[opa-nightly-tests] jam OPA_Daily_Tests_0320Sun_FAILED!!!
HDF Tester
hdftest at hdfgroup.org
Sun Mar 20 00:22:41 CDT 2011
*** OPA Tests on 0320Sun ***
Tests Summary
****FAILED duty: standard****
PASSED amani: standard
PASSED heiwa: standard
PASSED jam: standard
PASSED linew: standard
Tests Time Summary
duty: Ran 1(0/1/0) tests, Grand total test time = 0m 27s
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 19s
amani: Ran 1(1/0/0) tests, Grand total test time = 1m 48s
heiwa: Ran 1(1/0/0) tests, Grand total test time = 5m 30s
linew: Ran 1(1/0/0) tests, Grand total test time = 11m 22s
jam: Ran 6(0/0/0) hosts, Grand total test time = 12m 22s
Timekeeper log
Timekeeper started at Sun Mar 20 00:10:31 CDT 2011
Timekeeper sleeping for 1800 seconds
Tests Failures
Dumping logfile of duty: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/duty_0320Sun_0010
/bin/sh ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c -o opa_primitives.lo /home/hdftest/snapshots-opa/current/src/opa_primitives.c
/bin/sh ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c -o opa_queue.lo /home/hdftest/snapshots-opa/current/src/opa_queue.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_queue.c -o opa_queue.o
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_primitives.c -o opa_primitives.o
In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.h:10,
from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/home/hdftest/snapshots-opa/current/src/opa_primitives.h:114:2: #error no primitives implementation specified
In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/home/hdftest/snapshots-opa/current/src/opa_queue.h:56: error: syntax error before "OPA_ptr_t"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_rel_to_abs':
mv -f .deps/opa_primitives.Tpo .deps/opa_primitives.Plo
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: warning: initialization makes pointer from integer without a cast
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: `size_t' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: (Each undeclared identifier is reported only once
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: for each function it appears in.)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: syntax error before "offset"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_abs_to_rel':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: `size_t' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: syntax error before "a"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_swap_rel':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:82: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_cas_rel_null':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:92: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_is_empty':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:165: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:166: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:171: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_peek_head':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:196: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:197: error: `NULL' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_init':
/home/hdftest/snapshots-opa/current/src/opa_queue.c:31: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c:32: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c:33: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_header_init':
/home/hdftest/snapshots-opa/current/src/opa_queue.c:38: error: structure has no member named `offset'
gmake[2]: *** [opa_queue.lo] Error 1
gmake[2]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
gmake[1]: *** [all] Error 2
gmake[1]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
gmake: *** [all-recursive] Error 1
Failed running make
===== Exit bin/snapshot with status=0: Sun Mar 20 00:11:22 CDT 2011 =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
00:10:09 up 44 days, 14:42, 47 users, load average: 1.96, 1.99, 1.96
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 3986620 26113572 14% /
/dev/sda1 101086 22885 72982 24% /boot
/dev/sda2 31738420 2555260 27544932 9% /tmp
/dev/sda6 31738392 6004320 24095848 20% /var
/dev/sda7 31738392 28936184 1163984 97% /usr
/dev/sda8 124991068 10812896 107726472 10% /var/tmp
/dev/mapper/VolGroup00-home
198351840 15388216 172725264 9% /home
/dev/sde1 565688764 379139216 157350612 71% /scr
/dev/sdc1 961432072 803664004 108930068 89% /mnt/scr1
/dev/sdd1 961432072 878229920 34364152 97% /mnt/hdf
tmpfs 8313848 16 8313832 1% /dev/shm
gumund:/data/ftp 480719072 279346464 176953408 62% /mnt/ftp
gumund:/data/web 480719072 279346464 176953408 62% /mnt/web
amani:/mnt/rw-src 288451232 179573408 94225344 66% /mnt/ro-src
amani:/mnt/rw-src 288451232 179573408 94225344 66% /mnt/rw-src
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0320Sun
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0320Sun.30383: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0320Sun.30383': No such file or directory
*** launching tests from jam ***
TESTHOST is linew
jam
amani
heiwa
duty
liberty
Fork off timekeeper 30
cannot remote command with liberty
Testing linew
ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname linew
12:10am up 8 day(s), 6:07, 2 users, load average: 3.87, 3.17, 2.27
/ (/dev/dsk/c1t0d0s0 ):71313928 blocks 8272033 files
/devices (/devices ): 0 blocks 0 files
/system/contract (ctfs ): 0 blocks 2147483607 files
