to_abs':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: warning: initialization makes pointer from integer without a cast
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: `size_t' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: (Each undeclared identifier is reported only once
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: for each function it appears in.)
mv -f .deps/opa_primitives.Tpo .deps/opa_primitives.Plo
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: syntax error before "offset"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_abs_to_rel':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: `size_t' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: syntax error before "a"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_swap_rel':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:82: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_cas_rel_null':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:92: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_is_empty':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:165: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:166: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:171: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_peek_head':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:196: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:197: error: `NULL' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_init':
/home/hdftest/snapshots-opa/current/src/opa_queue.c:31: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c:32: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c:33: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_header_init':
/home/hdftest/snapshots-opa/current/src/opa_queue.c:38: error: structure has no member named `offset'
gmake[2]: *** [opa_queue.lo] Error 1
gmake[2]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
gmake[1]: *** [all] Error 2
gmake[1]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
gmake: *** [all-recursive] Error 1
Failed running make
===== Exit bin/snapshot with status=0: Mon Mar 28 00:11:22 CDT 2011 =====
Dumping done
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 00:10:09 up 52 days, 14:42, 65 users,  load average: 1.97, 2.40, 3.38
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda3             31738420   3981420  26118772  14% /
/dev/sda1               101086     22885     72982  24% /boot
/dev/sda2             31738420    187276  29912916   1% /tmp
/dev/sda6             31738392   5901600  24198568  20% /var
/dev/sda7             31738392  30256060         0 100% /usr
/dev/sda8            124991068   4263648 114275720   4% /var/tmp
/dev/mapper/VolGroup00-home
                     198351840  15434924 172678556   9% /home
/dev/sde1            565688764 380218824 156271004  71% /scr
/dev/sdc1            961432072 807274888 105319184  89% /mnt/scr1
/dev/sdd1            961432072 872586328  40007744  96% /mnt/hdf
tmpfs                  8313848        16   8313832   1% /dev/shm
gumund:/data/ftp     480719072 284657952 171641920  63% /mnt/ftp
gumund:/data/web     480719072 284657952 171641920  63% /mnt/web
amani:/mnt/rw-src    288451232 179573408  94225344  66% /mnt/ro-src
amani:/mnt/rw-src    288451232 179573408  94225344  66% /mnt/rw-src
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0328Mon
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0328Mon.18582: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0328Mon.18582': No such file or directory
*** launching tests from jam ***
TESTHOST is linew
jam
amani
heiwa
duty
liberty
    Fork off timekeeper 30
cannot remote command with liberty
Testing linew
ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname linew
 12:10am  up 16 day(s),  6:07,  3 users,  load average: 2.55, 2.55, 2.14
/                  (/dev/dsk/c1t0d0s0 ):71326666 blocks  8272033 files
/devices           (/devices          ):       0 blocks        0 files
/system/contract   (ctfs              ):       0 blocks 2147483606 files
/proc              (proc              ):       0 blocks    29916 files
/etc/mnttab        (mnttab            ):       0 blocks        0 files
/etc/svc/volatile  (swap              ):20321392 blocks  1182203 files
/system/object     (objfs             ):       0 blocks 2147483493 files
/etc/dfs/sharetab  (sharefs           ):       0 blocks 2147483646 files
/platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):71326666 blocks  8272033 files
/platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):71326666 blocks  8272033 files
/dev/fd            (fd                ):       0 blocks        0 files
/tmp               (swap              ):20321392 blocks  1182203 files
/var/run           (swap              ):20321392 blocks  1182203 files
/scr               (/dev/dsk/c1t1d0s0 ):896862034 blocks 226812031 files
/home              (jam:/home         ):365833832 blocks 50914024 files
/mnt/hdf           (jam:/mnt/hdf      ):177691488 blocks 114296963 files
/mnt/scr1          (jam:/mnt/scr1     ):308314320 blocks 116183686 files
/mnt/web           (gumund:/mnt/web   ):392122208 blocks 60893606 files
/mnt/ftp           (gumund:/mnt/ftp   ):392122208 blocks 60893606 files
