[opa-nightly-tests] jam OPA_Daily_Tests_0322Tue_FAILED!!!
HDF Tester
hdftest at hdfgroup.org
Tue Mar 22 00:18:39 CDT 2011
*** OPA Tests on 0322Tue ***
Tests Summary
****FAILED duty: standard****
PASSED amani: standard
PASSED heiwa: standard
PASSED jam: standard
PASSED linew: standard
Tests Time Summary
duty: Ran 1(0/1/0) tests, Grand total test time = 0m 26s
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 21s
amani: Ran 1(1/0/0) tests, Grand total test time = 1m 50s
heiwa: Ran 1(1/0/0) tests, Grand total test time = 5m 33s
linew: Ran 1(1/0/0) tests, Grand total test time = 7m 22s
jam: Ran 6(0/0/0) hosts, Grand total test time = 8m 19s
Timekeeper log
Timekeeper started at Tue Mar 22 00:10:31 CDT 2011
Timekeeper sleeping for 1800 seconds
Tests Failures
Dumping logfile of duty: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/duty_0322Tue_0010
/bin/sh ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c -o opa_primitives.lo /home/hdftest/snapshots-opa/current/src/opa_primitives.c
/bin/sh ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c -o opa_queue.lo /home/hdftest/snapshots-opa/current/src/opa_queue.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_queue.c -o opa_queue.o
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_primitives.c -o opa_primitives.o
In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.h:10,
from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/home/hdftest/snapshots-opa/current/src/opa_primitives.h:114:2: #error no primitives implementation specified
In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/home/hdftest/snapshots-opa/current/src/opa_queue.h:56: error: syntax error before "OPA_ptr_t"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_rel_to_abs':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: warning: initialization makes pointer from integer without a cast
mv -f .deps/opa_primitives.Tpo .deps/opa_primitives.Plo
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: `size_t' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: (Each undeclared identifier is reported only once
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: for each function it appears in.)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: syntax error before "offset"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_abs_to_rel':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: `size_t' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: syntax error before "a"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_swap_rel':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:82: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_cas_rel_null':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:92: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_is_empty':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:165: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:166: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:171: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_peek_head':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:196: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:197: error: `NULL' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_init':
/home/hdftest/snapshots-opa/current/src/opa_queue.c:31: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c:32: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c:33: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_header_init':
/home/hdftest/snapshots-opa/current/src/opa_queue.c:38: error: structure has no member named `offset'
gmake[2]: *** [opa_queue.lo] Error 1
gmake[2]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
gmake[1]: *** [all] Error 2
gmake[1]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
gmake: *** [all-recursive] Error 1
Failed running make
===== Exit bin/snapshot with status=0: Tue Mar 22 00:11:20 CDT 2011 =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
00:10:09 up 46 days, 14:42, 49 users, load average: 2.40, 2.29, 2.13
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 3986456 26113736 14% /
/dev/sda1 101086 22885 72982 24% /boot
/dev/sda2 31738420 199204 29900988 1% /tmp
/dev/sda6 31738392 5922612 24177556 20% /var
/dev/sda7 31738392 28941272 1158896 97% /usr
/dev/sda8 124991068 10480580 108058788 9% /var/tmp
/dev/mapper/VolGroup00-home
198351840 15395016 172718464 9% /home
/dev/sde1 565688764 378812732 157677096 71% /scr
/dev/sdc1 961432072 803689708 108904364 89% /mnt/scr1
/dev/sdd1 961432072 878489360 34104712 97% /mnt/hdf
tmpfs 8313848 16 8313832 1% /dev/shm
gumund:/data/ftp 480719072 279525280 176774592 62% /mnt/ftp
gumund:/data/web 480719072 279525280 176774592 62% /mnt/web
amani:/mnt/rw-src 288451232 179573408 94225344 66% /mnt/ro-src
amani:/mnt/rw-src 288451232 179573408 94225344 66% /mnt/rw-src
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0322Tue
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0322Tue.14238: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0322Tue.14238': No such file or directory
*** launching tests from jam ***
TESTHOST is linew
jam
amani
heiwa
duty
liberty
Fork off timekeeper 30
cannot remote command with liberty
Testing linew
ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname linew
12:10am up 10 day(s), 6:07, 2 users, load average: 1.20, 0.92, 0.46
/ (/dev/dsk/c1t0d0s0 ):71322872 blocks 8272033 files
/devices (/devices ): 0 blocks 0 files
/system/contract (ctfs ): 0 blocks 2147483608 files
