[opa-nightly-tests] jam OPA_Daily_Tests_0321Mon_FAILED!!!
HDF Tester
hdftest at hdfgroup.org
Mon Mar 21 00:17:27 CDT 2011
*** OPA Tests on 0321Mon ***
Tests Summary
****FAILED duty: standard****
PASSED amani: standard
PASSED heiwa: standard
PASSED jam: standard
PASSED linew: standard
Tests Time Summary
duty: Ran 1(0/1/0) tests, Grand total test time = 0m 28s
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 22s
amani: Ran 1(1/0/0) tests, Grand total test time = 1m 50s
heiwa: Ran 1(1/0/0) tests, Grand total test time = 5m 31s
linew: Ran 1(1/0/0) tests, Grand total test time = 6m 11s
jam: Ran 6(0/0/0) hosts, Grand total test time = 7m 7s
Timekeeper log
Timekeeper started at Mon Mar 21 00:10:30 CDT 2011
Timekeeper sleeping for 1800 seconds
Tests Failures
Dumping logfile of duty: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/duty_0321Mon_0010
/bin/sh ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c -o opa_primitives.lo /home/hdftest/snapshots-opa/current/src/opa_primitives.c
/bin/sh ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c -o opa_queue.lo /home/hdftest/snapshots-opa/current/src/opa_queue.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_queue.c -o opa_queue.o
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_primitives.c -o opa_primitives.o
In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.h:10,
from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/home/hdftest/snapshots-opa/current/src/opa_primitives.h:114:2: #error no primitives implementation specified
In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/home/hdftest/snapshots-opa/current/src/opa_queue.h:56: error: syntax error before "OPA_ptr_t"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_rel_to_abs':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: warning: initialization makes pointer from integer without a cast
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: `size_t' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: (Each undeclared identifier is reported only once
mv -f .deps/opa_primitives.Tpo .deps/opa_primitives.Plo
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: for each function it appears in.)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: syntax error before "offset"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_abs_to_rel':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: `size_t' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: syntax error before "a"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_swap_rel':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:82: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_cas_rel_null':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:92: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_is_empty':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:165: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:166: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:171: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_peek_head':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:196: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:197: error: `NULL' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_init':
/home/hdftest/snapshots-opa/current/src/opa_queue.c:31: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c:32: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c:33: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_header_init':
/home/hdftest/snapshots-opa/current/src/opa_queue.c:38: error: structure has no member named `offset'
gmake[2]: *** [opa_queue.lo] Error 1
gmake[2]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
gmake[1]: *** [all] Error 2
gmake[1]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
gmake: *** [all-recursive] Error 1
Failed running make
===== Exit bin/snapshot with status=0: Mon Mar 21 00:11:21 CDT 2011 =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
00:10:09 up 45 days, 14:42, 47 users, load average: 1.07, 1.09, 1.24
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 3986832 26113360 14% /
/dev/sda1 101086 22885 72982 24% /boot
/dev/sda2 31738420 198588 29901604 1% /tmp
/dev/sda6 31738392 5915476 24184692 20% /var
/dev/sda7 31738392 28937988 1162180 97% /usr
/dev/sda8 124991068 10480584 108058784 9% /var/tmp
/dev/mapper/VolGroup00-home
198351840 15388960 172724520 9% /home
/dev/sde1 565688764 379077772 157412056 71% /scr
/dev/sdc1 961432072 802618988 109975084 88% /mnt/scr1
/dev/sdd1 961432072 878230360 34363712 97% /mnt/hdf
tmpfs 8313848 16 8313832 1% /dev/shm
gumund:/data/ftp 480719072 279524640 176775232 62% /mnt/ftp
gumund:/data/web 480719072 279524640 176775232 62% /mnt/web
amani:/mnt/rw-src 288451232 179573408 94225344 66% /mnt/ro-src
amani:/mnt/rw-src 288451232 179573408 94225344 66% /mnt/rw-src
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0321Mon
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0321Mon.11876: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0321Mon.11876': No such file or directory
Mon Mar 21 00:10:29 CDT 2011
*** launching tests from jam ***
TESTHOST is linew
jam
amani
heiwa
duty
liberty
Fork off timekeeper 30
cannot remote command with liberty
Testing linew
ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname linew
12:10am up 9 day(s), 6:07, 2 users, load average: 1.21, 1.56, 1.75
/ (/dev/dsk/c1t0d0s0 ):71323186 blocks 8272033 files
/devices (/devices ): 0 blocks 0 files