TEST_TYPES=standard
Mon Mar 28 00:10:58 CDT 2011
*** starting standard tests in linew ***
Uname -a: SunOS linew 5.10 Generic_144488-07 sun4u sparc SUNW,A70
Running snapshot with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/linew_0328Mon_0010
*** finished standard tests for linew ***
Mon Mar 28 00:19:44 CDT 2011
Total time = 8m 46s
*** finished tests in linew ***
Mon Mar 28 00:19:45 CDT 2011
Testing jam
ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
 00:10:38 up 52 days, 14:42, 65 users,  load average: 2.26, 2.43, 3.37
/dev/sda2             31738420    187392  29912800   1% /tmp
/dev/sda6             31738392   5901604  24198564  20% /var
/dev/sdc1            961432072 807274920 105319152  89% /mnt/scr1
TEST_TYPES=standard
Mon Mar 28 00:10:48 CDT 2011
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-194.3.1.el5PAE #1 SMP Thu May 13 13:48:44 EDT 2010 i686 i686 i386 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/jam_0328Mon_0010
*** finished standard tests for jam ***
Mon Mar 28 00:12:09 CDT 2011
Total time = 1m 21s
*** finished tests in jam ***
Testing amani
ssh amani -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname amani
 00:10:41 up 41 days, 10:40,  2 users,  load average: 0.01, 0.40, 1.17
/dev/hda6             39021196  29749864   7257188  81% /
/dev/hda3             12192636   4103424   7459868  36% /var
/dev/hda2             12192636    164224  11399068   2% /tmp
/dev/hda1               101086     23784     72083  25% /boot
tmpfs                  2057868         0   2057868   0% /dev/shm
jam:/home            198351840  15434912 172678560   9% /home
jam:/mnt/hdf         961432096 872586336  40007744  96% /mnt/hdf
jam:/mnt/scr1        961432096 807274944 105319168  89% /mnt/scr1
smirom:/scr          267601440  37497024 216291712  15% /mnt/tmp
/dev/sdb1            144221592 110963332  25932220  82% /scr
/dev/sda1            288451232 179573436  94225316  66% /mnt/rw-src
TEST_TYPES=standard
Mon Mar 28 00:10:51 CDT 2011
*** starting standard tests in amani ***
Uname -a: Linux amani 2.6.18-194.32.1.el5 #1 SMP Wed Jan 5 17:52:25 EST 2011 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/amani_0328Mon_0010
*** finished standard tests for amani ***
Mon Mar 28 00:12:40 CDT 2011
Total time = 1m 49s
*** finished tests in amani ***
Testing heiwa
ssh heiwa -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname heiwa
 00:10:38 up 23 days, 11:41,  4 users,  load average: 0.00, 0.00, 0.00
/dev/sdb8             35435232   2727624  30907568   9% /
tmpfs                  2008144         0   2008144   0% /dev/shm
/dev/sdb4               198337    106660     81437  57% /boot
/dev/sdb6             12385456   1372996  10383316  12% /tmp
/dev/sdb7             12385456   3374928   8381384  29% /var
/dev/sda6             82573108    686812  77691728   1% /scr
jam:/mnt/scr1        961432096 807274944 105319136  89% /mnt/scr1
TEST_TYPES=standard
*** starting standard tests in heiwa ***
Uname -a: Linux heiwa 2.6.32.16-150.fc12.ppc64 #1 SMP Sat Jul 24 05:19:27 UTC 2010 ppc64 ppc64 ppc64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/heiwa_0328Mon_0010
*** finished standard tests for heiwa ***
Mon Mar 28 00:16:19 CDT 2011
Total time = 5m 31s
*** finished tests in heiwa ***
Testing duty
ssh duty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname duty
12:10AM  up 88 days,  8:25, 1 user, load averages: 0.00, 0.02, 0.05
Filesystem       1K-blocks      Used     Avail Capacity  Mounted on
/dev/aacd0s1a       507630     60986    406034    13%    /
devfs                    1         1         0   100%    /dev
/dev/aacd0s1h    188433016 123604522  49753854    71%    /data
/dev/aacd0s1g     32494668  24936782   4958314    83%    /local_home
/dev/aacd0s1f     12186190   4125638   7085658    37%    /usr
/dev/aacd0s1d       507630     50360    416660    11%    /var
/dev/aacd0s1e       253678       946    232438     0%    /var/tmp
procfs                   4         4         0   100%    /proc
jam:/home        198351840  15434924 172678556     8%    /home
jam:/mnt/hdf     961432072 872586328  40007744    96%    /mnt/hdf
jam:/mnt/scr1    961432072 807274944 105319128    88%    /mnt/scr1
gumund:/data/web 480719056 284657952 171641904    62%    /mnt/web
gumund:/data/ftp 480719056 284657952 171641904    62%    /mnt/ftp
devfs                    1         1         0   100%    /var/named/dev
/dev/md0            126702        98    116468     0%    /tmp
TEST_TYPES=standard
Mon Mar 28 00:10:55 CDT 2011
*** starting standard tests in duty ***
Uname -a: FreeBSD duty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:10:59 CDT 2008     sukoziol at duty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/DUTY  i386
*** finished standard tests for duty ***
Total time = 0m 27s
*** finished tests in duty ***
****SYSTEM ERROR duty: Abnormal exit from runtest ****
	****SYSTEM ERROR duty: runtest command failed ****
Testing liberty
liberty does not accept Remote Command (Mon Mar 28 00:11:19 CDT 2011)
	****SYSTEM ERROR: liberty does not accept Remote Command (Mon Mar 28 00:11:19 CDT 2011)
	****INCOMPLETE liberty: snaptest did not complete****
More information about the opa-nightly-tests mailing list