/proc (proc ): 0 blocks 29916 files
/etc/mnttab (mnttab ): 0 blocks 0 files
/etc/svc/volatile (swap ):20770000 blocks 1182203 files
/system/object (objfs ): 0 blocks 2147483494 files
/etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
/platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):71313928 blocks 8272033 files
/platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):71313928 blocks 8272033 files
/dev/fd (fd ): 0 blocks 0 files
/tmp (swap ):20770000 blocks 1182203 files
/var/run (swap ):20770000 blocks 1182203 files
/scr (/dev/dsk/c1t1d0s0 ):898928130 blocks 226812951 files
/home (jam:/home ):365927248 blocks 50914563 files
/mnt/hdf (jam:/mnt/hdf ):166404304 blocks 114294766 files
/mnt/scr1 (jam:/mnt/scr1 ):315541696 blocks 116222500 files
/mnt/web (gumund:/mnt/web ):402745160 blocks 60893675 files
/mnt/ftp (gumund:/mnt/ftp ):402745160 blocks 60893675 files
TEST_TYPES=standard
Sun Mar 20 00:11:04 CDT 2011
*** starting standard tests in linew ***
Uname -a: SunOS linew 5.10 Generic_144488-07 sun4u sparc SUNW,A70
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/linew_0320Sun_0011
*** finished standard tests for linew ***
Sun Mar 20 00:22:08 CDT 2011
Total time = 11m 5s
*** finished tests in linew ***
Sun Mar 20 00:22:09 CDT 2011
Testing jam
ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
00:10:39 up 44 days, 14:42, 47 users, load average: 2.04, 2.01, 1.97
/dev/sda2 31738420 2555384 27544808 9% /tmp
/dev/sda6 31738392 6004324 24095844 20% /var
/dev/sdc1 961432072 803661160 108932912 89% /mnt/scr1
TEST_TYPES=standard
Sun Mar 20 00:10:49 CDT 2011
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-194.3.1.el5PAE #1 SMP Thu May 13 13:48:44 EDT 2010 i686 i686 i386 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/jam_0320Sun_0010
*** finished standard tests for jam ***
Sun Mar 20 00:12:08 CDT 2011
Total time = 1m 19s
*** finished tests in jam ***
Testing amani
ssh amani -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname amani
00:10:41 up 33 days, 10:40, 2 users, load average: 0.89, 0.60, 1.19
/dev/hda6 39021196 29708776 7298276 81% /
/dev/hda3 12192636 4210588 7352704 37% /var
/dev/hda2 12192636 210172 11353120 2% /tmp
/dev/hda1 101086 23784 72083 25% /boot
tmpfs 2057868 0 2057868 0% /dev/shm
jam:/home 198351840 15388192 172725280 9% /home
jam:/mnt/hdf 961432096 878229920 34364160 97% /mnt/hdf
jam:/mnt/scr1 961432096 803662848 108931264 89% /mnt/scr1
smirom:/scr 267601440 37497024 216291712 15% /mnt/tmp
/dev/sdb1 144221592 98873324 38022228 73% /scr
/dev/sda1 288451232 179573436 94225316 66% /mnt/rw-src
TEST_TYPES=standard
Sun Mar 20 00:10:51 CDT 2011
*** starting standard tests in amani ***
Uname -a: Linux amani 2.6.18-194.32.1.el5 #1 SMP Wed Jan 5 17:52:25 EST 2011 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/amani_0320Sun_0010
*** finished standard tests for amani ***
Sun Mar 20 00:12:39 CDT 2011
Total time = 1m 48s
*** finished tests in amani ***
Testing heiwa
ssh heiwa -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname heiwa
00:10:40 up 15 days, 11:41, 4 users, load average: 0.00, 0.00, 0.00
/dev/sdb8 35435232 2727628 30907564 9% /
tmpfs 2008144 0 2008144 0% /dev/shm
/dev/sdb4 198337 106660 81437 57% /boot
/dev/sdb6 12385456 1372960 10383352 12% /tmp
/dev/sdb7 12385456 7281020 4475292 62% /var
/dev/sda6 82573108 686812 77691728 1% /scr
jam:/mnt/scr1 961432096 803664128 108929984 89% /mnt/scr1
TEST_TYPES=standard
Sun Mar 20 00:10:50 CDT 2011
*** starting standard tests in heiwa ***
Uname -a: Linux heiwa 2.6.32.16-150.fc12.ppc64 #1 SMP Sat Jul 24 05:19:27 UTC 2010 ppc64 ppc64 ppc64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/heiwa_0320Sun_0010
*** finished standard tests for heiwa ***
Sun Mar 20 00:16:20 CDT 2011
Total time = 5m 30s
*** finished tests in heiwa ***
Testing duty
ssh duty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname duty
12:10AM up 80 days, 8:25, 0 users, load averages: 0.06, 0.02, 0.00
Filesystem 1K-blocks Used Avail Capacity Mounted on
/dev/aacd0s1a 507630 60986 406034 13% /
devfs 1 1 0 100% /dev
/dev/aacd0s1h 188433016 123604522 49753854 71% /data
/dev/aacd0s1g 32494668 24660236 5234860 82% /local_home
/dev/aacd0s1f 12186190 4125638 7085658 37% /usr
/dev/aacd0s1d 507630 50484 416536 11% /var
/dev/aacd0s1e 253678 178 233206 0% /var/tmp
procfs 4 4 0 100% /proc
jam:/home 198351840 15388216 172725264 8% /home
jam:/mnt/hdf 961432072 878229920 34364152 96% /mnt/hdf
jam:/mnt/scr1 961432072 803664724 108929348 88% /mnt/scr1
gumund:/data/web 480719056 279346476 176953380 61% /mnt/web
gumund:/data/ftp 480719056 279346476 176953380 61% /mnt/ftp
devfs 1 1 0 100% /var/named/dev
/dev/md0 126702 96 116470 0% /tmp
TEST_TYPES=standard
Sun Mar 20 00:10:56 CDT 2011
*** starting standard tests in duty ***
Uname -a: FreeBSD duty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:10:59 CDT 2008 sukoziol at duty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/DUTY i386
*** finished standard tests for duty ***
Total time = 0m 26s
*** finished tests in duty ***
****SYSTEM ERROR duty: Abnormal exit from runtest ****
****SYSTEM ERROR duty: runtest command failed ****
Testing liberty
liberty does not accept Remote Command (Sun Mar 20 00:11:19 CDT 2011)
****SYSTEM ERROR: liberty does not accept Remote Command (Sun Mar 20 00:11:19 CDT 2011)
****INCOMPLETE liberty: snaptest did not complete****
More information about the opa-nightly-tests