/proc (proc ): 0 blocks 29933 files
/etc/mnttab (mnttab ): 0 blocks 0 files
/etc/svc/volatile (swap ):20880064 blocks 1182206 files
/system/object (objfs ): 0 blocks 2147483493 files
/etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
/platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):71322872 blocks 8272033 files
/platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):71322872 blocks 8272033 files
/dev/fd (fd ): 0 blocks 0 files
/tmp (swap ):20880064 blocks 1182206 files
/var/run (swap ):20880064 blocks 1182206 files
/scr (/dev/dsk/c1t1d0s0 ):896018148 blocks 226812458 files
/home (jam:/home ):365913648 blocks 50914424 files
/mnt/hdf (jam:/mnt/hdf ):165885424 blocks 114296842 files
/mnt/scr1 (jam:/mnt/scr1 ):315581008 blocks 116216509 files
/mnt/web (gumund:/mnt/web ):402387552 blocks 60893656 files
/mnt/ftp (gumund:/mnt/ftp ):402387552 blocks 60893656 files
TEST_TYPES=standard
Tue Mar 22 00:10:51 CDT 2011
*** starting standard tests in linew ***
Uname -a: SunOS linew 5.10 Generic_144488-07 sun4u sparc SUNW,A70
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/linew_0322Tue_0010
*** finished standard tests for linew ***
Tue Mar 22 00:18:06 CDT 2011
Total time = 7m 15s
*** finished tests in linew ***
Testing jam
ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
00:10:38 up 46 days, 14:42, 49 users, load average: 2.54, 2.33, 2.14
/dev/sda2 31738420 199324 29900868 1% /tmp
/dev/sda6 31738392 5922616 24177552 20% /var
/dev/sdc1 961432072 803641576 108952496 89% /mnt/scr1
TEST_TYPES=standard
Tue Mar 22 00:10:48 CDT 2011
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-194.3.1.el5PAE #1 SMP Thu May 13 13:48:44 EDT 2010 i686 i686 i386 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/jam_0322Tue_0010
*** finished standard tests for jam ***
Tue Mar 22 00:12:09 CDT 2011
Total time = 1m 21s
*** finished tests in jam ***
Testing amani
ssh amani -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname amani
00:10:40 up 35 days, 10:40, 3 users, load average: 0.00, 0.00, 0.22
/dev/hda6 39021196 29718444 7288608 81% /
/dev/hda3 12192636 4158720 7404572 36% /var
/dev/hda2 12192636 208600 11354692 2% /tmp
/dev/hda1 101086 23784 72083 25% /boot
tmpfs 2057868 0 2057868 0% /dev/shm
jam:/home 198351840 15395008 172718464 9% /home
jam:/mnt/hdf 961432096 878489376 34104736 97% /mnt/hdf
jam:/mnt/scr1 961432096 803641600 108952512 89% /mnt/scr1
smirom:/scr 267601440 37497024 216291712 15% /mnt/tmp
/dev/sdb1 144221592 98066532 38829020 72% /scr
/dev/sda1 288451232 179573436 94225316 66% /mnt/rw-src
TEST_TYPES=standard
Tue Mar 22 00:10:50 CDT 2011
*** starting standard tests in amani ***
Uname -a: Linux amani 2.6.18-194.32.1.el5 #1 SMP Wed Jan 5 17:52:25 EST 2011 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/amani_0322Tue_0010
*** finished standard tests for amani ***
Tue Mar 22 00:12:40 CDT 2011
Total time = 1m 50s
*** finished tests in amani ***
Testing heiwa
ssh heiwa -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname heiwa
00:10:39 up 17 days, 11:41, 4 users, load average: 0.08, 0.08, 0.08
/dev/sdb8 35435232 2727620 30907572 9% /
tmpfs 2008144 0 2008144 0% /dev/shm
/dev/sdb4 198337 106660 81437 57% /boot
/dev/sdb6 12385456 1372948 10383364 12% /tmp
/dev/sdb7 12385456 6949224 4807088 60% /var
/dev/sda6 82573108 686812 77691728 1% /scr
jam:/mnt/scr1 961432096 803641600 108952480 89% /mnt/scr1
TEST_TYPES=standard
Tue Mar 22 00:10:49 CDT 2011
*** starting standard tests in heiwa ***
Uname -a: Linux heiwa 2.6.32.16-150.fc12.ppc64 #1 SMP Sat Jul 24 05:19:27 UTC 2010 ppc64 ppc64 ppc64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/heiwa_0322Tue_0010
*** finished standard tests for heiwa ***
Tue Mar 22 00:16:22 CDT 2011
Total time = 5m 33s
*** finished tests in heiwa ***
Testing duty
ssh duty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname duty
12:10AM up 82 days, 8:25, 0 users, load averages: 0.00, 0.00, 0.00
Filesystem 1K-blocks Used Avail Capacity Mounted on
/dev/aacd0s1a 507630 60986 406034 13% /
devfs 1 1 0 100% /dev
/dev/aacd0s1h 188433016 123604522 49753854 71% /data
/dev/aacd0s1g 32494668 24936782 4958314 83% /local_home
/dev/aacd0s1f 12186190 4125638 7085658 37% /usr
/dev/aacd0s1d 507630 50370 416650 11% /var
/dev/aacd0s1e 253678 178 233206 0% /var/tmp
procfs 4 4 0 100% /proc
jam:/home 198351840 15395016 172718464 8% /home
jam:/mnt/hdf 961432072 878489360 34104712 96% /mnt/hdf
jam:/mnt/scr1 961432072 803641600 108952472 88% /mnt/scr1
gumund:/data/web 480719056 279525280 176774576 61% /mnt/web
gumund:/data/ftp 480719056 279525280 176774576 61% /mnt/ftp
devfs 1 1 0 100% /var/named/dev
/dev/md0 126702 94 116472 0% /tmp
TEST_TYPES=standard
Tue Mar 22 00:10:54 CDT 2011
*** starting standard tests in duty ***
Uname -a: FreeBSD duty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:10:59 CDT 2008 sukoziol at duty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/DUTY i386
*** finished standard tests for duty ***
Total time = 0m 26s
*** finished tests in duty ***
****SYSTEM ERROR duty: Abnormal exit from runtest ****
Tue Mar 22 00:18:38 CDT 2011
****SYSTEM ERROR duty: runtest command failed ****
Testing liberty
liberty does not accept Remote Command (Tue Mar 22 00:11:18 CDT 2011)
****SYSTEM ERROR: liberty does not accept Remote Command (Tue Mar 22 00:11:18 CDT 2011)
****INCOMPLETE liberty: snaptest did not complete****
More information about the opa-nightly-tests
