[opa-nightly-tests] jam OPA_Daily_Tests_0326Sat_FAILED!!!
HDF Tester
hdftest at hdfgroup.org
Sat Mar 26 00:18:57 CDT 2011
*** OPA Tests on 0326Sat ***
Tests Summary
****FAILED duty: standard****
PASSED amani: standard
PASSED heiwa: standard
PASSED jam: standard
PASSED linew: standard
Tests Time Summary
duty: Ran 1(0/1/0) tests, Grand total test time = 0m 30s
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 22s
amani: Ran 1(1/0/0) tests, Grand total test time = 1m 50s
heiwa: Ran 1(1/0/0) tests, Grand total test time = 5m 35s
linew: Ran 1(1/0/0) tests, Grand total test time = 7m 41s
jam: Ran 6(0/0/0) hosts, Grand total test time = 8m 38s
Timekeeper log
Timekeeper started at Sat Mar 26 00:10:30 CDT 2011
Timekeeper sleeping for 1800 seconds
Tests Failures
Dumping logfile of duty: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/duty_0326Sat_0010
/bin/sh ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c -o opa_primitives.lo /home/hdftest/snapshots-opa/current/src/opa_primitives.c
/bin/sh ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c -o opa_queue.lo /home/hdftest/snapshots-opa/current/src/opa_queue.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_primitives.c -o opa_primitives.o
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_queue.c -o opa_queue.o
In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.h:10,
from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/home/hdftest/snapshots-opa/current/src/opa_primitives.h:114:2: #error no primitives implementation specified
mv -f .deps/opa_primitives.Tpo .deps/opa_primitives.Plo
In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/home/hdftest/snapshots-opa/current/src/opa_queue.h:56: error: syntax error before "OPA_ptr_t"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_rel_to_abs':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: warning: initialization makes pointer from integer without a cast
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: `size_t' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: (Each undeclared identifier is reported only once
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: for each function it appears in.)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: syntax error before "offset"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_abs_to_rel':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: `size_t' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: syntax error before "a"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_swap_rel':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:82: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_cas_rel_null':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:92: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_is_empty':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:165: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:166: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:171: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_peek_head':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:196: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:197: error: `NULL' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_init':
/home/hdftest/snapshots-opa/current/src/opa_queue.c:31: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c:32: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c:33: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_header_init':
/home/hdftest/snapshots-opa/current/src/opa_queue.c:38: error: structure has no member named `offset'
gmake[2]: *** [opa_queue.lo] Error 1
gmake[2]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
gmake[1]: *** [all] Error 2
gmake[1]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
gmake: *** [all-recursive] Error 1
Failed running make
===== Exit bin/snapshot with status=0: Sat Mar 26 00:11:24 CDT 2011 =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
00:10:09 up 50 days, 14:42, 67 users, load average: 1.95, 1.97, 2.12
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 3986484 26113708 14% /
/dev/sda1 101086 22885 72982 24% /boot
/dev/sda2 31738420 189352 29910840 1% /tmp
/dev/sda6 31738392 5960636 24139532 20% /var
/dev/sda7 31738392 30251588 0 100% /usr
/dev/sda8 124991068 4421024 114118344 4% /var/tmp
/dev/mapper/VolGroup00-home
198351840 15407824 172705656 9% /home
/dev/sde1 565688764 379918436 156571392 71% /scr
/dev/sdc1 961432072 807149104 105444968 89% /mnt/scr1
/dev/sdd1 961432072 872620548 39973524 96% /mnt/hdf
tmpfs 8313848 16 8313832 1% /dev/shm
gumund:/data/ftp 480719072 284657792 171642080 63% /mnt/ftp
gumund:/data/web 480719072 284657792 171642080 63% /mnt/web
amani:/mnt/rw-src 288451232 179573408 94225344 66% /mnt/ro-src
amani:/mnt/rw-src 288451232 179573408 94225344 66% /mnt/rw-src
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0326Sat
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0326Sat.9647: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0326Sat.9647': No such file or directory
*** launching tests from jam ***
TESTHOST is linew
jam
amani
heiwa
duty
liberty
Fork off timekeeper 30
cannot remote command with liberty
Testing linew
ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname linew
12:10am up 14 day(s), 6:07, 2 users, load average: 1.20, 0.93, 0.48
/ (/dev/dsk/c1t0d0s0 ):71326606 blocks 8272033 files
/devices (/devices ): 0 blocks 0 files
/system/contract (ctfs ): 0 blocks 2147483608 files