/system/contract (ctfs ): 0 blocks 2147483608 files
/proc (proc ): 0 blocks 29932 files
/etc/mnttab (mnttab ): 0 blocks 0 files
/etc/svc/volatile (swap ):20794224 blocks 1182206 files
/system/object (objfs ): 0 blocks 2147483494 files
/etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
/platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):71323186 blocks 8272033 files
/platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):71323186 blocks 8272033 files
/dev/fd (fd ): 0 blocks 0 files
/tmp (swap ):20794224 blocks 1182206 files
/var/run (swap ):20794224 blocks 1182206 files
/scr (/dev/dsk/c1t1d0s0 ):895976532 blocks 226812106 files
/home (jam:/home ):365925760 blocks 50914562 files
/mnt/hdf (jam:/mnt/hdf ):166403424 blocks 114294762 files
/mnt/scr1 (jam:/mnt/scr1 ):317624776 blocks 116243980 files
/mnt/web (gumund:/mnt/web ):402388832 blocks 60893657 files
/mnt/ftp (gumund:/mnt/ftp ):402388832 blocks 60893657 files
TEST_TYPES=standard
Mon Mar 21 00:10:47 CDT 2011
*** starting standard tests in linew ***
Uname -a: SunOS linew 5.10 Generic_144488-07 sun4u sparc SUNW,A70
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/linew_0321Mon_0010
*** finished standard tests for linew ***
Mon Mar 21 00:16:54 CDT 2011
Total time = 6m 7s
*** finished tests in linew ***
Mon Mar 21 00:16:55 CDT 2011
Testing jam
ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
00:10:36 up 45 days, 14:42, 47 users, load average: 1.18, 1.12, 1.24
/dev/sda2 31738420 198708 29901484 1% /tmp
/dev/sda6 31738392 5915480 24184688 20% /var
/dev/sdc1 961432072 802619744 109974328 88% /mnt/scr1
TEST_TYPES=standard
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-194.3.1.el5PAE #1 SMP Thu May 13 13:48:44 EDT 2010 i686 i686 i386 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/jam_0321Mon_0010
*** finished standard tests for jam ***
Mon Mar 21 00:12:08 CDT 2011
Total time = 1m 21s
*** finished tests in jam ***
Testing amani
ssh amani -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname amani
00:10:39 up 34 days, 10:40, 2 users, load average: 0.00, 0.01, 0.00
/dev/hda6 39021196 29714468 7292584 81% /
/dev/hda3 12192636 4212556 7350736 37% /var
/dev/hda2 12192636 208596 11354696 2% /tmp
/dev/hda1 101086 23784 72083 25% /boot
tmpfs 2057868 0 2057868 0% /dev/shm
jam:/home 198351840 15388960 172724544 9% /home
jam:/mnt/hdf 961432096 878230368 34363712 97% /mnt/hdf
jam:/mnt/scr1 961432096 802619840 109974240 88% /mnt/scr1
smirom:/scr 267601440 37497024 216291712 15% /mnt/tmp
/dev/sdb1 144221592 98318464 38577088 72% /scr
/dev/sda1 288451232 179573436 94225316 66% /mnt/rw-src
TEST_TYPES=standard
Mon Mar 21 00:10:49 CDT 2011
*** starting standard tests in amani ***
Uname -a: Linux amani 2.6.18-194.32.1.el5 #1 SMP Wed Jan 5 17:52:25 EST 2011 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/amani_0321Mon_0010
*** finished standard tests for amani ***
Mon Mar 21 00:12:39 CDT 2011
Total time = 1m 50s
*** finished tests in amani ***
Testing heiwa
ssh heiwa -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname heiwa
00:10:38 up 16 days, 11:41, 4 users, load average: 0.73, 0.23, 0.08
/dev/sdb8 35435232 2727620 30907572 9% /
tmpfs 2008144 0 2008144 0% /dev/shm
/dev/sdb4 198337 106660 81437 57% /boot
/dev/sdb6 12385456 1372948 10383364 12% /tmp
/dev/sdb7 12385456 6952392 4803920 60% /var
/dev/sda6 82573108 686812 77691728 1% /scr
jam:/mnt/scr1 961432096 802619968 109974144 88% /mnt/scr1
TEST_TYPES=standard
Mon Mar 21 00:10:48 CDT 2011
*** starting standard tests in heiwa ***
Uname -a: Linux heiwa 2.6.32.16-150.fc12.ppc64 #1 SMP Sat Jul 24 05:19:27 UTC 2010 ppc64 ppc64 ppc64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/heiwa_0321Mon_0010
*** finished standard tests for heiwa ***
Mon Mar 21 00:16:19 CDT 2011
Total time = 5m 31s
*** finished tests in heiwa ***
Testing duty
ssh duty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname duty
12:10AM up 81 days, 8:25, 0 users, load averages: 0.00, 0.17, 0.36
Filesystem 1K-blocks Used Avail Capacity Mounted on
/dev/aacd0s1a 507630 60986 406034 13% /
devfs 1 1 0 100% /dev
/dev/aacd0s1h 188433016 123604522 49753854 71% /data
/dev/aacd0s1g 32494668 24936782 4958314 83% /local_home
/dev/aacd0s1f 12186190 4125638 7085658 37% /usr
/dev/aacd0s1d 507630 50534 416486 11% /var
/dev/aacd0s1e 253678 178 233206 0% /var/tmp
procfs 4 4 0 100% /proc
jam:/home 198351840 15388960 172724520 8% /home
jam:/mnt/hdf 961432072 878230360 34363712 96% /mnt/hdf
jam:/mnt/scr1 961432072 802620012 109974060 88% /mnt/scr1
gumund:/data/web 480719056 279524640 176775216 61% /mnt/web
gumund:/data/ftp 480719056 279524640 176775216 61% /mnt/ftp
devfs 1 1 0 100% /var/named/dev
/dev/md0 126702 94 116472 0% /tmp
TEST_TYPES=standard
Mon Mar 21 00:10:54 CDT 2011
*** starting standard tests in duty ***
Uname -a: FreeBSD duty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:10:59 CDT 2008 sukoziol at duty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/DUTY i386
*** finished standard tests for duty ***
Total time = 0m 27s
*** finished tests in duty ***
****SYSTEM ERROR duty: Abnormal exit from runtest ****
Mon Mar 21 00:17:26 CDT 2011
****SYSTEM ERROR duty: runtest command failed ****
Testing liberty
liberty does not accept Remote Command (Mon Mar 21 00:11:17 CDT 2011)
****SYSTEM ERROR: liberty does not accept Remote Command (Mon Mar 21 00:11:17 CDT 2011)
****INCOMPLETE liberty: snaptest did not complete****
More information about the opa-nightly-tests
