[opa-nightly-tests] jam OPA_Daily_Tests_0319Sat_FAILED!!!
HDF Tester
hdftest at hdfgroup.org
Sat Mar 19 00:19:02 CDT 2011
*** OPA Tests on 0319Sat ***
Tests Summary
****FAILED duty: standard****
PASSED amani: standard
PASSED heiwa: standard
PASSED jam: standard
PASSED linew: standard
Tests Time Summary
duty: Ran 1(0/1/0) tests, Grand total test time = 0m 29s
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 22s
amani: Ran 1(1/0/0) tests, Grand total test time = 1m 49s
heiwa: Ran 1(1/0/0) tests, Grand total test time = 5m 33s
linew: Ran 1(1/0/0) tests, Grand total test time = 7m 43s
jam: Ran 6(0/0/0) hosts, Grand total test time = 8m 42s
Timekeeper log
Timekeeper started at Sat Mar 19 00:10:32 CDT 2011
Timekeeper sleeping for 1800 seconds
Tests Failures
Dumping logfile of duty: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/duty_0319Sat_0010
/bin/sh ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c -o opa_primitives.lo /home/hdftest/snapshots-opa/current/src/opa_primitives.c
/bin/sh ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c -o opa_queue.lo /home/hdftest/snapshots-opa/current/src/opa_queue.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_primitives.c -o opa_primitives.o
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_queue.c -o opa_queue.o
In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.h:10,
from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/home/hdftest/snapshots-opa/current/src/opa_primitives.h:114:2: #error no primitives implementation specified
In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/home/hdftest/snapshots-opa/current/src/opa_queue.h:56: error: syntax error before "OPA_ptr_t"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_rel_to_abs':
mv -f .deps/opa_primitives.Tpo .deps/opa_primitives.Plo
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: warning: initialization makes pointer from integer without a cast
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: `size_t' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: (Each undeclared identifier is reported only once
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: for each function it appears in.)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: syntax error before "offset"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_abs_to_rel':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: `size_t' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: syntax error before "a"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_swap_rel':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:82: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_cas_rel_null':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:92: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_is_empty':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:165: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:166: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:171: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_peek_head':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:196: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:197: error: `NULL' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_init':
/home/hdftest/snapshots-opa/current/src/opa_queue.c:31: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c:32: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c:33: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_header_init':
/home/hdftest/snapshots-opa/current/src/opa_queue.c:38: error: structure has no member named `offset'
gmake[2]: *** [opa_queue.lo] Error 1
gmake[2]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
gmake[1]: *** [all] Error 2
gmake[1]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
gmake: *** [all-recursive] Error 1
Failed running make
===== Exit bin/snapshot with status=0: Sat Mar 19 00:11:25 CDT 2011 =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
00:10:10 up 43 days, 14:42, 44 users, load average: 2.10, 2.11, 2.19
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 3986552 26113640 14% /
/dev/sda1 101086 22885 72982 24% /boot
/dev/sda2 31738420 2567136 27533056 9% /tmp
/dev/sda6 31738392 6001724 24098444 20% /var
/dev/sda7 31738392 28933924 1166244 97% /usr
/dev/sda8 124991068 10812900 107726468 10% /var/tmp
/dev/mapper/VolGroup00-home
198351840 15387640 172725840 9% /home
/dev/sde1 565688764 379139148 157350680 71% /scr
/dev/sdc1 961432072 802334712 110259360 88% /mnt/scr1
/dev/sdd1 961432072 878212636 34381436 97% /mnt/hdf
tmpfs 8313848 16 8313832 1% /dev/shm
gumund:/data/ftp 480719072 279346400 176953472 62% /mnt/ftp
gumund:/data/web 480719072 279346400 176953472 62% /mnt/web
amani:/mnt/rw-src 288451232 179573408 94225344 66% /mnt/ro-src
amani:/mnt/rw-src 288451232 179573408 94225344 66% /mnt/rw-src
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0319Sat
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0319Sat.6531: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0319Sat.6531': No such file or directory
*** launching tests from jam ***
TESTHOST is linew
jam
amani
heiwa
duty
liberty
Fork off timekeeper 30
cannot remote command with liberty
Testing linew
ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname linew
12:10am up 7 day(s), 6:07, 2 users, load average: 1.21, 0.98, 0.68
/ (/dev/dsk/c1t0d0s0 ):71313750 blocks 8272033 files
/devices (/devices ): 0 blocks 0 files
/system/contract (ctfs ): 0 blocks 2147483608 files