/proc (proc ): 0 blocks 29932 files
/etc/mnttab (mnttab ): 0 blocks 0 files
/etc/svc/volatile (swap ):20745504 blocks 1182211 files
/system/object (objfs ): 0 blocks 2147483493 files
/etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
/platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):71326606 blocks 8272033 files
/platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):71326606 blocks 8272033 files
/dev/fd (fd ): 0 blocks 0 files
/tmp (swap ):20745504 blocks 1182211 files
/var/run (swap ):20745504 blocks 1182211 files
/scr (/dev/dsk/c1t1d0s0 ):894796506 blocks 226811359 files
/home (jam:/home ):365888032 blocks 50914519 files
/mnt/hdf (jam:/mnt/hdf ):177623048 blocks 114301323 files
/mnt/scr1 (jam:/mnt/scr1 ):308564312 blocks 116162837 files
/mnt/web (gumund:/mnt/web ):392122520 blocks 60893606 files
/mnt/ftp (gumund:/mnt/ftp ):392122520 blocks 60893606 files
TEST_TYPES=standard
Sat Mar 26 00:10:51 CDT 2011
*** starting standard tests in linew ***
Uname -a: SunOS linew 5.10 Generic_144488-07 sun4u sparc SUNW,A70
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/linew_0326Sat_0010
*** finished standard tests for linew ***
Sat Mar 26 00:18:24 CDT 2011
Total time = 7m 34s
*** finished tests in linew ***
Sat Mar 26 00:18:25 CDT 2011
Testing jam
ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
00:10:37 up 50 days, 14:42, 67 users, load average: 2.10, 2.00, 2.13
/dev/sda2 31738420 189476 29910716 1% /tmp
/dev/sda6 31738392 5960640 24139528 20% /var
/dev/sdc1 961432072 807149936 105444136 89% /mnt/scr1
TEST_TYPES=standard
Sat Mar 26 00:10:47 CDT 2011
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-194.3.1.el5PAE #1 SMP Thu May 13 13:48:44 EDT 2010 i686 i686 i386 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/jam_0326Sat_0010
*** finished standard tests for jam ***
Sat Mar 26 00:12:09 CDT 2011
Total time = 1m 22s
*** finished tests in jam ***
Testing amani
ssh amani -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname amani
00:10:39 up 39 days, 10:40, 2 users, load average: 0.00, 0.00, 0.23
/dev/hda6 39021196 29738976 7268076 81% /
/dev/hda3 12192636 4085376 7477916 36% /var
/dev/hda2 12192636 208592 11354700 2% /tmp
/dev/hda1 101086 23784 72083 25% /boot
tmpfs 2057868 0 2057868 0% /dev/shm
jam:/home 198351840 15407808 172705664 9% /home
jam:/mnt/hdf 961432096 872620544 39973536 96% /mnt/hdf
jam:/mnt/scr1 961432096 807150048 105444064 89% /mnt/scr1
smirom:/scr 267601440 37497024 216291712 15% /mnt/tmp
/dev/sdb1 144221592 111803364 25092188 82% /scr
/dev/sda1 288451232 179573436 94225316 66% /mnt/rw-src
TEST_TYPES=standard
Sat Mar 26 00:10:49 CDT 2011
*** starting standard tests in amani ***
Uname -a: Linux amani 2.6.18-194.32.1.el5 #1 SMP Wed Jan 5 17:52:25 EST 2011 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/amani_0326Sat_0010
*** finished standard tests for amani ***
Sat Mar 26 00:12:39 CDT 2011
Total time = 1m 50s
*** finished tests in amani ***
Testing heiwa
ssh heiwa -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname heiwa
00:10:37 up 21 days, 11:41, 4 users, load average: 0.03, 0.10, 0.09
/dev/sdb8 35435232 2727620 30907572 9% /
tmpfs 2008144 0 2008144 0% /dev/shm
/dev/sdb4 198337 106660 81437 57% /boot
/dev/sdb6 12385456 1372948 10383364 12% /tmp
/dev/sdb7 12385456 3376156 8380156 29% /var
/dev/sda6 82573108 686812 77691728 1% /scr
jam:/mnt/scr1 961432096 807150080 105444000 89% /mnt/scr1
TEST_TYPES=standard
Sat Mar 26 00:10:48 CDT 2011
*** starting standard tests in heiwa ***
Uname -a: Linux heiwa 2.6.32.16-150.fc12.ppc64 #1 SMP Sat Jul 24 05:19:27 UTC 2010 ppc64 ppc64 ppc64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/heiwa_0326Sat_0010
*** finished standard tests for heiwa ***
Sat Mar 26 00:16:22 CDT 2011
Total time = 5m 34s
*** finished tests in heiwa ***
Testing duty
ssh duty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname duty
12:10AM up 86 days, 8:25, 0 users, load averages: 0.07, 0.02, 0.00
Filesystem 1K-blocks Used Avail Capacity Mounted on
/dev/aacd0s1a 507630 60986 406034 13% /
devfs 1 1 0 100% /dev
/dev/aacd0s1h 188433016 123604522 49753854 71% /data
/dev/aacd0s1g 32494668 24936782 4958314 83% /local_home
/dev/aacd0s1f 12186190 4125638 7085658 37% /usr
/dev/aacd0s1d 507630 50386 416634 11% /var
/dev/aacd0s1e 253678 178 233206 0% /var/tmp
procfs 4 4 0 100% /proc
jam:/home 198351840 15407824 172705656 8% /home
jam:/mnt/hdf 961432072 872620548 39973524 96% /mnt/hdf
jam:/mnt/scr1 961432072 807150172 105443900 88% /mnt/scr1
gumund:/data/web 480719056 284657796 171642060 62% /mnt/web
gumund:/data/ftp 480719056 284657796 171642060 62% /mnt/ftp
devfs 1 1 0 100% /var/named/dev
/dev/md0 126702 96 116470 0% /tmp
TEST_TYPES=standard
Sat Mar 26 00:10:54 CDT 2011
*** starting standard tests in duty ***
Uname -a: FreeBSD duty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:10:59 CDT 2008 sukoziol at duty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/DUTY i386
*** finished standard tests for duty ***
Total time = 0m 30s
*** finished tests in duty ***
****SYSTEM ERROR duty: Abnormal exit from runtest ****
****SYSTEM ERROR duty: runtest command failed ****
Testing liberty
liberty does not accept Remote Command (Sat Mar 26 00:11:18 CDT 2011)
****SYSTEM ERROR: liberty does not accept Remote Command (Sat Mar 26 00:11:18 CDT 2011)
****INCOMPLETE liberty: snaptest did not complete****
More information about the opa-nightly-tests