/proc (proc ): 0 blocks 29933 files
/etc/mnttab (mnttab ): 0 blocks 0 files
/etc/svc/volatile (swap ):20825616 blocks 1182211 files
/system/object (objfs ): 0 blocks 2147483494 files
/etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
/platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):71313750 blocks 8272033 files
/platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):71313750 blocks 8272033 files
/dev/fd (fd ): 0 blocks 0 files
/tmp (swap ):20825616 blocks 1182211 files
/var/run (swap ):20825616 blocks 1182211 files
/scr (/dev/dsk/c1t1d0s0 ):895393120 blocks 226812282 files
/home (jam:/home ):365928400 blocks 50914564 files
/mnt/hdf (jam:/mnt/hdf ):166438872 blocks 114294767 files
/mnt/scr1 (jam:/mnt/scr1 ):318217624 blocks 116223016 files
/mnt/web (gumund:/mnt/web ):402745328 blocks 60893675 files
/mnt/ftp (gumund:/mnt/ftp ):402745328 blocks 60893675 files
TEST_TYPES=standard
Sat Mar 19 00:10:52 CDT 2011
*** starting standard tests in linew ***
Uname -a: SunOS linew 5.10 Generic_144488-07 sun4u sparc SUNW,A70
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/linew_0319Sat_0010
*** finished standard tests for linew ***
Sat Mar 19 00:18:29 CDT 2011
Total time = 7m 37s
*** finished tests in linew ***
Sat Mar 19 00:18:30 CDT 2011
Testing jam
ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
00:10:39 up 43 days, 14:42, 44 users, load average: 2.35, 2.16, 2.21
/dev/sda2 31738420 2567260 27532932 9% /tmp
/dev/sda6 31738392 6001728 24098440 20% /var
/dev/sdc1 961432072 802323364 110270708 88% /mnt/scr1
TEST_TYPES=standard
Sat Mar 19 00:10:49 CDT 2011
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-194.3.1.el5PAE #1 SMP Thu May 13 13:48:44 EDT 2010 i686 i686 i386 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/jam_0319Sat_0010
*** finished standard tests for jam ***
Sat Mar 19 00:12:11 CDT 2011
Total time = 1m 22s
*** finished tests in jam ***
Testing amani
ssh amani -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname amani
00:10:41 up 32 days, 10:40, 2 users, load average: 0.04, 0.02, 0.06
/dev/hda6 39021196 29702968 7304084 81% /
/dev/hda3 12192636 4218532 7344760 37% /var
/dev/hda2 12192636 208628 11354664 2% /tmp
/dev/hda1 101086 23784 72083 25% /boot
tmpfs 2057868 0 2057868 0% /dev/shm
jam:/home 198351840 15387616 172725856 9% /home
jam:/mnt/hdf 961432096 878212640 34381440 97% /mnt/hdf
jam:/mnt/scr1 961432096 802323424 110270688 88% /mnt/scr1
smirom:/scr 267601440 37497024 216291712 15% /mnt/tmp
/dev/sdb1 144221592 74773996 62121556 55% /scr
/dev/sda1 288451232 179573436 94225316 66% /mnt/rw-src
TEST_TYPES=standard
Sat Mar 19 00:10:51 CDT 2011
*** starting standard tests in amani ***
Uname -a: Linux amani 2.6.18-194.32.1.el5 #1 SMP Wed Jan 5 17:52:25 EST 2011 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/amani_0319Sat_0010
*** finished standard tests for amani ***
Sat Mar 19 00:12:40 CDT 2011
Total time = 1m 49s
*** finished tests in amani ***
Testing heiwa
ssh heiwa -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname heiwa
00:10:41 up 14 days, 11:41, 4 users, load average: 0.16, 0.03, 0.02
/dev/sdb8 35435232 2727624 30907568 9% /
tmpfs 2008144 0 2008144 0% /dev/shm
/dev/sdb4 198337 106660 81437 57% /boot
/dev/sdb6 12385456 1372956 10383356 12% /tmp
/dev/sdb7 12385456 7278652 4477660 62% /var
/dev/sda6 82573108 686812 77691728 1% /scr
jam:/mnt/scr1 961432096 802323520 110270592 88% /mnt/scr1
TEST_TYPES=standard
*** starting standard tests in heiwa ***
Uname -a: Linux heiwa 2.6.32.16-150.fc12.ppc64 #1 SMP Sat Jul 24 05:19:27 UTC 2010 ppc64 ppc64 ppc64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/heiwa_0319Sat_0010
*** finished standard tests for heiwa ***
Sat Mar 19 00:16:23 CDT 2011
Total time = 5m 32s
*** finished tests in heiwa ***
Sat Mar 19 00:16:24 CDT 2011
Testing duty
ssh duty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname duty
12:10AM up 79 days, 8:25, 0 users, load averages: 0.00, 0.00, 0.00
Filesystem 1K-blocks Used Avail Capacity Mounted on
/dev/aacd0s1a 507630 60986 406034 13% /
devfs 1 1 0 100% /dev
/dev/aacd0s1h 188433016 123604522 49753854 71% /data
/dev/aacd0s1g 32494668 24660236 5234860 82% /local_home
/dev/aacd0s1f 12186190 4125638 7085658 37% /usr
/dev/aacd0s1d 507630 50406 416614 11% /var
/dev/aacd0s1e 253678 178 233206 0% /var/tmp
procfs 4 4 0 100% /proc
jam:/home 198351840 15387640 172725840 8% /home
jam:/mnt/hdf 961432072 878212636 34381436 96% /mnt/hdf
jam:/mnt/scr1 961432072 802323620 110270452 88% /mnt/scr1
gumund:/data/web 480719056 279346392 176953464 61% /mnt/web
gumund:/data/ftp 480719056 279346392 176953464 61% /mnt/ftp
devfs 1 1 0 100% /var/named/dev
/dev/md0 126702 96 116470 0% /tmp
TEST_TYPES=standard
Sat Mar 19 00:10:56 CDT 2011
*** starting standard tests in duty ***
Uname -a: FreeBSD duty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:10:59 CDT 2008 sukoziol at duty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/DUTY i386
*** finished standard tests for duty ***
Total time = 0m 29s
*** finished tests in duty ***
****SYSTEM ERROR duty: Abnormal exit from runtest ****
****SYSTEM ERROR duty: runtest command failed ****
Testing liberty
liberty does not accept Remote Command (Sat Mar 19 00:11:19 CDT 2011)
****SYSTEM ERROR: liberty does not accept Remote Command (Sat Mar 19 00:11:19 CDT 2011)
****INCOMPLETE liberty: snaptest did not complete****
More information about the opa-nightly-tests
